ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Honda 7.5 v. Mercury 7.5
Author | Topic: Honda 7.5 v. Mercury 7.5 |
JW_Spencer |
posted 05-10-2010 02:13 PM ET (US)
With apologies to the purists, I am looking for a kicker/auxiliary motor for my 1991 Wahoo 1850 (Whaler wanabe, the hull is like the bastard love child of an Outrage 18 or 19 and Montauk without the smirk, deep vee, cathedral -- and I am very grateful, because I am loving it). BACKGROUND: Low budget operation, 1st boat, it will be used for trolling for salmon in the Puget Sound (there can be some 7-8 mph tidal currents in places). I searched this forum and while I could not find uniformity of opinion, there seemed a quorum of those who thought a 6 hp would be the smallest recommended kicker for an 18 Outrage (similar hull and weight). I am looking at a 70's Merc 7.5 hp -- asking price $250 and an 80's Honda 7.5 hp -- asking $425. If it gets be through a summer or two, I'll be happy enough. What are your thoughts/recommends? ( for discussion purposes, assume same decent running condition -- I know -- big assumption). Thanks, |
acseatsri |
posted 05-10-2010 06:11 PM ET (US)
If you already have a 2-stroke that you mix the oil and gas, go with the Mercury. If you have an outboard that mixes the oil in the fuel automatically( or a 4-stroke), go with the Honda. |
JW_Spencer |
posted 05-10-2010 07:06 PM ET (US)
Thank you. Oh yeah, an important piece of information. The current motor is a Yamaha 150 oil injected 2 stroke. |
adlert |
posted 05-11-2010 10:15 AM ET (US)
Though acseartri's comments certainly make good sense, if you have room, many would say there is also value in having a totally separate fuel supply for your kicker for maximum redundancy. If your main engine goes down and the main fuel supply is to blame you'll be happy you've got the totally separate kicker set-up. If you choose to use the same (currently straight gas) fuel supply as acseartri suggests then I guess your easiest choice would be the Honda. Additionally, the Honda is newer which is often a good thing. I think I'd try to assess the actual mechanic condition and use history of the two engines and let that be my guide. Either should provide excellent service if in good shape. |
burning_hXc_soul |
posted 05-11-2010 10:46 AM ET (US)
I keep a separate 3 gallon gas tank on board for my kicker even though it uses the same pre-mixed gas as my main engine. That way, you always have at least 3 extra gallons of good gas on hand. I personally like mercury's but that's just me. A recommendation from me would be to always make it a habit to start your kicker motor each time you take your boat out. I don't use mine for trolling hardly ever, just a back up means of propulsion. That being said, my main motor has never left me stranded since I've owned it, but I keep my kicker motor current by running it at least 15 minutes each trip to keep it from just sitting and rotting. |
Tohsgib |
posted 05-11-2010 12:08 PM ET (US)
Condition would be the main point. You also need a long shaft or it might be a moot point in rougher seas. |
Kingsteven18 |
posted 05-13-2010 06:58 PM ET (US)
Here's mine: http://s189.photobucket.com/albums/z84/kingsteven18/18%20Wahoo/ |
