| Author | Topic: Considering a Whaler |
| GRB |
Hi All--I just registered and this is my first post, however I’ve lurked for some time. I recently sold my dingy and I'm planning on upgrading to a small side or center console boat. This boat will be used by my children and I for river and creek cruising and casual fishing. I plan to occasionally tow this boat behind my boat as well (whole different topic that I'll post). I like the smaller 13-foot and 15-foot Bosotn Whalers Sport and Super Sport models, and I'm leaning toward those, but don't know for sure. I'd prefer a boat no older than approximately 10-years-old with a four-cycle fuel-injected engine. Any and all information and recommendations are appreciated. Thanks, Greg |
Hi Greg--Your entry into Boston Whaler boats is precisely like mine: I wanted a 13-footer to use as a dingy with a larger boat. I came across a nice SPORT 15 and bought it. I have never looked back. The hulls of the 13-foot and 15-foot classic Boston Whaler boats are quite different. The 13-foot hull has a rather flat bottom and is extremely stable for its size. The 15-foot hull has a finer entry and has a more rounded bottom. It is not as stable as the 13-foot hull, but the 15-foot hull will give a much better ride in head seas. There is some support for the claim that the 15-foot Boston Whaler hull is the best small boat ever made. Then again, some would say that about the 13-foot hull. On a small boat, and particularly on a small and light boat like a Boston Whaler, you need to be aware of the transom weight. If a four-cycle outboard motor is used, I advise to look for one with the minimum possible weight. Also, a motor with fuel-injection will typically not be able to start without battery power. There are a few exceptions. I think the small TOHATSU four-cycle engines can start without a battery, but other than that most four-cycle outboard engines will need a battery to start. Factor that into your plans. Don't be afraid of buying a Boston Whaler boat that was made before 2002. There are thousands and thousands of beautifully preserved classic Boston Whaler boats that are more than ten years old. |
| Binkster |
[Re four-cycle engines]: I have a small TOHATSU 25-HP four-cycle EFI on my 13 footer. It comes equipped with a pull start. (see pic) http://s27.photobucket.com/albums/c191/floridaboy2053/ Whaler%20with%20Mercury/?action=view¤t=whalerfinished1.jpg I have never tried to pull start it without a battery, but I have tried to pull start it with a good battery and no can do. I can only pull it one compression stroke and no more. OK, I'm not so young anymore, but I asked my neighbor who is 20 years younger and he had the same result. I don't think any 4 stroke will start with a 1/2 turn of the flywheel, you need multiple revolutions. |
| Jessielove |
[Changed TOPIC. Please start a new thread if you want to change the topic. Thanks--jimh] I agree with Jim, a 13 or 15 footer would be ideal and don't overlook some of the older boats. My first whaler was an early 13 at 10 yrs old. I grew up on it and many of the fondest memories of my youth were the times I spent on it. The 13 is very stable and I feel easier to jump/dive and climb back into than the 15. I also would reconsider a two stroke. They generally start quicker and more easily than a 4 stroke. You do have to consider oil storage and consumption, but this is not a huge factor considering the potential weight savings. If you buy a newer whaler, you will face depreciation. Older whalers maintained hold their values. You could buy a 13 from the 70s or 80s, use it for 5 years and generally sell it for what you paid to buy it. There is always a market for high quality smaller whalers, even in this slow economy. Buy the best quality one you can afford, keep it well maintained, and you and your kids will be rewarded with many pleasant memories. |
| MarkoOR18 |
[Endorses] the classic 15' hull. I used to guide salmon fishing in Campbell River British Columba, and have 100's of hours experience in that hull in protected salt waters. Amazing ride and handling for such a small boat. With a tiller, we found 50hp to be a great match for the boat, though you can go as much as 70hp if you want to ski behind it! A very good friend of mine has owned his 15' since 1985 and still uses it more often than his 22 Guardian. He has also owned a classic 17, but sold it as he prefers the ride of his 15, albeit at the expense of some room. |
