ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Speculation About Florida Boating Accident Off Clearwater
Author | Topic: Speculation About Florida Boating Accident Off Clearwater |
lurkynot |
posted 03-10-2009 05:31 AM ET (US)
[Quoted without attribution, the following account presumes to describe the recent capsize of a boat off the coast of Florida in which three fishermen drowned and one survived, as reported by someone, somewhere, with some unknown knowledge.]:
fourdfish |
posted 03-10-2009 07:37 AM ET (US)
As I suspected and expressed before, it was not the weather that was the factor that caused this accident. These guys were just reckless. Sad! |
lurkynot |
posted 03-10-2009 07:51 AM ET (US)
Reckless! I could'nt disagree with you more. Making the decision to pull anchor as weather fouled was prudent. A mistake no doubt to attempt to free anchor in that manner however not reckless. |
Dave Sutton |
posted 03-10-2009 08:13 AM ET (US)
"to attempt to free anchor in that manner however not reckless." No, just incompetent.
Dave . |
Dan |
posted 03-10-2009 08:15 AM ET (US)
I recently purchased new anchor line and it had a strength of over 6,000 pounds. Therefore, when the boat driver tried to power away, it was equivalent to having 6,000 pounds pulling the stern down. It's been a long time since college physics, and I know many people on this forum will have the right equations to compute all this. I bet it's even worse if you factor in the pulling power of the motor. I wouldn't want to put this kind of load on a stern cleat. In the movie Jaws they did this with tragic results. I was at a boat supply store yesterday and I notice they have this ring/device that you can drop down to your anchor when it's stuck. What they perhaps should have done is tie the anchor line to a few fenders and come back when the weather was better to retrieve it all. If they're fishing a wreck, then it might be impossible to remove without the help of a diver. |
TransAm |
posted 03-10-2009 08:58 AM ET (US)
If that is the way things went down, I don't thing their actions were reckless. In fact, I think many would have tried something similar albeit in a less aggressive fashion. If I was faced with the anchor stuck and unable to dislodge it by hand, I don't think I would just say "oh well" and cut my $200 anchor and rode assembly loose. I would probably try and use the power of the boat, to a lesser degree than these guys apparently did, to dislodge the anchor by backing off SLOWLY with the anchor line attached to the forward center cleat, in the opposite direction than was used to set the anchor. After a couple failed attempts, then get out the knife. These guys just got a little squirrely and careless when trying to use the boats power, and bad things happened. |
wezie |
posted 03-10-2009 09:04 AM ET (US)
As lurkinot said, "the recoil". It is possible to pull the transom under with the engine. The next event is chopping the throttle and having the nylon (most of them are nylon) recoil; pulling the transom through a wave or two. Take my word for it, you can fill a boat in flat water. I almost sank an 18ft. that way in 100 ft. of water. We then cut it and let the pump work. I did not sink the boat, so I was not labeled incompetent. Personally, I put my actions somewhere between "a little too smart, and real close to stupid". I would not label others. Nylon stretches 10% to 15% at working load, and up to 50% at breaking strength. Sometimes we do not put the whole picture in focus. What is the cost of the anchor and line, vs the admission of losing them. Good luck to us all. |
20dauntless |
posted 03-10-2009 09:26 AM ET (US)
It is rarely a good idea to have an anchor tied to an aft cleat, especially offshore. The only time I see this as acceptable is when a stern anchor is required (in addition to an anchor of your bow) to keep you from swinging into another boat or using it to secure the stern of the boat when beached. In both of these situation the stern anchor is only deployed in calm conditions. Furthermore, if you can't get your anchor up from the bow, DO NOT tie it to the stern. If you anchor in areas with strong currents, you can inadvertently end up with your anchor rode in your prop. With your stern to the current, the same thing can happen where the stern goes down and fills with water. Whenever you are anchoring (probably anytime you are on a boat), keep a good knife nearby. Nobody likes to cut an anchor line and lose the ground tackle, but it's sure a whole lot better than losing a boat or lives. |
20dauntless |
posted 03-10-2009 09:28 AM ET (US)
