| Author | Topic: Evinrude Announces New Engines 3.5-HP to 15-HP |
Evinrude announced today it has entered into an agreement with Tohatsu to have Tohatsu supply Evinrude outboard engines in the 3.5-HP to 15-HP range. The engines will be available in 2012. BRP has recently invested $15-million in the Evinrude plant in Sturtevant, Wisconsin where it builds the higher-horsepower Evinrude engines using E-TEC technology in the 25-HP to 300-HP range. The deal with Tohatsu will provide engines in the lower horsepower range, 15-HP and below. The engines will be four-cycle outboard engines. |
| 20dauntless |
So now you can buy a Tohatsu, Nissan, Mercury, or Evinrude that are all the same engine. I'll take the cheapest, please. |
I don't have any details on the engines. One might assume that the Tohatsu engines built for Evinrude may be the same as the Tohatsu engines built for Mercury and Nissan. If that were true, then the smaller outboard market would offer essentially four choices: Honda engines, Yamaha engines, Suzuki engines, and Tohatsu engines sold under various brands as Tohatsu, Nissan, Mercury, or Evinrude. |
I believe that Evinrude already sold a few four-cycle outboard engines when it was offering engines made for Evinrude by Suzuki about ten years ago. I don't recall if the four-cycle engines under the Evinrude brand had any special model designators. Since Evinrude apparently won't have any overlap in horsepower ratings, I suspect these new engines will just be called Evinrude engines. It will be very unlikely these engines will be referred to as E-TEC, as they apparently will not use any E-TEC technology. |
| L H G |
Since TMC is the Tohatsu/Mercury JOINT VENTURE, this means MERCURY will essentially be allowing their their JOINT VENTURE 4-stroke engines to be sold to EVINRUDE. Obviously, as half owner of this operation, this arrangement could not have been made without Mercury's approval. That should provide for some interesting Confidentiality Agreements. Oh boy. This is going to be fun. If they look like a Mercury, and walk like a Mercury, they probably are Mercurys! But it sounds like a winning proposition for all, and helps a North American company fill a badly needed HP void, and helps the Joint Venture utilize more manufacturing capacity. After all, this Venture can crank out 200,000 engines a year. I wonder why they didn't turn to their previous supplier, Suzuki? Maybe the Mercohats are better? Could it be possible that BRP did their own R & D, and designed and engineered a new small 4-stroke engine platform, and are simply having the Joint Venture manufacture and assemble them for them? That would be even better. |
The agreement with Tohatsu and Evinrude does seem to make for some strange bedfellows. To me it shows that Mercury has no real control of Tohatsu and the Komegane plant. Mercury is just another customer of Tohatsu, the same as Nissan and now Evinrude. |
We will have to wait until Spring of 2012 before we will likely see any of these Evinrude four-cycle engines in the 3.5 to 15-HP range. No other details have been announced. I think it is highly speculative to put forth details about the design of the engines. I doubt anyone knows, other than a few people at Evinrude and Tohatsu. |
The outboard engine business is a bit of a cozy manufacturing business. There are several interlocking relationships. One that comes to mind is the Mercury--Orbital--BRP affiliation. Recall that BRP sold its Delavan, Wisconsin electronics plant to Orbital. Orbital took over the operation and now makes the E-TEC direct fuel injector there (under license from BRP). Orbital also is the owner of the Orbital Combustion Process, which Mercury licenses for its OptiMax engines. There seems to be similar relationships with Showa, who makes hydraulic trim-tilt units for several outboard brands. Several different brands of outboard were all using the same Showa tilt units. I think there is too much price competition in the small horsepower market and not enough volume for BRP to be able to design and manufacture these engines domestically at this time. They're probably taking the sub-contracted manufacturing just to be able to give their dealers some product to sell in this horsepower range. |
Oh--I forgot to mention this other relationship: Tohatsu is a customer of Orbtial, too. Tohatsu also licenses the Orbital Combustion Process for their TLDI series of engines. As I said, this outboard engine manufacturing is a cozy business. I think that really only 250 people work in the business and they all move around a lot. (Just kidding.) |
| L H G |
Here is an interesting Mercury press release regarding possible interuptions in the supply of Mercury 2.5 - 30 HP 4-strokes as a result of the earthquake. http://www.brunswick-marine.com/en/News.aspx?id=8766 Note that Mercury indicated they were happy that none of their people were injured, and that Mercury is working to continue to source the necessary components needed for these engines. In another document, Mercury shows the TMC plant as one of Mercury's many manufacturing locations. I don't think OMC ever showed Suzuki as one of their manufacturing locations. My guess is that now the plant is back up and running, they have the capacity to produce the engines to sell to Evinrude. I also learned that the Joint Venture was formed in 1988, and the two companies have been working together ever since jointly producing outboards. Nissan is not part of this JV, and only buys engines from it, presumably like Evinrude will be doing. |
Evinrude will probably be getting the same engines from Tohatsu that Mercury does, except Tohatsu will leave out the unobtainium parts and some of the floobydust. |
| onlyawhaler |
I wonder how Evinrude will handle the two stoke issue which they have put so much emphasis on as being superior and then offer 4 stroke smaller motors. |
| Sourpuss1 |
I am pleasantly suprised by the restraint shown in the disscussion of the BRP and Mercury outsourcing! Very nice! I wonder if BRP will ever use the Johnson name again? |
| an86carrera |
Small Johnson does not have any good connotations. Especially with them being only 2 or even 4 stroke varieties. Len |
| Peter |
"I wonder how Evinrude will handle the two stoke issue which they have put so much emphasis on as being superior and then offer 4 stroke smaller motors." DFI 2-stroke still provides a superior power curve for the same displacement. The problem is there is no weight savings at the low HP level and a superior power curve isn't a strong selling point for a 2.5 HP to 15 HP outboard where you aren't pulling up water skiier's or pushing heavy high deadrise boats. Application of DFI to small 2-strokes would, however, seem to solve the hydraulic lock up problem that happens some times with portable 4-strokes.
| frontier |
Great move by Evinrude. Dealers will be very happy. High quality, small engines. Matching kickers are a big seller and look great on a boat. |
| adlert |
Thanks for that Len. You are a hoot! |
| contender |
Why can't Evirude just build their own small engines? |
| Peter |
It boils down simply to a make or buy decision. Do I invest in a plant to manufacture small motors that have a low profit margin or do I simply buy from another who has already made that investment and which will help them get better economies of scale and profitability on that investment? Apparently their analysis is that buy makes more economic sense than make for 3.5 to 15 HP. This probably means the end of the 35 cubic inch 15 HO which is a detuned 25. That one never made any sense to me. Tohatsu and Evinrude are similar now in the low HP range they offer 4-strokes and in the higher HP ranges (25 and up for Evinrude and 40 and up for Tohatsu), they go 2-stroke DFI. Given that Evinrude had a gap in its line up below 25 HP (I don't count the 15 HO) which Tohatsu fills in and Tohatsu has a gap above 140 HP, I wonder whether we will see a Tohatsu rebranding of Evinrude E-TECs above 115 HP for sale in Asia? |
| Binkster |
Its unfortunate that in this country we can't build a superior outboard in the full range, that foreign manufacturers would want to form a joint venture with us and buy our outboards and put their names on them. How many joint ventures have there been, incluing GM/Toyota, Mazda/Ford Mitsubishi/Chrysler, I can't remember them all, but they all involve putting our name on foreign products and selling them as our own. Thing is these foreign products are better than ours. |
| leadsled |
Peter,Tohatsu has a gap above 115 hp. They don't make the 140 anymore after they started making injected two strokes. And you should see just how big that 115 is,I mean wide. It has to be as big around as many 200's. My kicker motor easily fits next to my 90 Tohatsu on the transom of my 1977 outrage. There's no way that 115 would work for me. |
ASIDE: Re Japan-USA joint manufacturing There is a Ford-Mazda joint-venture plant in Flatrock, Michigan. It builds the MAZDA 6. The Ford version of that frame or chassis is built in Mexico as the FUSION. Figure out those arrangements. |
| Tohsgib |
Shocking since Suzuki and OMC and even BRP were in bed together for over a decade. Then again it may be why BRP ditched Johnson because of a fallout with Suzuki. Then again it could be that since BRP ditched Johnson/Suzuki, Suzuki said no to making them small engines now? Who knows, who cares? Cool thing is that you will now be able to go to just about ANY dealer and buy parts for your 3-15hp outboard...even Theft Marine. I wonder if you will be able to get these in blue, white, or both? If your kicker is gonna match, it HAS to match. I'm going with White as most offshore guys use kickers, then again you walleye guys do so as well. |
| Peter |
You are right, the gap starts above 115 HP. |
| andygere |
I imagine that Evinrude dealers have been screaming for a line of low hp (often called portable) outboards since the Suzuki OEM deal ended. I have also been told by more than one Evinrude dealer that BRP has been working on bringing the E-TEC down to the 9.9 h.p. platform, but compliance with emissions requirements has been a challenge. I wonder if BRP is abandoning it's efforts to bring a small E-TEC line to fruition, or if the Tohatsu deal is simply buying them some time. It may well be that the low h.p. segment of the market doesn't have enough profit in it to make pursuing the technology a worthwhile endeavor. |