| Tohsgib |
Your best bet might be a 2000 or newer Sport 130 which is the newer style hull. Most have Mercury 4 stroke 40hp on them and they ride, weigh, and handle like a hybrid between the old 13 & 15 hulls. It meets your criteria and most likely will be easier to find and cheaper than a repowered classic. They are also sans wood so easier to maintain. You can find a nice say 2005 for roughly $6-7k in mint shape. |
| Jeff |
Greg, During my almost 20 years now of owning and operating Whalers I have had the luck of owning both a 13 sport and a 15 Super Sport. With that, I would have to say I enjoyed the 15 far more than the 13. The 15 had a far better ride due to the deeper V in the hull but, because of that it does make it a bit less stable at a resting stop than the 13. This is also the reason the 15 has a lower Swamped Capacity than the 13. When I had the 13 (actually owned it after having the 15) I found it wear my back out with the all pounding if there were was any type of wave action. I also found the 13 had a tendency to porpoise a lot no matter where I set the motor in height and in trim. This I am sure is mainly due to the hook that is designed into the bottom of the hull at the transom. With the V on the 15 you can easily trim the bow up and adjust the hull for the best angle of approach for the on coming seas making for a more comfortable ride. The 15 did have one draw back in my view. The hull had a great tendency to chine walk at speeds over 40 mph which is faster than most ever go in their 15's so, take that with a grain of salt. The 15 is rated for 70hp but, honestly it can get a great boat with a 40 or 50 hp on it. You only need more horsepower if you have to tow heavy skiers. We had a Mercury 75 on our 15 and it was a rocket that would top out in the low to maybe mid 50's which was WAY to fast. Personally if I was looking for a 15 again I would try and find a 15' Center Console Sport. These are hard to find but, that small Montauk Style console is great to operate from. If you can not find one of those I would look for a Sport as I have found that interior to be more comfortable than the Super Sport style. When looking you will find the 15's tend to carry a bit of a higher price tag but, It is well worth it. Jessie, I may be wrong but Rich's wood looks to be Ribboned Sapele Mahogany which was that coloration and ribboning in it naturally. |
| GRB |
Thanks for the replies thus far. Few more questions: 1. What's the difference(s) between the Sport and the newer Super Sport? Thanks again, Greg |
| Peter |
A good condition 1980s vintage classic 13 with a good condition 30 HP outboard and a trailer should be no more than about $ 5000. Classics are in demand. I'm not sure that is the case with post classic 13s. 30 HP and under 2-strokes are either pre-mix or have their own reservoir so there should be no oil storage concerns. Modern direct fuel injected outboards use so little gas and oil that a gallon should last a full 50 hour season under typical usage. |
| GRB |
To clarify the pricing average I mentioned in my previous post (question #3), it was for 2001-2006, 13 and 130 Sports with trailers. The majority had 40HP engines, but two had 25HP engines (hence question #2) Greg |
| Binkster |
My 13 footer with its 25hp 4 stroke EFI Mercury/Tohatsu as pictured above will do 28-29 mph with one or two average adults. With 3 adults it will do 24-25 mph. With 4 adults forgetaboutit, just under plane maybe 19-20 mph. I run a 9 inch pitch cupped prop WOT is 6000rpm. Another thing to consider. 25-30hp Merc/Tohatsu 4 strokes don't come with tilt/trim. (nice to have but not really needed on 13 footers.) The best motor for a 13 footer is the 31.8 cu inch OMC 2 stroke at 115 lbs. It the type of outboard the boat was designed for. These motors were available from 1978-2005 in hp ranges from 20-25-30-35. Only differences were the carbs and the exhaust tube. Average adult---not fat(able to easily sit in one seat) Testing was done with one male and the rest were smallish women. |
| contender |