Also, this is a case for keeping safety gear attached to your lifejacket rather than a ditch bag. It is also a case where an EPIRB (not PLB) with hydrostatic release could have made a very real difference. |
bluewaterpirate |
posted 03-10-2009 10:10 AM ET (US)
A Euro transom probably would have prevented the boat from capsizing because it would have given them more time to evaluate the what was about to happen. Here's a picture of my 210 Ventura notice how the stern sits in the water and how the motor well bulkhead is designed. That area would have submerged first but the bulkhead would have prevented water to fill the cockpit all at once. The stern on the Everglades 211c is not designed this way. As soon as the stern started to submerge the water broached the back of the boat. |
fourdfish |
posted 03-10-2009 10:11 AM ET (US)
"reckless", "incompetent" or "inexperienced" You can call it what you want, but those that would gun the engine enough to swamp the boat are not the sharpest knives in the drawer. It was a very costly mistake. I have hung up a few downrigger lines so I have seen the possibilities. I have also cut a few anchor rode. The poor weather coming up that night was the final factor. The weather here now has been just great and may have changed the results. |
Tohsgib |
posted 03-10-2009 10:13 AM ET (US)
Don't know about you but it seems like it might take a little more than what was said to turtle it....as per this video. |
lurkynot |
posted 03-10-2009 10:47 AM ET (US)
like adding 1000lbs to the stern in building waves? |
fishinchips |
posted 03-10-2009 10:49 AM ET (US)
Couple of years ago, a montauk got caught up in a crab pot line. It got wrapped up on the prop. The skipper tried to unwrap it, but the montauk turtled. Three were in the water, They climbed on top of the turtled montauk. After 6 hours a passing boat came to there rescue. Moral of the story, Just cut the darn line ! Bring along a sharp knife. In the case of the football players and the everglade boat. Detach the anchor from the boat and put a float on it. You can always come back next time to retrieve it. Ken (170 montauk / 22 hydrasports wa) |
BlueMax |
Looks like it would turtle just fine if it were yanked down and backw and filled with water as in the video - and had a nice T-Top and a likely full live well on it as in the boat we are discussing. |
Chuck Tribolet |
posted 03-10-2009 11:01 AM ET (US)
If you are gonna yank an stuck hook with the motor, leave it attached at the bow and put the motor in reverse. It's harder to pull the bow under.
Perry |
posted 03-10-2009 11:53 AM ET (US)
Sad story. I wonder if it was told by the sole survivor. I wonder what the guy meant by saying this: "If they had been wearing a PLB of some sort then there may have been some possibility of survival." "some possibility"....If someone was wearing a PLB, the chances of survival would have been VERY likely. |
rowmer1 |
posted 03-10-2009 11:55 AM ET (US)
"If I was faced with the anchor stuck and unable to dislodge it by hand, I don't think I would just say "oh well" and cut my $200 anchor and rode assembly loose." It seems pretty clear to me that's what they should have done. Had they cut it loose the outcome is going to the boat store to buy a new anchor. I learned a valuable lesson from their actions. I know I'm not alone here in, "learning things the hard way", I've read many of your posts. Tragically these men lost their lives, hopefully we can all learn something from this. |
Brian7son |
posted 03-10-2009 12:20 PM ET (US)
If I was faced with the anchor stuck and unable to dislodge it by hand, I don't think I would just say "oh well" and cut my $200 anchor and rode assembly loose." -------------------------- If the wind was blowing 20 kts and the seas were picking up and I was 20-30 miles off shore....I would cut that line in a heartbeat. Never, ever tie it off to a stern cleat in those conditions. On an offshore fishing trip like that, $200.00 doesnt even cover your gas bill. Cut the rope and go home. The safety of the Captain and crew takes absolute priority over anchors, ropes or any other material items. |
chopbuster |
posted 03-10-2009 01:02 PM ET (US)
No known technology trumps experienced seamanship skills and common sense out on big blue. |
TransAm |
posted 03-10-2009 01:22 PM ET (US)
