ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Anchors, or no anchors?
Author | Topic: Anchors, or no anchors? |
69boo307 |
posted 02-14-2009 01:30 PM ET (US)
My Striper has front and rear anchors with 'anchor buddies' and winches, that the original owner added. I'm debating whether or not I want to keep them or try to remove them and patch the mounting holes. They can be seen in these photos: http://picasaweb.google.com/69boo307/BostonWhaler# On one hand they can be useful for fishing, on the other those mushroom anchors don't really hold the boat that well, and I think it just adds 'clutter' to the boat's lines and gets in the way. There aren't many circumstances where I'd be still fishing and would need an anchor. It would probably be more likely that I might need some kind of mooring line to beach the boat, but not anchor it in the water. Opinions on if you would keep them or not if it was yours? How difficult would it be to repair the mounting holes? thanks, |
Chuck Tribolet |
posted 02-14-2009 02:42 PM ET (US)
I'd have an anchor, but not a mushroom, They are really heavy for not much holding power. Seek local knowledge about what works in your area. Every year or two, I hear VHF conversation that goes roughly: Boater: Mayday, Mayday, the motor won't start and we are USCG: Do you have an anchor? At this point, either there's a long pause while they drop the
HAPPYJIM |
posted 02-14-2009 04:56 PM ET (US)
I consider an anchor emergency equipment. If you can't start your motor and you are drifting towards rocks, falls or into a channel with heavy freighter traffic, you need one good anchor to save your boat and souls on board. Seeing that you are from Durham, you may make a trip or two to the coast. The mushroom will only hold in sandy bottom with no wind. It may be good for fishing the lakes out there but would be pretty useless in any fast moving water. I'm sure it bangs around a lot stowed the way it is in the photo. A galvanized danforth would be a better all around anchor. http://www.danforthanchors.com/standard.html I'll try to keep this short but this is why chain length is important. We were out drift fishing in the summer for flounder and a thunder storm moved in fast, too fast. We couldn't get the motor started and after many attempts the battery was cranking slower and slower. The wind was blowing the boat fast into shallow water and worse than that, trees and stumps. Out went the anchor to stop our drift and with all 100 foot of rhode out the 4 foot of chain was not enough to hold us. After several attempts it was looking very bad. Hull damage was iminent at least and the waves building to almost 3 feet would have caused big problems and could have capsized the boat. We looked for anything possible to stop our movement and I took every lead fishing weight in our tackle boxes and tied them to the chain with fishing line as fast as possible. I was almost at panic stage with the hidden stumps approaching fast. Out went the anchor and it held this time with maybe 5 lbs of assorted weights. After a good soaking and missed lightning strikes, we tried the motor again. I guess after setting for a while the battery had just enough power restored to just barely start it. It taught me a good lesson and I tripled the chain length on my boat after that. |
Dave Sutton |
posted 02-14-2009 06:09 PM ET (US)
Chain is important, but a good anchor doubly so. I had a Danforth clone that WOULD NOT set no matter what I did. It almost cost me a boat. I went to watch it work once in diving gear and it skipped and simply WOULD NOT set. No length of chain would make it work. It looked exactly like every other Danforth clone but just would not work. I tossed it overboard.... without a rhode attached. I use Fortress anchors and they set like crazy... even with minimal chain they set and hold tight. Love them. Have (3) 55's, a 32, and a 23 on my Trawler, and a smaller one (?) size on the Montauk. Costly but well worth it. Mushroom anchors? They are 'fishing tackle'. not 'anchors'. They will hold you to fish, but not in any sort of emergency. Dave . |
elaelap |
posted 02-14-2009 07:16 PM ET (US)
I'm no fan of mushroom anchors for most everyday uses, but I've gotta disagree about their holding power. If used as designed--set to settle slowly and deeply over time in soft sand or mud--they become bombproof. In fact, their major problem at that stage is the difficulty--sometimes the impossibility--of breaking them free. In fact, the mushroom design, on a large scale, makes for a great permanent buoyed mooring, just because of their holding strength once they're down where they're supposed to be. I agree with everyone else that perhaps the best compromise anchor for a relatively small Whaler skiff used in various locations is a real Danforth with a generous length of chain. On the other hand, how absolutely boring it would be if this were proven to be some sort of absolute truth...what else would we have to argue about over a couple of pale ales at a seaside bar or club? Tony |
