Topic: E-10 in Florida update from Oil Express 3/13/09
JMARTIN |
posted 03-16-2009 12:09 PM ET (US)
BP moving to all-E10 in Florida; Marathon will pitch recreational ethanol-free blend"BP marketers have been able to lift both E10 and conventional blends of gasoline on Florida’s west coast, but that will end next month, when branded and unbranded jobbers are routed to the Marathon terminal. While Marathon will continue to provide conventional gasoline, that privilege will only be for Marathon’s branded jobbers, sources say. "BP’s move was foreshadowed a few weeks ago when the major told jobbers that an expansion project to create an ethanol hub at Tampa had been pushed back by budget constraints. BP distributors will start pulling E10 from Marathon’s Tampa terminal on April 28, and no gasoline or diesel liftings from the BP facility will be allowed after May 4.The news doesn’t have much impact on service stations, but may cut into sales to marinas and other commercial customers who want to avoid ethanol for as long as possible. "Meanwhile, Marathon appears intent on capturing some of that anti-ethanol blend business. It plans to promote a new “recreational gasoline” that will not contain ethanol, clearly targeting Florida’s boating business. There is an aversion to E10 on the water, and some marketers have hauled conventional gasoline hundreds of miles to the Keys in order to supply high-margin boating accounts. The “recreational” grade will only be available to branded Marathon jobbers at Tampa and Port Everglades racks. It will have an octane number of 91 and will be the only conventional fuel Marathon sells in Florida. It’s not known if the company will market the recreational blend in other Gulf Coast markets." Good and bad news: good in as conventional gasoline is available for marinas, bad in that only Marathon branded jobbers have access to it. John
JMARTIN
posted 03-16-2009 01:30 PM ET (US)
Sorry about the crummy cut and paste job, it's hard to read.Another observation, the conventional fuel is a 91 octane. Most motors are tuned for 87 octane. John |
Tohsgib
posted 03-16-2009 01:36 PM ET (US)
Modern fuel loses it's octane VERY quickly. Running 91 is not a bad idea being in 2 months it might only be 88. If you run 87 and let it sit, it might be 84 and you WILL do damage if your outboard detonates(pings) which you can't usually hear like in a car. I run 89 exclusively for this reason, 91 is even better, especially if no ethanol. |
frontier
posted 03-16-2009 02:19 PM ET (US)
My local Yamaha outboard dealer and mechanics say 87 octane is fine, 89 is OK, but 91 is not only unnecessary and more expensive , but can damage the engine. |
lakeman
posted 03-16-2009 02:46 PM ET (US)
Frontier, is the Yamaha dealer talking about e-10 or regular gas? I have often thought about using 91 when switch to e-10 enriched gas. |
frontier
posted 03-16-2009 02:54 PM ET (US)
Regular gas. |
Tohsgib
posted 03-17-2009 10:40 AM ET (US)
Show me in an owners manual where it says that. It will always tell you 87 minimum. So if you let it sit and it goes below 87 what will you do? |
cgodfrey
posted 03-17-2009 09:41 PM ET (US)
At this point in the conversation it would be helpful if someone could produce an official graph showing the decrease of gasoline's octane over time.CG |
Mambo Minnow
posted 03-20-2009 01:37 PM ET (US)
Does anyone know a retail chain other than Marathon that is still selling non-ethanol fuel in Florida?Stopped by and my mechanic predictably commenting on seeing lots of ethanol related problems including blown engines from lean fuel due to line clogs. |
Plotman
posted 03-23-2009 09:43 AM ET (US)
Frontier-Your local Yamaha dude doesn't know what he is talking about. There is no way that running a gas with a 91 octane rating will harm an engine. There is no benefit to running a gas with a higher than needed octane rating, but it wont hurt anything. |
New 2 Whalers
posted 03-23-2009 10:14 AM ET (US)
I stopped at the one remaining Marathon Dealer in St. Pete and the owner knew nothing abut the non-ethanol possibility.My boat came with a rebuilt Johnson and the rebuilder's paperwork mandated high test gas or the one-year warranty (now expired) would be voided. I have always used Sta-Bil and now use the E-10 formula and have had no problems so far. Knock on wood. |
New 2 Whalers
posted 03-23-2009 10:17 AM ET (US)
Additionally, if anyone knows of a marina gas station in the Tampa Bay area that has non ethanol fuel, I'll drive there and buy it.Thanks:-) |
New 2 Whalers
posted 03-23-2009 10:18 AM ET (US)
Sorry, that should be marina OR gas station. |
JMARTIN
posted 03-23-2009 11:00 AM ET (US)
Florida Petroleum Marketers & Convenience Store Association, Inc. 209 Office Plaza Drive Tallahassee, FL 32301-2807 Telephone: (850) 877-5178 Fax: (850) 877-5864 E-mail: fpma@fpma.org President & CEO / Association Executive: Jim Smith PMAA Director: Bill McKnight Website: www.fpma.org I would try here.
