  Emission Regulation and Fuel Economy
Author Topic:   Emission Regulation and Fuel Economy
jimh posted 02-06-2013 01:32 PM ET (US)   Profile for jimh   Send Email to jimh
I am starting this thread as an outgrowth of another discussion. I did not want to drag the original discussion off-topic.
As I understand it--and this could very likely be wrong--the present regulations of the EPA and CARB require outboard engines to meet a standard of exhaust gas emission. The standard imposes a limit on the amount of controlled exhaust gas emitted based on the operation of the engine as measured by power output and time. (I will just call these controlled exhaust gases "air poilution" as a general name.) For example, a certain exhaust gas emission of a particular combustion product is regulated by allowing only so much volume or weight of the exhaust gas per unit of power and time. If this is not correct, I would like someone to reply and give me a more precise explanation. But let me proceed with the assumption that I have correctly stated the regulating process. For example, if you run a particular engine at 100-HP for one hour, you are allowed to produce a certain amount of a certain exhaust gas and no more; if you make too much you do not meet the standard.
I do not see where fuel economy plays a role in these ratings. I do not see any regulations that would restrict the amount of fuel burned to produce the horsepower. This sort or regulation appears to be different from the regulations imposed on automobiles. Automobiles have to meet emission standards and fuel economy standards simultaneously. Apparently outboard engines only have to meet emission standards.
I have two insights to offer. First, it would be impossible to measure fuel economy of outboard engines in terms of miles-per-gallon because the hull design of the boat they were used with, along with the propeller, have a very significant influence. So it seems reasonable that CARB and EPA regulations make no mention of fuel economy in terms of miles-per-gallon.
Next, it seems that fuel economy is actually part of the emission standard already, in an indirect manner. Because the emission standard is imposed on a basis of exhaust output per unit of horsepower-hour, it seems that the less fuel burned to produce the power the less exhaust gas emission being produced. For example, if engine-A burns 10-gallons of gasoline in one hour making 100-HP, and if engine-B burns 11-gallons of gasoline in one hour making 100-HP, it seems very clear that the engine using less gasoline will have an advantage in meeting the emission standard. The less fuel you burn, the less exhaust gas emission (in total) there will be.
On the basis of this analysis it seems at the most fundamental level, good fuel economy in an outboard motor naturally tends to produce lower exhaust gas emission, and lower exhaust gas emission means it should be easier to meet the regulations for exhaust gas emission by weight per horsepower-hour.
In fact, we see this trend. All of the engines meeting the emission standard get significantly better fuel economy than engines that do not. I can testify to this first hand. My old carburetor high-emission engine got 1.8-MPG at displacement speed. My new direct-injection ultra-low-emission engine gets three or four times better fuel economy at that same boat speed, about 7-MPG.
We all know that if a certain amount of fuel is burned, there is going to be a corresponding amount of exhaust gas created from the combustion. In the exhaust gas there are good components and bad components. The usual products of all combustion of hydrocarbon fuels are water and carbon-dioxide. In perfect combustion, the exhaust gas contains just those two compounds. In not-so-perfect combustion, the exhaust gas contains other compounds. These other compounds are the combustion products that are regulated.
The regulated exhaust gas emission are in two groups: hydrocarbons (or sometimes called reactive organic gases) and oxides of nitrogen. These compounds are measured and regulated by CARB and EPA.
I am no scientist of the combustion process, but apparently the amount of the controlled gases can vary significantly based on the many factors that occur in the combustion process. But there is still one fundamental and basic relationship: the less fuel you burn, the less exhaust gas you produce. Therefore it would seem that on a fundamental level, the EPA and CARB regulations would tend to improve fuel economy.
The fuel being burned by all engines is the same fuel. In fact, I think for the testing a very particular fuel must be used; you can't just go down to the local gasoline station and get the fuel. It has to be a specific fuel. What happens in the combustion chamber is the same for everyone; a chemical reaction takes place, and it is going to be the same reaction, based on the laws of Chemistry. Everything is equal for all engines.
Even though the fuel is the same and the laws of Chemistry are the same, not all engine combustion chambers are the same. There can be all sorts of changes. The ratio of fuel and air can be different. The temperature can be different. The pressure in the cylinder can be different. But one thing remains constant: if you use less fuel to make a certain amount of power, you will be making less exhaust gas. The engine that burns less fuel has an advantage in meeting the emission limits.
At first glance, it seems completely paradoxical that there could be a situation where an engine that burned less fuel could produce more air pollution. Or, conversely, that an engine burning more fuel to make a certain horsepower could produce less air pollution.
I also have to observe that among many manufacturers of outboard engines, all the manufacturers are able to produce engines that meet the present day highest standards of CARB and EPA with their engines, with one notable exception. The outboard engine industry as a whole has been able to produce outboard engines, across a very wide range of power levels, and using a wide range of methods and technologies, that meet the most stringent emission ratings, that is, the CARB Three-Star and the EPA 2010 ratings, and, at the same time, these engines are getting excellent fuel economy. Indeed, some of the Three-Star engines, for example the new Honda BF250, are demonstrating fuel economy that has never been seen before in an outboard engine. On that basis it seems clear that there is no inherent physical or chemical law that would exclude an outboard engine from reaching the most stringent emission requirements while producing the best fuel economy. It clearly can be done and it clearly is being done.
From this I conclude:
--improved fuel economy is beneficial to meeting emission limits
--fuel economy and emission limits are not mutually exclusive
If a particular engine uses some method or technique that causes it to not be able to simultaneously meet the most strict emission regulations and produce the best fuel economy, I do not find it reasonable to blame the regulations for this.
swist posted 02-06-2013 02:08 PM ET (US)     Profile for swist  Send Email to swist
I own a carbureted 4-stroke engine. It has a three-star rating. One of the reasons it has this rating is that the engine is made to run very lean. This coincides with what seems an obvious assumption that less gas burned yields fewer pollutants.