Ritzyrags |
posted 02-14-2009 09:02 PM ET (US)
I have used with reasonable success a similar type as shown of fold able anchor. It is versatile enough to do the job fur a light craft. But for heavy holding power I have used the "Plow" types with great success. http://www.marinepartdepot.com/anchor.html
69boo307 |
posted 02-15-2009 11:58 AM ET (US)
So it sounds like I'm probably better off getting rid of the fishing anchors and getting one more suitable for emergency type use. I could actually use the anchor locker, right now it is empty. Any advice on repairing the mounting holes where all this hardware is mounted? It think they actually drilled holes then filled them with something to hold the screws, I dont' think it is just screwed into the fiberglass. |
mateobosch |
posted 02-15-2009 02:57 PM ET (US)
The continuouswave reference section contains a plethora of information on minor gel coat patching and repairs. A good place to start would also be spectrumcolor.com as they are able to provide gel coat matched to specific years and models of boats. Matt |
Dave Sutton |
posted 02-15-2009 05:09 PM ET (US)
"I'm no fan of mushroom anchors for most everyday uses, but I've gotta disagree about their holding power. If used as designed--set to settle slowly and deeply over time in soft sand or mud--they become bombproof."
Tollyfamily |
posted 02-15-2009 05:45 PM ET (US)
I'm with HAPPYJIM, the anchor is one of the most important pieces of safety equipment. My kids all know to deploy the anchor in the Whaler or the big boat with a power failure. Dan |
Nails |
posted 02-15-2009 07:03 PM ET (US)
We use the Danforth most of the time, but we'll drop a mushroom from the stern along with a reef anchor from the bow when diving. |
20dauntless |
posted 02-15-2009 09:39 PM ET (US)
Definitely carry an anchor with you! It could save your life or boat. As to which anchor, everyone has different opinions. I personally have a Delta and it works great, but your area may have specific challenges. Look at this link for an interesting, if unscientific, anchor test. http://www.c-brats.com/viewtopic.php?t=8167&highlight=manson+supreme+ delta |
Buckda |
posted 02-16-2009 02:04 PM ET (US)
Keep the Mushroom and a short length of line attached in the locker for an emergency as described above. Rig it with two feet of quality line and a caribiner attached. When the poop hits the fan and you can't get your regular hook to set, haul it in and clip the caribiner to the chain where it connects to your line rode. That will greatly improve your holding power. When overnighting, I keep a lunch hook aboard to hold the stern in place where I want it, or to set anchor for a leisurely lunch or temporary anchor, but more importantly, to deploy as described above in an emergency situation where I absolutely need my main anchor to hold. ...but I have 20 feet of chain rode for my 18' Whaler. The lunch hook is much easier to use for repeated use during the day - typically the big anchor (mine's a 5KG Bruce) is only used at night or if conditions warrant it. If you have 8-10 feet of quality chain, you should be in good shape. I agree with others - an anchor is perhaps one of the most important pieces of safety equipment you can have aboard - you need a quality anchor and appropriate chain/rode for your conditions. Regarding patching the hull - it is worth it and you can do it well, however, it may take a few attempts to do it well, and by the time you're finished with the last hole, you may want to go back and re-do the first couple...your technique will have improved by then... |
Dave Sutton |
posted 02-16-2009 06:26 PM ET (US)
"Keep the Mushroom and a short length of line attached in the locker for an emergency as described above. Rig it with two feet of quality line and a caribiner attached. When the poop hits the fan and you can't get your regular hook to set, haul it in and clip the caribiner to the chain where it connects to your line rode. That will greatly improve your holding power"
With a decent length of chain (10-15 feet or so) the chain-rope intersection is a good spot. But even with 5-10 feet of chain, you can toss a loop of line around the anchor line several feet above the chain and add a kellett there, which has the same effect as a longer piece of chain. Any dead weight can be used, a mushroom anchor just happens to be a handy thing to handle and if it lays on the bottom it 'may' add some holding power due to it's shape as well. On EXPLORER, the 42 foot Trawler that I live on, I have (4) 20 pound clump weights of lead with rings cast into them for just this purpose for my storm anchors. Her main rhode is 175 feet of chain backed up with 400 feet of line, but the other two (my storm rhodes) only have 20 feet of chain on each. A pair of those 20 pound kelletts (total 40 pounds for each rhode) added to each one effectively triples the effective