| Author | Topic: VERADO DTS Accident |
| 6992WHALER |
I'm not a liberty to share everything about this. Here is what I can tell you. The boat is a 2011 Dauntless 20 with a Mercury Verado 200-HP engine, with fly-by-wire [DTS] controls. [Note--all VERADO engines have DTS controls; they are mandatory with the VERADO--jimh]. There were less than 20 hours on the boat. During a quick stop from plane, the operator pulled the throttle back quickly, intending to stop with the engine in the neutral position. The boat came off plane and the engine slowed down nicely, but, when the engine reached about 1,200-RPM, the computer put the engine into reverse and accelerated it up to the current throttle setting. Apparently the operator did not stop with the throttle set in neutral but missed neutral and left the throttle in reverse (at a fairly high speed). The engine went in reverse so fast that water was sucked up into the power head and the engine was ruined. No one on board was hurt but it was quit startling. Insurance paid for the engine. There has been communication with Mercury and they are basically saying that they did not know the engine/fly-by-wire would do that. With a mechanical throttle if you had missed neutral you would have known immediately and you would have pushed the throttle back into neutral. In this situation the operator had no idea the boat was not in neutral and was totally unprepared for the boat to go into reverse. I personally have very limited experience with fly-by-wire controls, but I wonder if this would happen the same way on other brand engines such as an E-TEC with fly-by wire controls. |
| K Albus |
I have electronic controls on my new boat with a Yamaha motor, but I am not willing to experiment to see how it would handle a quick shift from forward to reverse. |
| bluewaterpirate |
Bottomline ...... know your boat, motor, and motor controls. The computer put the motor in reverse at the command of the operator. Sounds like the operator was not familiar with the boat. Tom |
| Tohsgib |
Why would somebody pull it back to neutral anyway? That is unsafe. A boat needs to be in gear in order to maneuver safely. |
| 6992WHALER |
Lets not turn this into a topic about driving and operator experience. Lets stay focused on the fly-by-wire controls and their response to the operators actions. TOHSGIB if you want to have a discussion about |
I don't see how the fly-by-wire contributed to this engine failure. If the operator put the shift into reverse, the fly-by-wire system correctly waited for the engine speed to slow down, then made the shift into reverse, just as the operator had commanded. I do not think that water can be "sucked up" into a power head by rapid reverse operation. Making way at a high speed astern and then shutting off the engine might allow water pressure to push water upwards into the exhaust passages, but, if the engine were running, the pressure of the exhaust gases should tend to prevent water from rising from the propeller hub upward to the engine. If this were not the case, then all outboard engines that were operated with the propulsion astern and at a good speed would be liable to experience the same outcome. It sounds to me like the operator became confused, pushed the throttle and shift lever into reverse, then shut off the engine while the boat was making sternway at a good speed. This forced the water into the engine. If the fly-by-wire contributed to this, I would ask for suggestions on what intelligence could be added to the fly-by-wire system to know that the operator really wanted to go to neutral instead of reverse. How would anyone but the operator know this? |
| bluewaterpirate |
The DTS control unit on the 20 Dauntless is easy to use and understand. When moving the throttle back toward neutral there is a point where you can hear and feel it click into neutral. The system works as advertized and is safe to use as long as the person using it knows how to use it. Tom |
I am surprised that Mercury has been represented as saying they were not familiar with how their electronic controls would operate in this situation. I would have expected that a crash shift from forward to reverse at high speed would have been a standard situation for testing. I can't accept the notion that Mercury did not test for this or that they were not aware of this possible control action. Anyone designing electronic controls would be likely to make this situation their first consideration in the control software design. I think Mercury's response is perhaps not fully explained or properly represented here. They must have know how the control system would behave in a crash shift like this. |
| 6992WHALER |
I agree the fly-by-wire did what it was told. The operator missed the neutral position on the boat. But unlike a mechanical throttle the operator had no warning that they had missed neutral. So no attempt was made to put the engine in neutral until after it reengaged with no warning. I do not know if the engine was shut off or if it stalled but either way water intrusion ruined the engine. It is lucky no one was hurt when the four people on board all thought the engine was in neutral and had no indication it was going to go into reverse hard. |