However, the carburetor mixture adjustments, unlike in older engines, are sealed and are theoretically not adjustable. Well why is this? Because if you richen the mixture by adjusting the screws, you produce more emissions and the 3-start rating would be lost BUT the engine is not running optimally at its sealed lean setting. If you remove the plugs (as I have) and richen the mixture a little, the performance of the engine is noticeably better - so I would guess that it may at a given power setting be using less gas, but the gas that it is using is producing more pollutants.
It seems like there must be some crossover point here, and I wish I had the equipment or the time to actually measure some of the above, but this is my opinion at the moment.
pcrussell50 posted 02-06-2013 02:08 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Jim, not 100% true. You are partially correct. It depends on which emissions compound you are talking about. The two of greatest import are unburned hydrocarbons, HC, and oxides of nitrogen, NOx. And THOSE two ARE mutually exclusive of each other. The means of reducing one of them, increases the other... except for a very narrow band of fuel mixture that is only possible and safe at low loads, such as idling, (or steady cruise in a car)).
At higher loads, such as max power or even 4500rpm cruise in a boat, you simply MUST run the motor a little bit rich, which MUST increase HC emissions, and decrease fuel economy compared to what you would get running a stoichiometric fuel mixture. Now, how rich you run in this regime is up to the engine designer and the "safety margin" against engine destruction that he is comfortable with. If he is bold, he can run leaner at high load. That will reduce HC emissions AND increase fuel economy. In that light, your statement is correct. HOWEVER, if you run (relatively) lean at high load, you will INCREASE the production of NOx (oxides of nitrogen). In light of that, fuel economy and emissions ARE in fact, mutually exclusive.
It is this narrow apex of emissions control where decreasing HC, increases NOx, and vice versa, where catalytic converters come in. With a cat, it makes having your cake and eating it too, (emissions-wise) much more feasible. The staggering cost, weight, and complexity of adding a cat or cats to an outboard have been discussed elsewhere and I'm sure they will continue to be.
My prediction (and I hope I'm wrong): We will have cats on outboards one day. And it will be as complex, expensive, and ugly as some are predicting. But 90% of us will still be just as desperately excited to buy one as we are over four strokes today.
-Peter
jimh posted 02-06-2013 02:52 PM ET (US)     Profile for jimh  Send Email to jimh
If I may summarize Peter's analysis: there are inherent contradictions in the regulations that prevent convergence of good fuel economy and low emission. I disagree.
I believe in the regulations there are weighting factors. An engine does not have to qualify at every possible combination of throttle and load conditions. There are several defined testing points. The emissions are measured at those points, and then those points are weighted. The weighted average emission over the whole range of load and operating conditions is what becomes the rating factor. (Again, if this is not correct, let me know.)
The use of multiple points of power and load, and a weighting of those (which is probably according to some model of he typical pattern of use for an outboard) provides the engine designer with the ability to run the engine somewhat differently at high-load settings than at low-load settings. The engine designer can run a rich mixture when needed and a lean mixture when more advantageous.
Further, the tolerance of an engine to resist failure in certain operating conditions is really a function of its design. The more robust the design, then the more likely the engine will operate without failing, even at certain operating conditions where it is subject to maximum stress. I recognize that adding more fuel is a useful way to relieve some of the stresses, but at the same time there must be other methods to relieve those stresses. For example, increased strength of materials, better cooling, and in general craftier design could be employed. This must be true because we have evidence. Almost every outboard engine manufacturer can make engines, even engines of over 200-HP, that simultaneously meet the most strict emission standards and give good fuel economy. Clearly those engineers have solved the problem. This means there are solutions to the problem.
It may very well be that to arrive at the solution to the problem requires using a certain path or method. If someone designs an engine using a method, a path, that just cannot lead to the solution, this is not proof that there is no path to the solution. They just took the wrong path.
I can appreciate that an engine manufacturer may be stuck on a path. If an engine manufacturer adopts a certain approach to the design of an outboard engine, spends $150-million developing that approach, and discovers, at the end of the road, their method cannot solve the problem, they may be stuck. Outboard engines are a boutique product, and you cannot get $150-million to develop new ones very easily.
To go back to the real word, we look at the outboard engines on the market now. The majority meet the Three-Star rating. There is really only one product line that cannot meet the Three-Star rating. Even that product line's manufacturer makes other engines that meet the Three-Star rating, but they use completely different methods and technologies. What I see from those facts: the problem in meeting the standard must be in the particular technology, and not in regulators setting a standard that cannot be met.
pcrussell50 posted 02-06-2013 03:02 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Jim, it sounds like you are talking about a set of regulatory rules. I am merely talking about the physics of the situation:
The leaner you run at higher loads, the more NOx emissions you will produce. Period. Even if such lean running increases fuel mileage and decreases HC emissions. Thus, tuning for good fuel economy increases one bad emissions product, while decreasing another. It suck, I know. But didn't make that rule. God did. As for the details of the regulator's rules that allow engine makers to work with that physical fact, I defer to you. But it is incorrect from the standpoint of physics, to say that tuning for better fuel economy, reduces emissions in their entirety. It only reduces one of the two big emissions, while increasing the other.
-Peter
jimh posted 02-06-2013 03:09 PM ET (US)     Profile for jimh  Send Email to jimh
Yes, I am talking about regulatory rules. The topic line clearly indicates that.
