  MONTAUK Capsize
Author Topic:   MONTAUK Capsize
pglein posted 05-19-2012 02:27 AM ET (US)   Profile for pglein   Send Email to pglein
17-foot Whaler capsizes near Sucia Island with three aboard. One dead.
gusgus posted 05-19-2012 03:14 AM ET (US)     Profile for gusgus  Send Email to gusgus
Holy MOLY! That is so sad to read. My heart goes out to every one involved.
domlynch posted 05-19-2012 09:55 AM ET (US)     Profile for domlynch
I wonder how much the capsize has to do with the low freeboard, low transom height and what I feel is the quite narrow beam for the classic 17. I have only spent a few hours in mine in good conditions and while it has great stability and unsinkability, I'm still not convinced about the low transom and gunwale height.
Get swamped and then I reckon you're in big trouble. So far I have felt more comfortable in boats, one or two shorther than the classic 17, with significantly higher transoms + gunwales + large beam, even though they are sinkable.
I feel it's about not getting swamped.
Maybe these guys snagged a pot or anchor and tried to drag it out under power and pulled the stern or bow under. With low freeboard + some short chop I don't think it would take too much to cop a dangerous amount of water onboard. (i.e. enough to gravely affect lateral stability). Unsinkability doesn't necessarily matter that much then.
No anchor, lobster pot or crab trap is worth a capsize, from which we have such tragedies.
It's so easy to take trips out for granted - but things can go so horribly wrong - it's easy to die/lose crew in calm water too.
Bless their familes,
Dom
domlynch posted 05-19-2012 09:58 AM ET (US)     Profile for domlynch
Sorry my spelling is bad tonight eg."+ large beam" should read "larger beam"...
It may be due to a stout or two that I had tonight to keep myself warm in our rapidly approaching winter (and yes it can feel quite cold here in Sydney even though temps. never really get too low)
fishgutz posted 05-19-2012 10:03 AM ET (US)     Profile for fishgutz  Send Email to fishgutz
I wonder what happened to the drowning victims PFD. They said he was unable to inflate it. Doesn't it automatically inflate? I just don't trust those things. I'll wear my foam filled vest.
20dauntless posted 05-19-2012 10:06 AM ET (US)     Profile for 20dauntless
Very sad, and accidents like this hit close to home. I just looked up the weather data from some buoys around the San Juans and it looks like the winds were blowing from the south in the 10-15 knot range, which doesn't suggest the conditions were particularly rough. I was up at Sucia in January during a winter gale with winds in the 25-35 knot range, and even then I wouldn't have expected a Montauk to have any trouble unless something else went wrong (losing propulsion, etc).
I don't want to speculate on the cause, but as in many boating and aviation accidents I suspect a number of factors influenced the capsize. Hopefully the Coast Guard will release more details so we can all learn from this tragedy.
andygere posted 05-19-2012 11:21 AM ET (US)     Profile for andygere  Send Email to andygere
The story said they were trying to free a stuck shrimp pot, which certainly had something to do with the capsize. Not all inflatable PFDs are automatic. Many of them require you to pull a cord to activate them. Condolences to the families of the person lost in this terrible accident.
Binkster posted 05-19-2012 12:08 PM ET (US)     Profile for Binkster  Send Email to Binkster
domlynch,
This accident probably has little to do with the low freeboard and low transom of the 15' Whaler. It sounds about the same as the capsizing and drowning of the pro football players in the Gulf off Tampa back in 3/10. They had a stuck anchor and were trying to free it by pulling it with the stern cleat on their 21' outboard which had a lot more freeboard and stern height than a 17' Whaler.
Its rather easy to do, just cinch up the anchor line or trap line to a stern cleat, and just keep taking the slack out of the line each time the stern drops into a trough, Pretty quickly the line will have no scope at all and will be in a vertical position. Hopefully and the next big wave will lift the stern and it will pull the anchor or the trap free. But possibly the anchor or trap will not budge, the line most likely will not break due to the stretch factor, the stern will not rise, and in a heart beat your boat is full of water and over you go. At least a Whaler will not sink, or sit in the water with just the bow showing.
You seem uncomfortable with a low freeboard boat. Perhaps a classic Whaler is not for you.
rich
jimh posted 05-19-2012 12:40 PM ET (US)     Profile for jimh  Send Email to jimh
The hull design of a Boston Whaler MONTAUK could have influenced this event. A hull like a Boston Whaler MONTAUK shows very good initial lateral stability. The resistance to roll is initially high. However, after the hull is inclined past a certain point, a marked changed in stability may occur.
Assume four people aboard a boat like a MONTAUK are trying to haul a pot aboard over the side gunwale. The initial hull stability and resistance to roll seems very good. This may lead to a false sense of stability. If two people are at the gunwale hauling, and two more come over to join them, there could be a marked change in stability that occurs very rapidly.
contender posted 05-19-2012 02:08 PM ET (US)     Profile for contender  Send Email to contender
So much for inflatable life vest, I'm surprise that these type are even legal. I would also like to know why the 3rd guy could not hang onto the engine in the overturn boat? Was the water rough? 3 Guys on one side of the boat trying to pull the pot? I use to pull pots all the time with my 13 and 16 whaler, if the pot was stuck we would use the rear lifting ring and gun the engine forward to pull the pot loose. Can also use a large anchor ball the same way, floats the pot to the surface....
Dave Sutton posted 05-19-2012 04:54 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"If two people are at the gunwale hauling, and two more come over to join them, there could be a marked change in stability that occurs very rapidly"
Been there, done that: Two guys hauling a 40 pound fish over the rail while a freediver in the water was holding onto the gunwale from the water = immediate capsize.
'Tauks are seaworthy boats, but need to be handled with skill. They can handle almost anything... in the hands of a capable operator.
Anyone who thinks they can hang on the engine of a capsized boat in a seaway ought to try it sometime. It's a damned dangerous place to be when it's rough.
Dave
martyn1075 posted 05-19-2012 05:12 PM ET (US)     Profile for martyn1075  Send Email to martyn1075
So hard to say what happened. So many things could have made the boat capsize. Perhaps they rapped the trap rope around one of railings reversed the boat to free the trap with too much weight on one side, or perhaps the engine was caught on something else while the trap was locked into the mud way down deep.
Sometimes a recreational trap can get caught up in a line of heavy duty commercial trap setup and when that happens your trap is locked up. It takes a very powerful winch system to lift the traps up one at a time. These lines between traps can be many many feet apart and the line just floats between each. Apparently the currents are fast moving in that area. This is rally sad I feel for that man and his family and friends.
jeffn posted 05-19-2012 09:17 PM ET (US)     Profile for jeffn  Send Email to jeffn
That is a very sad and tragic story to hear about, my sympathies to his family and boating partners, such a fun activity should never end that way. A very unfortunate accident, one that is open to so much speculation as to what happened.
I do a lot of prawning around the Victoria, BC area, it is one of the main reasons I bought my Classic 15.
The Whaler is the only boat, except for a Zodiac, I see on the water pulling prawn traps that by its' own design allows me to pull my traps over the bow which in my opinion is the best and safest way. I have a small electric trap puller attached to the bow rail, works outstanding, any wind will generally keep the boat pivotting around the rope as the trap comes up so any waves will hit the bow. I did the same method with a had puller before the electric. Traps don't too often get stuck but when it happens I will still pull from the bow while my partner has the boat in reverse. The open area in the bow also makes it easy for emptying and reloading the traps again. The low freeboard is actually an asset with pulling the traps as they still need to be pulled into the boat once they break through the surface.
Most other boats I see on the water, the larger runabouts and such, always need to haul in from the side at the rear, in most cases it is the only spot to attach their trap pullers. The boat size is able to withstand the weight of two people at the side pulling if necessary. In rough water their higher freeboard is also an asset.
The Whaler is a very stable little boat but I am also very aware of not having two people standing on the same side particularly in rougher water.
My method works effectively and safely in my 15, I would think it should work well in a 17.
Binkster posted 05-19-2012 10:04 PM ET (US)     Profile for Binkster  Send Email to Binkster
comment:
(Been there, done that: Two guys hauling a 40 pound fish over the rail while a freediver in the water was holding onto the gunwale from the water = immediate capsize.)
Are you sure? I never tarpon fished with supermen, but more than a few 80-100lb tarpon have been hauled over the gunwale of my 13 footer by one average size male, back in the eighties, when that was my hobby. I know folks are a lot heavier nowadays but it takes two fatties to haul a 40 pounder aboard? And what has the freediver have to do with it, He's only holding on and treading water.
Please elaborate. Must have been a funny site though.
rich
domlynch posted 05-19-2012 10:24 PM ET (US)     Profile for domlynch
I'm with Dave Sutton on this one:
"Tauks are seaworthy boats, but need to be handled with skill. They can handle almost anything... in the hands of a capable operator.