| 6992WHALER |
I agree I thought that Mercury's comment was strange, maybe it is deliberately ambiguous, maybe part of the statement was left out of the report, maybe the statement is from someone who should not have answered the question? I am pretty confident that I will not be shown any more detail so I will probably not be able to get a better answer. |
| bluewaterpirate |
I do a lot of offshore fishing some on boats with 2/3/4 verados. I seen these boats crashed back and run hard astern backing down on fish to the point where we had water coming over the sterns and not once did I observe and engine stall or be filled with water. You can go full ahead to full astern in matter of seconds if you want to. So until we know the whole story it's really just speculation on what really happened. One thing we do know is the operator totally missed neutral which is pretty hard to do. I've also seen Yamahas run in the same fashion. Tom |
| Peter |
I think the point here is that the instant feedback that one gets from a mechanical system may be buffered out by the intelligence in the fly-by-wire system delaying the transition. That same action with a mechanical system would likely provide instant feedback to the operator in the form of a shredded gearcase or broken drive shaft. |
| 6992WHALER |
Tom, It is interesting to have your first hand experience with the controls. The comment that keeps coming out from the operators is that they found it very hard to find the neutral even before and since this has happened. The comment was made that it does not click into neutral. Yes Peter you said it very well. |
| bluewaterpirate |
Absolutely, however, if you put someone behind the wheel of your boat you better be darn sure they understand the systems whether they be fly by wire or mechanical. The operator should have had some time to familize him/hersself as to the feel of the DTS throttle. Some lessons learned from this event. How fast was the boat moving forward when the motor was put into reverse and how long did it stay in reverse? Tom |
| 6992WHALER |
I do not have an exact speed but the boat was not going much faster than the minimum speed to keep it on plane. Again I have no time on how long it was in reverse, but it does not appear to have been long, just as long as it took to get it back into neutral. The engine was cut hard over I don't know if it was to port to Starboard. |
| 6992WHALER |
The boat was moving forward at the time she went into reverse I do not know how fast. |
| ConB |
The first time I drove a Verado powered Outrage 21 I was coming off plane and went though neutral and into reverse. Knew what I did and found neutral again. The DTS controls need much less effort to operate than the 20+ year old OMC controls I own. just suffered embarrassment, no motor problems. And I'm not a beginner. Con |
| makoman310 |
[There are] red light to see if you are in neutral. If [the boat operator] was going that fast and slammed it into reverse, that [Mercury VERADO] will shut down. [This narrative] sounds fishy to me. [I have] run a [Mercury VERADO 250-HP] on my OUTRAGE 22 for the last four years. [The Mercury digital throttle and shift] never fails. |
| kwik_wurk |
How many times have we missed the neutral set point when driving our cars[?] Quite a few times when starting from park, but very few times when going 25-MPH, mainly because you typically don't shift into N, and more importantly because when you miss, it makes an awful sound or you'll end up with a pool of red ATF or the transmission on the ground. Manual throttle controls on most marine gear applications won't allow this to happen until the engine slows down enough. And when it does, just like on a car, you know something is wrong, and hopefully you can react fast enough to nudge the throttle/shifter back into neutral Now if the DTS has a reversal rate control, also known as a set point, then I could easily see how this could happen, reversal rate [or] set point being the RPM limit at which the lower unit is allowed to engage reverse. Missing the detent on the DTS is easy, and easier yet for a new boater, assuming it was a new boater. How many of you have taught a spouse or other how to drive the boat, or watched someone cowboy when docking a boat[?] Stalling the engine and failure [due] to water ingress is very strange. I have come off plane in some boats and had the back swell roll over the top of the cowlings, intakes and all--a little spooky, but the baffles worked, and no water. Loss of back pressure due to killing the engine while in reverse at a high rate of speed [is] possible, but unlikely. The engine would still spin down and create some pressure on the exhaust. Now, if the boat weight 5-tons, then maybe, as the momentum would be such that the back pressure could be overcome. So the ruined engine is baffling to me, and the statement provided is ambiguous at best, only providing speculation: "There has been communication with Mercury and they are basically saying that they did not know the engine fly-by-wire would do that." |
