  170 Montauk or 160 Dauntless
Author Topic:   170 Montauk or 160 Dauntless
jason78 posted 08-21-2011 12:25 PM ET (US)   Profile for jason78   Send Email to jason78
I am looking for a 16 or 17 foot Whaler. Can someone please describe the differences between the Dauntless and Montauk models? As far as I can tell they have a different hull design and the Dauntless seems to have more standard options. I am not sure what the difference in the hull design means for each model or if I am missing anything else. Montauks seem easier to find than Dauntless models.
I plan to use this boat for fishing and some watersports. Also some intercoastal waterway use. Mainly looking for something easy to trailer. I think I was to get the 115 engine no matter which I get.
Thanks. Just wanted to add that I am looking in the [2000 and newer] model year range
Marlin posted 08-21-2011 10:40 PM ET (US)     Profile for Marlin  Send Email to Marlin
You can read the specs to see the difference in size and weight, but in general the Montauk is a bit longer and has a bit more space in the bow area. The Dauntless has a slightly deeper V-hull and is a bit heavier, which in theory should make it ride better, but the additional waterline on the Montauk probably makes that about a wash.
The Dauntless has significantly more storage space, with storage under the pilot's seat (or a livewell) and storage under both aft quarter seats and beneath the splashwell. Both boats have storage inside the center console, but the Dauntless is a bit deeper because the storage area is recessed into the deck, while the Montauk is not.
I think the biggest difference between the boats is that the Dauntless has a 45-gallon internal fuel tank, while the Montauk is limited to on-deck fuel. I will say, however, that a full tank does make the Dauntless a bit heavy in the stern -- you'd be better off with a late-2002 or newer Dauntless hull without the notch in bottom of the transom, and a lower-unit hydrofoil helps too.
By the way, the Montauk is only rated for 90HP, while the Dauntless is rated for (and really ought to be equipped with) 115HP.
-Bob
jason78 posted 08-21-2011 11:18 PM ET (US)     Profile for jason78  Send Email to jason78
Thanks for the info Marlin. It sounds like I should focus on the 160 Dauntless which is kind of what I was leaning towards anyway. They are so darn hard to find though. I have found a bunch of 13 and 15 Dauntless available but I really want the 16 because it includes the transom seating; as far as I can tell the smaller ones do not.
Thanks!!
Jefecinco posted 08-22-2011 09:29 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Jason--Marlin summed it up very well. The Dauntless transom seating is good for only two people and due to the fuel tank weight aft adding weight there is not always what you'll want to do. Hole shot and slow planing speed is always a challenge with the Dauntless so keeping weight forward is a better idea. The added weight and deeper V of the Dauntless will require much more fuel to operate and a larger tow vehicle to move around. Launching and retrieving at the ramp is a little more difficult with the Dauntless.
As a former 16 owner I strongly advise against buying a Dauntless with less than 115 HP if your plans include water sports or several aboard.
The Dauntless has three advantages over the Montauk; ride, below deck fuel capacity for long runs, and storage capacity.
If I was in the market for a Boston Whaler in the 16 to 17 foot range I would choose an older Montauk. There is no advantage to purchasing a model year 2000 or later Montauk. Older Montauks in excellent condition can be purchased for much less money than can a similar Dauntless or a late model Montauk. Furthermore, operation and maintenance costs over the long term will be much lower.
GreatBayNH posted 08-22-2011 10:32 AM ET (US)     Profile for GreatBayNH
Really? None? Them's fighin' words. At least if we're talking 2002 or later. 2000, 2001 model year Montauks should not really be thrown into the "or later" category. The Montauk design changed quite a bit in 2002. So much so there are posts on continousWave saying it should be called 'Newtauk', not 'Montauk' [To my knowledge, this has never occured. A boat with the wider gunwale decks of the NEWPORT and a center console of a MONTAUK, is said to a NEWTAUK, a portmanteau word combining NEW from Newport and TAUK from Montauk--jimh]
That said, if money is not an object, and you are doing fishing AND watersports, the Dauntess was made for that versatility. I've yet to see a water skier behind a Montauk and I don't think I'd want to. Just like I cringe when I see a lake boat out in the deep blue. It just doesn't fit.
andrey320 posted 08-22-2011 01:02 PM ET (US)     Profile for andrey320  Send Email to andrey320
Jason,
FYI - my Dauntless 15 has the rear seating - http://www.thehulltruth.com/boating-outdoor-photos/ 327014-new-home-made-wakeboard-rack.html
Jefecinco posted 08-22-2011 07:27 PM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
GreatBay,
I won't disagree with your statement that the 2002 and later Montauks are different from their predecessors. But, are they better? If they are better, why? If they are better are they enough better to justify a much higher price than a 1990 Montauk with a newer engine?