Anyone who thinks they can hang on the engine of a capsized boat in a seaway ought to try it sometime"
Rich, it's not clear to me why or how this tragedy occurred - whether it relates to freeboard or not - however it is a tragedy indeed. I have heard of numerous tragedies by the manner you describe, where people try to lift a snagged anchor. With nearly 30 years on the water I have tried to drag snagged anchors free (using the method you describe, progressively shortening the anchor line, but off the bow, not stern) and only in relatvely calm conditions, with easing on the throttle done very gently. (and backing off when it looks like it's not going to succeed). It is definitely not something I would recommend though - each skipper has to make his own decision. I have taken the decision to cut free snagged anchors a few times - this is never a nice decision to make but in the cirumstances I was in I felt it was safer. I would never try to raise/unsnag an anchor or trap by using the stern in any way - whether the vessel is a 15, 17, or 21, Whaler or otherwise. There are other ways to reduce the chances of losing an anchor (which I will not raise here) - just as there are many ways to skin a cat.
Regardless of how much (or little) skill, common sense and experience we may have, when accidents happen they can happen quickly and tend to catch us by suprise. There is always something to learn from others & from the sea.
Again it is another sad story of the loss of more boating folk, condolences to their families.
Dom
DeeVee posted 05-19-2012 10:44 PM ET (US)     Profile for DeeVee  Send Email to DeeVee
The Sakonnet I owned for 20 years and the Montauk my brother in law owned for a little longer than that, were both rigged with shrimp pullers in the bow.
The buoy was always approached upwind. As the line was made up to the puller, the boat would always face the wind. While the capstan head was engaged , the boat set at about a 20 to 30 degree angle, but with the bow into the wind- always. Even in rough weather, this always felt safe, though sometimes water would be shipped over the bow.
If a puller was rigged aft of midship, I can see how classic 17 could ship water. If it was a big roller, and the puller was engaged with a heavy pot, I can see how a 17 could roll, pretty easily, especially with too many people on the same side of the boat.
My Outrage 22 is currently set up to have my puller rigged at the aft, port side flush rod holder location. I could not come up with a clean mounting set up in the bow like I had in my Sakonnet. I will definately be vigilant of a situation like that in the future.
A terrible tragedy that no one should have to experience.
Doug Vazquez
domlynch posted 05-19-2012 10:49 PM ET (US)     Profile for domlynch
A little thing I forgot to add - re when I tried to raise a snagged anchor off the bow - I never made the line too short i.e. near vertical, and motored around gently in circles in an attempt to unsnag it. If this didn't work I would not try further. Again, not something I recommend - each skipper must make his/her own decision.
Binkster posted 05-20-2012 08:37 AM ET (US)     Profile for Binkster  Send Email to Binkster
comment:
When the boat is turtled, you have no lifeline, what else can you hang on too. The survivor of the football players boat overturning and drowning hung on for two days.
(article and picture of survivor clinging to lower unit below)
http://www.huffingtonpost.com/2009/03/04/ survivor-nick-schuyler-sp_n_171878.html
rich
Dave Sutton posted 05-20-2012 08:48 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Are you sure? I never tarpon fished with supermen, but more than a few 80-100lb tarpon have been hauled over the gunwale of my 13 footer by one average size male, back in the eighties, when that was my hobby. I know folks are a lot heavier nowadays but it takes two fatties to haul a 40 pounder aboard? And what has the freediver have to do with it, He's only holding on and treading water.
Please elaborate"
Rich,
I am regularly amazed that you continue to write things here that are only framed within your own limited worldview. Not everywhere in the world is like your tropical backyard.
We were hauling in a 40 pound striper in the edge of "The Race", a spot at the entrance to LI Sound, which if you did a little research you would know is a place with very dangerous rips and standing waves over the reef that often reach 5 feet. We free-drift divers thru there for bass, and pick them up on the other side of the race. Remember that when you pick up a diver, you need to be in neutral.. you have only a few seconds before a 'Tauk will turn beam to the seas. Add to that the fact that the diver in the water is trying to control a 40 pound fish that has not given up yet and things can get tense. Generally the diver shows the tip of his gun to the boat driver to indicate "no fish" as a pickup signal, and the butt of the gun to indicate "fish on" as he fights the fish, which will be at the end of a 100 foot kevlar line (less line may naturally be out too, but the reel-lines are 100 feet long). The way the fish are boated is for the diver to hand the gun into the boat, and then hand-line the fish to the surface, while the boat driver takes up the line onto the gun reel from the boat. When all is said and done, there is a diver in the water with a struggling fish in his hands, and a boat laying broadside to the sea next to him. The diver usually grabs the gunwale with one hand and hoists the fish over into the boat, which if you have ever tried it will roll a 'Tauk at least 20 degrees. If it's a big fish, the boat driver will often reach over to assist, which can roll the boat another ten degrees or so. Add all of that to low freeboard and then let the boat drift into another standing wave and you can easially fill the boat with water. On this day we had "one more guy" who was learning the sport, and he tried to be "way too helpful" and joined the boat driver to help get the fish in (rather than going to the opposite rail to counterbalance). First standing wave filled the boat... second wave capsized her onto the diver.
This was an unusual case, but shows that skill (or lack of it) and coordination between crew members (or lack of it) can have real outcomes on the water. We routinely flood 'Tauks to the gunwales with water fishing here: We run the boat hard to slosh the majority of the water over the transom and let the 5000 GPH pump (yes, 5 THOUSAND gallon per hour pump) pump out the rest. What we do is world class spearfishing, and yes... it's dangerous.
The end of the story is that we lost all of the gear, swam with the boat for a while (all were in wetsuits, as is the norm), hung onto the tagline from the transom and tried to stay AS FAR AWAY AS~POSSIBLE frome the engine, which would have impaled and killed anyone trying to climb on it, and waited for help. We were picked up, with the assistance of the other boat we were able to right the 'Tauk, pump her dry, and amazingly we were able to restart her and run her under escort to the beach. New wiring, etc... and she is as good as new. But if you think for one moment that you can hang onto the outboard in any sea conditions that you will have capsized one of these in, you are crazy.
If you want to try it, you can come on up and show us how it can be done better.
Dave
Binkster posted 05-20-2012 11:16 AM ET (US)     Profile for Binkster  Send Email to Binkster
Sounds like you need to use a bang stick on the big ones.
JMARTIN posted 05-20-2012 02:33 PM ET (US)     Profile for JMARTIN  Send Email to JMARTIN
Maybe they were trying to pull the stuck pot with the motor, from the stern, going with the waves instead of pulling from the bow or amidships backwards with the waves.
When pulling 50 pounds of pot and 400 feet of weighted line, the boat can end up in all sorts of awkward attitudes towards wind and waves. I will make boat correction moves during a pot pull at times.
gss036 posted 05-20-2012 05:13 PM ET (US)     Profile for gss036  Send Email to gss036
After reading all this in a hurry, I didn't see anyone mention any thing about TIDES. From reading the newspaper account this AM it sounds like several boats were in the area. Its says it took the Coast Guard about 45 minutes to get there from Bellingham, that says a lot about the water conditions as that is about 18 miles from the harbor.
There was about 8.5+- ft tides, so if they tied off the stern and 2 of them tried pulling form the stern they probably got pulled under in the tide as it would have been running fast and hard and it was windy. I see the refinery smoke stacks from my house ans they were laying off hard. I had a 23 ft boat and I would not have wanted to be out in that area.
I am familiar with the area as I fish there a lot. There is a large reef on the west side and that adds to the turbulence of the water.
Just so tragic to hear of these things.
Teak Oil posted 05-20-2012 09:28 PM ET (US)     Profile for Teak Oil  Send Email to Teak Oil
The man who passed was 72, no life jacket, and in cold Pacific water.
I don't think any of us when we are 72 could hold on for long at that age in those conditions.
Just a sad situation
lizard posted 05-21-2012 12:40 AM ET (US)     Profile for lizard  Send Email to lizard
The auto inflate vests operate when in water of a certain depth for a number of seconds, if I recall. THe manual inflate vests usually have a plastic tab, with a cord, on the right side, below the vest, that you pull down on. We have both. I have noticed, when underway, if it is really windy, the manual pull down whips around and occasionally becomes entangled in the lower vest belt. This might make deployment problematic.
davej14 posted 05-21-2012 05:42 AM ET (US)     Profile for davej14  Send Email to davej14
I always use an auto-inflate vest. There are two types of auto-inflators. One mechanism uses a dissolving pellet (think alka-selzer) which releases a spring loaded pin to puncture the seal of a CO2 cartridge. The other mechanism uses the pressure of the water immersion to release the pin. They both have tubes for inflating by mouth as a back up. Hopefully more detail will be reported about the vest that failed to function.
One of the best features of the auto-inflation style vests is that you will tend to wear them. No vest is going to help you if you don't have it on and the bulkier types tend to be left in the locker.