Modern fly-by-wire controls, like the ones on my boat, have very prominent indicator lamps which show with complete certainty which gear, F-N-R, is engaged, and, as an option, the tachometer instrument can also be configured, if desired, to show what gear has been engaged. To make a blanket statement that one cannot tell what gear is engaged in a modern electronic control system is very misleading. In well designed modern electronic controls there is NO ambiguity for the operator about what gear is engaged. The operator simply has to look to see what gear is engaged. My boat has Evinrude ICON electronic controls. |
| phatwhaler |
A certain government agency recently switched to Gaffrig six-handle controls from DTS controls because of the water suction [problems]. There [were] a few instances of young guys [hydro-locking] the motors and rough-housing the gear cases. Interestingly, this same agency has gone back to DTS controls because of the difficulty in dealing with six handles. |
The mention of six handles implies three VERADO engines. This leads to the simple question: What government agencies have triple-engine VERADO boats as part of their standard boat configuration? Looking at the U.S. Coast Guard, I don't see a three-VERADO-engine standard boat listed in http://en.wikipedia.org/wiki/Equipment_of_the_United_States_Coast_Guard Did I miss something? Perhaps it is the boat mentioned here, http://en.wikipedia.org/wiki/United_States_Coast_Guard#Boats and here http://uscg.mil/datasheet/spc-le.asp the 33' Special Purpose Craft – Law Enforcement (SPC-LE). This was the go-fast boat that the Coasties were driving in San Diego when they ran over a family on a smaller recreational boat. Too much horsepower, too much youth, and an arch with blue lights can be a bad combination. I think Homeland Security favors the triple-engine configuration, and perhaps so does the Immigration and Customs on-water assets, the ICE boats. In any case, with all those VERADO engines--and all using DTS--having run thousands of hours, the total on-the-water time for DTS must be approaching a very large number of hours. It would be astonishing that a new boater in 20-hours of operation of a single VERADO could discover some new and totally unanticipated software glitch in the DTS. This narrative is hard for me to take at face value. As phatwhaler suggests, this cannot be the first VERADO to hydro-lock from some unusual control interaction. To suggest that Mercury never heard of this or it had never been done before seems a bit of a stretch. |
| sosmerc |
The best way to find any shortcomings or deficiencies in a new design is to put it in the hands of the public....the ultimate test. |
| RobP |
If your want answers to Verado questions I'd also take the discussion to Glen's site. Search for "reverse" there you will find Glen has discussed putting his Verados into reverse in an emergency situation, he did blow a hub after a couple of times but not the power head. They also covered "shifting into reverse at high speed" and apparently you can adjust the amount of friction you feel with the throttle. The DTS takes little effort to move in and out of gear and unless you pay attention to what your hand it doing you can easily over shot neutral. My father got behind the helm once while I was setting the anchor and almost threw me over when I asked him to "pop" it into reverse for a second. He was used to clunky cable controls and pulled back hard on the throttle. Except for when trimming the engine, I generally don't hold the hand grip I hold the arm close to the base and control with thumb and forefinger. I feel it give me finer control on the throttle. |
| Hoosier |
Isn't there a check valve in the exhaust plumbing that is supposed to prevent water ingestion into the powerhead? If this was a panic stop the operator would have been looking at what he was avoiding, not idiot lights on his controls. From this discussion is sounds like Mercury has not put enough tactile feedback in the controls to allow the operator to "feel' what they are doing. If that's true, Kevin could have lot of fun in court with this one. |
| bluewaterpirate |
The tactile feel is adjustable and set by the installer or by the operator if he/she doesn't like the current feel. Takes two allen wrenchs (2.5 mm & 5 mm) and five minutes at most. At delivery it's one of the items on the seller to buyers check off list. Tom |