As I said, I think it is reasonable that the regulators must have known at least as much about combustion chamber chemistry as you know, and they must have provided for some allowance to work around what you say are two divergent trends. And, again, there are plenty of Three-Star outboards that meet the rules. It cannot be said that the rules themselves prevent compliance due to the nature of the physical or chemical world.
jimh posted 02-06-2013 03:48 PM ET (US)     Profile for jimh  Send Email to jimh
It is also clear from the nature of the regulations themselves which characteristic is to be preferred. The regulations attempt to regulate exhaust emission. They do not regulate fuel consumption It is therefore reasonable to assume that if there were a conflict between achieving reduced exhaust gas emission or in achieving improved fuel economy, the regulations must favor the choice of reducing exhaust gas emissions.
If the regulations intended to regulate fuel consumption, they would have included some measurements of brake specific fuel consumption and set limits. I do not believe there are any limits about brake specific fuel consumption, and the conclusion is therefore fuel economy is not being regulated.
russellbailey posted 02-06-2013 04:20 PM ET (US)     Profile for russellbailey  Send Email to russellbailey
I'm fairly certain this is the applicable rules for now (2010 model year forward)
From
http://www.ecfr.gov/cgi-bin/text-idx?c=ecfr&SID=0b807b404a9925a56fc1deebfed16a6a&rgn=div5&view=text&node=40:34.0.1.1.8&idno=40
§ 1045.103 What exhaust emission standards must my outboard and personal watercraft engines meet?
(a) Duty-cycle emission standards. Starting in the 2010 model year, exhaust emissions from your outboard and personal watercraft engines may not exceed emission standards as follows:
(1) Measure emissions using the applicable steady-state test procedures described in subpart F of this part.
(2) The exhaust emission standards from the following table apply:
Table 1 to § 1045.103—Emission Standards for Outboard and Personal Watercraft Engines (g/kW-hr)
Pollutant Power 1 Emission standard
HC + NOX
Power > 4.3 kW
2.1 + 0.09 × (151 + 557/P0.9)
CO
P > 40 kW 500 − 5.0 × P
300
russellbailey posted 02-06-2013 04:26 PM ET (US)     Profile for russellbailey  Send Email to russellbailey
Oops.
Here is the data table. Note that the units for all emission standards shown is g/kW-hr, which is mass of emissions per unit of power generated.
Emission standard g/kW-hr
HC + NOX
Power > 4.3 kW (6 hp)
2.1 + 0.09 × (151 + 557/P^0.9)
CO
Power > 40 kW (54 hp)
300
[A kW is 1.341 hp. There are different standards for lower power units. There are also various averaging approaches you can read about in the rule from the above web address]
So, jimh, you understand it correctly. If an outboard is more efficient at making power, it can emit more pollution per unit of fuel input. This does incentivize efficient engines.
pcrussell50 posted 02-06-2013 05:47 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
So, "the man", who even with all his regulatory might, cannot change the laws of physics, instead will allow you to make a dirtier engine (mass of pollutants/power produced) as long as it's BSFC* meets a certain standard?
*BSFC = Brake Specific Fuel Consumption
http://en.wikipedia.org/wiki/Brake_specific_fuel_consumption
-Peter
L H G posted 02-06-2013 07:43 PM ET (US)     Profile for L H G
What about the fact that a 2-star Verado 150 gets better fuel economy than a 3-star E-tec 150? Less fuel and OIL burned, perhaps less overall pollution.
jimh posted 02-06-2013 08:19 PM ET (US)     Profile for jimh  Send Email to jimh
Larry--You are wrong. The EPA and CARB say so. It is very simple. We run each engine for one hour at the various loads and speeds of the test. At the end, the E-TEC has made less air pollution. That is why it gets a better emission rating, Three-Star. If the Verado made less air pollution, it would get the better rating. It does not. That means the Verado made more air pollution.
We can't really tell from the EPA test data or the CARB test data which engine will burn more fuel. I understand that you are able to interpret the Mercury test data to mean the Mercury will burn less fuel. That is only what Mercury says, and you would expect them to say that. I have never seen any real data by an independent tester that shows a particular advantage. But assuming you are correct, and the E-TEC used more fuel during that hour, it would have still produced less air pollution.
The pollution rating is based on power-over-time. The E-TEC produces less air pollution for the same power and the same time as the Mercury. That is the fundamental definition of having a better rating.
jimh posted 02-06-2013 08:24 PM ET (US)     Profile for jimh  Send Email to jimh
Oh, and that includes any oil the E-TEC burned in its combustion chamber. This is actually a beautiful benefit. The E-TEC consumed the oil in an extremely clean process. It did not leave it behind to be poured into the ground, or soaked into rags and filter elements, and then to be sent to an industrial furnace to be burned.
russellbailey posted 02-06-2013 08:55 PM ET (US)     Profile for russellbailey  Send Email to russellbailey
Not quite Peter. If the BSFC is better (more efficient) you can emit more pollution per heat input (e.g., more mass of pollution per gallon of fuel)
jimh posted 02-06-2013 10:51 PM ET (US)     Profile for jimh  Send Email to jimh
The measurement being tested is how much air pollution is created by a particular engine when it produces a particular amount of power for one hour. The emission regulations to not attempt to impose any fuel consumption limits; they don't try to directly regulate fuel economy. But it is clear to anyone who understands the concept of a chemical reaction, that the more fuel used as the input to the combustion, the more exhaust gases will be produced.
Let us go back to our two engines, A and B. A uses 10-gallons in the hour long test. B used 11-gallons. If it happens that engine B actually produces lower amounts of air pollution, then engine B must be very clean burning because it burned more fuel but still made less air pollution. The CARB or EPA does not measure the amount of fuel used to create the power; they just measure the amount of air pollution created in the process.