If you use this type of vest you are well advised to inflate them occasionally to test the auto-inflators and make sure they are sound. If you havent done this give it a try. You will be surprised at how fast they inflate and how quickly your head is correctly positioned. Properly maintained, it is my opinion that auto-inflatable vests are very reliable and perhaps the best at keeping your head above water if you are unconscious. You cannot slip out of them.
domlynch posted 05-21-2012 07:13 AM ET (US)     Profile for domlynch
Dave,
Your description of "The Race" complete with dangerous rips, standing waves etc and how quickly a boat in neutral (eg when picking up a diver or taking the leader on a big fish eg.marlin) can turn beam on to the seas is for mine right on the money. I've never been there (but I can imagine it from your description and from my own experiences in rough water) and it is the sort of place I would definitely want to avoid (if I had the chance too). I'm not as adventurous or game (or possibly as skilled as you in boat handling).
The first wave flooding the boat and the second causing the capsize....it sounds like the diver it flipped on was very lucky not to get hurt. And that everyone survived too.
I'm sure I would feel very disconcerted with a flooded boat - especially in those conditions - even if I could run a lot over the transom and have a huge capacity bilge pump.....
As to hanging on to an upturned motor in seas rough or closely spaced enough to flip a Montauk, I would think that virtually impossible. Just keeping one's head above water (even with a lifejacket that keeps your head above water) and maintaining a sense of orientation in between chop/swells would be a battle. I am not a good swimmer but I think such conditions would pose real challenges even for good swimmers. Swimming in a pool is totally different from in open and choppy waters...
I sure as hell hope I never have to be in this situation and I wouldn't wish it on anyone.
I reckon your point about coordination (or lack of) of crew members was very important - especially on small boats. I have always found it a pleasure to fish/boat with a good crew who have interchangeable skills etc etc. This also considerably increases safety margins + enjoyment on the water.
Dom
domlynch posted 05-21-2012 07:34 AM ET (US)     Profile for domlynch
Sorry, I should clarify - we are normally in gear when tracing a big fish - not neutral, so some steerage can be maintained.
Dave's situation of having to be in neutral briefly (to pick up divers) reminded me once of having a marlin boatside (many years back) in building seas. I was on the helm and had to slip her into neutral briefly, and leave the helm to assist a mate with the leader (no one else was on board), while the fish was arcing around the stern of the vessel, at risk of getting snagged/cut off on the prop. In the wind and chop, it was very difficult to control the boat while in neutral, even for only a few seconds. I kept having to return to the helm very quickly as we had lost steerage. I was never able to get a decent chance at tracing that fish. As it turned out, the fish (which was tiring) spat the hook and swam off to fight another day. If we had another crew member (which we normally did have - dont you just hate Murphy's law)), I would have remained on the helm, in gear etc if possible and we most likely would have landed that fish.
The lesson learned for me in this instance is twofold: 1. how quickly steerage is lost and how easily one can become beam on to bad seas & 2. the value of having experienced crew. There are literally only a few seconds in some conditions before you get beam on - that's how I relate to Dave's situation.
Dom
Dave Sutton posted 05-21-2012 09:40 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
Thanks Dom.
It seems we have both "seen the elephant" so to speak. You need to "be there" a few times to even be able to discuss it.
'Tauk's are darned seaworthy boats. You *can* go almost anywhere with one... as long as you keep them aimed into the seas. Surfing them thru the breachway in 8 foot rollers(inlet to anyone not from Rhode Island) in a following sea, putting out to sea thru the same breachway, running them thru areas of standing waves and rips, etc... all can be done with skill. But make a mistake and you're just another chip in the whirlpool.
My guess is that most owners use these within about 25% of the *boats* capability. That may represent 80% of the *owners* capability though.
The real fact is that not very many people have gained the experience needed to go into bad water with small boats. Some have... most have not. It takes many years of graduated experiences and a lot of small mistakes made, and likely a few bad mistakes barely survived to make a skilled bad water boater. As for what we do, I really don't think we are doing anything too extreme here: As long as we have squared away people aboard, the boat is not even breathing hard. We PLAN to ship a hundred gallons of water into the boat when we fish, it's just part of the sport.
Dave
Dave Sutton posted 05-21-2012 09:47 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"The auto inflate vests operate when in water of a certain depth for a number of seconds, if I recall"
Not so: They use a 'pill' that dissolves in water and releases the striker. What you are thinking of is the hydrostatic release that releases a life raft from a sinking vessel.
The auto-inflates work great as long as you keep them (fairly) dry: What we have found in the 'Tauk (and in my Zodiac) is that we get inadvertant inflations at times, as we are often water-soaked. That's small stuff compared to the penalty for hitting your head on the way overboard and drowning because you cannot inflate manually.
When spearfishing, we have all hands in wetsuits, even if they do not plan to dive, both for buoyancy and for immersion exposure.
Dave
6992WHALER posted 05-21-2012 10:18 AM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
Auto inflate or manual inflate, either way these PFDs are designed to be used only by very competent swimmers.
Never put a weak or non-swimmer this type of PFD.
If everything works perfectly they will probably be OK, but if anything malfunctions the victim is not a good enough swimmer to deal with the PFD and keep themselves above the surface.
Many people can swim if they put themselves in the water under controlled conditions, but these same people will panic if they find themselves in the water unexpectedly. Asking this panicking person to find and pull a ripcord is asking to much.
davej14 posted 05-21-2012 12:17 PM ET (US)     Profile for davej14  Send Email to davej14
Dave S,
A couple of years ago auto-inflatable vests were introduced that work with hydrostatic pressure. They are more expensive but eliminate the possibility of an inadvertent inflation due to undesired water encroachment to the dissolve-able "pill", as you call it. Here is a link to one:
[urlhttp://www.mustangsurvival.com/recreational/hit%E2%84%A2-inflatable-pfd[/url]
For those operating in cold water be sure to get one with a lifting "D" ring.
6992whaler,
Please provide some supportive evidence for you statement below, I have never seen this design criteria or recommendation before:
"Auto inflate or manual inflate, either way these PFDs are designed to be used only by very competent swimmers."
davej14 posted 05-21-2012 12:36 PM ET (US)     Profile for davej14  Send Email to davej14
Fixed the link typo:
pcrussell50 posted 05-21-2012 01:07 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Tough to tell from the pic what kind of motor it is, and from skimming the posts to date, I didn't catch it, but at least one of our more esteemed members has cited concerns about top-heavy newer motors, (four strokes), and their contribution to rollover incidents in classic hulls which were designed and sea-trialed before such monstrosities existed. Disclaimer: I have such a monstrosity on my classic 17 too, so I'm hardly throwing stones in my glass house.
-Peter
Dave Sutton posted 05-21-2012 01:37 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"A couple of years ago auto-inflatable vests were introduced that work with hydrostatic pressure"
Thank You!
Methinks you just cost me money...
The lifting ring comment is right on: We always insist on them. The SOSuspenders I carry now aboard also have crotch straps so you do not slip thru the vest if you become too weak to hold it on.
Dave
6992WHALER posted 05-21-2012 02:38 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
OK, The easiest place to find the info is in the owners manual for my Mustang Survival MD3003 Inflatable PFD page 1.
"Not recommended for non-swimmers or weak swimmers"
If I had the motivation I am sure I could look up some other sources to support my statement.
Doing a training with the local water patrol we had one deputy jump in the water and his vest did not inflate. Apparently he did not go deep enough to set off the Hydrostatic valve. When he jumped in the second time the vest inflated.
The moral of the story is make sure you know how to pull the rip cord and make sure you also know how to inflate it by mouth.
6992WHALER posted 05-21-2012 02:50 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
If you hit the mustang link above and open up the owners manual of the unit being discussed there, pg two in bold print "Not recommended for non-swimmers or weak swimmers".
These really are special use PFD, they are not meant for kids, they do not count as a PFDs for required equipment unless they are actually being worn.
I think they are great because they are getting more people to wear life jackets, but they are not meant to replace the more traditional life jackets for most people.
davej14 posted 05-21-2012 03:21 PM ET (US)     Profile for davej14  Send Email to davej14
Dave S.
I noticed on the Mustang Survival website they are now saying that there is a new "membrane" technology. I didn't research it but you may want to check it out before you spend you money.
Sorry about the cost, but that's half the fun, LOL.
davej14 posted 05-21-2012 03:59 PM ET (US)     Profile for davej14  Send Email to davej14
6992 Whaler,
I will concede your point to a limited extent. Forgetting the legal disclaimer stuff from the manufacturer, the USCG also does not recommend inflatable vests for non-swimmers and infants while at the same time stating that the most important factor in life vest safety is that you wear one. Go figure that double speak.
We can agree to disagree on the following:
1. Inflatable vests are not "designed" to preclude anyone who can get a proper fit, swimmer or non-swimmer, size of the person, makes no difference.
2. I enjoyed your comment that "they do not count as a PFDs for required equipment unless they are actually being worn". I suggest that having an inherently buoyant vest that is not worn may not help you much either.
3. Inflatable vests are designed to be a suitable replacement for inherently buoyant vests. In fact they have 25% to 35% more buoyancy than same class inherently buoyant vests.