| fourdfish |
Andy--I am thinking they are buying some time until they can produce the small E-TECs. Obviously they have not been able to get them right yet. |
| L H G |
I would say Evinrude quite effectively burned their bridges with Yamaha because of all those anti 4-stroke ads aganinst Yamaha. So they were out. Suzuki was a major OMC creditor, and maybe BRP didn't take care of them financially (and probably didn't have to legally), so they had enough. That only left Honda or the Mercury/Tohatsu Joint Venture. I don't think a company like Honda would ever give an American company their outboards to brand, so who's left? If Tohatsu sells to Nissan in Japan, maybe Mercury could sell to Evinrude over here? After all, the majority of the engine output of the JV that comes over here, are painted black. I doubt if Tohatsu USA sells many compared to what Mercury sells. I agree, that kickers are a big sales item in any of the fishing market segments, fresh or salt. It's good that Evinrude dealers can now sell a matching kicker. The 9.9HP Mercury Pro-Kicker with power trim is a big seller, so now Evinrude will have it also. Probably both in blue for the bass/walleye crowd, and white for the saltwater crowd. They must have quite a painting operation over there! I see that both Tohatsu and Nissan engines are painted black also, but not the same as the high gloss Mercury Phantom black. |
| andygere |
Larry, I think you are on to something. I'm going to just paint my old 2-smoke Mercury kicker white, put on some new decals, and as long as I don't start it up, it will look like a new Evinrude kicker : ) Sadly, as well as that old motor runs, I really hate all the smoke when I'm trolling slowly and the wind is behind me. The little bugger is louder at trolling speeds than the big 200 too. |
I have already presented all the real information I have about the Evinrude-Tohatsu deal, but let me speculate a bit. The current Evinrude E-TEC line uses the same direct injector in all the engines. This injector can deliver enough fuel to make 50-HP from one cylinder, as in the 300-HP V6 E-TEC. If Evinrude tries to make a 5-HP engine, it seems like they might have to develop a smaller direct injector. It does not seem reasonable to use an injector that can make 50-HP in one cylinder to be the injector in a 5-HP engine. That injector is too big. Having the right direct injector to bring E-TEC to smaller engines may be what's missing. I don't have any real information about future plans for making lower horsepower E-TEC engines, but I speculate that BRP is probably continuing to pursue that goal. The Tohastsu-BRP deal may just be a temporary fill-in, much in the same way Mercury filled in a gap in their product line when they bought thousands of 225-HP four-cycle engines from Yamaha when their VERADO project did come to market on time. As for Honda, they do sell a lot of engines to other manufacturers for incorporation in non-Honda products. But I do not recall any product where Honda has provided a completely assembled turn-key product to a competitor to re-brand as his own. |
| fourdfish |
I don't really know how Larry thinks Evinrude cares a crap about burning any bridges about 4 stroke engines? Currently it is only selling direct injected E-TEC's from the top on down to 25hp. How he thinks this will change is a mystery. To think that BRP will stop it's R&D program is foolish. They have worked the R&D down to 25hp with success and is not about to stop now. |
| goldstem |
I too had hoped for smaller E-TEC engines, I think it is more than just the injector. A lot of electrical power is still needed and the CPU. That's a bit of overhead for a really small engine, and of course not all necessary for a [small] four-cycle engine. |
| Peter |
DFI can be brought down to the 50-CC single cylinder, 2- to 4-HP size. Aprilia (part of Piaggio) makes and sells a 50-CC DFI 2-stroke scooter. It appears to use an Orbital style air assist system. I don't think the electrical load would be the hold back. Why would the electrical overhead be any worse than the mechanical valve train overhead of a 4-stroke or the air compressor in the Aprilia system? I think this move is driven primarily by economic, not technical, constraints. I think that at some point, as Jim has mentioned, getting into the smaller sizes probably requires development and tooling of a smaller injector. It's likely that this injector would not be manufactured in the same volumes as the larger common injector that serves 2 to 6 cylinder engines from 25 to 300 HP given that the 3.5 to 15 HP motors are either 1 or 2 cylinder engines. Unless you can find other uses for small 2-stroke engines, such as on leaf blowers, scooters, lawn mowers (like OMC did) the volumes for outboard motor power heads is quite small making the investment quite large, relatively speaking. |
| jharrell |
I would think small light DFI two-stroke engines would have quite a market if the cost where reasonable. When getting down to yard tool engine size, the power to weight of a carburetor two-stroke is such an advantage the it will likely be the last bastion of that type of engine, even with the huge relative pollutant output and wasting of fuel. It would be interesting to know the true reason why the E-TEC technology has not been miniaturized, first to smaller outboards then on to mowers, chainsaw and weed-wackers. The four-stroke outboard makers got off easy here because a simple carburetor four-stroke can still attain a 3-Star emission rating which would be impossible for a two-stroke without DFI. This must be a hard pill to swallow for BRP since their marketing material tends to revolve around the superiority of a two-stroke, they held out for some time with no kicker and no portable offering. Perhaps this is just a temporary arrangement until they can perfect a smaller system. |
| onlyawhaler |
I am going to take a big guess here and say its all about cost. Last boat show in Dec showed our single Evinrude dealer from northern Utah in the show and when I stopped by he had the cowling off a 225 E-tec and surrounding plastic shields off revealing what I had not seen before on E-Tecs. It looked complicated. Really complicated. The main ICU was huge, on top of the motor and was plumbed for water to go through it. Alot of wires, sensors and the main injectors were explosed. It look downright intimidating when compared to my last 1993 Evinrude 225 vindicator. Simple then, very complex now. Hats off to Evinrude to pulling this all off, but I think when a portable low hp kicker is involved and the competitive price point market that exists, it seems that simple carb 4 stroke that can still hit a 3 star rating without all this cost and complexity seems to be the answer for why Evinrude is doing it. Four stroke, 3 star kickers look simple now. It's not like Evinrude can't build a 4 stroke either, They have great ones in the BRP lineup with everything else. Just probably not worth tooling up for this and alot easier to pick up the phone and order these in unfortnately. Onlyawhaler |
| TohatsuGuru |
Can anyone tell me why the one guy keeps mentioning TMC(the joint venture real-estate company)as if it makes outboards? I would swear I previously put that fable to rest. As a courtesy, Tohatsu informed Mercury (Tohatsu's largest customer), that Tohatsu was adding BRP as another customer...Just like Mercury is a C U S T O M E R of Tohatsu. Mercury does not make outboards in Japan. Mercury's joint company with Tohatsu (TMC) does not make outboards at all. Tohatsu makes outboards to whatever spec Mercury wants...It will do the same with BRP.
| L H G |
Guru - You have not the slightest clue what you are talking about. Zero. |
| TohatsuGuru |
Actually I do know what I am talking about. You, on the other hand, simply say crap...Over and over and over and over again. I get my info directly from the top two people in Tohatsu's organization. You get yours from your own imagination and seem to enjoy misleading people. [Ad hominen comments deleted--jimh] I'm done with your drivel. |
| dscew |
Wow, for a newbie you sure stick it out there, don't you? Your name isn't Greg, is it? |
| TohatsuGuru |
A) Not a newbie...I only post on things I am an expert on. B) Not a Greg...My name is Elvin D'Angelo. C) I don't suffer fools...That irritates the fools! |
| Tom W Clark |
[Rebuttal to ad hominen comments deleted--jimh] |
| fourdfish |
It looks like Larry finally said some crap that was completely refuted by someone who really knows. It had to happen sooner or later. Hoof in mouth Larry! |
As I already pointed out, the fact that Tohatsu is going to build engines at Komagane and sell them directly to Mercury's competitor Evinrude shows that Mercury has nothing to say about what goes on at Komegane. They're just another customer of Tohatsu. |
| fourdfish |
OK, So I did a little quick research and it looks like Larry is COMPLETELY wrong about the Tohatsu company. Mercury is just a customer of Tohatsu. Of course that makes real sense and I wonder why no one here picked up on that earlier.Thanks Mr D'Angelo--I guess many here just take Larry's word for gospel. |
| L H G |
No, Guru, you really don't have a clue, and have no idea what you are talking about. Your sources are a fraud, if you even have any for your fiction. Try doing some reading and learn a little about the concept of a Joint Venture. If Jim and Bill want to defend this unknown poster, be my guest. It's your reputation, not mine. |
| Peter |
Joint venture is a very loose term.
quote:legal-dictionary.thefreedictionary.com/Corporate+joint+venture Given that the Tohatsu, Nissan and Mercury 4-strokes are virtually identical, and it is likely that Evinrude products will be identical, it would appear that in the Mercury-Tohatsu joint venture, Tohatsu brings its expertise in making small 4-stroke outboards and Mercury brings its expertise in the application of black paint and Mercury decals.