I've seen a 17 Montauk towing skiers and tubers but not wakeboarders. They seemed to get the job done without difficulty and looked rather grand during the process.
I forgot to mention that the 16 Dauntless is much more tender than a 17 Montauk. That's not a desirable feature in a boat with children moving about.
I felt that my 16 was very well suited for fishing after adding a few after market rod holders and a 5 gallon live baitwell. The extra storage was very welcome.
Tohsgib posted 08-22-2011 07:32 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Montauk and 170 Montauk are 2 VERY different animals. Kinda like calling a Leopard a cat. Are they better than classics, depends if you think 500more pounds(50%) more weight is better. Some like the lightweight nimble classics, some like the better ride from a heavier 170.
Dauntless has built in tank, Montauk does not. Personally I like the 170 as it seems roomier. The 160 is tight and stern heavy.
pcrussell50 posted 08-22-2011 08:08 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
I read in another thread on here that the classic Montauk, with it's tri-hull'ish design, (like the classic 13's as well), are much more laterally stable, like when people are fighting a fish against the side, or embarking/disembarking, etc... People can use the step pad in the forward corners and not have that unstable, "tippy" sensation you get with "fast bottom" v-hulls.
From looks alone, Dauntless'es look more like conventional, v-hull'ed recreational boats, (albeit, with superior Whaler-quality construction). Almost like it's not a Whaler. Whereas, the Montauk is Whaler "to the bone".
Do not take lightly or as insult, what I said about the looks of the Dauntless. If I were in the market for a typical, v-hull recreational boat, I'd way rather have a Dauntless than any other, because of the Uni-Bond construction.
-Peter
boatdryver posted 08-22-2011 10:34 PM ET (US)     Profile for boatdryver  Send Email to boatdryver
With the Dauntless you can't walk to the transom because of that stern seating, whereas with the Montauk you can as in fishing or tending to a kicker motor.
So it all depends on whether you are mainly wanting a family boat with the most seating or a fishing boat with the most walk-around deck space.
I chose a Dauntless. It fits my needs now, as did the Montauk I had previously.
JimL
jason78 posted 08-23-2011 12:03 AM ET (US)     Profile for jason78  Send Email to jason78
Thanks everyone for the feedback! I think I will probably lean towards the 160 Dauntless. I really am looking for a more "all around" type boat and it seems the Dauntless is it. Also, for watersports I think I will really need the 115 motor which the Dauntless is rated for. Thanks so much again for the help. I can't wait to be able to join the Whaler family. I have looked at other CC boats but the Whalers just stand out in design and overall quality so I keep coming back to them. Now all I have to do is find one, that seems to me more than half the challenge. Especially since many of the ones I have seen are 2 stroke rather than the 4 stroke I prefer. Thanks Jason
jason78 posted 08-23-2011 12:05 AM ET (US)     Profile for jason78  Send Email to jason78
OIA posted 08-23-2011 01:47 AM ET (US)     Profile for OIA  Send Email to OIA
I believe it's important to understand whatever you dream today is only a fraction of what your Whaler can deliver. There is no other boat I know that provides the ability to go beyond the farthest point. You may not want to run offshore today but, don't discount that you may want go scuba dive or fish on a shipwreck sixty miles offshore tomorrow.
Clearly, both boats are safe, fun, versatile vessels. That being said, what I've been able to do in a Montauk: The fun I've had, the places I've been, the freedom the boat has provided, she has performed beyond my wildest dreams. Just last week I was slalom skiing on Lake Mead and next week I will be heading 26 miles across the open ocean to Catalina Island.
I have never owned a Dauntless but, I can say without hesitation, the Montauk will take you wherever you want to go.
John Mirassou
Tohsgib posted 08-23-2011 10:13 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Do a search on the 160 with a 4 stroke. I know they changed the hulldesign early on but something about weight sticks in my mind.
pcrussell50 posted 08-23-2011 01:37 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Jason,
It's beginning to look like the only drawback to the 160 Dauntless, (for your uses), may be it's relatively tight quarters/interior size. Maybe the 180 Dauntless will take care of that? Sounds like that would be the solution to whatever remaining reservations (or concerns from the others), you have about the 160.