4. You need to do proper maintenance and inspection to make sure the auto-inflate mechanism is "armed and ready". Since the hydrostatic type of mechanism is designed to trigger in 4" of water depth, immersion depth should not be a factor.
My main purpose in this long response is that I wouldn't want other boaters to eliminate an inflatable vest because they thought they were only for strong swimmers. At least we can agree that wearing a vest of any type is far better than just having it on board.
Safe boating to all.....
6992WHALER posted 05-21-2012 07:30 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
davej14
I can agree to disagree, but I do find it interesting that you are totally disregarding the recommendation in the owners manual to be meaningless legal speak. I think it is an important safety issue if the life jacket manufacture says don't use this type of life jacket if you are a weak swimmer.
Mustang apparently did not feel they needed to include this warning on any of their non inflatable life jackets. At least I could not find any such warning on there web site.
My concern is that people are putting these life jackets on and thinking they are safe when in reality they do not have the skills needed to inflate the PFD if they end up in the water in an emergency situation. That old false sense of security thing.
domlynch posted 05-23-2012 07:24 AM ET (US)     Profile for domlynch
Dave,
Yeah, the elephant is a big one - you and I both know we have been there - I have experienced it a fair few times......I'm not ashamed to say I didn't feel great looking UP at water in front and behind, hardly a boat length apart. (every small boater's nightmare I think)
Thanks for your comments/description of the seaworthiness of the classic Montauk (I'm relatively new to mine - but I'm very impressed with her so far). ((The tracking, especially when running up behind a yacht and then overtaking them at a shallow tangent (ie almost parallel) off their wake, without any hint of broaching/slewing unnervingly off line - says a lot to me)). I have only driven mine a few hours - but that was more than enough to have a good sense of her general seaworthiness - basically very seaworthy in my estimate - with skill, experince, and care of course.
Your point that most people are not experienced in bad conditions is IMO also absolutely right on. It is hard to get that experience. What I have learned re boat handling techniques in rough weather comes firstly from being out with others (generous enough to impart their knowledge) and then having been caught offshore numerous times in unforcasted and unforseen weather. If you spend a fair bit of time offshore, close or far, you will get caught out in bad conditions - no matter what the forecast. It pays to be ready for that. At least I knew the fundamental principles of smal boat handling and put them into practice - and got home. Knowledge truly is power.
It is hard to get the chance to learn, practise & gain genuine experience in such conditions - as most boaters don't plan on getting out in them ..............a course (eg Coast Guard) in the principles of boat handling in rough weather would be good for all who plan on going "outside" (in the ocean, either sometimes or often). Then, when confronted with bad conditions (even for the first time), at least small boat skippers have an idea of what to do.
Dom
lizard posted 05-23-2012 11:06 PM ET (US)     Profile for lizard  Send Email to lizard
Dave Sutton- you are incorrect. See Dave 14's comment about the auto inflaters"
"The other mechanism uses the pressure of the water immersion to release the pin."
Also, it is not Alka Seltzer that is used, it is a generic baby aspiring, according to the staff at West Marine.
6992Whaler- it is NOT a Mustang designation about the need to "wear the vest to have it count" that is a USCG requirement for labeling and use.
I can tell you this, once we went to inflatable vests, NO ONE balked about wearing one. Low profile, light, thinner, no bulk AND greater greater lbs. of buoyancy.
6992WHALER posted 05-24-2012 10:40 AM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
lizard
"6992Whaler- it is NOT a Mustang designation about the need to "wear the vest to have it count" that is a USCG requirement for labeling and use."
When did I say Mustang had the power to write rules and regulations? Of course that is a Cost Guard regulation.
"I can tell you this, once we went to inflatable vests, NO ONE balked about wearing one. Low profile, light, thinner, no bulk AND greater greater lbs. of buoyancy."
That is fantastic, I think it is great that more people are wearing these devises, but you are missing the point, if you do not know how to use it or are not a good enough swimmer to be able to use it, just wearing will do you no good.
newt posted 05-24-2012 12:30 PM ET (US)     Profile for newt  Send Email to newt
I used to own and wear an inflatable life vest, but then decided I did not want to trust my life to a device that could fail and also needed to be updated with a new cartridge every so often. Then again, I don't always wear a life vest...so maybe I have shot myself in the foot.
Binkster posted 05-24-2012 12:58 PM ET (US)     Profile for Binkster  Send Email to Binkster
In Florida where I have boated for 43 years, I can't recall a group of people out boating where everyone was wearing a life vest, blow up or standard. Mostly, the water is warm and the air is hot. If I ever see a boatload of jacketed boaters can I assume its Lizard @ company? On the other hand, when I boat alone, I wear sometimes I'll wear my blowup life vest.
rich
elaelap posted 05-24-2012 01:27 PM ET (US)     Profile for elaelap  Send Email to elaelap
Good for you, Rich. Nobody gets in my Whalers or my sailboat without a PFD, at least on the ocean, no matter the weather. Call me a wuss, but that's the way it is.
Tony
davej14 posted 05-24-2012 02:16 PM ET (US)     Profile for davej14  Send Email to davej14
Same here Tony. You cannot foresee the circumstances where a life vest is needed so it doesn't make sense to me that you would not wear one. You may be unconscious or unable to reach the life vest drifting away from you or caught under the boat. We have had a few tragic hit and run incidences here leaving the victims in the water without assistance. There is also the possibility of a seizure of some sort. To each his own but on my boat if you want a ride you must abide.
JMARTIN posted 05-24-2012 02:26 PM ET (US)     Profile for JMARTIN  Send Email to JMARTIN
Accidents happen. They took a very sea worthy boat and made if fast to the bottom. A big no no in bad conditions.
My PFD which will get tested this weekend and recharged. It's been two years since the last test/recharge.
Lizard, there is a baby asprin under the word "Lot" for comparison to what dissolves to charge my PFD.
http://i34.photobucket.com/albums/d137/jmartin-/DSCF0151.jpg
John
kwik_wurk posted 05-24-2012 03:19 PM ET (US)     Profile for kwik_wurk  Send Email to kwik_wurk
Life jackets are required on my boats (power or sail) in open ocean or similar waters. Same is true when racing (sailboat), or when boating solo. -- Now there are stand-down times, when crew does not need one, but as skipper I always wear mine. (As with the crew I keep, it may take awhile to figure out I am overboard, and even longer to decide if they should turn around.) -- I relax the rules on summer lakes where you can swim to shore or warm waters.
But binkster's comment, makes sense. Florida leads the country in boating accidents and deaths, both in gross total and per capita of registered boats. (From my 2010 info, don't have anything newer.) -- So keep it up Florida, local law enforcement agencies love to have new dive gear and reasons to use it.
gusgus posted 05-24-2012 03:42 PM ET (US)     Profile for gusgus  Send Email to gusgus
ATGATT, is a word I have used for many years while riding my motorbike. It means to ride for the crash, not the ride. So it makes sense that it would be a good word for boating safety too.
ATGATT=All The Gear, All The Time.
Binkster posted 05-24-2012 05:02 PM ET (US)     Profile for Binkster  Send Email to Binkster
If I was forced to wear a life jacket in 95 degree weather I would take it off jump overboard just to cool off.
rich
lizard posted 05-24-2012 08:13 PM ET (US)     Profile for lizard  Send Email to lizard
If I had a dollar for every boating accident that I read where the folks who died had PFDs on board but weren't wearing them, I'd be retired. My boat is no jacket, no boarding and I am not interested in discussing it with anyone who balks. Common sense.
newt posted 05-24-2012 09:08 PM ET (US)     Profile for newt  Send Email to newt
To paraphrase the local harbor master " I've never recovered a drowning victim who was wearing a life jacket"
For me, It depends on the circumstances. When out alone or with the kids I usually wear one. In nice weather with other adults, not so much. I do have good life insurance though and I grew up in NH. Live free or die.
lizard posted 05-24-2012 11:49 PM ET (US)     Profile for lizard  Send Email to lizard
NEWT- I also grew up in one of the 13 original colonies, but times have changed. They did not have boats with props that did 40 mph.
I will steal your paraphase, for something I heard a GAZILLION times in my trauma center days, by a highway patrol cop-
"I have never unbuckled a dead man". Well the fact is, they do. We have a burn unit full of people in seatbelts. Every other passenger in the car died because they were ejected. Frankly, I think ejection death is far better than surviving 3rd degree burns on 87% of your body.
At the end of the day, after 3 decades in this field, I opt for seatbelts and PFDs. Most people here will never be confronted, with seeing the outcome of either.
17 bodega posted 05-25-2012 01:06 AM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
In addition to discarding your chosen PFD while boating, you forgot to mention stepping up your blood alcohol level somewhere north of 1.0 so that your ability to swim is enhanced.
gnr posted 05-25-2012 09:10 AM ET (US)     Profile for gnr
I'm impressed Lizzy.
You resisted the urge to turn this thread into yet another of your soapboxes for almost an entire week. In the end though, you didn't let us down, as can be expected.