rowmer1, you and Brian would make good liberals...take half of what someone says and assert it as the whole story. Since it stands to reason that the anchor was tied off on the front cleat to start, an attempt to SLOWLY back off is not unreasonable. It would take, oh, about 90 seconds to accomplish this and determine if it would work or not. I'm assuming of course they didn't wait until the seas had built to overwhelming height to decide to pull up anchor. I did not advocate tying off to the stern and giving full power-sheesh. Following up on your "seems pretty clear to me..." comment, it seems pretty clear to me that what they should have done is not go out. That would be the appropriate 20/20 hindsight statement. |
lurkynot |
posted 03-10-2009 01:23 PM ET (US)
Hind site is 20/20 I do not think I would have just cut the line without an ohnest attempt to free it.prior to this trajic event. That being said this incident has taught me a lesson without learning the hard way I am very lucky and humbled. It is a shame an awful shame that this happened. Simply saying: "No known technology trumps experienced seamanship skills and common sense out on big blue." |
R T M |
posted 03-10-2009 01:31 PM ET (US)
Sounds like it may work on a large inboard boat, but not on an outboard. Too bad they made this bad decision. rich(Binkie) |
Buckda |
posted 03-10-2009 01:37 PM ET (US)
T/A I disagree: Yes, one form of hindsight is to say "don't go out" - but accidents and mistakes happen in calm, shallow and near-shore waters as well. The same hindsight can be applied. If you never go out in a boat, you eliminate 100% of the risk. Maximum security. It only exists in prison, and even then, it is a myth. No, you can indeed learn many small lessons from this tragedy, including what to do in the real world - when you find yourself in a predicament due to your own previous mistakes. You can learn how to save yourself from your own mistakes. So they went out. The very act itself did not account for the tragedy - it contributed. Lots of people who boat frequently find themselves in situations which they did not intend or did not foresee. What you do in that situation is critical...and where many of these lessons can be taught. We all start and progress to different points on the "seamanship" timeline. We can all learn certain things from this event that may help us at each of those stages in the progression of becoming a good captain. What is a learning for one is old news to another. What is profound to another may be missed by someone with less experience who doesn't understand the depths of the lesson...yet. I know one thing: I've learned that sacrificing a fender to mark my anchor is a good idea if I can't get it to release from the sea floor - I can come back in better conditions to try for a better result. Dave |
R T M |
posted 03-10-2009 01:41 PM ET (US)
Who knows how high the seas were when they attempted this. I have freed anchors from stuck bottoms, not wreck fishing, if the seas are say 2-3 feet, by motoring up on the anchor, till the line is almost vertical, and tying it fast to the bow cleat. The rise and fall of the bow most times will dislodge the anchor. If it doesn`t do it, forgetaboutit and go home without it. If the seas are so high that they will come aboard, don`t try this, or if it is flat calm, don`t bother. rich(Binkie) |
Tohsgib |
posted 03-10-2009 01:42 PM ET (US)
With a fluke type anchor I was always told to drive OVER the anchor to release it, not to yank it out which in theory drives it further in the ground. We have used balls and/or rings to bring up stuck anchors as well. On my boats I use a $15 Hooker 8lb danforth type, $15 of chain and whatever the rope costs, I have no problem cutting it as I always carry a spare as well. If I had a $200 Fortress setup, I might be more willing to try and free it but chances are the flukes would bend under that much strain and release it anyways. My Dad's friend's son was on a small boat in FL when the anchor stuck. Being a professional swimmer he decided to dive for it in like 20 feet of water...never found him. |
SpongeBob |
posted 03-10-2009 01:43 PM ET (US)
If it happened as described it sounds more like ignorance to me. As I've said before, I came to Whalers from sailboats and learnd how to drop anchor and weigh anchor using both sail and motor. It is not hard unless you are hooked on an ubstruction. Most small sail boats do not have large powerful motors to pull the anchor nor are they needed, it can be done under sail power alone. Anyone who has read or looked at Chapmans can do it successfully. Power/sail up slowly on the anchor with the bowman pulling in the line. Let the motor/sails do the work to get you over the anchor and then pull. If it is still hard to do wrap it around the samson post (or cleat) once and let the wave action snap it free. I it is to rough to cleat the anchor off, power over the anchor a little and it should flip free. To back down on an anchor as described