ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area Trailer decision
Author | Topic: Trailer decision |
RobertRibley |
posted 11-21-2010 12:15 AM ET (US)
I'm trying to make a decision on which is the best trailer to keep for my 88 Outrage 18. Type of trailering is 98% fresh water Trailer # 1 we built in 2005: Steel 3 in trailer channel steel
2005 Rolls tandem axle, all aluminum bunk trailer If I choose Trailer 2, I would add keel rollers to support the Whaler and LED lighting. I sometimes trailer the Whaler behind our dual axle 22 foot Airstream. I've done a lot of trailering of livestock, etc. my whole life but am having trouble making this decision. Thanks in advance for your thoughts, |
Jefecinco |
posted 11-21-2010 10:14 AM ET (US)
I can see why it's a tough decision for you. Because of the towing environment you most encounter the higher strength of the steel trailer is desirable. The negatives I associate with the steel trailer are the electric brakes, and powder coating. Virtually any sea water use of the trailer will provide maintenance problems with corrosion and the electric brake system. The powder coating will be damaged when towing on gravel roads. Tandem axle trailers are not as easily handled as single axle trailers. The virtue is less heavily loaded tires and axles and the ability to continue on in the event of a tire failure by elevating the failed wheel and securing it to the frame. A very useful feature when trailering in the back country. I assume surge brakes are used with your aluminum trailer. With your extensive experience tandem axle handling difficulties should not be a problem. For your stated use I believe trailer number two would best serve your long term requirements. If the trailer is not equipped with brakes I recommend you install corrosion resistant disc brakes with a surge actuator. Butch |
SJUAE |
posted 11-21-2010 01:35 PM ET (US)
Ditto on what Butch said I would also think the extra safety on the twin in the event of a blowout when coupled with your Airstream makes it a no brained IMO Regards |
contender |
posted 11-21-2010 07:26 PM ET (US)
Trailer Number #2 this is a no brainer. 4 tires, no rust, more support. |
