  Cetacea page 66's Newport gets a facelift
Author Topic:   Cetacea page 66's Newport gets a facelift
Jeff posted 05-28-2012 04:03 PM ET (US)   Profile for Jeff   Send Email to Jeff
Back in December of 2007 I bought Jeff Holmes' Newport that was featured on page 66 of Cetacea. That winter I updated the boat a bit with all new wiring, I derigged and repainted the motor, installed new steering helm and cable as well as some other updates. The boat looked good but, I still wanted to make it better.
This past winter I decided to do a major update of the boat. I had Hall's Nautical make a new interior set for the boat. Since I have never been a huge fan of the Newport front bucket seats I designed and had them fabricate a new front seat that looks more like a Montauk Cooler seat cushion for the font to go with the Montauk Seat Back Rod holder and cushions I have installed on the console. I also had them make a new RPS cushion for the boat. The other updates I did was to remove the old mahogany console cleats and made new mounting cleats out of 2" aluminum angle. I then fastened the console to the cleats using screws with self locking nuts on the back of them. This way no matter how rough the water may get the console will never come loose again. I also removed all of the railing screws and thru-bolted all of the sanctions with the same self locking fasteners to prevent the railing from coming loose as well. The final step was to refinish the forward locker hatch as well as the Sapele mahogany RPS seat back I built.
All in all I am pretty proud of how "Hells Bells" is looking these days. The OEM cushions sure make a world of difference when in come to the level of appearance and class on a Classic Whaler.
Here are some images
http://smg.photobucket.com/albums/v427/jeff_rohlfing/ 1976%20Newport%2052812/?start=all
ConB posted 05-28-2012 08:26 PM ET (US)     Profile for ConB  Send Email to ConB
I like what you did with the front seat Jeff. She is looking good including the trailer and rub rail color coordination.
Con
dfmcintyre posted 05-28-2012 08:58 PM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
Jeff -
Count me in as a "like" on the forward seat. Is it removable for access to storage underneath?
Regards - Don
andygere posted 05-29-2012 12:29 AM ET (US)     Profile for andygere  Send Email to andygere
Jeff, the boat looks fantastic. Great job on the seatback, and the front seat design looks great.
Lionheart posted 05-29-2012 06:00 AM ET (US)     Profile for Lionheart  Send Email to Lionheart
What a beauty Jeff. Thanks for sharing.
lizard posted 05-29-2012 11:54 AM ET (US)     Profile for lizard  Send Email to lizard
Jeff- Awesome outcome and a clear labor of love. Great details. How did you polish the bow bit? Those Halls cushions do make "the" statement.
Wish I had some crew to help me wash the boat down!
Jeff posted 05-29-2012 05:22 PM ET (US)     Profile for Jeff  Send Email to Jeff
Thanks all...
Don, I designed and had Halls add the so it could hinge forward or mount to the existing holes that were there for the bucket seats. My goal is to build a custom vacuum formed kydex storage tray that is located under the cushion and adds some good line storage on the boat. That project as well as making the hinges for the seat bottom are going to have to be a winter 12/13 project.
Liz, I polished the bow bit back in 08 on a bench mounted grinder / polisher using a cotton jewelers wheel.
Binkster posted 05-29-2012 07:13 PM ET (US)     Profile for Binkster  Send Email to Binkster
Great looking job on everything. How did you polish the hull?
rich
L H G posted 05-30-2012 12:25 AM ET (US)     Profile for L H G
Beautiful boat, Jeff. That's the finest looking Newport I have ever seen, and I think the front seat design is exceptional, but still looks like it could be original.
The matchng year engine makes it a true classic.
jimh posted 05-30-2012 08:18 AM ET (US)     Profile for jimh  Send Email to jimh
I have always admired that NEWPORT, particularly for the harmony of the colors between the hull and engine. The red rub rail and the red stripe on the engine cowling are just a delight.
Jeff posted 05-30-2012 08:14 PM ET (US)     Profile for Jeff  Send Email to Jeff
Thanks Larry. Your comments mean a lot.