in the first post only sets it deeper. I have always used this methon and have always had success, granted I don't sail in waters strewn with rocks and coral, it's usually sand or mud but then I'm in the same area that the tradedy took place. The closest I have come to losing and anchor was in Sarasota Bay one day when powering over the anchor was the only way it came up. It came up with a 10 gal. plastic planter full of mud, one of the flukes of my Fortress had pierced the planter and hooked it. Having said all of the above, I was not there and they may have tried the very method I described with no success and until I see an interview with the survivor I will withhold judgement. I've been in to many tight spots when things happened way to fast to be judgemental at this point. Jeff |
TransAm |
posted 03-10-2009 02:09 PM ET (US)
Dave, you missed my point. My 20/20 hindsight was not suggesting to "never" go out; just under the circumstances they did. With the readily available forecast, would you have ventured out 40 miles in a 21' boat? Slowly backing your vessel in the opposite direction in which the anchor was set will often dislodge it with minimal effort and risk. If it still wont budge, then by all means, cut her loose. If a 90 second exercise like that is too much to undertake as a captain, perhaps boating in general is asking too much. With all that is known, what these folks were trying to accomplish was not unreasonable or even dangerous. How they went about it was their doom. |
Austin Whaler |
posted 03-10-2009 02:20 PM ET (US)
As my step dad has always said to me, "Protect yourself from yourself, you are your own worst enemy" he has always said that i will never become a captain until i learn that. Always use common sense. |
Buckda |
posted 03-10-2009 02:33 PM ET (US)
Agree - what they did caused the outcome. That is why it is important to identify what "not to do" so that we can have a better chance of surviving our own foolish mistakes that we all make. Incidentally re: freeing a stuck anchor: I have a Bruce anchor and have attached the chain to the front of the anchor, and zip-tied three medium sized zip ties along the shank so the chain is "free" at the aft part. This set-up allows me to yank on that puppy and break those zip ties free, which immediately allows me to free the anchor as it is pulled "backwards" out of the hole it has dug, instead of "through" the mud it is buried in. Something to think about....and it is theory. I've never had to try to implement this strategy to remove that anchor. I have had to cut ground tackle free before though. I fouled a small 14 lb Navy anchor that I was using for my dingy on a log-littered bay up in Lake Nipigon. No amount of pulling in any direction would help - even with it secured to the bow eye and backing down very hard in all directions. That sucks. |
20dauntless |
posted 03-10-2009 02:43 PM ET (US)
SpongeBob, I have always used the method you've described for freeing an anchor with success. I'd also recommend the Chapman's guide for any boater, it is the definitive source for information on just about anything related to the operation of a boat. Buckda, Your setup sounds interesting. If I understand it correctly it should work well for most situations. My only concern would be if the ties came loose when you don't want them to. I could see having one anchor set up like this as a "lunch hook" but I'd still rather have my primary anchor set up without the ties for overnight use. |
Buckda |
posted 03-10-2009 02:57 PM ET (US)
Yes, that is an excellent point. I may revisit this idea. I've often also thought about using a second, floating line to this part and tying it to a fender. That way it will stay above the anchor when you set it. You can then retrieve that line and tie it away from the main anchor line and use it to recover the anchor, if needed. That would address your concerns about overnight holding power. I'll think about that some more and may implement that as a solution when anchoring out. |
tedious |
posted 03-10-2009 03:23 PM ET (US)
The second line is a good approach, for anchors that have the extra hole such as the Bruce. The buoy floats right above the anchor, so it also helps you get an idea of scope and the swing circle. And if you do get into trouble like these poor guys did, you can always just dump the anchor and come back for it another, calmer day. Tim |
SpongeBob |
posted 03-10-2009 03:59 PM ET (US)