chain length in a pinch. Toss out 300 feet of 5/8 line with 20 feet of chain, a 40 pound kellett and a Fortress 55 and you can hold just about anything. Toss out three of those in a circle 500 feet in diameter and it's hurricane holding time. The biggest problem after a storm is getting the damned things back to the surface! Anchors are something that people swear-by or swear-at, and there's more discussion about them than you can imagine. Danforth, Bruce, Delta, etc... all have their cheering and jeering squads. The Fortresses are what the professionals now seem to think are best. Take a look at any of the Coast Guard 47 foot motor life boats (surf boats). The Coast Guard wanted an anchor that would hold one of these off of the beach in the surf *every time* in an emergency. They tested everything and ended up with Fortress 32's with 20 feet of chain and the balance a nylon rhode. They are expensive, but are the best stuff made. They are light (aluminum) so use the saved weight for more chain and you will never go wrong.
Moe |
posted 02-16-2009 07:12 PM ET (US)
This is the best resource I've found for configuring an anchor chain and rode: http://alain.fraysse.free.fr/sail/rode/rode_b.htm The spreadsheets are great! -- |
BlueMax |
posted 02-16-2009 07:19 PM ET (US)
Great articles of instruction and Lessons Learned. Thanks to all, especially D2 (Dave squared) in those last two postings above. Max |
Buckda |
posted 02-16-2009 10:56 PM ET (US)
Dave Sutton - THanks for the terminology - I couldn't recall it until you posted it. I believe that the technique is described in good detail in my copy of Chapman: Piloting. By the way to those reading this - The current edition of this periodical is about $50, but you can buy it used on Amazon for less. This is an invaluable resource to ANY boater, and well worth the money spent. My dad gave me his copy (1977 edition) when I was 15 and I pored over that thing for hours on end in the wintertime, waiting for the warm summer breezes of Michigan's Upper Peninsula to welcome me back to the islands where I spent my summers fishing and swimming and just horsing around...with the boats. Chapman: Piloting is the boater's Bible as far as I'm concerned. Get your copy while the water is still hard up here in the north, and keep it on your desk as a reference guide. Great section on anchoring. Also a good resource is the WEST ADVISOR. Dave |
Dave Sutton |
posted 02-17-2009 11:24 AM ET (US)
"The Other Dave" wrote: "Chapman: Piloting is the boater's Bible as far as I'm concerned."
Any of the editions have great information in them. Buy several and leave them scattered about the house... ;-)
high sierra |
posted 02-17-2009 11:49 AM ET (US)
Up here in the high desert, you always drift ashore, usually miles from civilization and no cell phone service. Now that I'm going to the San Francisco bay area for the rendezvous, I'm reading this very attentively. high sierra |
69boo307 |
posted 02-17-2009 12:54 PM ET (US)
Awsome information everyone! I'm now determined to re-do my anchor situation and get rid of the current setup. Maybe I'll try repairing a couple of small scratches on the bottom first before I get into it, to get some practice with gelcoat. |
sheikofthesea |
posted 02-17-2009 01:11 PM ET (US)
I use a number 7 fortress on my Montaulk 190. It's got Freddy Kreuger like claws that grab into most things. Even so, if I am dealing with wierd currents, anchoring up can still be hard. I have a Danforth as a back up in case something comes up. I have only been boating for 6 years and anchoring is a real skill to develop. |
HAPPYJIM |
posted 02-17-2009 02:54 PM ET (US)
You need to take into consideration how the bottom is made up also. Rocky bottoms may require a different anchor than muddy or sandy bottom. Ask at the local marina what is best all purpose anchor. If boating in a different area, do a little research and find out what they use in that area. Here in NE North Carolina the bottom is either sandy or muddy so the danforth works well. |
mgeiger |
posted 02-17-2009 04:47 PM ET (US)
No messing around here. 9# Danforth with 12' of chain and 200' of 3/8" line. For a Montauk. It held my 29' sailboat on many overnights, one of which we saw 40+ mph winds. |
Buckda |
posted 02-18-2009 04:18 PM ET (US)
One important note when setting a kellet: Don't let the weight foul the main anchor; you should ensure that the kellet can only go so far down the rhode before it stops (at least several feet forward of the main anchor). This is why I recommended using a caribiner clipped to the end of your chain rhode - that would hold the weight at a fixed point on the overall scope. I.E. - you don't want to just clip the caribiner to the rope rode at the surface and send it down the "zipline" to the bottom. |
Dave Sutton |
posted 02-18-2009 05:05 PM ET (US)
"I.E. - you don't want to just clip the caribiner to the rope rode at the surface and send it down the "zipline" to the bottom."