I found an account of the Mercury VERADO motor failing when the operator cut back from high speed on plane to idle very rapidly. Ironically, the boat was a Boston Whaler 305 CONQUEST. This particular boat owner lost several VERADO motors, apparently due to hydrolock, that is, water getting into the cylinder. Apparently the cylinder most affected is the lowest cylinder, which makes sense. Due to the in-line six arrangement, the bottom cylinder may be a bit lower than one would find on a V6 engine. My explanation of this behavior is a follows: when the engine is cut back very rapidly the boat falls off plane immediately. This results in the stern of the boat going down and a large following wave from the wake overrunning the transom. If the engine has stalled at a point where both the intake and exhaust valve of the lowest cylinder happen to be open--such valve overlap is likely on a high performance engine--water could easily rise through the exhaust system and enter the lowest cylinder and perhaps even higher cylinders. The weight of the VERADO would tend to make the transom sink more than might otherwise occur when coming off plane. If the transom sinks far enough and the wave from the wake is high enough, the wave passing by the VERADO may be high enough actually be higher than the lower cylinder(s). Also, as we know from nature as demonstrated in the Bay of Fundy, if a volume of water is traveling along a passage with some speed, the water can be propelled at higher speed as the width of the passage narrows. This situation may be occurring in the Verado. Even if the wave height is not high enough to reach the lowest cylinder, the push of the water into the exhaust passages may accelerate the water and propel it higher than the wave height. See: http://www.veradoclub.com/smf/index.php?topic=1423.0;wap2 What role has electronic control to play in this? Not much, that I can see. Cutting back very rapidly on the throttle appears to be the root cause. The weight of the VERADO probably aggravates the problem. The in-line six design may make the lowest cylinder even lower than in other designs. The electronic fuel injection design also aggravates this problem. In carburetor engines the suction of the intake manifold may continue to pull fuel out of the carburetor when the throttle is cut. In electronic fuel injection, there will be no fuel provided when the throttle is pulled back. The difference is very noticeable. On my boat the motor has electronic fuel injection. When the throttle is cut back the engine speed immediately drops, and the boat speed reduces dramatically--much faster than it did with a carburetor engine, which tended to coast as it decelerated. My take-away from this: don't cut back the throttle from full speed to nothing, especially if you have a heavy VERADO on a small boat. |
There is also discussion about a problem with hydrolock on a VERADO at http://www.veradoclub.com/smf/index.php?topic=2972.0 but I can't read this archive due to access restrictions. However, it seems that the possibility of damage from hydrolock is not unknown among VERADO owners. |
Also related to this problem of hydrolock with VERADO motors and Boston Whaler boats may be the tendency of Boston Whaler to mount the engines a bit lower on the transom than might be otherwise done. Boston Whaler tends to deliver their boats with the engine mounted rather low. A difference of 0.75-inch or 1.5-inch of engine mounting height might influence the tendency for water to be able to reach the lower cylinder. |
As for electronic controls, I have observed that there is a very high probability that an operator who is not accustomed to the feel and friction of the electronic throttle lever to move the throttle lever with too much force. I have observed this on my boat with electronic controls when someone takes the helm for the first time. The friction of movement of the controls can be adjusted, and they can be made to have high friction of movement, if desired. However, I find that the lower friction is often preferred, once one becomes accustomed to it. In the account of this accident it is mentioned that the engine had 20-hours of operation. I would assume that an operator would become accustomed to the feel of the throttle after 20-hours of operation, but, if executing some sort of emergency stop to avoid a collision, they might yank the control harder than normal. That is just human nature. That the engine was pulled into reverse might aggravate the situation. In reverse the propeller would he pulling water toward the exhaust outlet, and this might also help accelerate the water into the exhaust passage and upward toward the engine. |
| seahorse |