As can be expected you didn't own up to being called out on your complete misunderstanding of another member's comments and the subsequent lecture you gave that member. Once again not letting us down.
Comparing Connecticut to New Hampshire? Really?
LOL!!!
gusgus posted 05-25-2012 12:58 PM ET (US)     Profile for gusgus  Send Email to gusgus
Aren't they the same place? From the left coast, they seem even further left than us.
fishgutz posted 05-25-2012 01:40 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
I find it ironic and somewhat hypocritical that members here extol the virtues of an unsinkable foam filled hull, yet will don a hollow tube of perhaps permeable and puncturable material and rely on a mechanical device to possibly inflate it.
Binkster posted 05-25-2012 01:44 PM ET (US)     Profile for Binkster  Send Email to Binkster
What to you call a resident of Conn. A Connecticutian? Whatever, I think most of them are former NYers who moved to Jersey, were ostracized, and then followed others like them to Conn. Somewhat like the Scotch Irish deal in England.
rich
Binkster posted 05-25-2012 02:01 PM ET (US)     Profile for Binkster  Send Email to Binkster
comment from Lizzy as to "her" requirements for wearing life-jackets full time aboard recreational boats.
"They did not have boats with props that did 40 mph."
So I am OK not wearing them in my 13 footer with a top speed of about 29mph. What a relief.
Also, Liz, if you were to take a cruise on a cruise ship, would you bring your inflatable life jacket along, and wear it when your ship is underway. Would like a truthful answer, I don't think you would, even though the recent cruise ship sinkings/crashes have shown us it could be somewhat dangerous. I think you would submit to peer pressure, from other passengers.
rich
Dave Sutton posted 05-25-2012 02:46 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"I find it ironic and somewhat hypocritical that members here extol the virtues of an unsinkable foam filled hull, yet will don a hollow tube of perhaps permeable and puncturable material and rely on a mechanical device to possibly inflate it."
Yet military pilots do it all the time: You ever try to swim with steel toe leather boots, flightsuit, winter underwear, helmet, survival vest (all 50 pounds of it), and all of the other crap that we wear? Added to all of that is a LPU, or "Life Preserver Unit", which is... (drumroll please) nothing but a glorified inflatable vest, and not hugely different than the better quality ones available at your local West Marine.
I've floated with all of that crap on for a few hours once a year in training since I was a pup... and they always work. And let me tell you... they make us swim for a minute before we are allowed to inflate them, and you do NOT want to try treading water without one for long.
I wonder sometimes if people check their intellect in at the door here at times. What a recitation of nonsense above. Inflatables are "work jackets": They are not designed for long term at-sea survival, they are intended to be of benefit and to be worn continuously without interfering with crew duties. They are not a Type 1 offshore PFD. But they WILL save your ass far better than a doggie-paddle after you fall overboard one day. The best lifejacket is the one you have on at the moment. Inflatables are a very good bridge between nothing and a jacket that you simply cannot wear and work in.
The "since it's not perfect I'm not gonna wear it at all" routine is just stupid noise. And I think we can all tell the difference between a cruise ship and a low freeboard skiff. All things need to be done with a good solid dose of common sense. Sadly... it's not that common.
Dave
fishgutz posted 05-25-2012 03:06 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
My point exactly, except I wouldn't have "in" in the quote.
6992WHALER posted 05-25-2012 03:38 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
I think your post Dave, completely supports my position that inflatable PFDs should only be used by competent swimmers who are trained to use them.
If you practice using one every year and have to be able to tread water for a minute fully clothed and then some. You are a competent swimmer who is trained to use this a piece of equipment.
My concern is that we hand a guest on our boat an inflatable vest and say this is your lifejacket. The guest has no idea how to use it, may not be a good swimmer, but now they are safe because they have this inflatable PFD on. Then something goes wrong and they find themselves in the water. They have to treat water while they overcome the urge to panic and they have to figure out where the rip cord is and how to pull it. I think this person would have been a lot safer if we had put them in a traditional lifejacket.
Let's be honest how many of us have pulled the ripcord and tested our PFD in the water. I know I am to cheap to waist the cartridge. How many of us have followed the 2 pages of maintenance every year that goes along with these PFDs. They just are not as simple as a standard PFD.
I love mine, but I do not hand it to anyone I do not trust in the water. And trust me I do not trust many people in the water.
So again let me say that I think it is great that more people are wearing PFDs because of the inflatable option, but they should not be used by everyone.
Binkster sorry but I have to say it, boating in Fl is not an excuse not to wear a PFD, look at your local law enforcement out there in those polyester shirts and body armor, they wear their PFDs. So just be honest like me, I do not always wear a PFD because I do not like wearing them, and they screw up my tan.
fishgutz posted 05-25-2012 03:49 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
I go by the bass anglers rule. When the big engine is running the vest is on. When pulling up the anchor or doing any other physical activity the vest is on. When sitting and/or fishing it is sometimes or most times off. Often we lay around in the water with our vests on. Quite relaxing.
Dave Sutton posted 05-25-2012 04:16 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"My concern is that we hand a guest on our boat an inflatable vest and say this is your lifejacket. The guest has no idea how to use it, may not be a good swimmer, but now they are safe because they have this inflatable PFD on. Then something goes wrong and they find themselves in the water. They have to treat water while they overcome the urge to panic and they have to figure out where the rip cord is and how to pull it. I think this person would have been a lot safer if we had put them in a traditional lifejacket."
I can't disagree. Then again, I've never invited Grandma to go out into the white water of The Race... For that I have a 42 foot Grand Banks... ;-)
Come to think of it, I've never had incompetent swimmers aboard the 'Tauk. It's not a boat that lends itself (in my use) to casual sightseeing by noobs who don't have previous boating & diving experience. Anyone who looks for a seat rather than naturally knowing to stand next to me with their knees bent isn't a 'Tauk-Ride candidate.
Dave
skinnywater posted 05-25-2012 04:22 PM ET (US)     Profile for skinnywater
Good Rule of Thumb - The order of "vest on" is given long before the call of "fish on" will ever be heard......
boatdryver posted 05-25-2012 04:56 PM ET (US)     Profile for boatdryver  Send Email to boatdryver
Just so the person is informed and understands the risk, and still decides not to wear a PFD, maybe its not such a bad thing.
After all, this planet is getting awfully crowded.
Now, the people who are really doing society a bit of a favor are those sport bike folks who ride super-aggressively on curvy two lane roads on weekends. Such a great source of organ donors....
JimL
Binkster posted 05-25-2012 10:49 PM ET (US)     Profile for Binkster  Send Email to Binkster
Drunks should be wearing life vests. The resto fo us will be OK without them, unless the weather turns bad.
lizard posted 05-26-2012 12:43 AM ET (US)     Profile for lizard  Send Email to lizard
Let me be clear- I think people who object to wearing PFDs while aboard a boat, are cocky, Darwin want to be's, not thinking, educated people. They are evolutionary discards.
I disagree that poor swimmers are not candidates for auto inflate PFDs. They AUTO INFLATE. For the manual inflate PFDs, I always show the people wearing them the BRIGHT YELLOW, LARGE pull tag.
A conventional PFD does NOT keep your head out of the water the way any inflatable PFD does. Inflatables have higher buoyancy ratings and right your head better than conventional PFDs.
I am mystified every time this topic surfaces. If you simply look at CG statistics, nearly every, non-traumatic, boating death involves the absence of a PFD. How much more information do you need?
If you are too cheap to re-arm your auto inflate PFD every two years, for $29, I don't want to be on your boat. Cheapskate=numbskull. What other corners do you cut?
This topic is so beyond any realm of common sense or argument.
gusgus posted 05-26-2012 02:59 AM ET (US)     Profile for gusgus  Send Email to gusgus
When asked, "hey you wanna go fishing?" I always think, what if the boat sinks and I drown? What if?
The truth is no one spends much time worried about the risks, or we just wouldn't do it. The reasons are many, but it is not because we are "cocky" or brave, that we choose to go naked while fishing, It is because we don't want to wear a PFD, period. I am an adult, it is my choice, NO?
This entire thread is just like a gear thread on motorcycle forums.
A few people always seem to call people who don't want to wear the gear, names and yet it only makes the know it all's seem like they "just don't understand human nature."
When anyone rants about wearing helmets/PFD's or condoms, we learn that we just don't like being told what to do, especially by this person that now we just don't like. Causing an end of any worthwhile discussion.
How about we let people live the way they choose and risk it all, if they choose to? It is after all their hind ends. Their boats occupants are either at the mercy or the will of the captain anyway, what business is it of anyone else's, anyhow?
The Coast Guard and our laws already have laws and rules that cover all of these things. We sure don't want more restrictive laws, do we? There is already a law that says if you don't follow these laws and rules, you will pay.
Dave Sutton posted 05-26-2012 08:38 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"When asked, "hey you wanna go fishing?" I always think, what if the boat sinks and I drown? What if?"
Right On.