John |
frontier
posted 03-23-2009 11:41 AM ET (US)
Regarding Yamaha not recommending 91 octane gasoline.John, maybe you can shed some light on this. Yamaha told me the additives put in 91 octane gas are for high end, high compression cars and could damage an outboard engine. It would cost you more at the pump AND possible engine damage in the future. When my engine was new (1996 130 Yamaha 2-Stroke) they recommended 84 octane (87 now). My local Yamaha dealer and mechanics also warned us NOT to use premium gas. |
dfmcintyre
posted 03-23-2009 12:11 PM ET (US)
I got curious and checked the owners manual for my 1999 Yamaha SC200X. Page 1-11: Recommended gasoline: Regular unleaded, with a minimum octane rating of 86 (Pump Octane Number) = (R+M)/2 If knocking or pinging occurs, use a difference brand or premium unleaded fuel. Do not use leaded fuel, it will cause damage to the oxygen sensor. Regarding Gasohol: Two types, ethanol and methanol; ethanol not to exceed 10%, and minimum octane ratings. Methanol not recommended. Don |
gnr
posted 03-23-2009 12:20 PM ET (US)
quote: Modern fuel loses it's octane VERY quickly.
Source please. I don't believe this to be true. |
Tom W Clark
posted 03-23-2009 12:26 PM ET (US)
From my Owner's Manual for the 1989 Mercury 135, 150, 175 and 200 HP models:GASOLINE RECOMMENDATIONS Any leaded or unleaded (lead-free) gasoline, with a minimum posted pump octane rating of 86 (research octane number 90) is satisfactory for use in these model outboards. While the use of the preceding grades of gasolines are acceptable, for optimum performance we recommend the use of premium (super) unleaded gasoline. However, gasolines containing alcohol, either methyl alcohol, (methanol) or ethyl (ethanol) may cause increased: - Corrosion of metal parts. - Deterioration of elastomer and plastic parts. - Fuel permeation through flexible fuel lines. - Wear and damage of internal engine parts. - Starting and operating difficulties. |
JMARTIN
posted 03-23-2009 12:38 PM ET (US)
Losing octane depends on region and type of fuel. There are many different types of fuel mandated for certain areas at certain times. I only know about my area, Skagit County, Washington.We got two different blends, both are conventional gasoline. We have winter gasoline, approx time we are switched over is during the first two weeks of October. Since we are below 65 degrees or so in the Winter, the refiner can put in more butane to increase octane. When it's warm out, this butane evaporates and you lose octane. So we have a summer blend, {switch first two weeks of May}, and you do not have the butane to lose and that fuel will keep it's octane better. John |
Dave Sutton
posted 03-23-2009 03:07 PM ET (US)
"My local Yamaha outboard dealer and mechanics say 87 octane is fine, 89 is OK, but 91 is not only unnecessary and more expensive , but can damage the engine." In a word.... Uhh.. (let me pick one carefully... consult dictionary...... yes, this is the right one:
Bullshit ;-) Sorry for the plain language, but this is simply not true. The higher the octane, the harder it is to get the fuel to burn. The advantage to high octane fuel is that it is *less sensitive*. That allows higher compression ratios to be used without detonation, which is a fancy way of saying that in a high compression engine, or one run at very high manifold pressures, that high octane gas is helping prevent your gasoline engine from trying to become a Diesel. There is a real misconception that high octane fuel is somehow 'more powerful'. That's just nonsense. Is it unnecessary to run a higher octane than the engine requires? Yes. Will it harm the engine? No way. Read what follows, clipped from the following Wikipedia Article:
See: http://en.wikipedia.org/wiki/Octane_rating ++++++++++++++++++++++
Higher octane ratings correlate to higher activation energies. Activation energy is the amount of energy necessary to start a chemical reaction. Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause detonation.
It might seem odd that fuels with higher octane ratings are used in more powerful engines, since such fuels 'explode' less easily. However, an explosion is not desired in an internal combustion engine. An explosion will cause the pressure in the cylinder to rise far beyond the cylinder's design limits, before the force of the expanding gases can be absorbed by the piston traveling downward. This actually reduces power output, because much of the energy of combustion is absorbed as strain and heat in parts of the engine, rather than being converted to torque at the crankshaft. +++++++++++++++++++++++
Dave
fourdfish
posted 03-23-2009 05:14 PM ET (US)
I gotta go with Dave on that one! I use 91 all the time. frontier, Show us the real proof! |
