ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Diver Needed At Sugar Barge Marina On Bethel Island
Author | Topic: Diver Needed At Sugar Barge Marina On Bethel Island |
dlburns |
posted 11-15-2009 11:29 AM ET (US)
I had my 15' Dauntless out last Wednesday up on the Delta for a little striper fishing and as I was pulling it into my slip at the Sugar Barge Marina on Bethel Island I shifted it into reverse to straighten out and spun my prop right off the motor. The hub, washer, castle nut and cotter pin are all still in place on the shaft just no prop! I contacted Tom Clark and sent him the photos of the hub and everything still on the shaft. He thinks that the washer I had was to small for the prop and it just spun right over it. In any case, I looked for the prop for quite a while and could not locate it. The water is only about 6 foot deep but the bottom is covered in a mat of weeds so it is most likely buried in a clump of weeds behind slip C-21. Tom suggested I post something here to see if any of you folks in the bay area might know a diver who could help me retrieve my brand new prop. I am certainly willing to pay someone to find it for me, just don't know where to start looking. If you can point me in the right direction I can be reached via email at dlburns36@sbcglobal.net or david_burns@sjwater.com. Or cell phone 408-206-3847. Thanks Dave |
K Albus |
posted 11-15-2009 12:03 PM ET (US)
Ask your marina manager for the names and numbers of some professional divers in your area. Especially in marinas where there are a number of large boats, there will be local divers who regularly work on boats that are in the water. |
dlburns |
posted 11-15-2009 12:06 PM ET (US)
I just sent an email to them to see if they could help me out in finding someone. Dave |
Chuck Tribolet |
posted 11-15-2009 09:25 PM ET (US)
MMMM, on my Evinrude, if the rubber between the hub and the prop let go of the prop, there's no way the washer would keep the prop there. And if the rubber let go of the hub, I wouldn't be surprised if the washer and cotter pin could chew the rubber up enough to get off the shaft. That prop may have propelled (PUN INTENDED) itself some
HAPPYJIM |
posted 11-16-2009 08:30 AM ET (US)
How about trying a large magnet to bring it up. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36904 |
Nauti Tauk |
posted 11-16-2009 08:33 AM ET (US)
Aen't stainlees and aluminum non-magnetic? |
RevengeFamily |
posted 11-16-2009 08:36 AM ET (US)
Is that a special Stainless steel magnet? Or is it the new Aluminum magnet? :) |
Buckda |
posted 11-16-2009 08:54 AM ET (US)
Grappling hook. Drag the bottom in a grid pattern from the slip behind you, through the fairway and into your slip. You'll pull up a lot of weeds, some beer bottles, a watch or two, several sunglasses and at least one cell phone..... |
posted 11-16-2009 09:19 AM ET (US)
Where is Bethel Island? |
HAPPYJIM |
posted 11-16-2009 10:36 AM ET (US)
Won't work on aluminiun but there should be enough steel in the stainless to bring it up. |
acseatsri |
posted 11-16-2009 11:39 AM ET (US)
Depending on the grade, stainless may or may not be magnetic. 400 series are magnetic, 300 series aren't. |
Tom W Clark |
posted 11-16-2009 12:40 PM ET (US)
Bethel Island is in California about fifteen miles east of Stockton. Forget the grappling hook. Most folks don't have one laying around and it is VERY unlikely to hook the propeller even if you were able to drag it directly across it. All stainless steel propellers are magnetic, even Mercury's X-7 alloy Enertia, but that does not mean a magnet would be able to pick up a propeller. A propeller's shape is very complex and a large magnet will only make solid contact with it at one or two small points while spanning or rocking on the surfaces of the prop. Dave reports the water is only six feet deep. The trick is to locate the prop in the first place before retrieving it. If visibly prohibits even snorkeling, then I would probe the area with a rod. You should be able to tell if you are tapping the prop by feel. Once located, the prop could be scooped up with a long handled pool skimmer. Obviously, getting in the water with SCUBA gear would be the fastest way to locate the prop. I have to think there is some CW member nearby with SCUBA gear or even a competent Free Diver? Chuck is correct that the prop is not likely to be directly below the point where it came off the prop shaft, but by the same token, it will not have gone far if the water depth is only six feet. The search area is probably less than 100 square feet. |
contender |
posted 11-16-2009 12:45 PM ET (US)
Try a local Fire/Police Depts. should have a dive team, they can use it as a drill, just buy them lunch/dinner... |
Tom W Clark |
posted 11-16-2009 12:53 PM ET (US)
Correction: Bethel Island is in California about fifteen miles west of Stockton. |
Tohsgib |
posted 11-16-2009 12:58 PM ET (US)
