posted 03-17-2010 07:00 PM ET (US)
And tom976 makes a great point. It is an old engine. When buying an old engine you are rolling the dice. Could run great and have no problems for a couple of years or you may be faced with a significant repair bill the day after you take possesion even after a dilligent pre-delivery inspection and test.This engine I purchased looked brand new. Ran great on an engine stand. I purchased the engine from a private individual who was affiliated with a different engine manufacturer.
He purchased a used Whaler with this engine but was going to repower with the brand that he was affiliated.
I believe he was honest with me that he never put the boat in the water and ran the engine installed on the boat. He simply purchased the boat, removed the engine and offered it for sale.
Turns out the carbs were clogged and needed a link and synch after I installed it on my buddies boat.
I paid a premium price for this engine and wound up spending close to $900 to have a bunch of work done to bring it up to snuff.
Then the lower unit cracked after dumping the money into it.
Shame on me for not running the engine under a load before purchasing it. But that is the risk you take- I did not exercise or insist on this option.
So moral of the story is if you cannot run the engine installed on a boat I'd be very careful. A compression test on an engine stand is not going to show carb problems and possibly will not show ignition problems. Testing an engine on a hose is much different than testing an engine influenced by a load.
If I were to do it again I would spend more than $1000 on an engine of this age even if it checked out perfect. If it didn't check out I would pass and keep looking for a better engine.
Rich