GRB: Here me out on this one...I have always been/grew up on the water, I have lived in the Keys and currently in South Fla. so boating is a big factor in my life, and I'm now 58. I have had a Boston Whaler since 1962 (13) And we still own it today, (currently I own a 1979 11 Boston Whaler, my brother has the 1962 13, and I have a 1975 16'7") back then when my brothers and I were smaller it was no problem to have 3 of us in the 13. As we got older the boat just did not have enough juice to tow and ski with, still this was an excellent boat. The 15 is a step up from the 13, the problem with this is they are more expensive and harder to fine than a 16/17 whaler. (I have also heard that the 13 is more stable than the 15, do not know if it is true or not) The older 16'7" Boston Whaler will be the one to find/purchase. No matter what vehicle you have it will tow it just fine, a lot better ride than the 13 (never been in a 15) and a lot dryer boat. What is nice about the 16 you will have taller sides for the kids and some more space for toys, equipment, and just storage. I would go with at least a 75 hp engine, better would be a 90 hp. I think that this boat will serve your family well and in the years to come. |
| PeteB88 |
My 40 Yamaha on 13 Sport is perfect for my use - lightweight, power tilt, goes fast and for me, the tilt gets me in and out of almost anywhere - I need to use it more often is one thing. Last season was our year of almost constant use of the Outrage 17 - this coming year I see lots of small lake and river trips, back water fishing and going for Mr Bluegill - 13 is perfect. |
| Jessielove |
GRB You don't have an e-mail in your profile so I couldn't send this to you directly; I have to post it here. I saw this recently repowered clean 15 super sport on e-bay. Not totally original, but modifications I think are nicely done in the spirit of boston whaler: |
| GRB |
Jessielove, I apologize for my email not being accesible, I've corrected that in my profile. Thanks for the link, however I have a budget of ~$8K and that Whaler is above that and is located in CA (I'm in PA). Thanks again though. Greg |
| Tohsgib |
The newer 130's were originally rated for 30hp in 2000. The 25 is marginal. friend had one with a 30 2 stroke and it did pretty well for the weight. Honestly I would not consider it, 40 or nothing on a 130. A classic 13 is another story. I have a 40 4 stroke on mine and it is overkill. It is perfect for you and within your budget but I can never sell this boat as my father bought it for me new in 1982. That is the reason for my first post, a repowered classic will cost as much or more than a newer 130. The 130 is also in the middle between a classic 13 & 15 in ride, weight, etc and I personally think it is a great match for you as a kinda first boat. Keep looking, you will find like I said a 2005 or so for $6-7k. |
| Ridge Runner |
Here is a 2006 130 w/40 in South NJ. Asking $7,500 has the bow rail (great with kids). http://www.boats.com/boat-details/Boston-Whaler-130-Super-Sport/ 124126231 |
| Striper15 |
For $8k you should be able to find a decent 13' and possibly even a 15'. In my opinion, either would be a good purchase for what you describe. I have ridden in both and prefer the 15' but I wouldn't hesitate to go with the 13. However, I don't think you need to limit yourself to a ten year old or less boat. Boston Whaler is a different breed and boats 20, 30, even 40 or more years old are still cruising the waterways with very happy owners (including me). You are on the right track. Good luck and welcome aboard! |
| Tohsgib |
Ridge...great example and a 45hour EFI to boot. Try and get EFI if you can, early 4 strokes have/had carb problems. |
As I recall, somewhat hazily, the early Boston Whaler 130 boats had 25-HP motors standard, and the choice was likely to hold down the retail price. A small boat is very sensitive to added passenger weight, as the passenger weight is often a very large percentage of the total boat weight. Doubling the weight causes a very noticeable decline in speed. In the classic 13-foot boats you can see the various model differences explained and illustrated in http://continuouswave.com/whaler/reference/13/ |
| Jeff |
Greg, I emailed you about a 15' I recently ran across.... Best, |
| GRB |
Thanks for all the information and suggestions guys, it gives me more direction. I'm going to focus (my engine portion of the search) on 40HP boats. Reason being, there will be times where I could have 3, possibly 4, adults on board. @ Ridge Runner - Thanks for the link. That looks like exactly what I'm searching for. I'm going to follow up on that one. @ Jeff - Email reply sent. Thanks. Greg |