If you do not reduce scope to a point where the line is almost perpendicular pulling from the opposite direction will only reset the anchor in the other direction. "Good" anchors are designed to do this, to reset if pulled in another direction by the wind or waves. If your anchor will not do this do not leave your boat at anchor unattended, you may find it gone upon your return. I carry and have carried Bruce (my favorite), Fortress, Danforth (and clones), grapnel, and coffey cans with concrete (when I was young and penniless). It dosen't have to be a brand name, only perform correctly. Jeff PS: The coffey cans were on jon boats on farm ponds. |
Jordi |
posted 03-10-2009 04:35 PM ET (US)
Many of us have been in similar conditions and perhaps the similarity leaves a saddened feeling inside. Anchoring is truly a skill which requires patience, knowledge, etc and even under moderate condition things can turn ugly quickly. My heart goes out to the families of these men and to the many folks that tried to offer assistance. This tragic event happened in my "back yard" so I have tried to make sense of how I would have handled the same condition. Personally I use a claw anchor with a "ball ring retrieval system" and this works 99% of the time. When a few attempts fail to bring up the anchor and the weather is rough you really only have one choice. Cut the line and head home. Be prudent and give yourself a second chance at the fish tomorrow and more importantly at life. Jordi |
towboater |
posted 03-10-2009 07:32 PM ET (US)
Ive always wondered how bare boat charters and competence would marry up. Terrible thing. Great advise previously. Maybe I missed it, I might add, Disclaimer: Practice backing against a current or wind til you have the feel down pat. The anchor buoy will always be downstream or downwind of the anchor. OK, everything is cool. Now you can start using surge power as you back. Come fwd a little, then back til the line comes tight. This surge power will pull your bow around or down a little but it wont flip your boat. Instead of the transom digging in, the surge will raise the transom and try to cavitate the engine. Be ready for this, the weight/momentum of the boat surge is going to free the anchor, not horsepower. Ive even used the momentum of a log connected to another that is buried in the sand to free it. Another thing, many times you will have able bodied crew more than happy to scramble for a bow line when you make a landing. Another time, you might not. What a great feeling to know you can just tell the green crew of kids or Mother in Law to sit tight, maneauver the stern in, grab line, step out on the dock, grab the bow line and take their hands as they step to the dock. Practice. Configure your gear linkage & idle speed so it is easy to bump in and out of gear when you idle in for a landing. Have fun. Sorry bout the diatribe. Maybe someone will make sense of it. |
flawton |
posted 03-10-2009 08:13 PM ET (US)
Source Please??? |
lurkynot |
posted 03-10-2009 08:27 PM ET (US)
flawton, as I said at the beginning of the post that it was a post from another forum. http://www.thehulltruth.com/dockside-chat/212922-unsinkable-saved-his-life-4.html page #4 look for userid TheShortAnswer |
HAPPYJIM |
posted 03-10-2009 08:40 PM ET (US)
lurkynot said in the initial post. "Would I rely on or incorporate a turtled hull as part of my safety plan?.........probably not. Is a turtled hull more easily spotted by searchers?.........probably but don't count on it." With many hours spent looking out of a C-130 doing 200 MPH at 100 feet looking for lost souls I can say that the ONLY situation that I would leave a boat, turtled or not, would be if it was on fire. If a person is floating in the sea, the only thing that is above water and visible is your head and the top of your shoulders. Much easier to spot a needle in a haystack, believe me. Even if the boat does burn, it will only go down to the waterline or to a point where the water will put it out. Stick with whatever is left. If it is just a cooler lid, keep it with you. The bigger that you make yourself the better chances of the Coasties finding you. Stay with the boat....you will be found. |
HAPPYJIM |
posted 03-10-2009 08:42 PM ET (US)
Sorry lurk.....after reading it again, I see it was not your wording. |
flawton |
posted 03-11-2009 09:37 AM ET (US)
I find this "account" totally plausible yet I find it interesting that, if this is indeed what happened, none of the major news outlets have picked it up. |
lurkynot |
posted 03-11-2009 09:57 AM ET (US)
flawton, and your point is??????? |
PeteB88 |
posted 03-11-2009 10:19 AM ET (US)