Well I know this guy.... Years ago a not so nice neighbor of his made such a fuss about boats being kept at the end of his street(public area with slips) that the town made it illegal to dock your boat at the public street ends which had been practice of many for DECADES. Needless to say the prop nuts on his twin engined SeaRay somehow came loose and when he put the screws in reverse the props went flying off. As far as I know, they were never found. You would be amazed at how far they may go, especially if reved up some. Good luck but I would not be amazed if they are a few hundred feet from your slip. |
Tom W Clark |
posted 11-16-2009 01:11 PM ET (US)
Not likely Nick. Dave told me the prop came off when he was coming into his slip as he put it in reverse. That means it happened at idle speed or close to it. With only six feet of depth, it *might* have gone six or eight feet laterally. I also told Dave the story of a friend of mine here in Seattle who did the same thing with his 50 footer as he approached a draw bridge in the Lake Washington Ship Canal here in Seattle. He put it in reverse, there was a clunk, and the prop was gone. He asked a local commercial diving school if they wanted to send some students to try to find it. They were thrilled to have a "real" recovery mission to practice on. They found his bronze five blade stuck in the muck with only one tip exposed. That was in 30-40 feet of water. |
dlburns |
posted 11-16-2009 04:13 PM ET (US)
The hub, washer, castlenut and cotter pin are intact and still on the shaft. The rubber portion of the hub is pristine, not a mark on it. I hope that Tom is correct in that the prop should be relatively close to the entrance to my slip. I just pushed it into reverse for a second and I was basically at idle. I spoke with the young man who works at the Sugar Barge and he said that he would go looking for it for me. I told him I would give him a $100 bucks if he found it for me. If he doesn't have any luck, one of my coworkers here has offered to go up with me and dive for it. He isn't a diver but is part fish so I have some options other than forking out the bucks for a new prop. Keep your fingers crossed for me. Dave |
ratherwhalering |
posted 11-16-2009 04:20 PM ET (US)
Hey Doug, while you're at it, ask your diver if he can look for my self respect...I lost it a few years ago at the Sugar Barge (or was it the Rusty Pelican? I can't remember...) |
ratherwhalering |
posted 11-16-2009 04:22 PM ET (US)
Uhh, correction, I meant the Rusty Porthole. The Rusty Pelican in Alameda was back in 2004. |
Buckda |
posted 11-16-2009 04:55 PM ET (US)
Is it legal/within your contract to enter the water in a Marina? I understand there are some authorized services that do hull cleanings/maintenance via divers at marinas, and of course, the fire department/police dive team can go wherever they want. I always understood that swimming in a marina was not allowed. Of course, that doesn't keep some people from doing it. Just this summer we witnessed a gentleman dive from the docks at Killbear Provincial Park Marina in Ontario after his wife dropped his cellular phone when disembarking the boat. If you are near powered docks, be sure to have a person standing by with a life ring and a boat hook to get you out of there if you get shocked by stray current. I like the pole/probe and then fish net strategy. |
dlburns |
posted 11-16-2009 05:46 PM ET (US)
I am sure that the marina will not have a problem with me trying to retrieve my prop. They have been wonderful in providing assistance thus far. I have a guy making me a grappling hook out of #4 rebar so that I can drag for it. If I can just locate it I will jump in and grab it. |
BigDaddyWhaler |
posted 11-16-2009 06:55 PM ET (US)
This has nothing to do with looking for a diver. But I keep Big Poppi my Outrage 25 just down the street. I think I'm like ten house away. You may want to call Kentco Construction. He is a certified diver and well experienced. He did the levee reconstruction on Russo's years ago. |
dlburns |
posted 11-16-2009 07:53 PM ET (US)
Big Daddy, do you have a number for Kentco by any chance? Dave |
BigDaddyWhaler |
posted 11-16-2009 08:42 PM ET (US)
I do not. If you look in a local phone book under pile driving contractors he'll be there. Or the next time you go up stop by his office. It is located on Bethel Island Rd. Right before you get to the bridge on the left next to marine emporium. Look for the cranes and equipment in the yard. Or you could do a search on clsb.ca.gov or something like that. Its like checking qualifications for contracotor. Hope this helps. |
diveorfish |
posted 11-16-2009 10:21 PM ET (US)
Did you find your prop yet? How much was that new Prop? Getting a professional diver to do it might cost almost as much as a the prop itself with no guarantee of success. I tried to retrieve someone’s new kicker out of potato slough once and the visibility was 0.0. It was in about twenty feet of water with a current. When I got to the bottom, I kicked up the silt and I couldn’t even see my air gauge. After fumbling around in literally pitch black water for about 40 minutes, I came up empty and got an ear infection for my trouble. Visibility anywhere in the delta is crap and you would have to literally bump into it to find it. I could do it, but between gas and gear rental, the cost would be at least $100 with no guarantee. |