| cbone |
It does make sense for TMC to sell engine to Evinrude. |
| Owtrayj25 |
Here we go again. Now all of the sudden the term "Joint Venture" has become ambiguous. I think if those who think they know so much about the TMC joint venture should speak up and disclose all of the financial arrangements between Mercury and Tohatsu, as this will most certainly end this uninformed speculation. Please...inform us...all. I think the fact that both Mercury and Tohatsu BOTH refer to their relationship as a joint venture is enough for most reasonable thinkers to conclude its a....joint venture. Now, should we discuss the meaning of the word "is" and what it "is"....sheesh |
We have discussed this in the past. Let's look at what the real participants say. Mercury--who is subject to criminal prosecution if they issue fraudulent information to investors--simply says that some of their engines are manufactured in Japan by Tohatsu in an arrangement they call a joint venture. I think that is about as far as Mercury is willing to go on this topic. However, Mercury fans are willing to go much further. They have invented the notion of 50:50 in the venture. They have invented the notion that Mercury owns the plant in Komagane or at least has some major role in its operation. Tohatsu never mentions Mercury in their presentations. They say they make their outboards at their plant and sell them all around the world. I have published several photographs of the Komagane plant. The signs on the plant all say TOHATSU. There is no indication of any presence of Mercury. I even published shipping documentation that showed engines manufactured in Komagane were being shipped to a customer in Wisconsin--Mercury. Participants who have said they are familiar with the plant say that at best there are perhaps one or two people from Mercury who work there in a liaison capacity. When an award was given for innovation in four-cycle outboard engine design for the engines manufactured in Komagane, the award was given to Tohatsu. Based on these observations, I am more inclined to accept TohatsuGuru's representation of the situation regarding Mercury and Tohatsu than LHG's. |
| cbone |
Common sense shows that they are building the engines together. Japan is not China and it is expensive to manufacture in Japan. The economies of scale allow them to overcome the cost together without it being a true joint venture it would not make sense. Mercury could instead go to Sail or Oxyn engines built in China for 1/4 of the cost. TMC selling to Evinrude makes perfect sense as it allows them to make more money off of the sale of an Evinrude then Evinrude themselves. Everything is already in place all that is needed is a blue paint gun and different stickers. For Evinrude it makes sense because currently they make nothing and have nothing in that range. If they $100 off the sale of a TMC then its $100 more then they would have and it keeps their customers blue. |
I would be interested to hear an explanation why Mercury should be pleased that their competitor Evinrude may be selling the same engines as Mercury sells--both built by Tohatsu--into the same market. |
| cbone |
Its not the same engine. There are differences and TMC (a joint venture) will make more off the engine then Evinrude. Every engine that Evinrude sells means profit for Mercury. |
OK--that explanation makes some assumptions about the price point at which the Tohatsu engines is being sold to the two re-sellers, and that one of the re-sellers gets to share in the OEM profit. Neither of those assumptions are particularly supported by anything more than speculation. I agree, under the speculated conditions, Mercury could profit from sales of Tohatsu engines to Evinrude. However, the assumption has failed to mention the consideration of lost sales of Mercury-painted engines. If BRP sells a Tohatsu engine as an Evinrude, it could mean a loss in sales to Mercury of an identical engine. Any speculative possibility for Mercury to profit on the OEM sale to Evinrude is offset by the loss of income from the lost retail sail to a dealer-customer. Also, the notion that there is great profit to be made as an OEM instead of as a retailer would undermine the entire business model of Mercury. If OEM sales were profitable, then Mercury should be dropping all of its retail sales and concentrate on being an OEM. Of course, they don't, and, in fact, they do just the opposite. They have a history of buying engines from other original equipment manufacturers and then re-selling them at retail as their own. This history shows that there is considerable profit in being the branded-seller, the retail seller. As long as everyone wants to speculate, I would offer this assessment. Tohatsu probably has excess manufacturing capacity at Komegane at the moment as a result of two events: the general global economic downturn which will affect outboard engine sales, and the especially difficult economic conditions locally in Japan due to the tsunami earlier this year. Tohatsu may have seen that in the near future the plant would be operating at lower production than it is capable. Based on these factors, Tohatsu may have been in a position to take on OEM business for another customer, BRP. We already have documented proof in the evidence gathered in the United States International Trade Commission investigation into import of outboard engines from Japan at less than fair market value that Japanese manufacturers were willing to export their excess manufacturing capacity to the USA and sell below fair market value just to keep their plants operating. This is another sound basis for my speculation that Tohatsu is doing just that in their arrangement with BRP. |
| cbone |
Tohatsu is not in control of the 2.5 thru 30hp engines sales. That is TMC. There is a specific difference between TMC and Tohatsu. Our views are different as we view differences in where the profits go. Mercury currently controls the life of an OB from birth to sale in all aspects. The only reason that went to other OEMs was to fill a gap in there line up. "If BRP sells a Tohatsu engine as an Evinrude, it could mean a loss in sales to Mercury of an identical engine."
| cbone |
Correction If BRP sells a [TMC] engine as an Evinrude, it could mean a loss in sales to Mercury of an [similar] engine. |
| Owtrayj25 |
jimh writes:
quote: This is a completely made up notion. No one has suggested the TMC joint venture with Mercury was or is 50:50, or that Mercury owns the Komagane plant. Since Tohatsu clearly seems to characterize the relationship with Mercury as a joint venture, I don't see why the E-Crowd wants to dispel this notion so vehemently. And further:
quote: really????their entire business model??? It seems to me that Mercury has figured out that is is more profitable to have a mix of OEM sales and re-branded retail sales, just as many successful companies often to...Not surprisingly, BRP is just figuring this out. Perhaps there will be an announcement soon for a Tohatsu/BRP joint venture. Then we can argue more about the meaning of a joint venture. |
Sorry to have to correct you, but the 50:50 notion has been a popular theme for the Mercury-Tohatsu arrangement. I guess you mean to say that it is not a 50:50 arrangement--is that fair to say? |
Re "the entire business model"--by having a brand, "Mercury", Mercury Marine has created a branded outboard engine. If Mercury Marine were to concentrate on being an OEM outboard engine builder, it would not have a brand like Mercury. It would just be an OEM, and its customers would have the branded products. Mercury Marine emphasizes its branding, not its manufacturing, as we have seen in its historical business of buying engines--sometimes complete engines and sometimes just assembled power heads--from other manufacturers and branding them as Mercury for retail sale. That is the basis for my description of Mercury as not having a business model of being just an OEM. Let's take Tohatsu out of the picture for moment. According to one view presented here, we would now expect Mercury to be glad to build engines in Fond du Lac, Wisconsin as an OEM, and paint them white, put on Evinrude decals, and deliver them to Sturtevant, Wisconsin to be sold by BRP. Would everyone who thinks Mercury would do that please raise your hands. |
| TohatsuGuru |
Can some of you just not read? Mercury keeps referring to the TMC joint facility...It's the freaking building people...That's what a facility is. No one can be that mind blind to that fact. Tohatsu leases the building from TMC. BRP makes no mention of TMC in it's press release because TMC is not involved. BRP is buying engines from Tohatsu...Just like Mercury does. Mercury's investment in TMC was less than $1,000,000.00 back in the late 90's when they started TMC. Mercury had been buying some model engines from Tohatsu as far back as the early 90's and other than some minor involvement in paint and the injection system on the 25/30 frame, Mercury's input into Tohatsu's engines is inconsequential. Any doubter's can simply email Tohatsu and ask what "joint venture means" in this case.Here's the head of Tohatsu's email address. wakabayashi@tohcorp.com As a courtesy to him I would suggest that one in the "TMC is God crowd" appoint one person to send the email so the guy does not have to repeat himself... |
| cbone |
I raise my hand. For the right price, I would think that Mercury would be happy to sell engines to anyone. The same way that Yamaha sold engines to its largest rival Mercury. My point is backed up with years of history TMC selling to Nissan and now Evinrude Is it better business to manufacture the vast majority (75%-80%) of the engines sold in the 3.5hp to 30hp range or to manufacture and sell under your own name 25% of the engines sold in the 3.5hp to 30hp range. We will never know because I am sure the margins on these engines is kept very secretive as is the percentage of the market but I am sure that it better to be the manufacturer as history has proven time and time again. The sale of replacement parts after the sale is also something to take into consideration. |
| K Albus |
All of the so-called information provided in this thread concerning the joint venture between Brunswick and Tohatsu is pure speculation. I doubt that anybody here has seen the actual joint venture agreement. That goes for both sides - Larry on the one side, and Jim H and TohatsuGuru on the other side. Nobody has provided any verifiable factual information regarding the terms of the joint venture. Jim - you should be more careful in your posts to distinguish between Tohatsu Corporation and Tohatsu Marine Corporation. These are two separate entities, the latter being the joint venture with Brunswick. It should also be noted that BRP's press release indicates that it's small motors will be manufactured by Tohatsu Corporation, not Tohatsu Marine Corporation. See: http://corp.brp.com/en-ca/company/news/ brp-provide-lower-hp-evinrude-outboard-engines-tohatsu . This would seem to indicate that Brunswick will not profit from the sale of small motors by BRP.