HOWEVER sliding the weight down the line portion of the rhode to stop at the line/chain intersection is a workable method BUT and this is a BIG BUT: You ABSOLUTELY need to size the caribiner correctly LONG before it's needed so it does not slide down the chain as well. If in doubt, DO NOT slide it down the line. Raise the anchor and attach the kellett directly.
(The Other) Dave . |
JMARTIN |
posted 02-18-2009 06:55 PM ET (US)
The anchoring technique is important also. I suggest practicing when you really do not need the anchor to hold. It is very entertaining to watch fellow boaters come into a bay where I have anchored for the night. You can usually spot the experienced ones just by how they have their crew organized and where they plan to drop the anchor. The most common cause for the anchor failing to hold, they do not let out enough scope before backing down. John |
20dauntless |
posted 02-18-2009 07:43 PM ET (US)
+1 John. I saw a lot of that last summer in BC. One particularly entertaining attempt was near Princess Louisa Inlet. Anyone who has been there can attest to the near vertical sides of the inlet and impossible anchoring depths in most of the inlet. One evening a large sundeck cruiser came in and tried to anchor for about 45 minutes...in water that was more than 200 feet deep! Now, they'd need at least 600 feet of rode to get to 3:1, and 1400 feet to get to 7:1! Don't ever try to set an anchor on anything less than 3:1 scope. It won't work. In Chapman's it is recommended to use 7:1. At least here in the PNW, that doesn't work very well since there isn't enough space to swing. I normally set mine at 5:1, but sometimes as low as 3:1, and have never had a problem. Last summer with 40 knots of wind one day I set at 10:1 and didn't drag at all. If I had been spending the night, I would have been up often to check and would have set the anchor alarm on the chartplotter. One final comment...remember to include the vertical distance from your transducer to your bow when calculating how much scope to let out. If you are in eight feet of water and the distance from the transducer to bow is 3 feet, you'll need to use 11 feet as your depth. Multiplied by 5 this means you'll need 55 feet of rode out. If you don't calculate using this distance you'll end up with just 40 feet of rode out. And don't skimp on the chain, especially if you use a Fortress or other danforth. Yeah, chain is heavy, a pain to carry, and annoying to haul up and down, but it will greatly add to the success that you have when trying to set the anchor. And like John said, practice! Go around and see how much scope you need to get your anchor to set. See what works and doesn't! |
69boo307 |
posted 02-19-2009 08:55 AM ET (US)
Bookmarking this thread, the responses have greatly exceeded my expectations :)... I'm considering the Fortress 7 to replace the mushroom anchors. It will probably be overkill for my little 15' boat, but it is lightweight and should fit in my bow locker. Other than emergency situations, my typical anchoring scenario will likely be stopping for a picnic on a calm, shallow freshwater lake. I do want to do a little inshore fishing with the boat though in saltwater, so I want to be prepared for conditions that could come up there. As suggested I may hang on to one of the mushrooms to add to the chain in tough conditions. |
pglein |
posted 02-19-2009 11:20 AM ET (US)
As others have said, an anchor is an essential piece of safety equipment, and I would never leave shore without one. Mushroom anchors are worthless and have no practical application on a boat. |
JMARTIN |
posted 02-19-2009 02:48 PM ET (US)
I have pulled anchor and moved before after watching my "new neighbor" anchor out the "rent a boat". Just pull everything out of the anchor locker, chuck the whole she-bang into the water, grab a fresh beer and crank up the tunes. With the Revenge, I can sneak into some really tight shallow places. With the Catalina 30, my anchorage options were more limited. I tried to position myself so I had land as a neighbor on three sides. Still, sometimes someone would try to get in between me and the shore. John |