Which is why in my "Wanna go Boating?" grab-bag, I have my own inflatable PFD that goes on if I feel it's needed, as well as (sunsceen, hat, sunglasses, sweatshirt, long sleeve T shirt, foul weather jacket, snickers bar, and a few bottles of water). If it's cold I bring my Float Coat.
The PFD is one with a lift ring and crotch straps. On it is a McMurdo Fastfind PLB, a strobe, and a knife. I would use it LONG before I would put on the $14.95 Walmart Type II PFD's that are usually found on small boats.
Dave
gnr posted 05-26-2012 08:40 AM ET (US)     Profile for gnr
Lizzy sez: "A conventional PFD does NOT keep your head out of the water the way any inflatable PFD does. Inflatables have higher buoyancy ratings and right your head better than conventional PFDs."
Are you sure about that lizzy?
Just so happens it is time for me to replace a couple of my pfd's. I just looked at every inflatable vest on the Mustang website and the highest rated inflatable I saw was a Type II with most of them being type III. Some were type V with either type II or type III capabilities.
More evidence that you really don't know what the hell you are talking about more often than not.
You do realize that you have called every member of this forum who has posted a picture of themselves and their friends, wives, relatives etc "cocky, Darwin want to be's, not thinking, educated people. They are evolutionary discards."
Do you not see the incredible irony in that?
This coming from someone who doesn't possess the most fundamental level of common sense which would allow her to realize that a foam filled container full or air (ie a cooler) might just be a valuable aid to floatation in an emergency situation.
Lizzy, You are all the proof necessary to illustrate that education does not equal intelligence. I would never step foot on any boat with you at the helm simply because you just don't get "it". All the safety precautions in the world can't always overcome a complete lack of understanding and common sense.
Sincerely, an evolutionary discard.
LOL
Dave Sutton posted 05-26-2012 09:43 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Just so happens it is time for me to replace a couple of my pfd's. I just looked at every inflatable vest on the Mustang website and the highest rated inflatable I saw was a Type II with most of them being type III. Some were type V with either type II or type III capabilities"
They definately vary in capability, but by definition none will be "rated" as Type I, although they might do the same job as far as an unconcious person is concerned.
There is a huge difference between something like this, and the basic cheapie that you buy at West Marine:
http://www.landfallnavigation.com/bodyharness.html
BTW, I don't consider Mustang to be the end-all in this category of device.
Social Comment:
What ever happened to polite civility, as well as common sense? There's a huge difference between a sunset cruise on the river when it's 75, the water is flat calm, and the water temperature is 72 and running a Montauk thru the surf up in Rhode Island, in March, when the water temperature is 55. In one case I'd take Grandma, sit her on the RPS facing backwards, and never worry about PFD's. In the other case I'd be in a wetsuit, and also have a lift-harness inflatable with PLB and stobe fastened on and secure. If folks are not able to understand the differences, they ought not be boating.
The ability to understand that there is a variety of environments, and not just "one way" and "one place" is part of being an intelligent thinker. The choice to be respectful of other environments and choices and experiences is part of civil discourse and debate. There is much to learn from others. I'd respectfully challenge those here to raise the level of the discussion out of the sandbox.
Dave
davej14 posted 05-26-2012 12:24 PM ET (US)     Profile for davej14  Send Email to davej14
GNR, why the personal attack on Lizzy ? It seems like there is something else going on here than a civil discussion of life vests.
Be that as it may, since an inflatable vest can easily be found with 35# and 40# of bouncy, can you provide one example of a type1 with even an equivalent amount of buoyancy ? I think the inherently buoyant vests are limited to around 25# or so.
I suppose I may now be attacked also.
Back to the original thread for a moment. Does anyone know why the drowned victim was not able to inflate his vest ? I was hoping there would be a follow up.
Safe holiday weekend boating to ALL....
Binkster posted 05-26-2012 01:43 PM ET (US)     Profile for Binkster  Send Email to Binkster
Dave, your comment said it all. I thinks that's what some of us were trying to say, but we didn't. Where I boat on the west coast of Florida, on most days especially in the summer, the winds are calm and the Gulf is flat calm. I'm always back at the dock before the afternoon thunderstorms start up.I don't go out in the winter usually becuase its always windy. The boating season is so long, we can pick out days. Up here, north of Tampa its 4-5 feet deep 2 miles offshore. Sure, the waves build up in that shallow water, when the wind kicks up, but you won't see me out there. I used to grouper fish off Ft. Myers, 20-30 miles offshore for most of the 30 years I lived there, same thing, in the summer the water was flat calm, we were back at the dock before the afternoon storms kicked up. I can remember only a couple of times we had to drive around them. If we ever got caught in one we would have life jackets on. I was/am careful who I fished with too, If I didn't have confidence in that person, I wouldn't go. I would never step on Lizzy's boat for the same reason that GNR states. Same goes for anyone who proudly states you have to put on life jackets first before you step on board, even if it was a canal cruise. I would be thinking, there must be a reason for that, I'll probably need it, so I'll stay ashore.
fishgutz posted 05-26-2012 03:36 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
I think one of the big differences is I am in a 14 foot boat that goes pretty fast. There is no room to stow PFDs so just put it on.
lizard posted 05-27-2012 12:39 AM ET (US)     Profile for lizard  Send Email to lizard
I NEVER boat in the conditions that Pinkster outlines. I am always offshore, east or west coast. The water I am in rarely hits high 60's. I don't need some warm. waterway, person, to tell me what is required in the waters I boat in.
FYI, I don't care who cares to boat with me, especially the manly hero in VT who shoots fish from trees. Nor do I care about speedy Pinkster. I don't boat in the regions that you do.
I have said it a thousand times, IF YOU DON"T EXPECT ANY RESCUE, go out as ill prepared as you want. IF YOU EXPECT ASSISTANCE, take simple steps you ensure your possible survival. OR- become a Darwin award.
What do you hope to prove, with your ill prepared machismo, anyway?
gnr posted 05-27-2012 02:54 AM ET (US)     Profile for gnr
davej,
It is curious that you feel obligated to call me out but seem willing to ignore lizzy's attacks. Why is that?
Please reread the quote I responded to regarding lizzy's specific claims about the capability of an inflatable pfd. The fact is the Mustang pfd's do not meet the USCG's type I rating and do not provide the same head out of water support that a USCG rated type I pfd would. You can argue this with the United States Coast Guard if you wish.
Lizzy, I'm curious. How do you define, "offshore"?
Dave Sutton posted 05-27-2012 09:13 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"The fact is the Mustang pfd's do not meet the USCG's type I rating and do not provide the same head out of water support that a USCG rated type I pfd would"
A few points:
(1): Inflatables are *not eligible* to be classified as a Type I PFD... so you will not find them so rated. That's likie looking for a Chicken marked as Grade-A Beef. ;-)
(2): A well designed *high quality* Inflatable WILL provide the same head out of water support of an unconcious person as a Type I. They are just not going to be "Rated" as a Type I due to the fact that they do not meet the technical description of a Type I. Ask any Navy Trained Pilot how his inflatable held him up in training: They keep the pilots head out of the water *while wearing over 75 pounds of survival gear, steel toe boots, and while wearing a helmet*. You can take this from me as a fact... I've been there, done that.
(3): I have never seen a Type I PFD carried on a Boston Whaler. Have you ever REALLY looked at one? Trust me.. you don't have the stowage space for them (I have 15 of them on my offshore dive boat, and they are HUGE).
(4): ALL open Whalers that I have ever seen are equipped with Type II PFD's. If you are the exception... you are the exception. Any GOOD (meaning not the cheapest one at West Marine) inflastable will outperform the common Type II vest with ease.
(5): Most people ACTUALLY USE an Inflatable as a substitute for a Type III, meaning that they are WORN and not simply carried, when engaging in activities that might result in inadvertant swimming. When boating solo, when entering or exiting an inlet with breakers, etc.... activities that are badly hampered or made impossible by wearing a "rigid" PFD. Try crewing a racing sailboat in a standard PFD sometime. All of the offshore racers wear inflatables.
(6): In my experience, I have never seen anyone *substitute* inflatables for their required PFD's. Everyone I have seen using them carries them IN ADDITION to the Type II's that are stashed here and there. They are generally *additional inventory* and not *substitute inventory*.
(7): MOST sinkings take place so fast that getting your Type II out of it's stowage is impossible. The bottom line regarding your Type II is that if it cannot float free *without any action being taken by the crew* then it's going to go down with the ship. Most stowages preclude this. An Inflatable that is worn, or tossed on the console, is far better than a foam one that is sitting on the bottom inside the center console of your sunken boat.