What'd I say two weeks ago? Anchor got these dudes. It's a freaking shame. From whitewater days I not only respect anchors I fear anchors bottom line because an anchor incident will get you and your boat in seconds and there is little time to react. I still have my Gerber River Runner (yellow) in the gunwhale groove next to the console on the 13 (not great access but I know exactly where it is at all times). The scabbard clips to PFD and I rig it handle down if things get knarly or I'm by myself. You can get them pointed or blunt end - mine's pointed and somewhat hazardous. I have an ammo can for tools and keep a second serrated folding knife there all the time. So here's what I'm going to do - Towboater used the work "practice". When the ice is gone and I get the Outrage over here and I get a new anchor, I'm going to go out and practice setting and retrieving my anchor in various conditions. I will also find a new spot for my yellow knife where I know it will always be. I know there are anchor buoys available but I remember back in Oregon some dudes came up with a buoy retrieval system they called Anchor BOY. It might be the same as the ring thing but I'm not sure. My friend shot a commercial for that device which was, as I recall, some kind of sliding clip (not a ring) you put on the anchor line and clipped to a round buoy and slid it down the line, Some how it cleated itself to the line and you powered back and the anchor lifted free from the bottom. I have the rough tape around here, maybe I'll double check it sometime. I remember being on the shoot on the Columbia and watching these dudes make it work. Most of the stuff I saw was shot at the dock. |
Hoosier |
posted 03-11-2009 12:32 PM ET (US)
Pete, is this what you're looking for? [url[http://www.ironwoodpacific.com/products/anchoring_mooring/anchorlift.htm[/url] |
Hoosier |
posted 03-11-2009 12:41 PM ET (US)
http://www.ironwoodpacific.com/products/anchoring_mooring/anchorlift.htm |
JMARTIN |
posted 03-11-2009 01:26 PM ET (US)
If you are brave, you can use that retrieval system to lift shrimp pots also. Been there, done that. There are lots of things that can go wrong. John |
towboater |
posted 03-11-2009 02:08 PM ET (US)
Thx Hoosier. If you buy it separately, the buoy ball needs to be big enough to hold the weight of your anchor and chain by itself. Avid small boat fishermen around here that need to move around a lot often prefer sacrificing the deck space in return for easy anchor retrieval. Simply put the boat in gear and idle ahead angling off enough to make way without risking the anchor line foul in the prop. A lot of guys with Cabin boats also have a long strap and D ring clipped into the bight of the anchor rope on the boat side of the buoy then secure it to the midships cleat. When the anchor comes up via buoy, they untie the strap and pull the bight of the anchor rope up on the aft deck then retrieve the anchor from the stern. This reduces prop issues and eliminates keeping the line tight and swinging a pike pole around trying to grab the bight from the stern when you have a lot of passengers on deck. Other times (various cabin boats) I have run the anchor rope thru the pulpit and then burn it around the outside of the railings and secure it midships. If we get a fish-on, it is faster to untie and flip the rope out of the pulpit than scurry up to the bow to do the same. And usually it is MY monster fish that requires chasing it down and I need to handle both jobs. smiley face here. Well, Nav locks are down for repairs, been fun, now its time to get back to work.
boatdryver |
posted 03-11-2009 02:15 PM ET (US)
Yep, I've used that system to avoid hand-pulling shrimp pots up from 300 ft in the PNW. Even in a 14 foot inflatable with MASSIVE buoyancy extending aft of the motor there was always noticeable stern squat in flat water. I doubt this system is intended to "break out" a deeply set anchor, but rather to raise one already broken out up to the surface in deep water. JimL |
pglein |
posted 03-11-2009 02:27 PM ET (US)
They were fishing a wreck. The anchor was likely fouled on the wreck. Freeing an anchor that is stuck on a sunken steel ship is very different than freeing one that is stuck in the mud. In their shoes, I would have probably cut it free. Maybe, MAYBE, I would have thougth to tie a fender to it before doing so. But there's no way I would have tried to "power" it free. Freeing an anchor through carefully applied brute force makes sense when it's likely stuck in the mud and conditions are safe and calm. But other than that, you cut it free and consider the cost of the anchor to be tuition. |
hookum |
posted 03-11-2009 02:40 PM ET (US)
Saw this article on the Everglades boat http://www.boattest.com/Resources/view_news.aspx?NewsID=3228 |
R T M |
posted 03-11-2009 03:23 PM ET (US)