Peter posted 02-07-2013 07:57 AM ET (US)     Profile for Peter  Send Email to Peter
"What about the fact that a 2-star Verado 150 gets better fuel economy than a 3-star E-tec 150?" -- L H G
Larry -- I presume you are relying on your favorite Mercury head-to-head advertisement for your statement. So what about the fact that your favorite advertisment in the confusing Gallons Per Hour graph represents that the Verado 150 burns 12.1 GPH at WOT but yet there is NOT A SINGLE, I repeat NOT A SINGLE, performance for the Verado 150 (Mercury created or 3rd party created) within the Mercury performance report library available on the Mercury Marine website that backs that representation up?
FYI, one of the performance reports in the library done by a 3rd party rather than Mercury shows the Verado 150 burning 18+ GPH at WOT! Most of the other reports show consumption in the 14.5 to 15 GPH range. Either way, that's a quite a gap from the 12.1 GPH in the advertisement.
Seems to me that your favorite head-to-head advertisment has a bit of a credibility problem.
Regarding emissions, as engine makers try to lean out the mixture to maximize fuel economy, it is possible that the more fuel efficient motor might not meet the highest emissions tier because, as I understand, even if the HC component goes down, the NOx component might go up such that the total of the two exceeds the highest emission tier's limit.
pcrussell50 posted 02-07-2013 04:37 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Aha. I missed that subtlety. And I'm pleasantly surprised, (shocked, really) at the sense and reason behind it.
Robert V posted 02-08-2013 08:08 AM ET (US)     Profile for Robert V  Send Email to Robert V
I went to the Mercury website and noticed that all the Verado motors are rated 2 Stars while the new 150 HP FOURSTROKE, as well as the smaller FOURSTROKE motors, are rated 3 Star. The 115-75 HP FOURSTROKE models share the same engine architecture as the Verado 150-200 HP motors. This leads me to believe that supercharging the motor increases the emissions. The naturally-aspirated motors, with the same block, have lower emissions. Why does forced-induction have this effect on the emissions (or does it)?
Robert
jimh posted 02-08-2013 09:31 AM ET (US)     Profile for jimh  Send Email to jimh
From Russell's formula (above), I would calculate as follows:
For a 225-HP engine, the power rating in kW is 225/1.341 or 167.8-kW. Since this is above the threshold of 40kW, the engine is allowed to emit 300-g/kW-hour of CO. This means that if I run my engine at full-throttle for one hour, I can emit up to
167.8-kW x 1-hour x 300-g/kW-hour = 50340-grams or 50.340-kg
That is 111-lbs of CO.
For the HC + NOx component, I calculate a limit of 16.19-g/kW-hour. An hour at full throttle should produce no more than 5.9-lbs.
Let's say the 225-HP engine was burning 20-GPH of gasoline that weighs 6.25-lbs/gallon. The fuel burned would have weighed 125-lbs.
DId I calculate these three weights properly?
Peter posted 02-08-2013 09:42 AM ET (US)     Profile for Peter  Send Email to Peter
Isn't the emissions standard set using the 5 point ICOMIA duty cycle? If so, a portion of the emissions at each of the throttle settings would be added together according to the weight of the throttle setting in the duty cycle to get the total emissions per hour.
jimh posted 02-08-2013 09:52 AM ET (US)     Profile for jimh  Send Email to jimh
Ignore the weighting for a moment, and just check my math at 225-HP for one hour.
Peter posted 02-08-2013 11:47 AM ET (US)     Profile for Peter  Send Email to Peter
The calculations appear accurate.
jimh posted 02-08-2013 12:10 PM ET (US)     Profile for jimh  Send Email to jimh
The regulations use the notation "CO". Does this refer to CarbonMonoxide? Or just to oxides of carbon in general?
Peter posted 02-08-2013 12:33 PM ET (US)     Profile for Peter  Send Email to Peter
Carbon monoxide -- the poisonous gas.
jharrell posted 02-09-2013 01:22 AM ET (US)     Profile for jharrell
Yes. It increases combustion temperatures which creates more NOx. Same heat energy in less space means higher temperatures.
Verados create the same horsepower from 2.6L of displacement that requires 3.4L-4.2L from the other normally aspirated outboards. Same energy less space equals higher temps.
Air which is roughly 80% nitrogen and 20% oxygen in high enough temperatures will form NOx. This requires no fossil fuel, only air and heat! The hydrogen and carbon in fossil fuel normally bonds to oxygen forming H2O and CO2 but an engine run lean rather than stoichiometric will have oxygen left after burning the fuel allowing nitrogen to bond to it, again if the temps are high enough.
jimh posted 02-09-2013 07:59 AM ET (US)     Profile for jimh  Send Email to jimh
jharrell--You have my thanks for the explanation you gave (above). That was a great explanation.
Peter posted 02-09-2013 09:17 AM ET (US)     Profile for Peter  Send Email to Peter
Here is an interesting article on outboard emissions written by Paul Dawson a few years ago. members.iinet.net.au/~pauldawson/IAME-57_Emissions-a-sml.pdf . He does some similar math.
jimh posted 02-10-2013 09:07 AM ET (US)     Profile for jimh  Send Email to jimh
In order to produce the best fuel economy, the ratio of fuel and air would tend to always favor having a surplus of air. This is referred to as a lean fuel-air ratio. If more fuel than air were available, some fuel would not be combusted, and that fuel would not produce any useful power output. The result would be that more fuel would be burned than necessary to create the power output. So any mixture of fuel and air in which there was any surplus of fuel, that is, a rich mixture, would reduce fuel efficiency. Such a mixture would tend to increase HC emission, too, as the unburnt fuel would be in the exhaust
To be certain combustion of all fuel in the combustion chamber took place, it seems like it would be useful to always have a surplus of air, that is, to always be running toward the lean side of the mixture. Some outboard engine manufacturers even describe their systems with terms like lean-burn.