-Peter
lefty93 posted 08-23-2011 11:16 PM ET (US)     Profile for lefty93  Send Email to lefty93
Jason,
lefty93 posted 08-23-2011 11:30 PM ET (US)     Profile for lefty93  Send Email to lefty93
Jason,
I have a 2002 Dauntless 160 and love it. I trailer it but also slip it for certain periods of time in different locations. It is easy to trailer and launch. It seems larger than a 16 foot boat and the generous storage and aft seating are very handy. When I bought the boat used it had a carbeurated Mercury 90 hp four stroke. The boat seemed underpowered with that engine. I have since put an ETEC 115 on it and the difference is amazing. It has really made the boat sort of a "pocket rocket" while also giving me much better slow speed control for docking, maneuvering, etc. I have also added a TurboLift fin which makes the hole shot even better and allows me to stay on plane at 13-15 MPH, depending on load, wind, and waves. I have no problem pulling a wakeboarder or skier with three adults in the boat and 30+ gallons of fuel. For your intended use I don't think you can go wrong with a Dauntless. Good luck on your search.
Marlin posted 08-26-2011 10:02 PM ET (US)     Profile for Marlin  Send Email to Marlin
A couple comments to what other folks have said...
I got a chance a few years ago to check out a fellow's Dauntless 15 in detail. It was a beautifully made boat, as one might expect, with a lot of features for a 15-footer. But it's much smaller than the 160 Dauntless, even more than the small 1-foot difference might suggest. Likewise, the 180 Dauntless is a much bigger boat than the 160.
I rarely find myself in disagreement with Jefecinco, but having been aboard a few classic Montauk 17s, I wouldn't say that the 160 Dauntless is a more tender boat. About the same, or maybe a bit more laterally stable, I'd think. The boat is very stable when in the bow, to the point that you can easily stand on the bow gunwale without the boat reacting badly -- or for that matter, hardly at all. The down side, of course, is that the heavier, less efficient Dauntless really needs more power -- every bit of the 115 rating, and when skiing, you might wish for more.
This is the "biggest" 16-footer I've ever been on, and one of only a few boats that feel bigger in the water than out of the water. Whenever I look at photos of my boat, or even more so see another 160 on the water, I always think "wow, is my boat really that small???"
Stern seats... they're okay, but not super. Some passengers don't find the low backrests very comfortable, and it's noisy right next to the engine. And unless I've also got a couple people in the bow to keep things balanced, I rarely want anybody sitting in the stern. Especially if the fuel tank is full. The Dauntless is hyper-sensitive to weight aft and to engine trim, and loading it up in the stern is the fastest way to turn it into a sluggish, hard-riding pig of a boat.
As for the looks versus the classic Montauk, well, rarely has form followed function so beautifully as with the Montauk, so you'll get no argument from me. In comparison, the Dauntless is positively pudgy.
Finally, I think a foil of some type is necessary equipment to get planed off promptly and to keep the bow down at slow planing speeds. Prop selection is important too; my 115 4-stroke came with a 16" Vengeance, but changing to a 17" Trophy Plus had a huge impact on performance. I have a big writeup on that at http://continuouswave.com/ubb/Forum4/HTML/004868.html .
-Bob
pcrussell50 posted 08-26-2011 11:04 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
EXACTLY! Being new to boating, I'm automatically new to Whalers, though I've heard of their great reputation all my life. To "outsiders" like me, the classic 13/15/17/Outrage ARE Whalers... even though the others are Whalers.
Just a POV from somebody new enough to remember not having a Whaler.
-Peter
brookseu posted 10-20-2013 07:46 PM ET (US)     Profile for brookseu  Send Email to brookseu
the problem with the 2000 hull Dauntless is that the fuel venting doesn't work. Fuel flows into the vent line blocking the vent and creates an air lock that prevents refueling because air from the less than full tank can't escape through the vent line. The only solution I have found is disconnecting the fuel vent line and blowing the fuel that has collected in the vent line back into the tank. This is a real pain. But once the line is cleared, the air from the air will vent and you can refuel without a problem.
I understand that this design defect does not exist on newer hulls. Whater does not have a fix for this design problem.
Jefecinco posted 10-21-2013 08:35 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Brook,
You're mistaken. There is a fix. Not that your incorrect information matters on this old post. If you had done a search on this site you would probably found the solution before posting.