| cbone |
"Mercury's investment in TMC was less than $1,000,000.00 back in the late 90's when they started TMC. Mercury had been buying some model engines from Tohatsu as far back as the early 90's"
| L H G |
Both Mercury and Tohatsu have indicated, in their corporate reports, that this Joint Venture, for the purpose of designing and building outboard engines, was formed way back in 1988, and not simply when their new plant was built. So this "thing" has been around for a long time. Most of the engines manufactured by this JV that are shipped to the US are sold as Mercurys, and now maybe some as Evinrudes, not Tohatsus. I'm sure that most sold in Asia, are sold as Tohatsus and Nissans. It seems that both partners now have an affiliate brand of the same nationality. These are popular engines. I see of lot of these Mercurys. I'm just the messenger here. You guys feel free to attack me and call me stupid anyway you like, and interpret the information anyway you like. It's your choice of how you want to think of these Joint Venture engines. Incidentally, Mercury's corporate literature shows this plant as ONE OF THEIR MANUFACTURING LOCATIONS. Guru's claim that this is only a real estate deal is ridiculous. Since 1988? Just a troll. As I said, he has no clue, and obviously, no business knowledge. I have noticed that Tohatsu now builds their TLDI's in this plant also, but unlike the small 4-strokes, they are specifically NOT joint venture engines - just Tohatsu. But is it a coincidence that both companies just happen to use the Orbital 2-stroke DFI system? Who knows? With no kickers to sell, Evinrude desperately needed this deal. Afterall, the biggest market for 150 DFI's and larger, is the Bass/Walleye go fast fishing segment. For Evinrude to really compete with the Merc Opti ProXS on this type of boat, they need a same color 4-stroke kicker. Merc's 9.9 Pro Kicker is a big seller alongside the black Opti's. So now the Evinrude fans can get a white or blue Pro Kicker, to go with the E-Tec HO's, from their selling dealer. No longer a need to put a black or gray (horrors) kicker on their rig. It's winner for both Mercury (because everyone will know it's a white or blue Mercury anyway) and a winner for future Evinrude E-Tec sales. |
| dscew |
I still think his name is Greg (Olsen). |
| L H G |
Just saw Guru's lastest post. Jim can continue to believe this troll, but Guru just gave it away that he knows nothing about this JV, telling us, as he is, that the JV was formed in the late 90's. A dead giveaway. Pure fiction. As has been stated, neither Mercury or Tohatsu say much about the legal aspects of this engine manufacturing operation, other than what they have published in press releases, above, etc. So for this guy to claim he has inside information is a joke. Now if you want to believe Gura, and consider Mercury publishing false information, be my guest. I have not seem any claim by Tohatsu that Mercury is misrepresenting this 23 year old deal in saying it is one of their manufacturing operations. Guru has no clue, as I said. The "Capt" seems to agree, and probably knows more about this than anybody here. As I said, I knew this was going to be fun. |
| cbone |
I don't know anything more then anyone else here. I am just a guy that loves boating and reads the internet. It all comes from common sense and public documents. Here is the perfect example. Please read chapter 5 pages 38-41. http://www.tohatsu.com/news/Tohatsu75Years.pdf
The facts are that TMC is a joint venture company between Mercury and Tohatsu. The 3.5hp to 30hp engines are built by that joint venture company. Evinrude is buying small engines from TMC. |
| cbone |
I don't believe that a reasonable person can come to the conclusion that Mercury Marine (an engine builder) simply has just a partnership in the structure where TMC engines are made. It does not make sense that an engine builder would go through the trouble to set up a joint venture simply to own part of building. It must be more then simply jointly own the building. Also what was the joint venture prior to the construction of that new TMC building? Common sense shows the joint venture is more then just them owning a building together. |
| prj |
Can we get a citation or link where Mercury claims the Komagane facility, or TMC facility, is one of their manufacturing locations? According to the E-CROWD's assertions (Note all caps in the proper spelling, Owtrayj) regarding the Mercury-Tohatsu arrangement, Evinrude could now claim Komagane as one of their manufacturing facilities as well. Lets keep an eye out for an announcement about this manufacturing base expansion. Additionally, this news of offshore outsourcing by Evinrude will enable the marginally relevant insertion of "foreign built motor" implying inferiority or hoping to spark jingoistic aversion to these products at every chance available and some self-manufactured. You know, like the remarks about Mercury's low HP offerings. |
| fourdfish |
A lot of companys around the world make products for other companies. Kawasaki makes engines for several American Companys. Kawasaki makes them to spec! (joint venture) That is it! Mercury pays for it. (building or whatever) PERIOD! Japan does not allow thier land to be owned by ANYONE except Japanese people. (A law) I spent 2 years there! Larry and others who think otherwise are fools. Guru buys directly from Tohatsu and knows more than Larry or the Capt about them. (Do a search) Larry knows SCAT about them! After all the crap he says here without any proof what-so-ever, people still believe his BS. He loves to say crap so as to provoke a response. This all he has left in his life. (See his comment about all the fun his comments cause) Tired of this crap! Have better things to do! |
I'll volunteer to contact the gentleman via email. Thanks for the lead. |
| K Albus |
Dennis - TohatsuGuru is not Greg Olsen. TohatsuGuru is a Tohatsu motor retailer. His website is: http://www.internetoutboards.com/ . In his post he gives his name as Elvin D'Angelo. He has posted in the past on the topic of the Brunswick joint venture with Tohatsu. His posts, like most of the others here, are not supported by any readily verifiable facts. They consist primarily of hearsay and other second-hand reports. Since everybody is speculating about the Brunswick joint venture with Tohatsu, I'll take a stab at it as well. If I had to guess, I would guess that the manufacturing equipment in the Komagane plant is owned by Tohatsu Corporation (or one of its subsidiaries). Brunswick and Tohatsu Corporation (which I will refer to as "Tohatsu") formed a joint venture which is known as Tohatsu Marine Corporation (I'll refer to the joint venture as "TMC"). I would guess that Tohatsu either manufacturers motors which are then sold to TMC, or that TMC leases or uses the Tohatsu manufacturing equipment on a part-time basis to manufacture its own motors (the TMC motors). I would further speculate that when the equipment is not being used to manufacture the TMC motors, it is used to produce the same motors for companies other than TMC. Under this scenario, there would likely be as many as three separate agreements covering the TMC motors which are eventually sold as Mercury motors: 1) Brunswick has a joint venture agreement with Tohatsu for the creation of TMC; 2) TMC has an agreement with Tohatsu whereby Tohatsu either manufactures the TMC motors for TMC or Tohatsu allows TMC to use the Tohatsu equipment to manufacture the TMC motors; and 3) TMC has an agreement with Mercury Marine to sell the TMC motors in the U.S. and elsewhere as Mercury Motors. I highly doubt that sole purpose of the Brunswick joint venture with Tohatsu Corporation is for the purpose of owning the Komagane land and/or building. |
| K Albus |
Patrick - here's a link to a Mercury Marine webpage which lists Komagane as one of Mercury's manufacturing locations: http://www.mercurymarine.com/about/plant-and-locations/ |
| Tom W Clark |
I do not understand the mystery and confusion here. Mercury and Tohatsu have a Joint Venture. Tohatsu makes motors for Mercury, Mercury sells them. It is not a difficult concept to understand. The Joint Venture (TMC) was established in 1988. From previously cited Tohatsu Corporate History: "In February 1988, Tohatsu established a joint venture company, “Tohatsu Marine Corporation”, with Brunswick. Matsumoto became the first president of that company. With Nissho Iwai and Itochu, two of the Japan’s biggest trading companies, Tohatsu had introduced its outboards to U.S., the biggest market for outboard motors. Brunswick, the parent company of Mercury Marine, was seeking a Japanese partner who could supply products with advanced technology and productivity. After fierce competition, Mercury Marine showed a great interest in Tohatsu. Mercury Marine hoped to have a capital participation in Tohatsu in early discussion, but at last it was decided that a joint venture company would be established. This new company was located in Okaya, Nagano, a mountainous area of Japan. At the same time, Tohatsu started to reconstruct the facilities of Okaya Plant, and the first stage of the construction; a new full - scale assembly line for Outboard motors up to 120-horsepower, was completed in November 1988. Tohatsu’s outboard business has thrived and established a strong position, especially overseas, by collaborating with these great partners." Along with Mercury and Nissan, BRP will now sell motors made for them by Tohatsu. |
| K Albus |
The big mystery here seems to be whether Mercury Marine (or Brunswick) plays any role in the manufacture of the TMC motors. The E-CROWD says "no". The Mercury crowd says "yes". Neither side has any hard evidence to support its claim. The quoted material from the Tohatsu history does not state that the motors are manufactured for Mercury by Tohatsu. It merely states that a joint venture was formed. Brunswick's 2010 Annual Report indicates that "Mercury Marine . . . produces smaller outboard engines in Japan pursuant to a joint venture with its partner, Tohatsu Corporation." See page 5 at this link: http://www.annualreports.com/HostedData/AnnualReports/PDFArchive/bc2010. pdf . This language seems to indicate that Mercury is involved in the manufacture of the motors. |
| Tom W Clark |
What role could Mercury play in the manufacture of the TMC motors? |
| Peter |
What role could Mercury play in the manufacture of the TMC motors? Provide black paint and Mercury decals. ;) This is what Brunswick's 10K has to say about the risk relating to its JV's --
quote: |
| K Albus |
quote: Tom, that's the big mystery here. From a practical standpoint it doesn't make a lick of difference to anybody. But the participants here like to argue about this kind of stuff. I guess it's one more piece of information that needs to be considered in the final determination of whether Mercury is better than Evirude or Evinrude is better than Mercury. |
I don't see any notion that there is contest to determine who is better, Brunswick or BRP. The effort here is mainly to separate the fantasy from reality. I take Mercury at their word, which is some of the engines they sell are built in Komagane for them by Tohatsu in a joint-venture. For some reason, this seems like a very bitter pill for the Mercury crowd to swallow, and they seem intent on making something more out of the arrangement. Soon they'll have Mercury making engines for Tohatsu, given a bit of encouragement. |
| K Albus |
Jim, nice try with this one:
quote: Mercury never said that some of the engines they sell are built for them by Tohatsu. Mercury has only said that some of the engines they are sell are manufactured in Komagane by the joint venture. |
| Owtrayj25 |
quote: Please, point to where the suggestion has been made the arrangement was represented to be 50:50. This is your made-up assumption. I believe there is a joint venture arrangement. I do not speculate on what the ownership percentages are, I don't know. Neither do you, or anyone else contributing to this thread. Capiche? |
| prj |
Actually, in Peter's selected quote from above, we can infer that the arrangement may be 50/50, or at least take the quote at its face value and call it "equal": These joint ventures are intended to be operated for the equal benefit of all co-owners, rather than for the Company’s exclusive benefit. That note in addition to the sentence above it seem to suggest that the JV is a bit more than an agreement allowing Mercury to purchase Tohatsu engines, as the E-CROWD repeatedly asserts. With respect to these joint ventures, the Company shares ownership and management of these companies with one or more parties. The alternate view, that Mercury simply purchases Tohatsus as a customer, would have Mercury also claiming Yamaha's manufacturing facility that produced the early 4 strokes, as one of their own, correct? Let me just go out on a limb and suggest this wasn't the case during that era. |
| L H G |
I agree with Kevin, and it appears Jim is in denial and refuses to believe what he reads, attempted manipulations and all! Tom - Mercury's role is that they are probably 1/2 owner of the manufacturing operation and facilities going all the way back to 1988. But you don't know the percentage and I don't know. But Joint Ventures are USUALLY 50/50 deals (at least the automotive ones between American and Japanese manufacturers that I have been involved with are). I am sure percentage of interests can change, however. Since Mercury sells a large percentage of these engines, it could be that Mercury now owns more than 50% of the TMC Joint Venture. But anyway you want to look at it, Mercury and Tohatsu both claim to be in the business of manufacturing small 4-stroke outboards. Tohatsu has never said they sell engines to Mercury, and Mercury has never said they sell engines to Tohatsu. That's because they make them together as Joint Venture partners. I think the Evinrude guys have beat this horse long enough. This thread has become great free advertizing for Mercury's and Tohatsu's small 4-stroke products. The two companies seem to work together very well, with a long standing relationship. |