This makes sense for reaching best fuel economy. As explained above, however, in a high-temperature environment there is a tendency for NOx to be produced as a separate reaction, distinct from the combustion of the fuel. It has also been mentioned in the past that a combustion chamber operating with a lean fuel-air mixture will tend to become hotter. Please explain why a lean fuel-air mixture tends to create higher temperatures.
pcrussell50 posted 02-10-2013 12:36 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
It's not that running excess oxygen causes hotter temperatures, per se. It's more that the absence of excess fuel deprives the motor of it's cooling "fluid" which is the fuel itself. Part of the combustion process is the release of heat. And the rate of heat released is proportional the rate at which fuel is combusted. That's why at idle and low load, it's OK to run an engine at stoich, because at those low loads fuel is being burned at a slow enough rate that the internal components can reject the heat at the same rate it's put to them. But as you increase the load and thus the rates at which fuel is burned, eventually, the internal parts are subjected to heat input at rates greater than the rate they can reject it. As a result, they get hotter and hotter. With no "cooling help" the weakest link eventually fails due to thermal fatigue and the engine is destroyed. The "cooling help" is extra fuel in the mixture. Supercharged motors are a worst case scenario, because they are small, relative to their capability to burn fuel and air, with less mass to absorb and reject heat in comparison to motors that achieve their power levels from having more massive reciprocating assemblies.
-Peter
jimh posted 02-10-2013 03:37 PM ET (US)     Profile for jimh  Send Email to jimh
Turning the unburnt excess liquid fuel into vapor requires the consumption of the latent heat of vaporazation, apparently now called Enthalpy of vaporization. I see that could use up some of the heat in the combustion chamber.
jimh posted 02-10-2013 03:39 PM ET (US)     Profile for jimh  Send Email to jimh
Is it fair to say that the heat rise that can occur with lean combustion could be handled if the components of the combustion chamber and the engine block were designed to have the capacity to absorb the heat and dissipate the heat without damage? Or, in other words, the heat rise is only a problem for engine designers that were depending on a rich fuel mixture to help cool the combustion chamber. Is that true?
jharrell posted 02-11-2013 02:28 PM ET (US)     Profile for jharrell
Leaning out will raise cylinder temperatures to a point then they will drop off and the engine will not run properly since so little fuel is being burned.
The reasons as mentioned have to do with the lean charge imparting more heat into the cylinder walls because of less hydrocarbon mass to carry the heat out the exhaust and the tendency for the boundary layer of oil and fuel on the cylinder wall to burn or wash off using the excess oxygen. This boundary layer acts as a insulation layer between the hot combustion gasses and the metal of the cylinder, it's not just for lubrication.
What must be remembered is an internal combustion engine is a heat engine, as such the hotter it runs the more efficient it is at creating mechanical work from heat energy. This must be balanced with the ability of the engines materials to stay in solid form under such heat.
Yes see diesels, they run very hot and lean most with forced induction. This is why they are heavy and require a large oil capacity, in order to withstand and dissipate the heat. This is also why they are very efficient and also why they generate large amounts of NOx, thus requiring aggressive catalytic systems.
This is also why you see modern 4-stroke outboards utilizing lean burning ratios more aggressively than DI 2-strokes. The extra stroke and wet sump allow the engine to withstand higher cylinder temps for longer periods as compared to a 2-strokes. This is the reason behind the E-TEC running lean only up through the 2000's while a Suzuki or Honda runs lean well up into the 4000's. This is also why E-TECs require special piston alloys from Nasa, to withstand the greater temps. Note this is also why Gen2 Verados have forged pistons. Evinrude could have gone with forged pistons as well, instead of the Nasa alloy they just cost more but could be more durable as well.
It's interesting that both the E-TEC and Verado are similar boats here. Mercury choose to go with forged pistons and lean out some to the point of blowing 3 star NOx emissions, while Evinrude stays with 3 star using a richer mix to keep things cooler and avoid more expensive components. All this while Suzuki,Honda and Yamaha are free to try lean burn systems being normally aspirated 4-strokes.
Peter posted 02-11-2013 03:37 PM ET (US)     Profile for Peter  Send Email to Peter
If you look at the EPA family certification data for the high HP models 200 to 300 HP you should find the following data:
HC----NOX---CO
06.65 03.9 084.9 Evinrude 250
05.36 07.6 200.9 Suzuki DF 200
10.68 03.8 259.0 Yamaha F225
04.90 15.0 109.2 Mercury Verado 300
I would not conclude that E-TEC and Verado are similar.
jharrell posted 02-12-2013 12:38 AM ET (US)     Profile for jharrell
Why because an ETEC 250 puts out less emissions than a Verado 300? I think you missed my point.
What about the E-TEC 300?
HC----NOX---CO
25.6 03.9 251 Evinrude 300
The E-TEC 300 is actually worse than the Verado 300, but it's from running rich vs lean so its fuel economy is probably worse as well.
How about a Gen I Verado 250 (gen 2 are not in the data):
HC----NOX---CO
11.09 4 278 Verado 250
Gen 1's ran richer obviously but within 3 star carb of 16.1 HC+NOx total while the Gen 2 300 blows that by only 3 g/kw-hr vs the E-TEC 300 blowing it by over 13!
jimh posted 02-12-2013 08:37 AM ET (US)     Profile for jimh  Send Email to jimh
Thanks for the continued flow of good information.