davej14 |
posted 11-17-2009 11:00 AM ET (US)
If you know someone with a metal detector that is rated for water exposure, you should be able to find it in six feet of water using a snorkel. If the bottom is muddy and visibility is poor you are going to have to actually find it by feel. Without a detector the probability is low. |
dlburns |
posted 11-17-2009 02:31 PM ET (US)
I received a call from Parker Diving and Salvage and they are going to get it for me today for a $100.00. The water is shallow there and visibility was good last weekend. I could see the bottom just not through the weeds. Diveorfish, if they strike out, I may need you services. I am happy to pay $100.00 to find it as the prop was more than double that. Thanks Dave |
posted 11-17-2009 08:37 PM ET (US)
Please keep us updated on the outcome of the search. |
dlburns |
posted 11-17-2009 08:44 PM ET (US)
Tim Parker was there today to look for it and could not get through the locked gate to the berths. I neglected to give them the code when I spoke with them this morning! He is going to return on Saturday and retrieve it for me. Thanks to everyone for the recommendations and tips on how to get it back. I'll keep you posted. Dave |
Tohsgib |
posted 11-18-2009 09:55 AM ET (US)
Gonna cost you another $50 to have it rehubbed. Might have been easier to buy a new one. |
dlburns |
posted 11-18-2009 11:53 AM ET (US)
Nothing wrong with the hub, everything is intact and Tom is helping out with getting the correct parts to keep it on the hub the next time. |
Tom W Clark |
posted 11-18-2009 02:44 PM ET (US)
Actually Nick, the hub kits only cost about $25, but Stiletto has already sent a new one to Dave, gratis, so the hub kit won't cost him a thing. |
Tohsgib |
posted 11-18-2009 04:38 PM ET (US)
Good |
dlburns |
posted 11-18-2009 08:08 PM ET (US)
That is really awesome customer service Tom! Thanks so much. Dave |
dlburns |
posted 11-23-2009 04:58 PM ET (US)
Looks like I will have to try fishing it out myself. The diver that I thought I had lined up blew me off and the kid that was going to look for it form me flaked. I haven't had time to get back up there but will over the upcoming long weekend. I guess I'll just probe around and see if I can find it then try and fish it out with a pool net. This sucks. |
RevengeFamily |
posted 11-23-2009 06:01 PM ET (US)
Dave, I've been following your story, Soory to hear of your latest dilema Does this diver think you'll ever recommend him to somebody else? So he'd only make a "Hundy"... That's just the tip of the monetary ice berg. Dave could have sent him other customers with other work... there is no substitute for good, FREE, word of mouth advertising. Good customer service really helps in times like these. If I lived a bit closer I'd throw my gear on and see if I could help you out. Good luck, Norm |
deepwater |
posted 11-23-2009 06:13 PM ET (US)
Some people in some jobs wont show up for less than $250,,one guy wanted a 3 year contract to spray for ants at $750 a year,,He wont just do the foundation he has to have a contract,,I said thanks ill share that with my neighbours,,He lives here and has called 2x,,Get a long piece of re-bar and start feeling around untill you hear metal to metal,,And your going to get wet |
pcrussell50 |
posted 11-24-2009 01:31 AM ET (US)
Some jobs, some times of year, I guess. We just reached the end of our tolerance for the heater ducts under our house, [it's a raised foundation, beach cottage, built in 1926].* Dusty, dirty work in cramped surroundings. Our house is 1100 square feet and has 7 floor registers. First estimate was for $3200 parts and labor. Second estimate was for $2700. Youch! About 5 others never returned my inquiries. So I decided to see if I could reduce the cost by at least removing all the old ducting myself. In so doing, I figured out how relatively easy it is to attach the flexible, slinky-esque ducting. So I forged ahead and did the whole job myself. $200 in materials, and about 12 hours in labor, myself only. If you take the lower estimate, that comes out to $200/hour for work that is low-skill labor, not unskilled. Outrageous. I guess times aren't THAT tough yet for HVAC workers. *Non-essential trivia ahead: Peter |
TransAm |
posted 11-24-2009 08:03 AM ET (US)
Peter--Although you are entitled to argue what is fair pay for any profession or job (dirty, unskilled or otherwise), I believe you have oversimplified your experience with the HVAC work at your house. You see, the HVAC company has many expenses that you as a homeowner do not. For instance, did you include your time rounding up the materials, or factor in expense for the $50,000 HVAC truck, stocked with $10,000 worth of tools, etc, the time to diagnose you problem, workers comp insurance, health benefits, phone expense, office expense, admin support for billing and receivables, maintenance for your office, utility, insurance, etc. expense for the office, the office rent and about 20 other expense components of operating a business. And the burden for employers is only going to get worse. On top of that, businesses are entitled to make a profit, although that word has been shortened to 4 letters of late. I would have been very surprised if the author of this thread was able to have his propeller retrieved by a 3rd party for less than the cost of a new one. btw, I think airline pilots are among some of the most underpaid professionals in the workplace. |