| dmeswi |
I have a 2005 130 Sport with a 40 hp Mercury 2 stroke. I live on Blackwater Bay which is fed by the Blackwater river. The 130 Sport is great for runs around the bay and up the river with up to five people. It's not so good for running out to the pass or places where you may run into choppy or rough water. I wouldn't want less than 40 hp because it takes some umph to get it on plane with 5 people on board. Also, with 40 hp it is great to pull a tube behind (we have a Big Mable for 2 people). You can make a sharp turn at full speed and the boat stays nice and flat. It is very stable. Three people can fish but two is better and when some stand up on the seats or move from side to side, it doesn't tilt the boat. I bought this boat instead of a wave runner and am glad I did. It fits just fine on my wave runner/skiff lift and for the times I have it on a trailer I can easily roll it into the garage. I do have a larger boat, so this little rocket suits me just fine and I look forward to the time the grandchildren are able to take it out. Dennis |
| GRB |
Update: I wound up (don't ask :-) purchasing a 2011 leftover 150 Super Sport with a 60HP EFI 4-stroke. It has bucket seats, bow rail, cooler/cushion and a spare gas tank. Hoping that the relatively mild temps continue so I can play once before summer, if not it's gonna be a long couple of months. Thanks for everyones help and suggestions. Greg |
| Jessielove |
Sounds great, welcome to the Whaler family! |
| MarkoOR18 |
GRB: Congrats on purchase of a very nice boat. I'm sure you will be happy you went for the larger model in your range of preferences. Contender: If you ever get a chance to go for a spin in a classic 15, you're in for a treat! Great riding little boat. I'd take one most days over any classic 16/17 for ride quality. |
| pcrussell50 |
Based on what I've read here since I joined back in 2009, I've come to view the 15 as a sport boat, (for going fast and water skiing and general playing on the water). If not for the 70hp limit on them, and the fact I already have two other sport boats of that size that both support more horsepower, I would be frantically searching for a classic BW 15. As it is, I have 1985 13 Sport with a Yamaha 40hp of the same year. I've been out in it with my 200lb butt, my NFL football player, 300lb brother in law, and his two sons, and I don't even need full power to get up on plane. Just a quick goose and she pops right up. I'm also in the camp that thinks PT'n'T is superfluous on this combo. The motor is only 158 lbs, weighted for easy manual tilt, and, and has a grab handle to boot. I just keep the motor's tilt pin in the position I most use for cruising and rely on a quick burst of power and the hooked hull bottom, and I'm up on plane in no time, at surprisingly slow speed. In the two and a half years I've owned it, I don't know if I've ever used the full power of that 40hp. I'm intrigued by Nick's idea of a 40hp, post-classic 13. But there has also been a couple of threads on here by owners complaining about having trouble getting on plane with loads that were far from the max. The conclusion I recall reading on here had to to do with the weight. 40hp is still 40hp, but the base, dry hull of the post-classic is a good deal heavier, (maybe double), than the classic. So keep that in mind, and/or maybe bring some heavy friends with you on your test drive to see if it's performance meets your needs. -Peter |
| Tohsgib |
Uh Pete....you are about 2 weeks late to the party, he bought a 2011 150. |
| pcrussell50 |
Ima go out on a limb here and guess the purchase price was a wee bit more than $6000? -Peter |
| Powergroove803 |
My 25 Johnson 2 stroke with a nicked up prop will plane out easily with 2 adults and 3 big kids on my 13, so a 40hp for me would be a luxury and not a necessity.(for the lake anyway) My top end is however a limited 28 mph with just me, and 24-25 with all 5 of us. I would like to go a little faster on occasion, so the 40(or a new nice prop)would probably be more than a luxury. |
| GRB |
"Ima go out on a limb here and guess the purchase price was a wee bit more than $6000? -Peter" Just a tad...LOL Greg |