The same water ingestion problem is seen on Yamaha 4-strokes and I assume other make 4-strokes, but I'm only familiar with the Yamahas. When going fast forward and shifting rapidly into reverse, with traditional control cables, the engine usually dies and when in reverse gear with the boat still moving forward, the motor will turn backward due to the water flow pushing against the prop blades (now that the motor is locked into reverse gear). That can cause sucking up water into the exhaust valves. While the stalled motor is turning over in reverse rotation, the exhaust valves become "intake valves" and will draw in water. Most often the motor will then hydro-lock and bend or break the connecting rods. On Yamahas this is usually confirmed by stored ECU codes for "incorrect cam timing" and "MAP pressure error". With the cams turning backwards the cam sensor detects a problem. Also with the reverse turning motor, the intake valve becomes the "exhaust" and pressurizes the intake manifold. The MAP sensor registers a pressure instead of a vacuum and also sets a code. I can't comment on fly by wire systems except that most won't shift above a certain rpm, such as 1500, but if the motor dies from quick de-acceleration, the controls will then shift into reverse while the boat is still traveling forward at a good clip. |
| tom976 |
This is like saying that while the engine is in forward gear, I can put it in neutral, kill the motor and put it back in gear and watch the engine spin. I have yet to see that one happen on mine. Sounds like a cool trick though that you might be able to bump start the engine. |
| martyn1075 |
The engine height is a rather interesting point. Is that a flaw of the boat? Or the engine? Or the Boston Whaler guys who installed it? I feel this owner was quite fortunate to have insurance cover it. I want his insurance. However Mercury probably knows more about this problem than we think, and, to keep everybody happy and out of the press, they worked it out with the insurance group. It's probably a rare occurrence that this happens, more or less like a perfect storm between operator and technology doing what it has been told to do. |
Re the propeller turning the shaft: I thought that most outboard engine gear case arrangements had a dog clutch which permits the propeller to turn faster than the propeller shaft. On a gear case like that when the propeller is turned faster than the propeller shaft (from the force of the water turning the propeller), a clicking sound is heard. It is possible that the gear case on the VERADO uses a different arrangement for the clutch than the typical outboard engine? Many years ago I wrote an informative article about the change in the Mercury FOURSTROKE outboards to a desmodromic clutch. See http://continuouswave.com/ubb/Forum1/HTML/015209.html for details. Perhaps this same desmodromic clutch is used in the VERADO, and has the characteristic that once engaged in a gear the propeller can turn the propeller shaft, so the propeller might be able to turn over the engine. |
| Peter |
"On a gear case like that when the propeller is turned faster than the propeller shaft (from the force of the water turning the propeller), a clicking sound is heard." The propeller is directly coupled to the propeller shaft and therefore cannot turn (rotate about its axis) faster than the propeller shaft unless the coupling between the propeller and propeller shaft is broken. The clicking sound is heard when the gear shift is in neutral and the boat is moving forward causing the propeller and propeller shaft to "windmill". |
| Tohsgib |
Even though I was informed not to comment on this thread I feel the need. First we have shongo info from a 3rd party and not even a full account of the incident(basically he does not know what occured). Second the more I read the more I laugh at some/most of this. 1) Obviously the engine did not stall coming off plane or it would NOT have gone into reverse. 2) Obviously he was not just under the neutral click he was pretty far back in reverse or the boat would not have slammed into reverse, almost killing people aboard, and moving so rapidly backwards that it ingested water. IF you were still moving forward and slammed a boat in reverse it will not throw people around if they are properly seated. It will be in reverse but still moving forward for a moment until the reverse thrust overcomes the forward momentum. This does NOT happen instantaneously or else the Titanic would have not hit the iceberg...capeesh! 3) If you are a new owner you SHOULD read the owner's manual as it is filled by roughly 60% of it's pages with WARNING signs and notes of what NOT to do. 4) Lastly even though I have no formal credentials to show the forum today, why on earth does this whole thing sound fishy? First it was NOT just a common mistake that this person was coming off plane and missed neutral, went into reverse and somehow stuffed an engine. Ok I might buy that as I would not put it past Mercury to design an engine that can be destroyed so easily. But I would not believe that they did not ever try doing that during the 10's of THOUSANDS of hours of testing(c'mon REALLY). Now we find out the engine was hard to port or starboard when it happened. So mister 6992WHALER I just want to ask you a question about your "friend"(in my best Columbo voice). You slammed me about my first post but I was on the right track. This "person" is a newbie or does not have much experience. I believe he was in a panick situation where he was about to hit somebody or something and did as described on PURPOSE in order to avoid a collision. Reason I say this Mister 