Regarding where various engines come in to the rating scheme, let me suggest that we get a finer grain of rating. Instead of just unitary values, could we describe the emission compliance in a decimal? For example, the VERADO engine rated Two-Star would be described as 2.0-Star if it just meet the criteria for the rating of Two-Star. If it exceeded the minimal standard for Two-Star and was halfway to Three-Star level, then it would be a 2.5-Star. If it were on the cusp of meeting the Three-Star, then it would be a 2.9-Star.
By looking at the actual emission test data--which seems to be going on here--can we have an estimate of the decimal-Star rating for a few models?
L H G posted 02-12-2013 04:53 PM ET (US)     Profile for L H G
[Changed topic. Began discussing the interest of the buying public in emission control, air pollution, and ratings. I would prefer to keep this discussion focused on its present topic, the combustion process, the ratings, and the legalities and technicalities. Please start a new thread for your new topic. I would give it the title: "Who Cares About Air Pollution, I'd Remove Those Two-Star Stickers If I Owned a VERADO" --jimh]
Peter posted 02-13-2013 08:38 AM ET (US)     Profile for Peter  Send Email to Peter
In further thought about this topic, this comparative statement bothered me. I don't think this is accurate.
The "lean" mode up to 2000 RPM or so that you refer to in the E-TEC is the stratified charging mode. The Ficht and the Optimax also employ a stratified charging mode. In that mode, there is a rich blob of atomized fuel injected into the cylinder near the spark plug and that blob is surrounded by air. In this mode, the overall cylinder is run very lean. None of the 4-stroke outboard makers including Suzuki and Honda have DFI systems and thus cannot employ any stratified charging of the cylinders. So I think the comparison of the E-TEC and Suzuki or Honda is one of apples to oranges. They are just different.
While the 2-stroke fires the piston every time and the 4-stroke fires every other time, the amount of fuel combusted in each power stroke of the 2-stroke combustion chamber is approximately 1/2 that which is combusted in the chanber for each power stroke of the 4-stroke assuming the same number of cylinders. If we compare a V6 2-stroke 150 to a I4 4-stroke 150, for example, the fuel charge per cylinder is less than 1/2.
By the way, 4-stroke engines that use direct fuel injection (DFI), such as the engines that I have in two of my cars, employ stratified charging at low engine speeds/loads just like the E-TEC and the FICHT before that. DFI is becoming more mainstream in automobile engines. As it becomes more mainstream, maybe it will make its way to 4-stroke outboards someday.
jharrell posted 02-13-2013 11:52 AM ET (US)     Profile for jharrell
Again your missing the point. Let me spell it out for you, regardless of carb, DI or EFI, a two-stroke has a much more difficult time managing heat from a lean burn than a 4-stroke, just like a forced induction engine. An E-TEC in it's current form is unable to run lean into higher RPM's either because of engine destruction or high NOx emissions or both.
This is because it has a higher power density, which as you have mentioned multiple times in the past, they need less displacement to create the same power. Just as the Verado, same power less space equals higher temps. This is compounded by the lack of wet sump and the cylinders firing twice as often allowing less downtime between fires for the heat to be carried away from the cylinder walls and pistons by the conductive mass of the engine and the non existent crank case oil.
This is incorrect, most lean burn designs employ a form of stratified charging, even the old carburated ones! Modern EFI outboards from Suzuki and Honda use precise injector control along with very specific intake dynamics to achieve a non-homogeneous charge. Honda's automobiles have been doing lean stratified charges since the 70's using CVCC.
jimh posted 02-15-2013 01:56 PM ET (US)     Profile for jimh  Send Email to jimh
I need some help. The information I have interest in is contained in rather large Excel spreadsheets, and that data is (presently) very hard for me to view. Please indulge me. Could someone who can see the EPA data comment on this:
I would like to see a representation of the CARB star ratings expressed with more granularity. Presently we only get CARB rating to the whole digit, always rounding down, I presume. I would like to see a few ratings expressed as decimal CARB ratings. By that I mean as follows: if the level of some air pollution to meet the Two-Star rating were said to be 200, and if the level of the Three-Star rating were said to be 300, I would like to see a rating that showed the relative air pollution of the engine. For example, if a particular engine rated 250 on my scale, it would only get a Two-Star. I would call it a 2.5-Star. If an engine just reached a rating on my scale of 300, it would be Three-Star. If an engine were actually rated 350, I would call it a 3.5-Star. With this in mind, could someone tell me the decimal-Star rating of
--the E-TEC 150
--the E-TEC 300
--the VERADO 150
--the VERADO 300
If you could offer some information along this line, I think it would be interesting. My goal is to quantify just where some engines are in the gap between Two-Star and Three-Star. I think this would be interesting to know. Throw in any other engines you think are worth mentioning, too.
jimh posted 02-15-2013 02:00 PM ET (US)     Profile for jimh  Send Email to jimh
As a corollary to the above, and much simpler, perhaps we should quantify the One-Star, Two-Star, and Three-Star air pollution levels. I think there is a tendency for boaters to consider these three to be related in a linear and proportional manner. I am not sure that is the case. I believe there is a much greater separation between Three-Star and Two-Star than between Two-Star and One-Star. In other words, to reach Three-Star level compliance requires more and more reduction.
swist posted 02-15-2013 02:18 PM ET (US)     Profile for swist  Send Email to swist
That may be true, but I'm sure the avergae boater tends to see those ratings as linear, or "good", "better", "best".