I agree with pglien. If the anchor is fouled on a wreck, no anchor retrieving system is going to work, and in 110` of water is is not possible to come back and free dive and get it later. Unless you are, or know a very experienced scuba diver who will retrieve it for free, just cut it off and go home. Obviously its not cost effective to pay someone to dive and retrieve it for you, at a later date. Of course you can tie a float on the end of your anchor line to mark the spot, and if you are the generous sort of person, come back and tie a really big float on it later, so it can be reached by fishermen who only steer by a compass, although I never new a fisherman to give away his spots to strangers. LOL rich(Binkie) |
flawton |
posted 03-11-2009 05:22 PM ET (US)
My point lurkynot, don't believe everything you read on the internet. There have always been some very entertaining "accounts" in the penthouse forum as well. With the amount of news coverage on this whole thing if this is what happened it would be all over the news outlets. Nothing personal, just would like to see an offical report on the whole accident before I accept it as the gospel. Btw lurky, you did start a nice discussion how not to retrieve an anchor. |
R T M |
posted 03-11-2009 07:05 PM ET (US)
I think this a little to technical for the news media, to report. Most people except for experienced boaters would understand the principle of line stretch, or a cleat from a clat or bow from stern or really care. Its the results that are of interest. rich(Binkie) |
lurkynot |
posted 03-11-2009 07:13 PM ET (US)
flawton. Someone has to know what happened since there is at least one survivor. That being said the survivor has either not told the details of this tragedy or he has. More likely than not as in human nature he has told someone - close friend, family member and then from there...no one knows for sure at this point. It does not necessarily have to be told to news agency if he did divulge details. Also there is no need to remind me that I should believe everything I gain from the internet. After 40+ posts I figured someone would call me out over this post and that is why I was careful to not make myself the "source" and did my best up front to point that out. The original source appears to have a reputable account that does make sense and thus another reason I felt better about posting. Until I hear a different account - prefferably from the lone survivor - this will have to do as far as filling in the missing pieces. |
flawton |
posted 03-11-2009 07:43 PM ET (US)
Agreed. |
samwhaler |
posted 03-11-2009 08:01 PM ET (US)
A "conventional type anchor" will most likely be fouled over a wreck. Ask spear fishermen who fish wrecks and they will tell you they retrieve an endless supply of anchors left by people who have cut off their lines. If you fish wrecks or artificial reefs,the "Mighty Mite", is the way to go. http://www.boatersworld.com/product/159190040.htm Here is a nice video of the use of a ball to retrieve a Mighty Mite taken on the Atlantic off SC coast. http://www.youtube.com/watch?v=JwiNDQW_r08 Sam |
an86carrera |
posted 03-11-2009 09:03 PM ET (US)
http://www.boattest.com/Resources/view_news.aspx?NewsID=3228 Read, |
PeteB88 |
posted 03-12-2009 12:15 AM ET (US)
Hoosier - that's gotta be the device - Anchor Lift, my pal Kevin shot the first promo vid for the dudes who invented it back in early 90s - the called it Anchor Boy or Buoy, can't remember. I do recall it worked great but we had drift boats then and didn't have any real interest. I found this vid on youtube obviously shot on a Pacific NW river but not the footage I recall. http://www.youtube.com/watch?v=8T8GdSvvL84&feature=related Thanks - I might get me one for the Outrage 17. I'm still trying to figure out what anchor to buy mostly for Lake Michigan, near the beach or fishing perch. I will use other anchors for inland lakes. |
Hoosier |
posted 03-12-2009 09:18 AM ET (US)
Pete, I have a Chene on my Montauk and use it as a backup on the Outrage. It's a hybrid, part Danforth, part Navy. http://www.cabelas.com/prod-1/0037213018123a.shtml I don't know the bottom for where you fish, let that guide your choice. Some anchors ae better in sand/mud, others are better in hard bottoms. That's the argument for having two kinds aboard. |
Hoosier |
posted 03-12-2009 09:24 AM ET (US)
fourdfish |
posted 03-12-2009 09:53 AM ET (US)
I carry 2 anchors and I also use a Chene anchor once in awhile and they work well. |
newrigs |
posted 03-12-2009 11:50 AM ET (US)