6992WHALER is that if a person was just nonchalantly coming off plane for whatever reason and missed neutral he would have immediately just clicked it back into neutral and we would not be having this discussion. The reason why he ruined his engine is because he saw he was going to hit something, yanked the steering to one side and slammed it into reverse full throttle. This had NOTHING to do with drive-by-wire. Your "friend" is lying to you or you are lying to us. If he would have done what you described the boat would have never gained so much reverse speed to ruin an engine....case closed! Lastly you should NEVER pull back into neutral when coming off plane as you...1) might need to move forward to overcome a stern wave. 2) Need to turn abruptly and therefore would have no ability to manuever. 3) You could miss neutral and hit reverse. That is just common sense and needs no credentials. |
| WT |
Isn't this kind of like a propeller lawsuit? Operator error but we find something/someone else to blame? The sun got in his eyes so the sunglass manufacturer is to blame too. :-) It's almost spring! Warren |
| Tohsgib |
Warren...when a thread is started off with..."I'm not a liberty to share everything about this. Here is what I can tell you." I automatically assume something is fishy. When somebody says "my friend" or "this guy I know" my radar goes off as well. A gun goes off and accidentally shoots somebody, you did'nt see Cheney suing Remington. |
| Tohsgib |
One LAST comment. When moving forward say even at a fast idle the bow is settled down, especially when coming off plane. The "initial" slam into reverse at high speed actually LIFTS the transom as the boat is still moving in the forward direction. It is not until you gain considerable amount of reverse speed that the transom ducks down and water either starts coming over the transom or being ingested through the exhaust. Ingestion rarely happens as many have commented because exhaust is pushing against the incoming water. Only when the speed is so great or the engine stalls that the incoming water will prevail. This whole thing makes no sense. oh sorry...my credentials are thousands of hours behind the wheel since I was a fetus. |
Re the propeller shaft speed and propeller rotation, I should have written "drive shaft" instead of "propeller shaft." The ratchet mechanism is in the clutch. |
| 6992WHALER |
First off I am not going to get in a shouting match. This thread has been a very interesting and civil discussion I hope we can keep it that way. I think I made it clear in the opening post that the operator made a mistake, He will be the first to tell you he missed neutral. I sent an email asking for clarification of some of the questions asked on this thread. The driver of the boat is a very experienced on the water instructor. When the boat was put into the Quick Stop Maneuver the operator missed neutral the engine slowed down and then went into reverse and then stalled. Mercury denied the warranty claiming it was an abused engine, insurance covered it. That's pretty much what I know. |
| egres |
OK, Got to love of the emotions pouring out of this interesting recounting of yet another engine failure. 69;For the lack of another name; has confided in an actual motor failure event. Good deed in describing the anecdote. I will take this one under advisement and chalk this one up as manufacturing,adjustment or an assembly flaw problem. After all,isn't that what Mercury has decided to list it as? The guarantee will be honored. The story was interesting with plenty of speculations as to cause and effects. The only thing left will be to recount of personal events from US, going from forward to fast reverse and it's effects on our personal motors. Manufacturing error will be a likely conclusion in this interesting failure. And Nick,Way to go Fetus. |
| Tohsgib |
Should have said that in the first place sir. Having the engine stall is a major fact on why it ruined the engine. Not what was conveyed originally. I don't doubt Mercury denied the claim as it was clearly driver error, experienced or not. To ANSWER your question...a mechanically throttled engine would have either.... 1) shifted right into reverse at speed or grinded a bit and the shifted. 2) Blew the lower unit to Bitsies. 3) Snapped a drive shaft or stripped the crank where the driveshaft mates. Everything except #1 would have NOT resulted in a blown engine from water ingestion. Does that help the suit? My only last question is why was the engine hard to port or starboard? That still makes this fishy. |
| Tohsgib |
Thanks Serge! aye! |
| 6992WHALER |
tohsgib if you spent more time listening and less time talking you would have noticed that I did not know the engine stalled when I made the original post. I think I made it pretty clear that I sent an email asking for some clarification based on the discussion here. As far as the helm being hard over, if you had training in high speed boat maneuvering and someone had told you they had done a quick stop or a high speed stop you would not be asking why is the helm hard over. Being good at handling a boat does not mean you actually know the best way to handle one. Now please stop trying to take over this thread, and dominate it with negative nonconstructive noise. |