| fourdfish |
Why would any American person or company be proud that a Japanese company is making a product for them? Joint Venture is a way of making it sound better. |
| Peter |
"...we can infer that the arrangement may be 50/50..." Maybe, and maybe not. Your inference makes an assumption that there are only two co-owners. If there are more than two co-owners than "equal" would not necessarily mean 50/50. |
| Tom W Clark |
quote: No, Larry, I see no evidence of that though there is evidence that neither Brunswick nor Mercury has any equity in the Komagane plant: "Mercury Marine hoped to have a capital participation in Tohatsu in early discussion, but at last it was decided that a joint venture company would be established." You guys are confusing a business entity (Joint Venture) with a factory. |
| Owtrayj25 |
prj makes a good point. We heard nothing of a joint venture when Mercury was buying 4-stroke blocks from Yamaha. Because there was no joint venture then...it was a relationship of buyer and seller, similar to what BRP has arranged with Tohatsu. As for "Why would any American person or company be proud that a Japanese company is making a product for them?" you should ask the hierarchy at BRP. Apparently Tohatsu is making low HP engines for them now. I assume Evinrude will be proud of their entire product line, including these low HP engines. |
| K Albus |
Tom - your quoted sentence only indicates that Tohatsu Corporation chose to enter into a joint venture with Brunswick rather than allowing Brunswick to purchase an equity stake in Tohatsu Corporation. It says nothing about ownership of the Komagane plant. |
| L H G |
No, Tom - Joint Ventures often and usually own the manufacturing facility they have built as well. Some time ago, we did the insurance for a new automobile assembly plant in Normal, Illinois owned equally by a Joint Venture formed by Chrysler and Mitsubishi. Almost identical (but not quite) cars for both brands were then manufactured there. Regarding these outboards, I believe there are very slight differences in the engines configured for Tohatsu vs those for Mercury. The Mercury engine output is considered the premium, slightly higher priced brand, incidentally. The Mercs may have some additional features on some versions. Even the Tohatsus are now painted black, but not the same as the glossy Mercury Phantom Black. I'm not going to take the time to dig it out now, but I remember reading in one of Brunswick's financial reports that THEIR new Joint Venture manufacturing plant in Japan was almost ready to begin operations and production of the 4-stroke engines. |
| fourdfish |
I'll say it again for those who did not comprehend. Japanese laws forbid foreign ownership of land in the country. Mercury may have paid Tohatsu to build the plant but they cannot own it. I'm also sure you won't find Americans in the plant working for any length of time since Japanese law states they must leave the country at least every six months. Except for Military personnel! That leaves only one thing. Tohatsu workers building engines that will be painted black and called Mercs. The only good thing is that the quality control will be better than if the Chinese made them. You can call it a pig or whatever you want. Joint Venture--What a joke! I am dissapointed that BRP is also having them build engines for them. At least John Deere offers both Kawasaki AND Kohler engines. At least BRP is not an American company. |
| K Albus |
fourdfish - Does Japanese law prohibit a Japanese company from owning land in Japan? Do you know whether or not Tohatsu Marine Company (the Mercury joint venture) is a Japanese company? Are you certain that the Mercury motors are being built by Tohatsu Corporation employees, and not by the employees of Tohatsu Marine Company? Has anybody ever claimed that American workers were assembling the Mercury joint venture motors? Are you certain that no Americans work at the TMC plant in any capacity, even if they are not stationed there 365 days per year? There are many ways that Mercury could have contributed to the joint venture besides owning the land or the factory or sending American workers to Japan to manage the factory or assemble the motors. Mercury could have contributed cash to assist the joint venture in the purchase of land, the factory, and/or the machinery. Mercury could have provided engineering and/or manufacturing expertise. Mercury could have provided assistance in distribution of the motors worldwide. Mercury could have provided guarantees of minimum purchases which helped to make the joint venture an economically viable entity. Without seeing the joint venture agreement, however, none of us will likely ever know what Mercury contributed to the joint venture. |
| fourdfish |
Just like Larry. Spin it as you may! I don't really care! |
I am not in denial. I am completely openminded. So far all I can find from Mercury is a footnote in a corporate report than says their engines are manufactured at a plant in Komagane as part of some sort of deal with Tohatsu. There is no clear explanation anywhere of the arrangement. As I said earlier, the notion of 50-50 was introduced, as I recall, by L H G, and based, as far as I can tell, on his own speculation. I have never seen any statement from either Tohatsu or Mercury that gives any support to a 50-50 arrangement concerning the ownership, operation, or management of Komagane. Here is some recent statement by a Tohatsu representative about the history of Tohatsu. Look closely to see any mention of how Tohatsu is partnered with Mercury , or that Mercury is a joint operator of their plant--there is none: Who is Tohatsu? Who is Tohatsu? Tohatsu recently published this description of their company. quote: Source: Trade-Only Magazine, recent 2011 issue. |
I earlier speculated--and will repeat here--that my guess is that Mercury learned a bitter lesson in its partnership with Yamaha. Toward the end of their partnership with Yamaha--and the partnership was with Yamaha as supplier and Mercury as customer--Mercury found themselves in a very difficult situation. They were completely reliant on Yamaha to sell them engines for re-branding as Mercury, and Yamaha was backing out of the deal, refusing to sell. Mercury had to take Yamaha to court and sue them to fulfill the contract obligations. I think this taught Mercury a lesson with regard to supplier arrangements, so when they decided to become a customer of Tohatsu for their smaller four-cycle engines, Mercury took the lesson they learned with Yamaha and applied it. Mercury and Tohatsu entered into some sort of partnership so that Tohatsu could not just jettison Mercury overboard like Yamaha had done. I also think Mercury suffered badly in public opinion when they were widely seen as being nothing more than a re-painter of Yamaha engines, so they set out to get some better play on their relationship with Tohatsu. By insisting that the engines they sell as Mercury but made by Tohatsu are part of a "joint venture" there is less bad publicity. You can see how fiercely the Mercury crowd wants to quash any notion of the Tohatsu-Mercury relationship as being akin to supplier-customer--that itself is a good indication of how damaging such a relationship must be to Mercury's image. The more the fans scream it is not true, the more desperation I feel in their protests. |
| L H G |
Pure baloney, with timelines that don't calculate. |
| Fishmore |
I don't know why I am posting this but you guys got me interested. Seems both Mercury and Tohatsu agree they have a joint venture (whatever that means) called Tohatsu Marine Corporation (TMC). To back up that statement I offer the following: Mercury in it's corporate literature and website list Komagane, Japan (TMC joint venture) as a Mercury manufacturing facility. http://www.mercurymarine.com/about/plant-and-locations/ Tohatsu in it's corporate literature from their website had this document http://www.tohatsu.com/news/Tohatsu75Years.pdf In that document they describe the Joint venture with Tohatsu / Mercury Marine and that Joint venture is called Tohatsu Marine Corporation (or TMC). Directly following the description of TMC, they identify themselves as being an OEM to Nissan (note that they never say they are an OEM to Mercury). Still further along in that document while discussing consolidation of manufacturing facilities they specifically identify Tohatsu as a separate entity from TMC. "there was a series of discussions on whether to move Tokyo Plant in which cylinder heads for bigger motors (bigger than 60-horsepower) had been made, to Komagane along with TMC which was moving there from old Okaya. Both TMC and Tohatsu have found a lot of advantages in working at the same place." Unfortunately Tohatsu kind of muddies the waters a bit when they refer to both Mercury and Nissan as "great partners" But I think that the difference is that TMC only makes Nissan outboards up to 30 hp and Tohatsu makes motors up to 115 HP and so both TMC and Tohatsu are OEM's to Nissan. Mercury on the other hand only uses the smaller TMC outboards. I base that assumption on the fact that Tohatsu outboards equal to or greater than 35 HP are all 2-stroke TLDI motors. Where as Mercury motors above 35 HP are not 2-stroke TLDI motors. Seems to me if both companies agree to have a joint venture called TMC and both companies agree it is not solely a Tohatsu entity nor solely a Mercury entity and both companies agree they are in the same manufacturing facility and Tohatsu points out that they are an OEM to Nissan but do not indicate that they are a OEM to Mercury then TMC is not just an OEM supplier to Mercury but they have a different type of relationship referred to as a joint venture. What is confusing is BRP's announcement that they have an agreement with "Tohatsu Corporation" for these small motors. So either these motors are not being made by TMC, TMC no longer exists as originally concieved or someone got lazy in their reporting and BRP actually has an agreement with "Tohatsu Marine Corporation" and not "Tohatsu Corporation". Thanks for the little brain escape guys... |
What astonishes me is how terse Mercury is with anything they say about Tohatsu. The only basis for all the howling is the very simple statement from Mercury that some of their outboard engines are made in a plant in Komegane in a joint venture with Tohatsu. From this very little and carefully worded seed, Larry has turned Mercury into an equal partner with Tohatsu, There is really no evidence for any of Larry's speculation. It is what it appears to be: Mercury pays someone to make engines for them in Komagane. Not too long ago I pointed out several other clear inconsistencies in Larry's theory of the world. First of all, the principals in Tohatsu Marine Corporation are all people with Japanese names. I listed them in my article. Second, at the USITC Tohatsu Marine Corporation was a participant and testified against everything Mercury had to say. With those two stunning revelations I thought I had crushed Larry's fanciful notion that Mercury was somehow running the show in TMC. Larry--Do you want me to repeat the details of that again? |
| prj |
quote: Thats simply not true. If you had read Peter's posting of Brunswick's statement regarding Joint Ventures, and my repeat with bolds of same, you would see that it is Brunswick who is claiming the "equal" part in the JV, not Larry. Now, if you would prefer to think that Mercury is receiving or intending to receive equal benefits without being an equal partner, feel free to do so. Do you actually believe that Japanese businessmen are so incompetent as to allow a minority partner equal benefits Jim? If your proposed arrangement were readily available, I can assure you I'd be chasing minority ownerships with equal benefits from here 'til Sunday. Its not a particularly sound business arrangement for the majority owner though, is it? |
PRJ--I think you are reading a lot into the statement you are quoting. Instead of trying to make an inference like that, perhaps you can just show me where Mercury states in clear and uncertain terms their 50-50 partnership with Tohatsu. |
Let me lay out my view on this Mercury and Tohatsu relationship, as I see it. First, we have two totally separate companies, Tohatsu of Japan, and Brunswick of the USA. Brunswick operates Mercury Marine. Hereafter we call this "Mercury." Tohatsu is a Japanese company; hereafter we call them "Tohatsu." Mercury and Tohatsu have a joint venture called Tohatsu Marine Corporation, and hereafter "TMC". There is a very large, very modern outboard engine plant in Komagane, Nagano Prefecture, Japan, hereafter called "Komagane." At issue is what exactly goes on at Komagane, who runs its, and who makes what and sells what to whom. According to the published report of the USITC, TMC is an outboard engine manufacturer in Japan. Here is an excerpt from USITC's Final Report on their Investigation into Import of Outboard Engines from Japan. Unfortunately, for some reason--probably the insistence of some participants that certain information was not to be revealed to the public--portions of the report are redacted. However, in some cases we can make a fairly educated guess about what was redacted.