I have found that when anchoring in deep water, move your chain to the head of the anchor. Simply drill a hole at the head of the anchor and use a shackle to attach the chain. Now, you can use a zip tie an zip tie the chain where you would normally attach the chain. You can purchase zip ties that are rated for many hundred pounds. Just remember to get the right size for your application.(boat size). So when the anchor hangs up the zip tie will break free at the shanke therefore pulling the anchor up by the head. We do this sometimes daily in the gulf of Alaska in 400ft. of water. The zip ties are cheap, it,s cheap insurance. Just as some of the others have stated if in dout leave it,bouy it off come back another day and remember to take this tragedy and make some good out of it, as ackward as that sounds the good is all the posts that have been made in the attemp to educate others and prevent the heart break of so many families. God's speed in healing these broken hearts! |
number9 |
posted 03-13-2009 07:35 PM ET (US)
It's a shame that inexperience and ignorance of basic seamanship caused the loss of three lives. Recommend anyone who owns a boat have a copy and read Chapman book. Have suggested it to many and few invest the time to lean how to safely operate a vessel. Remember watching the movie Jaws and thinking how unrealistic the whole story was, no captain would ever tie of a shark/large force to the stern of a boat. I learned the hard way through practical experience about forty years ago while in high school. Had built a eight foot pram in junior high shop class a few years earlier for my 3 1/2 Montgomery Ward's motor. Headed down the Potomac close to the C&O tow path, had the bright idea of stopping to drop a line to fish, held one of my oars up against a downstream tree branch, boat stopped but the strong spring current against the flat stern caused one corner to dip instantly capsizing the little boat. Never saw it again and hugged a tree limb over the river until rescued. I was know by some as Captain Glub Glub for the rest of my sophomore year. Sad to say but the average boat owner(present company excluded) today probably doesn't even know how to tie to a cleat. |
HAPPYJIM |
posted 03-13-2009 08:41 PM ET (US)
You got that right number9. I've seen all kinds of wierd ways to cleat off a boat. Most like to use all of the remaining line and keep wraping around the cleat until all line is gone or run out of cleat space. Here's the best and safest way to do it. How many can honestly say they do it this way? |
towboater |
posted 03-14-2009 02:29 AM ET (US)
Rule 1. Preconceived notions are a recipe for disaster. mkj |
BlueMax |
posted 03-14-2009 05:11 AM ET (US)
HappyJim - you posted that site at least once before - I know because this is the second time I boomarked it. Ha. That is indeed a great site and chock full of interesting information. Great learning tool for beginners and refreshers. Thanks for putting that back up - Max |
towboater |
posted 03-14-2009 12:57 PM ET (US)
40 years of tying ropes to cleats, I absolutely agree with the link, thanks Hap, great demo. Its amazing how much you can learn about a Mariners boating experience by just watching them secure a line to a cleat.
DEMO is correct = under, under, figure 8 at least 3 times THEN HITCH if you are going to carry a load. For small light boats with small cleats, big ropes or if you are short lined, go under, under, THEN DOUBLE HITCH...no figure 8s. The second hitch is just insurance. Actually I used this knot a LOT on all my boats, but always in a situation I know I will be able to get slack to untie it. I know it is pointless to go to that line to try to untie it if it is not slack. I teach my crew clove hitching a cleat is a MARINERS MORTAL SIN. Hitching right off the bat is not a clove hitch, you will recognize a clove hitch, once it cinches, you cant untie it with slack from either side! Another thing I see a lot...getting petty here... SLEEPER LINES 101: |
R T M |
posted 03-14-2009 02:19 PM ET (US)
(Is it possible to spend months and months of time and many dollars restoring a boat and then look like a fool the minute you tie a rope to the cleat? hehe.) I think that most of us that have restored, and/or built a few boats know our way around boating and boats,hoho. Now fishing may be another matter. as its hard to work on boats, and be out on the water every day, as that`s the only way to learn where the fish are. One thing I noticed in Coast Guard boot camp,and was surprised at the non boaters that joined up. Most of them never coiled a line before, and the way they did it was to fold their arm upright, and coil the line around their elbow and wrist. They were imedietly labeled as"Clothline" rich(Binkie) |