| Tohsgib |
"As far as the helm being hard over, if you had training in high speed boat maneuvering and someone had told you they had done a quick stop or a high speed stop you would not be asking why is the helm hard over." Then give all the information up front instead of me having to squeeze it out of you. You never mentioned he was in a panick situation...I did in a post a few back. I KNOW why the helm was hard over but you never said why until I pointed it out. I also KNOW that you never said the engine stalled. Many here have saying that is how a 4 stroke ingests water in MOST cases. In this case it did not stall and was fully submerged by a full reverse throttle Verado engine demolition by your "friend" as he was avoiding hitting somebody or something. FACTS is what we need, not some drivel about an incompetent driver trying to make a frivolous claim. |
| Tohsgib |
Let me rephrase that.... 1) in your initial post you never said the engine stalled. In your 2/8 5:25pm post you said "When the boat was put into the Quick Stop Maneuver the operator missed neutral the engine slowed down and then went into reverse and then stalled." Hence my rebuttal at 10:07pm. Sorry that I did not see the e-mail part. Next time your "friend" is out doing stupid shit and the engine stalls after trying to submarine it, tell him to bring a sparkplug wrench and drain the cyls before trying to restart. Will keep his insurance company from dropping him. Have fun. |
| 6992WHALER |
tohsgib I have asked you nicely twice to stay out of this conversation. I have no interest in what you have to say, which is to bad because you appear to be an intelligent knowledgeable person. Please go start your own thread. |
| Tohsgib |
Why? This is fun watching you paint yourself into the corner. Why don't YOU start a new thread with ALL the pertinent information instead of drivels of nothing and then you MIGHT get an answer. This whole thread was BS from the start. |
| Tohsgib |
I am NOT angry...I like turtles! |
| Tohsgib |
PS...The Honey Badger does not give a crap...he's crazy! |
| 6992WHALER |
If the entire thread is BS, you could just walk away and let the rest of us have a civil conversation. |
| 6992WHALER |
I was thinking that the new 4 strokes and the Fly-by -wire controls might make a lot of experienced two stroke and mechanical control operators feel less experienced. The first time I experienced a 4 stroke engine I did not realize I had started it so I started it twice. When I put it in gear it was so quiet that I applied too much throttle. I did not realize how much I listened to the sound of the engine when I operate an outboard engine. Now add a control system that is easier to move with an engine that is much quieter. In other words take two senses hearing and feel, and change what the operator is use to. If it is not clear in my posts when the operator put the boat into the quick stop he was not in an emergency he was practicing the skills he would be teaching his students. There was no danger or panic, just a lack of familiarity with the boat. Of course the reason they were practicing was to get familiar with the boat. |
| andrey320 |
Sucks about the accident. Nice that insurance covered it. I can see this happening on any boat, not only with electronic controls. I tightened my throttle to keep it steady at running speeds but think that it helps to keep this type of thing from happening. The engine should not have failed like that. A wave hitting an outboard is not a freak accident! This sort of thing probably happens every day. What if this boat was twenty miles off shore maneuvering near a rocky island? Picture yourself getting close to a rocky point that is new to you. Suddenly, you see a rock line just under the surface twenty feet in front of you. What do you do? This makes me think that my emergency braking is not well planned or practiced.... |
Some of the comments in this thread wound my heart with a monotonous languor. |
Several years ago I published an article about Mercury DTS controls in SMALL BOAT ELECTRICAL. See http://continuouswave.com/ubb/Forum6/HTML/001766.html It is interesting to note my comment from that article regarding the control friction setting.
quote: On my own boat, which I have recently converted to modern electronic remote controls, one of the first things I changed after actually using the controls on the boat in open seas was to increase the friction settings. |
| tmann45 |
The Mercury DTS controls have two separate adjustments, friction and detent tension. Use the detent to adjust the notch you feel when entering or leaving neutral. The Yamaha DTS system that I have does not have this feature of an adjustable detent, it only has a friction adjustment. |