quote: Source: http://hotdocs.usitc.gov/docs/pubs/701_731/pub3752.PDF Let me offer several comments about this quoted material: --the above excerpt is the only instance in the entire report in which TMC is mentioned. --there clearly have been some figures redacted related to unit volume or market share percentages, obviously done because the report has agreed to keep confidential and out of the public view this sort of information; none of the manufacturers wanted to share with the public their sales figures. This is an entirely reasonable wish, and I don't have any problem accepting that this data has been redacted. --unlike the sales data that has been redacted, I find it very odd that certain other names have been redacted. Specifically, I want to point out this sentence: "TMC did not have its own customers beyond *** and Tohatsu Japan." It seems to me that it is quite transparent that the report originally said this: TMC did not have its own customers beyond Mercury and Tohatsu Japan." My basis for this is as follows: --we know that TMC is a joint-venture between Mercury and Tohatsu; --we know that Mercury is selling Mercury-branded engines that are made in Japan by TMC; --since the report excludes all other possible customers, the redacted customer must be Mercury It seems bizarre to me that Mercury would want their name redacted from this report as being a customer of TMC. I think it goes to the nature of Mercury as an organization. They did not want to reveal to the public that their engines were being built in Japan by even their own joint-venture company. Now we look at TMC. As described above, it exists only to make engines for two customers: Tohatsu and Mercury. As I see it. TMC is a little shell company that was formed so that Mercury would not have to buy engines directly from Tohatsu. It gives Mercury a little bit of wiggle room and they can say they buy their engines from TMC, which is a joint venture. Tohatsu also buys engine from TMC, but they essentially buy engine from themselves, as they're running the show at Komagane. At about the same time frame as this report (c.2005) here is what Tohatsu was saying about Komagane:
quote: Source: BoatsAndYachting No. 60, March/April 2005, page 70. This is but one of many instances where Tohatsu refers to Komagane as being a factory they built, being their factory, and being under their control. Tohatsu is proud of their plant. They have a picture of it on their website: http://www.tohatsu.co.jp/en/boat/profile.html Please note that at the bottom of the page, Tohatsu lists TMC as an affiliated company. Based on this evidence, my view is that TMC is a legal shell that exists so it can make outboard engines in Japan for Mercury. TMC operates inside the Tohatsu plant, not the other way around. Mercury takes this and spins it to its own advantage, even convincing some that Mercury is running the show at Komagane, operates and manages the plant, and is an equal partner with Tohatsu in the Komagane operation. Sorry, but I just can't see it that way. If that is true, then Tohatsu is telling a completely different story. Mercury management ought to get on the next plane to Japan, straighten those people out, and get their name up on the building. Also, here is a list of some of the executives of TMC: Tohatsu Marine Corporation President Mr. Mitsuru Kaneko This ought to give readers an idea of who is controlling Komagane's production under the TMC sub-corporation. Also, Tohatsu list the following personnel on their website: Director / Plant Manager, Komagane I have my clear lens glasses on when I read all of this. I keep seeing the same pattern: Mercury is a customer of Tohatsu. |
| TohatsuGuru |
Wow! I make a typo between 80's and 90's and I become a troll? Here's a few other tidbits. I sold my interest in internetoutboards.com in March of last year. I worked for the U.S. Tohatsu distributor(NIMAC)in the early 90's I presently do work for a dealership that is a Mercury and a Tohatsu dealership. I speak to the two top U.S. employees at Tohatsu America every week. I correspond directly with Tohatsu Japan employees by email. It is also possible that I might be in error about some thing, some time. I'm not in error about the relationship between Mercury and Tohatsu. You either believe me or you don't. |
| fourdfish |
I believe you Guru. It is also obvious that you have far more resources than Larry who pulls this crap out of his rear end then laughs about it. I do not find him at all believable because he NEVER shows any proof. Thanks again! As they say: I believe this horse has been beaten to death. |
Further on the redacted portions of the quoted material above, look at this sentence: "TMC and Yamaha Japan shipped a portion of their production to ***. " I think it is transparently obvious that the redacted name is again Mercury, and the original read as follows: TMC and Yamaha Japan shipped a portion of their production to Mercury. It was very well known in c.2005 that Mercury was getting power heads, components, and in some cases completely built engines from Yamaha. That Mercury would be redacted from this is very strange to me, and, again, it goes to the nature of the Mercury organization. Mercury did not want a public statement to go out from the USITC saying they were a customer of Yamaha. What other explanation is reasonable for the redaction? I can't think of any. I assume the redacted material read as I propose above, and also in my other comment earlier, and from this I get the impression that Mercury is going to great length to obscure their true relationship with their Japanese suppliers from the public view. This goes along with their current terse and obscure mentions of their relationship with Tohatsu. To me it is a pattern of trying to conceal information. |
In one of his earlier postings, TohatsuGuru also recounted a number of myths about Mercury and Tohatsu which are routinely spread by representatives of Mercury, apparently as part of a disinformation campaign to mislead the public about the engines Mercury buys from Tohatsu via TMC. The notion that there could be so many incorrect representations getting passed around makes me wonder where these ideas come from. There must be some sort of policy directive that the real story about the Tohatsu engines is to be concealed, otherwise where would all the made-up stories come from? |
In contrast to all of this, I find the Evinrude statement rather clear and simple: they have an agreement with Tohatsu for Tohatsu to supply engines to Evinrude. I can't say it any simpler. No hocus-pocus, redacted material, secret insider- knowledge-that-can't-be-revealed needed to understand that relationship. |
I think it important to also clear up the standing of Mercury. According to some research done by investigators in Wisconsin, there is no legal entity Mercury or Mercury Marine. They say:
quote: On this basis I don't think Mercury is in a joint venture with anyone, it is Brunswick that would be involved. Source: http://www.wisconsinsfuture.org/publications_pdfs/tax/ MercuryMarineOct2009.pdf |
| TohatsuGuru |
Side Note. The majority of my job hours are spent doing contract bids and negotiations with the government(local, state and federal). Interestingly enough, the Feds specify a "widget" by a part number and who is the authorized manufacturer of the acceptable "widget". When that widget is a "Mercury" item you will never see anything reflecting "Mercury". Instead you will see "Brunswick" and the federal cage code 88907. Quite often the government will ask for traceability from us back to Brunswick...And that's when the comedy begins:) When we buy, it's from Mercury Marine and "Brunswick" does not appear anywhere. Sometimes we have to have Mercury write a letter specifying that they are a Division of Brunswick in order to satisfy the DLA. |
| TohatsuGuru |
This is the part where I tell the world I was WRONG about what I stated in previous posts. TMC is not a real-estate company. And Here's how this Tohatsu Mercury relationship actually works. Tohatsu owns the land, building and equipment. Then Tohatsu lease's the building to TMC. TMC is a 50-50 joint venture company. Mercury put in less than $1,000,000.00 years ago. Mercury has one employee who is at the plant. He has no role in management and his role is limited to relaying suggestions and occasional Mercury requirements for their Mercury labeled engines. Tohatsu is 100% in control of production, research and development and management. TMC should be considered the builder of the outboard. TMC then sells that production to Mercury and Tohatsu. Mercury had zero input into the decision by Tohatsu to sell to Evinrude and Mercury was only informed of that decision after Tohatsu had made the decision. Mercury is unhappy. Tohatsu is sorry that Mercury is unhappy. Tohatsu will do whatever is in it's best interest. This information comes from point blank, face to face meeting I had today with the top guy at Tohatsu...Same guy that four years ago told me what I preaching about TMC being a real-estate company. His English is a lot better now than then and I can only assume that: A) There was a language barrier issue that led me to an error in facts. or B) My memory is completely gone and I must have misunderstood what he told me way back then. I'm going with A as that at least leaves me with a tiny shred dignity:) |
| cbone |
Small Evinrude sold = profit for Mercury |
cbone--that does not follow. There are no details of the arrangements between TMC and Tohatsu and TMC and Mercury. The deal could provide that TMC does not make a profit, and all the profit occurs when the engine is sold by either Tohatsu as a Tohatsu engine or by Mercury as a Mercury engine. Any other arrangment means Tohatsu profits by a Mercury sale and vice versa. Why would that be required in a deal? It isn't and it may not be in the actual deal. |
Since we hear that Mercury is not happy--and who would be--the equation really is more like this: Small Evinrude sold = lost sale by Mercury |
| L H G |