HAPPYJIM |
posted 11-24-2009 10:36 AM ET (US)
The magnet will be the cheap way to retreive it. You may even bring up other treasures lost in the same spot. How about a nice anchor with rode? |
pcrussell50 |
posted 11-24-2009 12:50 PM ET (US)
Trans, Far be it from me to say what people should be paid. I believe in lettng the market decide. Around here, the skilled trades like welding and fabricating, machinists, and certified marine and auto service, go for about $100/hr give or take, overhead and all included. Two out of 7 hvac contractors even bothered to return my call. Both estimators spent 5 minutes, and neither got down in the crawlspace for a look before they spat out their huge estimates. As one who belives in the free market, I concluded that they really didn't want the job, (at least at market rates). But every man has his price, and I assume these guys found a price at which they would be willing to do this lousy job. Maybe they had plenty of other less unpleasant work they would rather do at market rates? Thanks for the vote of confidence about pilot pay. It used to be much better. It just hasn't kept up with COL. Peter |
dlburns |
posted 11-24-2009 01:27 PM ET (US)
I spoke with the Diving company yesterday and got an apology for not getting out there this weekend. She said that he would be out this afternoon to retrieve it. I can only go on what I was quoted and that was a $100.00. If it was going to be more than that I would have started dragging the area to see if I could retrieve it myself. I received the new hub kit yesterday so I am in hopes that he finds it today so I can do some fishing over the upcoming long weekend. I appreciate the offer Norm, I would have tried to find it on my own but unfortunately, I swim like a bucket of mud! |
boatdryver |
posted 11-25-2009 03:23 PM ET (US)
I don't understand why the prop came off. what happened here? JimL |
number9 |
posted 11-25-2009 03:45 PM ET (US)
May you tip very well if or not the prop is found. |
dlburns |
posted 11-30-2009 02:37 PM ET (US)
Bad news, the diver went down for it on Wednesday and was unable to find it. He said he searched a 100' area around my slip and could find no sign of the prop. He said that the bottom was very soft and could have swallowed up the prop and not left a sign of where it went in. He would not take any money from me for looking for it, he said that the deal was 100 bucks if he recovered the prop not for looking for it. Don't meet many folks like that anymore! I put the old prop back on on Saturday and when I took off the hub there was a pretty good gouge on one side of it where the prop twisted off. Complete bummer!!! |
elaelap |
posted 11-30-2009 05:08 PM ET (US)
Like number9 suggested, I hope you bought the diver a nice lunch or, even better, a couple of six-packs of Sierra Nevada pale ale. Tony Over the years I've found that it doesn't hurt in the least to do the same for the dealership wrench who provides yearly maintenance on my outboard motors (out of sight and sound of the shop's owner). I make minor repairs myself, change the fluids, and do the obvious stuff, but it helps me sleep at night--or relax when offshore a dozen miles in my little Whalers--to think that a friendly mechanic has gone over my rigs every couple of hundred of hours. In fact, when I bought my first four stroke outboard, a carbureted Yamaha High Thrust 50, I took the dealership mechanic out to a nice lunch at a local bar and grill, plied him with beer and beefsteak, and spent an hour or so asking him dozens and dozens of simple-minded (for me) questions about this new-to-me technology. Learned a lot which made my boating more enjoyable, and it's always been nice to return to that dealership's service department and be greeted with a smile and some personal attention. |
deepwater |
posted 11-30-2009 07:29 PM ET (US)
Get a set of Oyster tongs |
lizard |
posted 12-01-2009 11:54 PM ET (US)
Going to Tony's post about taking care of the mechanic, while not boating related, here are some thoughts: I have had the same painter employed in a variety of projects in my home, for many years now. It is almost insulting to call him a painter, as his breadth of knowledge is amazing. He has done a lot of custom interior wood staining for us. Many of his staff lack English as a primary language. Over the years while his crew are here, EVERY Friday, I provide lunch. When I worked part-time, I cooked it. When I worked full-time, I sent it in and mixed it up. Simple stuff- pizza, Chinese, etc. EVERY TIME his crew shows up here, they ALWAYS remember lunch. Old crew relay it to new crew (I speak their tongue, I know what they say). Cost me $20-40 dollars each time. It bought: 1) Incredible loyalty Take good care of your peeps. You are paid back, a hundred fold. Plus, you feel better about yourself for acknowledging a job well done. Pay it forward. |