20dauntless |
posted 02-19-2009 04:00 PM ET (US)
Brian, if other boaters in your area have reported success with the Fortress go for it. Make sure you get enough chain so that it will set properly. I'd say at least 15 feet... |
69boo307 |
posted 02-20-2009 08:17 AM ET (US)
I can tell you from experience that alot of boaters around here, at least fisherman, don't even bother with anchors. The few that have one probably use something homemade like a piece of PVC pipe filled with concrete. I've been around boats all my life in central NC, and this is the first boat I've been on or owned that even had an anchor. The boat I fished in with my dad for many years as a kid had no anchor. More common is just a long rope to tie off to a tree on the bank. You draw straws to see who has to get wet/dirty to tie the boat off :). Keep in mind that in this area we mostly have warm freshwater lakes where you could swim from shore to shore in most parts of the lake, and most of the shores consist of mud. There's also few places that you're more than 10 minutes from a boat ramp. So there isn't alot of concern about getting stranded or smashed against rocks. I'm more thinking about when I got to the coast. The NC coast and intercoastal area is mostly silty mud or sand bottom, or some mix of the two. |
an86carrera |
posted 03-04-2009 12:29 PM ET (US)
Never heard of a kellet before this thread, here is one I found on Craig's list: http://sarasota.craigslist.org/boa/1059880074.html len |
69boo307 |
posted 03-05-2009 10:39 AM ET (US)
This week I picked up a Fortress FX-7, a Danforth chain (6'), and 150ft of anchor line. Unfortunately the FX-7 is just a tad too long to fit in my anchor locker, I'll have to figure out some other way to stow it. I hope to get out during this weekend's warm weather and try it out. I know that is not a long chain, but I will rarely be anchored in more than 30' of water, probably 10-20' most of the time, so it should suffice. I'll find out and get more chain if need be. I also removed the old mushroom anchormate setup, the boat looks much cleaner without it, and it adds just a little room inside without the winches. My current project is filling and patching the screw holes... |
20dauntless |
posted 03-06-2009 01:12 PM ET (US)
I would recommend more chain. Try it out and see how it works, but Fortress anchors generally require quite a bit of chain to set well and hold. The FX7 should be a good match for your boat. |
Plotman |
posted 03-07-2009 12:26 AM ET (US)
I have used a 12 lb downrigger weight on more than one occasion as a kellett. Works like a charm, and it's already on the boat most times. No need to carry an extra item. |
kwik_wurk |
posted 03-07-2009 02:34 AM ET (US)
69boo307. Hi. You mentioned 6' of chain, but not the size (which determines the weight). I strongly suggest you double that length. Fortress anchors are great and bite hard, but they do require extra chain or a kellet. That anchor should fit in the fwd hatch. I had one on a Montauk, put some tennis balls around the ends so it doesn't destroy locker. |
69boo307 |
posted 03-09-2009 08:53 AM ET (US)
I have 3/8" chain. The guy at the store recommended the 1/4", but I went with the next heavier size. Sounds like I may end up getting another 6ft length. Unfortunately I didn't get a chance to actually try the anchor this weekend. |
69boo307 |
posted 03-09-2009 08:54 AM ET (US)
kiwk_wurk, it definitely will not fit in my hatch. Keep in mind this is a 15' boat, not a 17. I imagine the locker is slightly smaller. It only needs maybe another inch, but I couldn't maneuver it around any way to get it in and get the hatch closed. |