[Changed topic to speculate about how boat buyer make judgements. Thanks for the speculation. I would prefer we just stay on the topic of the regulations and the details. You might consider starting a new thread in which you speculate about how emission ratings affect boat sales. I would be glad to comment on that in a new topic.--jmh]
jimh posted 02-15-2013 02:35 PM ET (US)     Profile for jimh  Send Email to jimh
Swist--Thank you for concurring with my speculation about the perception of most boaters regarding the linearity of the ratings. This is precisely why I wish to investigate into the ratings a bit further. If you don't mind, I would like to learn more about the ratings in order to discover if what you and I agree is a possible misconception about them is actually true. Since you and are like-minded in this, I think you will find further information to be of value.
jharrell posted 02-16-2013 12:09 AM ET (US)     Profile for jharrell
I prefer to look look at the raw emissions numbers because it tells me more about the engine. However I put this together as an attempt to get a "decimal star" rating based on the carb formula and EPA data as an interesting exercise anyway.
It is just HTML/javascript so it should work for everyone with a modern browser:
http://jsfiddle.net/PWGnh/n/
Note if you make changes everyone will see them, so if you wish to experiment use the Fork button. It should be easy to add your own data.
I am not entirely sure about the average power rating for the engine "family", they mention sales weighted average, mine limits are slightly lower than the ones listed on the spreadsheets, so I would imagine the average powers are actually lower than what I am deriving.
jharrell posted 02-16-2013 12:29 AM ET (US)     Profile for jharrell
Actually the forking may not be necessary, the way jsHandles versioning should prevent any issues. As changes are made a new url is generated based on the version number, so for example the latest version after some minor tweaks is:
http://jsfiddle.net/PWGnh/7/
jharrell posted 02-16-2013 12:55 AM ET (US)     Profile for jharrell
Updated with E-TEC V4's and Verado I4's:
http://jsfiddle.net/PWGnh/13/
jimh posted 02-16-2013 01:20 AM ET (US)     Profile for jimh  Send Email to jimh
Great stuff. I will have to study it. Thanks.
jharrell posted 02-16-2013 11:28 AM ET (US)     Profile for jharrell
Here is a new version exposing some more details including the limits derived for the engine family: http://jsfiddle.net/PWGnh/15/
I noticed jsFiddle seems to be running slow, it seems they they are suffering from their own popularity and the server are very overloaded. It is a popular tool in programming circles for quickly sharing ideas. There is a similar service at jsBin.com that I may make a copy of there if this continues.
The basic premise of the decimal star is normalizing the HC+NOx value to a percentage of the total HC+NOx range in a star. The core piece of code that does that is:
engineData.star = engineData.starLimit.star +((engineData.starLimit.max-engineData.hcNox)/engineData.starLimit.range);
All the rest of the code implements the CARB formula and renders the data. There is more than a single decimal precision in the star rating, I am just rounding it in the rendering code for display to 1 place.
jharrell posted 02-16-2013 10:25 PM ET (US)     Profile for jharrell
Finally tracked down why my threshold numbers where slightly lower than the EPA's, I was using the incorrect exponent operator in javascript for the CARB formula. This one now lines up with the EPA standards as given in the spreadsheets. It ends up change a couple of the star ratings by a tenth:
http://jsfiddle.net/PWGnh/19/
jimh posted 02-16-2013 11:21 PM ET (US)     Profile for jimh  Send Email to jimh
Beautiful work! Thank you. It is great to have some actual data. I really appreciate this. For me, a bit of science and math is so much more significant than opinions and prejudice.
Jefecinco posted 02-17-2013 10:01 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Very impressive effort. It appears the Verado engines are very slightly below the three star threshold. Assumptions are never safe but I'm assuming Mercury could turn the Verados into three star engines with some ECU tweaks.
The Suzuki engines were impressive.
I wonder how the 150 HP Gen2 Verado fares. It's now the baby of the family. My engine is the 135 HP Gen2 Verado but because it is no longer produced the numbers are pretty meaningless unless one is planning to install a new higher HP ECU.
jimh posted 02-17-2013 10:31 AM ET (US)     Profile for jimh  Send Email to jimh
It is great to see data from actual measurements in the certification process. This sort of analysis is so much more concrete than wild speculation based on nothing but opinion and bias.
It appears that many engines rated Three-Star are well above the 3.0-decimal Star level. Manufacturers selling those engines are accumulating a lot of emission credits which they could use to create room in their sales mix for non-compliant engines, that is, engines rated below 3.0-decimal stars.
For a manufacturer selling mainly Three-Star engines with only one or two models rated Two-Star, there must be a wealth of emission credits available to provide the offset to the Two-Star engines. For a manufacturer hoping to sell a large number of Two-Star engines, there must be a more careful balance in the product mix.
At present it appears that Mercury is the only manufacturer in the situation of hoping to sell a lot of Two-Star engines, that is, their entire VERADO line. At the risk of being too demanding, is it possible to see some more details from the Mercury product line for their OptiMax engines? I would like to see how the OptiMax engines score on the decimal-Star scale. From that we could perhaps infer how much emission credit they might provide to Mercury so as to permit the sale of the Two-Star VERADO engines.
jharrell posted 02-17-2013 12:16 PM ET (US)     Profile for jharrell
I have updated with more engine data: http://jsfiddle.net/PWGnh/21/
It is very easy to add new data, it is in JSON format, and stored at the top of the source code in the engineData variable: http://en.wikipedia.org/wiki/JSON
It is structured as an array of engine family objects with each family containing an array of engine data objects. Emissions can be input as hc and nox separately or as hcNox combined for data coming from the supplemental EPA spreadsheets where it is not reported broken down.