Jimh, I agree there is a harmonious aesthetic quality that happening with the interplay of colors on the boat. I often wonder what I would do if I repowered. A white motor would I think look the best.
Rich, The waxing / polishing of the hull is a multi step process to start out. I no longer believe in wet-sanding gel coat to start with. I believe that process removes far to much precious gelcoat thickness for one. More importantly, when you start removing the outer most layer of gelcoat you can expose porous areas of gelcoat. It is tough to see these while sanding but, the first time you way all that dirty wax gets into those tiny voids and it looks like there is dirt embedded in the gelcoat. Once in you can not get the wax out.
I start with a heavy cut compound and a wool wheel mounted on a high speed angle grinder / polisher. I used this over all the larger flat areas of the hull and hull sides. After that I will go back with a fine cut compound with the same polisher. I finish by putting on a good wax by hand and then remove it with a porter-cable dual action buffer and finish with a polish by hand.
For yearly maintenance I do a once over with a fine cut compound and the porter-cable unit (if needed) then hand wax with a protectant wax (mothers) then a coating of a polish to finish. Then will polish once a month for the season.
In the past I have used Starbrite's Polish with PTFE Teflon.
http://tinyurl.com/7easpmc
Late last year I ran out of the Starbrite and ended up using Nu-Finish because I had a new bottle that was kicking around for years and figured I would use it up to get rid of it. I honestly did not give it a lot of credit due to the old "as seen on TV" type ads for it but, I have been super impressed with the finish it gives and how long the shine lasts. For $8.99 a bottle instead of the $34.99 for the Starbrite I might consider buying another bottle of Nu-Finish and continuing that route.
http://www.amazon.com/Nu-Finish-Liquid-Car-Polish/dp/B000BPSW7C
Just a note, remember wax protects and a polish is what give the shiny / glossy look.
Jeff posted 05-30-2012 08:20 PM ET (US)     Profile for Jeff  Send Email to Jeff
For refrence, here is the boat before I bought it:
http://continuouswave.com/whaler/cetacea/cetaceaPage66.html
Images I took once I brought it home
http://smg.photobucket.com/albums/v427/jeff_rohlfing/76%20newport/ ?start=all
dfmcintyre posted 05-31-2012 06:40 AM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
Jeff -
If you ever decide to replace / repair the forward shelter, contact me. Walt Steffens and I sketched out a shelter that took advantage of some of that models attributes.
Regards - Don
6992WHALER posted 05-31-2012 09:16 AM ET (US)     Profile for 6992WHALER  Send Email to 6992WHALER
Looks great Jeff.
I am always impressed with you guys that have this talent.
John
Jeff posted 05-31-2012 10:18 AM ET (US)     Profile for Jeff  Send Email to Jeff
Don,
I would be interested to know what you and Walt came up with. I have the original Mills Duck Cloth foul weather set for the boat and I never have cared for how the forward shelter works. The set is in pretty far condition but the cotton canvas is starting to show it's age.
http://img.photobucket.com/albums/v427/jeff_rohlfing/ 76%20Newport%20Near%20Complete/45c72ae5.jpg
http://img.photobucket.com/albums/v427/jeff_rohlfing/ 76%20Newport%20Near%20Complete/46d8bb8b.jpg
John,
Thanks, I hope to get the 23 up to these standard in the coming years.
Binkster posted 05-31-2012 11:27 AM ET (US)     Profile for Binkster  Send Email to Binkster
Jeff,
Thanks for your advice on renewing the gel coat. The hull on my 15 footer is in almost pristine shape, except for the yellowed water stains on the bottom. I wasn't looking forward to wet sanding the hull, anyway, so, I'll do it your way, your boats always look outstanding. The interior of this boat was in really rough shape, but now the rigging tunnel is finished, and after alot of grinding, filling holes and gouges, and sanding, its almost ready to prime.
rich
crow posted 06-01-2012 09:24 PM ET (US)     Profile for crow  Send Email to crow
Boat looks amazing Jeff! Great Job!