(8): In fact, boating practices and activities vary from day to day, and from hour to hour. Use of good sense and judgement is essential. Here's a hypthetical summer day on my Montauk up in Rhode Island. Solo run down the absolutely calm salt pond to pick up a dive buddy: I wear my vest since I am solo (as well as my wrist cord for the cut-off). I pick him up and we then run on the same salt pond to the inlet: I shed my vest because it's getting hot and I have a buddy to help me if I fall overboard "checking the transducer" or whatever, but I leave it laying on the console if needed. We reach the inlet and it's breaking waves for our penetration out: We lay to, get into our wetsuits (since we are going spearfishing anyhow), and both of us drop our inflatables on over the top. After we clear the inlet and run offshore we shed the vest when we feel like it, and are in our wetsuits. We fish all day, come back to the inlet, things have settled down, so we just stay in our suits. We run to his house, clean fish, and pick up his 6 year old son, 8 year old daughter, and his wife for a sunset cruise. Both of the kids go into normal Type III vests and the rest of us are in shorts and T shirts. We get to the place where we anchor, want to swim, all vests come off, and we jump into the water with bathing suits on and enjoy the day. But... as we are running back wit the kids wearing their Type III's and the adults in T shirts and shorts, we are stopped by our friendly Coasties, who ask to see our vests. I don't even bother to show them the inflatables, I just open the cooler forward of the console, and show them the 4 Type II vests that are stashed there for emergency use. The Coastie running the boarding comments as to how most folks need to fish under the center console for them, and in fact last week a guy had them LOCKED into his center console and had forgotten the key in his truck. I show him that the latch of the cooler has been removed so that the vests have a good chance to float free if we sink... he smiles and we go on our way.
In one very typical day we have used every tool in the box. If you do not know how to "roll with the punches" then all's lost. The key is to having the right tools, and knowing when to use them.
Dave
fishgutz posted 05-27-2012 09:34 AM ET (US)     Profile for fishgutz  Send Email to fishgutz
The facts remains, a person died while wearing an inflatable PFD that FAILED.
Dave Sutton posted 05-27-2012 09:53 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
(1): You don't have any clue if it "failed".. you just know he did not survive the mishap. There are 100 ways to drown in the water with any PFD you wear. All they do is to increase your chances.
(2): Nobody but kids are boating with Type I or II PFD's being worn while fishing... a worn inflatable is better than a stowed foam vest.
(3): By your logic, would he have been better off WITHOUT an inflatable? There certainly were normal vests stowed aboard, are you suggesting that his inflatable *prevented him* somehow from getting his "real" vest out of stowage? Of course not... he mishap was a "bolt of lightning" sinking. Instant and catastrophic. You are going to go into the water with EXCTLY what you are wearing at the moment. Better with "something decent on" rather than "something perfect stowed and inaccessable".
I suspect that you don't actually use this stuff too often... so you might want to listen to others who have experience levels that support their reasoning. Having (A) had a boat sink out from under me with 30 seconds of warning we had PFD's stowed in the under T-Top nets.. and had no time to get them..) I can tell you that if it's not on your body or in your pockets, you are not going to have it when you get rolled over or your transom goes down as you try to pull up a pot.
<sigh>
I'd like to modify what I wrote above though: It appears that the USCG has now written the specifications to permit Inflatables to be certified as Type I and Type II, but that no manufacturers have certified them. There is a very good chart here, and a good discussion of the pro and con of different vests. Good simple read. I agree with the conclusions.
http://www.boatsafe.com/nauticalknowhow/pfdbasics.htm
Dave
L H G posted 05-27-2012 10:07 AM ET (US)     Profile for L H G
Since 1986 when I first bougth my 18 Outrage, I carry two Type I's in the bow locker of all of my Whalers. Most often, there are only two of us in the boat. Two fit nicely in there. Yes they are expensive and bulky, but for the very few times I have been in conditions bad enough that I have felt compelled to put them on, you realize they are what you would want if you end in the water Offshore in the Great Lakes or Atlantic. But if you are boating in water less than 80 degrees, hypothemia is still your greatest risk if you don't get rescued fast. I know someone who died in about 8 hours while floating in a Class I in 72 degree water in Lake Erie.
Binkster posted 05-27-2012 10:53 AM ET (US)     Profile for Binkster  Send Email to Binkster
If you are inspected by the coasties, inflatables, only count if you are wearing them. If I'm going fishing solo, which I seldom do anymore, I wear my inflatable.
As Dave says its conditions that dictate wearing or not wearing a pfd. I never wear a cutoff lanyard in my 13 Whaler. I would say it would be impossible for me to be thrown overboard when driving the boat, and I am not stupid enough to move around in the boat with the engine in gear even idle speed.
rich
gnr posted 05-27-2012 11:42 AM ET (US)     Profile for gnr
Dave,
That link you posted does not make a very convincing argument for inflatables over a good type II. Assuming either will be worn of course.
I am not trying to knock inflatables at all. I value your experience with them and am going to purchase a couple myself to be used by extremely cautious passengers or by myself and my fishing partner during our winter fishing adventures when PFD's are mandatory when we cross the line into New York waters. I may even slip one on when not mandatory if conditions dictate. I will also carry the four type II's that I always carry, two in the cooler and two velcroed to the console stanchions.
I still don't think that any of this changes the fact that the USCG has not rated these things as type I and as such it cannot be assumed that they will perform like a type I, despite lizzy's claim that they will. Who are we to argue with the USCG?
That sure sounds like one hell of an exciting day on the water. I am envious.
fishgutz posted 05-27-2012 12:07 PM ET (US)     Profile for fishgutz  Send Email to fishgutz
Dave, it FAILED to inflate and save. A PFD made of foam can't fail to inflate. Seems pretty simple to me.
Binkster posted 05-27-2012 02:29 PM ET (US)     Profile for Binkster  Send Email to Binkster
Has anyone else used/tested their inflatable pfd? One of the ones I have is type V Sospenders brand. I bought it new on E-Bay. It has a factory applied US Coast Guard Auxiliary patch sewn on from the manufacturer. Couple of reflectors also. It also has a manual pull to inflate handle on it. It has a manual inflater, and a pocket with a spare cartridge too. It seems very well made. I guess When I bought it I thought I might as well see how/if this thing works. It also has a manual pull handle if the automatic device doesn't work I thought it was worth the cost of a new cartridge, for the experience.
So I jump in a swimming pool. The thing went off with a loud bang, I think before I was fully submerged. It was almost startling. The collar wrapped around my neck and side of my face, pushing my cheeks in. No way I could drown, I thought, but is was very confining. If someone else was in the water and needed help, I don't know If I could help them very much. I had little perifial vision. It was difficult to get off my back untill I deflated it somewhat.
I would rather use the work life jacket used by the Navy/Coast Guard. I never needed one. My work station was in the engine room.
Try yours, so you get the experience. Its not like a water toy.
rich
gusgus posted 05-27-2012 03:19 PM ET (US)     Profile for gusgus  Send Email to gusgus
This is the best update I have read as of today. It sounds like the older gentleman was unable to inflate his floatation devise with waders on, being drug under and was busy trying to fight for his life. His vest most likely didn't fail, it seems he was simply unable to give it the attention needed to find the cord and inflate the vest.
Sad,, but in a morbid sense, the good part is the realization that sometimes fear and that instant life struggle over burdens the brain with a "fight or flight" survival reaction, even with a better method within your grasp ignored.
http://www.thenewstribune.com/2012/05/19/2150900/ whatcom-county-man-identified.html
Dave Sutton posted 05-27-2012 04:31 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Dave, it FAILED to inflate and save. A PFD made of foam can't fail to inflate. Seems pretty simple to me"
(1): A foam PFD helps you ONLY IF YOU WEAR IT.
which precedes:
(2): NOBODY that I know WEARS a foam PFD as a matter of course. Every try working in one?
(3): Obviously, if it failed to inflate it was not correctly maintained. That's not the fault of the vest.
Basic observation: Two out of three aboard were saved by their vests. If they had only foam vests aboard, my bet is that not one of them would have had them on, and all three would have drowned.
LGH: Good for you keeping a pair of Type I's in your locker. That's the right spot, and the best vests. I maintain over a dozen of them on my big boat, each with stobe, whistle, dye marker, and drogue. Three of them have PLB's attached. It's always a compromise: The better the gear the greater the cost and the greater the bulk.
Dave
gss036 posted 05-27-2012 07:39 PM ET (US)     Profile for gss036  Send Email to gss036
The discussion seems to have shifted from the original post.
I just happened to run into the guy who's shrimp pots was hung up and the guys were trying to help after the electric puller was broken. Quite a story, but the short version, the victim who died had a heart attack when he went into the water. Did not die from hypothermia as reported as he was only in the water about 5 minutes and was dead when he was pulled into the boat.
Dave Sutton posted 05-27-2012 07:41 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Dave, That link you posted does not make a very convincing argument for inflatables over a good type II. Assuming either will be worn of course"
The link was not to make any argument at all: I posted it as a reference to give an easy to understand chart as to what each type is best at, and what it's limitations are. Most people do not even understand the differences between classes of vests.
And... I think many have misunderstood that I am not advocating REPLACING normal vests with inflatables. I consider my inflatables to be SUPPLEMENTAL to my other inventory, to be worn *when appropriate*.