As I keep saying, this Guru personification has no clue, and claims of typos, errors, language barriers, etc doesn't excuse false statements in prior posts this late in the game. He should have gotten the facts first before shooting off his big mouth and calling me a "little man". The latest baloney is: Mercury put in a measly 1M 23 years ago and now is 1/2 of the Joint Venture manufacturer of the engines. Give me a break! I don't know too many Japanese companies, of all people, that give away 1/2 the shop like that. Maybe he should check with a Mercury contact, for the other side of the story, who speaks English, instead of a Tohatsu contact who can't speak understandable English. Go back and read all of his previous posts, and see that none of his statements have been correct or make business/legal sense. But he did take in a few. So with a little reasoning and research, we now know: 1. Mercury and Tohatsu formed a 50/50 Joint Venture company called TMC in 1988, and have been putting out engines ever since. We are not sure it is 50/50, but as I have said, in most cases they are. Kind of what the word "Joint" implies. A 50/50 deal would also imply profits are split 50-50 also. But we don't know, and probably never will. 2. Mercury and Tohatsu BOTH claim they are manufacturing a new line of small 4-strokes at a modern manufacturing facility they own in Japan, with first engines from the new plant for the 2003 model year. Unless both Partners are liars, this sounds accurate enough to be true. It would be illegal for Brunswick to mis-represent that fact to Stockholders. ASIDE: two of the engines from this plant were new 25 and 30HP models. So in 2003 Mercury stopped making their older design 25 and 30 HP engines in WI. That caused Yamaha to lose the 25 and 30 HP powerheads they were getting from Mercury. Check Yamaha's line in 03'- '06. They had no engine between 15 and 40 HP after Mercury stopped supplying them. They needed time to develop their own 25-30's, which they now have. 3. TMC has only two customers, the Partners themselves. 4. Tohatsu sells some of the engines it takes from the TMC Joint Venture to Nissan, with blue paint. 5. We now know that Tohatsu Corp is also going to sell some of the engines it takes from the TMC Joint Venture to Evinrude. From Evinrude's perspective, it HAD to be this way. Buying from the Mercury side of the JV would be a public relations disaster for Evinrude here in the States, or in Europe. But people will still know they are white painted Merc or Tohatsus. Take your choice of what you want to call them. 6. It would be safe to GUESS that the majority of the engines produced in this deal which are sold in North America would be Mercurys. They have a huge distribution channel over here, including Bass Pro shops, Cabela's, West Marine and thousands of Mercury dealers. Tohatsu has minimal channels over here. 7. We don't know if Mercury makes any money from the Evinrude deal, but as a JV partner, it would make sense. My guess is that Mercury will probably not lose sales from the deal, since there is no way an Evinrude customer would put a black Merc on his boat in the first place, at least as a kicker. Yamaha, Suzuki and Honda are the likely losers, and Mercury/Tohatsu are the likely winners. In the midst of all this petty bickering, let's not forget these are really excellent engines, and everybody that has them, regardless of branding or features, seems to like them. Evinrude will be successful in selling them also. |
| Peter |
Now that Evinrude has kicker motors to sell, the big problem for Mercury is that Evinrude continues to have the upper hand when it comes to the combination main and kicker weight on the transom. For example, the single Verado 150 weighs as much as the Evinrude E-TEC 150 and a Tohatus 9.8 4-stroke combined. I mentioned this years ago when the 525 lb Verado I4 came out. It's excessive weight really leaves no room on the transom for a kicker so Mercury would potentially lose sales of the Verado if the customer also wanted a kicker motor thereby forcing the customer to go to the Optimax which is a 2nd tier product. So as I see it, the addition of the kickers to Evinrude's line up is just another stake in the heart of the Verado line. Probably another reason why they had to yet invest again in a complete outboard motor development project at the 150 HP level. |
| TohatsuGuru |
Wow. I admitted I was wrong, Explained why I was wrong. Took the blame for being wrong. Explained what the exact facts are now and still I catch crap? Larry, call Tohatsu and ask yourself or admit that "you really don't have a clue, and have no idea what you are talking about. Your sources are a fraud, if you even have any for your fiction. Try doing some reading and learn a little about the concept of a Joint Venture." Sound familiar? |
Regarding the availability of a Evinrude branded small engine for use as an auxiliary engine to go with an E-TEC on the transom, the combination does not have a great deal of appeal for me. I don't do any angling by trolling. My main engine runs beautifully at idle speeds and has very modest fuel consumption. The 225-HP E-TEC can idle down to 500-RPM and at that speed only consumes about 0.2-gallons-per-hour. I can troll for five hours on one gallon of fuel. It makes no sense to me to invest in an auxiliary engine for trolling. In addition to the auxiliary engine cost, I would have to install all sorts of rigging for remote control. The total investment in the auxiliary would be considerable, and the return on investment in the form of fuel saved by running the auxiliary for low speed operation would be small. Let's say the auxiliary could run at 0.1-GPH. This would be a saving of 0.1-GPH compared to running the main engine. The implication is that one could save 1-gallon of fuel every ten hours of operation. My boating history over the last decade shows that I consistently use the boat less than 100-hours per season. Let's use 100-hours per year as a over-estimate. My seasonal fuel savings by running the auxiliary would amount to 0.1-GPH x 100-hour = 10-gallons. Even at marina fuel prices of $5-per-gallon, the savings from the use of the auxiliary would only be $50 per year. The payback from the auxiliary engine saved fuel is a very long time span. The extremely good low speed characteristics of the E-TEC tend to reduce the need for an auxiliary engine for low speed operation. I think that's why Evinrude has been able to get by for several years now without these small engines in their line. |
With this latest view of the TMC relationship to Tohatsu regarding the Komagane plant, it looks like my earlier speculation was right on the spot. I said, "TMC operates inside the Tohatsu plant, not the other way around." That appears to be the precise arrangement. It looks like TMC pays the overhead on the plant to the landlord, Tohatsu. The burden of the plant overhead is shared 50-50 by Mercury and Tohatsu in their joint-venture shell TMC. We know (from the USITC investigation) that TMC only has two customers: Mercury and Tohatsu. The crux of the deal is that through this arrangement Mercury gets to buy these TMC engines at the same cost as Tohatsu. Once Mercury and Tohatsu buy the engines from TMC, they each go their own way and sell the engines as they wish. The advantage for Tohatsu in this arrangement is that the plant becomes a profit center for them because they lease it to TMC. The advantage for Mercury is they get access to the plant's output at the same cost basis as Tohatsu--that's where the "equal benefit" of the arrangement applies. A simple analogy would be this: let's say Larry and I are both in the business of selling insurance. We both need an office, but neither of us sells so much insurance that we can afford to have our own dedicated office. We each have our own business entity, but we create a third entity, a shell, called LJI (Larry-Jim-Insurance) that pays for all the office space, the telephones, the furniture, the electric bill, and so, on, and we share those expenses on an equal basis. Every day we both use the office to make our sales. The profit we make from selling our products is our own. We don't share that. We each pay, on a 50-50 basis, the cost of the office. Oh, and Larry happens to own the building. So every month, when our 50-50 shell pays the rent, it actually goes into Larry's pocket. This arrangement is analogous to the TMC deal, from what I can tell. |
| Peter |
These days, I don't believe the appeal of the kicker is to save fuel, but rather to finely control trolling speed and keep hours off of the more expensive large motor. In gear, at idle with a 17 inch pitch propeller turned by a 225 HP motor, I'll bet that minimum in-gear speed is about 2.5 MPH. |
| andygere |
Peter is right about trolling speeds. I can troll slowly enough for salmon with my E-TEC 200, but it's harder to make small changes in speed. The stinky old 2-stroke kicker does a good job of this, allowing very fine tuning of trolling speed, and easy adjustments as conditions on the water change. |
| DeeVee |
My reasons as well. My 200 Etec is a joy to run, but trolling for salmon can require a slower troll than the 19 pitch propeller will allow. The hours of running time that you save on the main power is a bonus. Doug |
| L H G |
I my opinion, a "kicker" is primarily for only one reason, at least when you are out on big water (ocean or Great Lakes) - to get you home when your main engine dies, for whatever reason. Yes it can and very well might happen. Low speed, economical trolling is another fringe benefit. The idea that Sea Tow is a reliable backup, if they are even operating within range of where you may be boating, is risky judgement. When I was much younger, and much more foolish, I used to routinely troll 15 miles offshore in Lake Michigan or the Atlantic, in a single engine Nauset. One day I looked back at the engine, and then the distant buildings, and thought this is crazy. That week I bought a matching kicker! I have two single engine boats, but now only use them during seasons and locations where rescue is more readily available. |
| DeeVee |
Larry, Thank you for reminding me of the more important bonus of having a kicker on the transom. Doug |
| fourdfish |