*Supplemental*
and
*When Appropriate*
are the operative terms.
Dave
6992WHALER posted 05-27-2012 08:38 PM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
When I made my original comment about inflatable PFDs not being recommended for weak or non swimmers:
I did not make it to tell people that they should or should not wear lifejackets. As an adult I do not begin to tell other adults on their own boat what to do. It is a personal decision, I am sad that members of this conversation started to insult people about their personal decisions.
I also think it is ridiculous for anyone to make an argument against the statement that wearing the proper lifejacket is less safe than not wearing one. Yes there are times I choose not to wear one, I am making a personal decision based on conditions and other factors to take the risk.
All I was doing is making sure that the people who read this post realize that inflatable PFDs are special use lifejackets that have some special limitations. I was and still am concerned that people are using these lifejackets without having the proper skills to use them.
If you are using an auto inflate lifejacket and everything works as it is suppose to then all is good no matter how good or bad of a swimmer you are. But if something does not work as planned a weaker swimmer may not be able to deal with being in the water and trying to inflate a lifejacket, either by ripcord or by mouth.
If you decide to use these lifejackets it is up to you, I would suggest that you read the manual and take the time to really figure out how they work before you need to make one work to save your life.
Dave Sutton posted 05-27-2012 08:58 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"If you decide to use these lifejackets it is up to you, I would suggest that you read the manual and take the time to really figure out how they work before you need to make one work to save your life"
Isn't that true for anything of this nature?
Even a basic Type I or Type II jacket requires training in order to safely don it, and even more so, to manage it in the water. How many folks here have actually tried their jackets in the water? My bet is a very small fraction. Type II vests of the sort bought at Walmart and West Marine will allow the user to slip down out of the thing and drown... unless you are actively holding onto the thing, I'd give a wearer about an hour.
Really...maybe untrained non-swimming granny-lady does not really need a ride in a small boat. One of the advantages of the 'Tauk is that only the brave come a second time.. ;-)
Dave
gusgus posted 05-28-2012 12:24 AM ET (US)     Profile for gusgus  Send Email to gusgus
You know how silly this entire argument sounds?
Who gives a Rats Patootie?
I could care less if you guys inflate these things in you backside, this is a not a lifejacket discusson, start your own argument thread!
This is and was about a whaler capsizing and a poor man dying.
Now it seems his heart stopped. Not his jacket failed.
Sad situation to watch a nice group fall into such peril after coming to the rescue of others. Sad indeed.
17 bodega posted 05-28-2012 01:56 AM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
I would disagree gus, because most lives are lost after a capsizing due to lack of life jackets. Coast Guard data is pretty solid here, especially in my locality.
Being an employee at a beach and boat launching facility, I will try to save a life every day that I work. Same goes for internet forums.
If this man died of cardiac failure, my heart goes out to his family, but I would hope the family would appreciate any efforts to save additional lives at sea.
As far as foam vs. CO2 operated PFD's, I would side with foam because of reliability... comfort is secondary.
Steve
pete r posted 05-28-2012 04:05 AM ET (US)     Profile for pete r  Send Email to pete r
When sailing in a dinghy or on small yachts when either in competion or rough water, we do not rely on inflatables.....
If you get hit by the boom or spinacker pole etc. you may not have your full factalties to realise your life jacket has not done what it's suppose to......
I don't have a problem with inflatables on power boats or large yachts
Jefecinco posted 05-28-2012 09:53 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Has it been established that the dead man was wearing an automatically inflatable PFD? Probably not but if so the PFD failed. If not he probably failed to pull the manual release on a non-automatic PFD.
I prefer and wear inflatable PFDs. I have an old manually inflatable and a new automatically inflated PFD. When out with my wife she gets the automatic. When alone I wear the automatic. I attach the engine kill lanyard under almost all conditions.
As a pretty safety minded person I'm always aware of which PFD I'm wearing. I also mentally rehearse various scenarios for going overboard. I've tested and rearmed both PFDs but have been unable to get the wife to test hers.
Our main reason for wearing PFDs in calm conditions is the possibility of hitting a partially submerged snag or a piling just under the surface and being bounced out of the boat at speed. Much of the waters in my area are unmarked or poorly marked with NAVAIDS.
Binkster posted 05-28-2012 10:16 AM ET (US)     Profile for Binkster  Send Email to Binkster
Dave sez,
Maybe the History Channel will do a reality show about your life. Sounds pretty dangerous and exciting. Your show could follow the one about morons baiting gators..;)
rich
Dave Sutton posted 05-28-2012 12:19 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Dave sez, One of the advantages of the 'Tauk is that only the brave come a second time.. ;-)"
Really: My test of a person in the 'Tauk is to see if they sit down on the RPS or (even funnier) on the forward cooler, and expect to stay seated while running.
Those that do... "are not boaters".
Those that stand... "are".
If they pass the "stand test" they get handed an Inflatable vest.
If they do not... they get handed a foamie, because they really probably ought not be be out on a small open skiff at all.
Dave
Binkster posted 05-28-2012 12:33 PM ET (US)     Profile for Binkster  Send Email to Binkster
Dave, can I be your director. For your opening show we can do a reenactment of the time you dumped the "tauk" hauling in a 40lb. fish you just speared. Only we'll use a bigger fish, so its more believable. How about a 150 tuna. They would really do a number flopping around in your "tauk", especially a green one you speared near its tail and manhandled to the surface.
rich, the director
Dave Sutton posted 05-28-2012 01:06 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
Real world here is enough without Tuna Fish.
This summer we do plan to run offshore to some of the sea buoys, to try to shoot the Mahi that lay in the shadows. Yes, we have Mahi (Dolphin, Dorado, whatever you want to call them) in RI, offshore naturally near the 'Stream.
We do also have tuna here, it's just that when they are chummed up to the back of the boat, they are always mixed with sharks... LOTS of sharks... and it's often at night. Jumping in with them snapping at chum is a little too entertaining even for me to consider. ;-)
(even though did rig a speargun last summer for it...)
End of segue... back to the topic at hand.
Dave
Binkster posted 05-28-2012 01:39 PM ET (US)     Profile for Binkster  Send Email to Binkster
Whoa, Daves comment(in RI, offshore naturally near the 'Stream.)
Not disputing that there might be some dolphin(fish) lurking around for the taking, but what "stream" are you talking about. The real one makes a NE turn about as far north as southern Jersey.
I've ridden the "stream" in a Coast Guard Cutter on a voyage from Baltimore through Cape Hatteras to Groton Conn. It was in December. When we reached the Gulf Stream off N.C. the weather turned warm and the the stream turned a dark cobalt blue. It was that way all the way to southern NJ with 75 degree air temp. We were over 200 miles offshore. At night you could see the Northern Lights. Never saw them from land. The ship continued north and the stream turned NE. The air temp dropped about 40 degrees when we left it.
Where can you pick up the "stream" from RI in a small boat?
As a charter boat mate on the south shore of Long Island I spent a few teenage years fishing for blue fish and big tuna and no one ever spoke of fishing the stream.
BTW, your tales are more interesting than this thread. I feel bad that the guy died from a heart attack, but in reality he died doing somthing he enjoyed. I knew a guy that died of a heart attack while driving a stock car. Really nailed the wall hard. Its better than dying in a bed from cancer, I think
rich
Dave Sutton posted 05-28-2012 03:46 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
"Where can you pick up the "stream" from RI in a small boat?"
We get eddies that come in close enough to influence the water here in the late summer, and in fact we get loads or small tropical fish in the shallows by late August: All sorts of damselfish, butterfly fish, etc. Fun for aquarium owners, and netting them in the shallows is a usual September game for many here. We shoot many Grey Triggerfish to eat starting about July 15th. It's a microclimate, and not a regular thing, but it does happen.
We use NOAA Infrared Spectrum satellite depictions to see what is going to influence the waters offshore. We get Loggerhead turtles, tuna, Mahi, and many of the "southern" fish starting about, oh... 30 miles off Montauk. That's just a normal 'Tauk run for us on a nice day.
I have not taken the 'Tauk out "alone" (yet) to the offshore buoys, but in years past on the way out to dive the Andrea Doria on my big boat, we have stopped at both the sea buoys and offshore lobster pot buoys to spear fish for dinner. The buoys act like shade does anywhere else: It attracts small fish that the big fish like to eat.
Just as an aside... we retrieved the bell of the Andrea Doria onto my big boat two summers ago. Two happy divers... and a measure of small fame for our group. I tow the 'Tauk offshore as a dive-tender.
If you want to see me strike 8 bells on the Andrea Doria ships bell for the first time since she sank, enjoy this:
http://pierdive.com/blog/page/2/
That was a good trip offshore...
My views of wearing vests, etc., are those gained by running boats into harms way, not puttering around the bays. My watchstanders at night as we run offshore in the big boat are required by me to wear jackets, and passengers are prohibited from the weather decks at night. During the day we are a bit more relaxed about it. In the Whaler they are an essential tool.
Dave