Well I do have a 15hp kicker on my boat and I use it for trolling. Had it awhile, it runs good and it gets a lot of use. Cut down on hours on the E-TEC and could be used as a back up if needed. Many years ago I needed it when my fuel oil filter got blocked up. I was glad I had it then. Foolish to run way out in the water like I do without it. Larry can do what he wants but I like being prepared out there. Now anyone can tell that a true joint venture means both parties own, share and reap the same profits. |
| Tom W Clark |
In this part of the world, kickers are for trolling for Salmon, especially trolling at slow speeds a large outboard cannot maintain. If, one day, you use one to get home, great, but kickers are for trolling. |
| jharrell |
In this part of the world (Tampa) most the kickers I know of, including mine are for getting home. Larger boats go for twins, but on Montauk sized boat a kicker is the only backup option. I time share a cabin on a island at the mouth of the Chassahowitzka river only accessible by boat. I am not getting back in if my engine isn't working, Seatow cannot navigate that area, their boats are too big. My 6hp kicker will get me back up the river in an hour and a half. You see a more kickers on Chassahowitzka than down in the bay. Even when I get a new motor that I am more confident in than my old Merc I will be getting a new matching kicker with charging circuit so it will run on the same fuel. It may seem silly but The E-TEC 90 not having a matching 6hp kicker offering was a detraction for buying it. Yes because of using the same dealer for both, but also matching cowl's etc. I think I have heard jimh speak of the pleasing ascetics of a white E-TEC on a Whalers transom, no one wants a mismatched kicker to go with such a nice looking setup, unless you just don't care about how your boat looks, I do. My current white Johnson 6hp clashes with my old Merc, but they use the same fuel and it was cheap, I might just paint it black at some point. So now that Evinrude will have a matching kicker, for me that eliminates one minor plus a all Suzuki setup would have. I am glad they are doing it, even if it's actually a 4-stroke Merc/Tohatsu, that part is actually kind of amusing. |
| leadsled |
Kicker motors are the only way to go for many reasons. Even if you had two new Etec's on the back what would happen if you strike a log or other solid object at 40 mph. And what about that common fuel tank that supplies both engines. I knew someone with a fairly new sport fisherman that suddenly lost both engines. The pickup tube broke off in the tank. And then there are those people who have that kicker for emergencies and hardly run them. My friend was out 20 miles on the tuna grounds and needed his and it would not run and his kicker's fuel tank would not have had enough fuel to make it home anyway! I am like you west coast salmon fisherman only I troll for Stripers at less than 2 mph. Even if the main engine could go that slow I would still use the kicker to save hours on the engine, save gas and it's not good to go that slow for many hours on end. By the way is Evinrude going to make these kickers in both of there colors? |
| L H G |
Foudy you are certainly welcome to your speculation on how Mercury functions in the manufacture of small 4-stroke engines, but why the personal attack on me for a different opinion than you have? Jim's ConinutousWave rules generally do not permit such attacks. As far as I know, he has not exempted Mercury owners from the rule. |
| Newtauk1 |
Xerox does not make paper nor are they in partnership with any paper mills.They buy it from paper mills. When a mill xyz is running a particular grade of paper they use their own xyz packaging. When its time to make the "special Xerox" grade paper made to "Xerox grade specs" the xyz packaging is removed and the xerox packaging is loaded in the machines. Xerox will tell you other wise , but cost of manufacturing makes it impossibel to make a grade for Xerox. I have to assume that Tohatsu is making motors with the Evinrude name on them. Evinrude then buys them and re-sells them. Mercury does the same thing.Buys Tohatsu and re-sells under the Mercury label. No joint ventures. Simple Supplier, re-seller relationship. What's the problem? |
jharrel mentions:
quote: I hope I spoke about the pleasant aesthetics. As for pleasing ascetics on my transom, well, that is another story. From M-W.COM ascetic noun : [one who practices] strict self-denial as a measure of personal and especially spiritual discipline :[someone] austere in appearance, manner, or attitude |
| jharrell |
Thanks for the grammar check jimh I would have preferred a simple bracketed correction, but I gues you where not in a ascetic mood. |
jharrell--it was just too funny to pass up. No offense to you was intended. You know your comments are always welcome and usually beyond the reach of any editor's blue pencil. |
| jharrell |
No offense taken, I'm much more interested in accurate information than preventing a bruised ego, and precise language helps further that cause. I have to say this site has sharpened my writing skills mostly from the lack of a edit feature and the moderators attention to detail. I really used to hate not being able to change a post once submitted, but I have come to appreciate the permanence of the action. So now all we need is some pictures of these new small engines to evaluate the aesthetics in relation to thier larger brethren. |
| onlyawhaler |
Quite a discussion. Sometimes the simple answer is the best answer. I don't think Mercury's name is anywhere on the outside of the Tahatsu plant over in Japan. I don't think there is a special office inside the plant with coffee and donuts for Mercury executives. I think its a ongoing shame to lose North America jobs and manfacturing overseas. Thats a entire different discussion. I don't think Mercury Techs are over there to oversee, influence , wave their fingers in the air to invoke Mercury ghosts of bygone decades to help the black paint dry smoother or to help the decals stay on longer. I think its just an agreement to have Tahatsu make make them so Mercury can resell them. They make them there, they land on the shipping docks here. Unfortunately the same applies to Evinrude. Its just an agreement and the business goes elsewhere. Onlyawhaler |
| frontier |
At the Portland (Oregon) Boat Show last week, a dealer had pictures of the new Evinrude kickers, but no brochures or motors. |
| fourdfish |
Well said Sterling. I agree! OH! well larry! |
| onlyawhaler |
The new Evinrude trolling motors are now up on Evinrude.com under portable engines. They are 4 strokes, 3.5hp through 15hp and they are all in Evinrude dark blue at this point. Here is the link http://www.evinrude.com/en-US/Engines/portable_engines Onlyawhaler |
| onlyawhaler |
Looking at the new Evinrude portables and the lower Mercury hp sizes look exactly like the same as I flip from site to site. The 6 hp by Mercury is said to be the lightest in its class at 55lbs. The Evinrude 6 hp appears to have the exactly the same cowling and weighs,,,,,55lbs. It appears to be just paint and stickers, not even a cowling change. Oh well, makes one feel really special about their new Merc/Evinrude kicker motor purchase Evinmercs. Larry isn't going to like this. Who would have thought? Onlyawhaler |
| L H G |
Mercury has had these engines on the market since 2003, 8 years ago. I have no problem whatsoever that Mercury is now selling these same engines to Evinrude with blue paint. |
| Peter |
"Looking at the new Evinrude portables and the lower Mercury hp sizes look exactly like the same as I flip from site to site" The shape of the upper cowling of the Mercury and Evinrude 9.8 and 15 HP 4-stroke models are different. The shape of the upper cowling of the Evinrude and Tohatsu 15 HP models are the same. The Evinrude 9.8 and 15 HP 4-strokes are a Tohatsu with Evinrude paint and decals. The shape of the upper cowling of the Evinrude 6 and 4 HP models are the same as the Mercury 6 and 4 HP models. Tohatsu uses a different shape for the 6 and 4 HP models. The shape of the upper cowling of the Evinrude, Mercury and Tohatus 3.5 HP models are the same. From this information we can reasonably speculate about the Mercury-Tohatsu "joint venture". Mercury supplies the black paint and decals, Tohatsu supplies the rest to make Mercury portable 4-stroke outboards. Tohatsu appears to be in complete control. |
Larry--I have to admire the fervor with which you stick to your fantasies about Mercury. |
| bloller |
I just purchased an 8hp Tohatsu Four Stroke for a square stern canoe. It is the same as the 9.8 Tohatsu with just a different carb. They are the lightest motors in their class. It is a very smooth and quiet runner. The three gallon tank that comes with it is enough gas to last a very very long time. I purchased it online for hundreds of dollars less than the Mercury version for the loss of shift on the throttle tiller and a few other insignificant features. The Mercury versions listed weight is a few pounds heavier as well. I see that BRP chose not to include the 8hp version in its lineup. It also did not list accurate motor weights for the long shaft and electric start versions. It will be interesting to see how much more they will want for them over the Tohatsu. It looks identical to my Tohatsu. Best of all though parts availability and the number of trained service technicians should increase. |
| fourdfish |
Larry--To say that Mercury is selling these engines to BRP is truly one of the most ridiculous things you have ever posted. Especially, since you have said that Tohatsu is making these engines. A mind is a terrible thing to waste! |
| andygere |
Decent little motors, the weights are pretty reasonable for 4-strokes in the 9.9 and 15 hp models. One advantage of Evinrude now selling the little Tohatsu outboards is that parts and service will be available at Evinrude dealers. This is an advantage that goes beyond the matching paint. Does anyone know if these will be available to match the white E-TECs? Nice to see an electric tilt option as well, and I'd like to see more details on mounting and rigging requirements for those models. |
| seahorse |
No white portable motors from Evinrude, only blue at this time. |