All data comes from here: http://www.epa.gov/otaq/certdata.htm#marinesi
Mercury sees to have the most engine models, and you must remember they do stern drives with catalytic converters, I have added them just to show what a cat can do for emissions. I have also added the new 150 Fourstroke from the 2012 supplement, it looks like they submitted multiple certifications as it was in development.
jharrell posted 02-17-2013 12:29 PM ET (US)     Profile for jharrell
Updated with table cells lined up again and some color: http://jsfiddle.net/PWGnh/22/
jharrell posted 02-17-2013 04:54 PM ET (US)     Profile for jharrell
Looking at the Mercury data I may have miss interpreted the 2012 supplement to be the new 3.0L 150 Fourstroke, it may actually be 3.0L Optimax data, the spreadsheet is not clear and I inferred from the displacement alone, although the engine family more closely resembles that of the Optimax from the main spreadsheet.
jimh posted 02-18-2013 08:52 AM ET (US)     Profile for jimh  Send Email to jimh
In the past when I have tried to find data about Mercury engines in the EPA spreadsheet, I noted the difficulty in identifying exactly what engine model was being described. All other manufacturers seem to use their standard model designators, but the Mercury data in the spreadsheet is obscure.
jharrell posted 02-18-2013 10:01 AM ET (US)     Profile for jharrell
At least the main spreadsheet has power rating and combustion cycles. This makes it relatively easy to determine although I agree the other manufacturers model numbers are obvious compared to Mercury's.
However in the supplemental's all they list is family code and displacement, making it difficult to determine exactly which engine is being referenced.
seahorse posted 02-18-2013 10:51 AM ET (US)     Profile for seahorse  Send Email to seahorse
jharrell,
The 4-stroke Merc 150 is family CM9XM03.02GB and may be listed as having 2.999L displacement
davej14 posted 02-18-2013 10:56 AM ET (US)     Profile for davej14  Send Email to davej14
This is a very useful and informative thread. I have a couple of questions for the experts:
If the EPA continues to tighten their emission standards (decrease the amount of allowable emissions) how close are we to needing bolt on devices such as catalytic converters ?
What is the limit for achieving less pollution ? It would seem that at some point the added weight and the amount of energy required to reduce emissions will be greater than the available HP to achieve the standards. So far new designs have been able to keep up but unless we switch to hydrogen powered engines are we at the point of diminishing returns for makeing additional improvements?
jharrell posted 02-18-2013 11:29 AM ET (US)     Profile for jharrell
In that case just the last entry labeled "150 3L GB" is the new engine, it was listed as exactly 3L like the rest.
I have updated to a new version removing the other entries and relabeling:
http://jsfiddle.net/PWGnh/23/
jharrell posted 02-18-2013 11:36 AM ET (US)     Profile for jharrell
In my opinion it's inevitable, just look at the difference in emissions on the Mercury stern drives with cats in the data, we are talking 1/10th the emissions of a 3 star OB. Not only that now the engines can be run leaner and hotter while staying easily within the emission standards making them more fuel efficient and more powerful.
There is speculation Mercury created a placeholder for the catalytic converter in the new 150: http://blog.boats.com/2011/09/mercury-150-outboard-insert-catalyst-here/
jimh posted 02-18-2013 12:07 PM ET (US)     Profile for jimh  Send Email to jimh
I need some clarification. Why do the values for 4-Star/3-Star/2-Star/1-Star shown on the right side of each listing vary with model?
For example:
--on the E-TEC V6 family the values are: 5, 16.1, 36, 45
--on the Yamaha Mid range the values are: 5, 17.1, 38.2, 47.7
I am confused.
jharrell posted 02-18-2013 12:18 PM ET (US)     Profile for jharrell
Per the formula which requires a average engine family power as an input. Interestingly enough as the power goes down the allowed emissions goes up.
The actual description is "Where P means the average power in kW (sales-weighted) of the subject engine family". http://www.arb.ca.gov/msprog/macs/mac0301/mac0301.pdf
Unfortunately I don't know the sales weighting or what exact models are in each family so I guessed grouping engines by displacement and cycle and it seems to agree with the EPA data. They have a column in the supplemental spreadsheet which denotes the limit for the particular engine.
It is easy to reconfigure the families in the data if they can be more accurately determined, however it would take a large change in average power to make any difference in the outcome.
dgoodhue posted 02-18-2013 03:18 PM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
Honda automobile used to sell a lean-burn CIVIC model in the US. It had modes of operation where it ran leaner than stoichiometric. It was never was sold in [California] due not meeting [CARB] emission standards. Other auto manufacturers make lean burn automobile engines just not [for sale] in the USA.
I had a Corvette that I got into tuning. I was surprise to find GM had put in the ECM source code a highway lean burn operation. I was able to enable it and easily pick up another 3-MPG highway, about 10-percent increase, by just turning it on. It ran about 15.2:1 [air-fuel-ratio] and a duty cycle of 30-seconds-on, 30-seconds-off. Other tuners were able to get 5-MPG [increase] by tweaking it further.
There are fuel economy gains to be had when going leaner than stoichiometric which is at the expense engine emissions.
jimh posted 02-28-2013 12:32 PM ET (US)     Profile for jimh  Send Email to jimh
jharrell--Thanks for the explanation. I think I understand. Let us say, for example, a certain manufacturer made three engines that were all rated in the same family. The engines were 200-HP, 225-HP, and 250-HP rated models. They constitute a family of engines under the system of the EPA or CARB regulations. In this family, the actual sales volume of the three various models would establish the average power for the family, and this average power of the family would, in turn, set some level of emission compliance. If the 250-HP model was sold much more than the 200-HP model, the family average power would tend to increase. If the 200-HP model greatly outsold the 250-HP model, the family average power would tend to decrease.
dgoodhue--Your comment about discovery of a unused mode of operation for your GM vehicle is quite interesting. The relationship of fuel economy to emission regulation--the topic of this entire discussion--is nicely demonstrated in your example. At first glance, it would be hard to impute any motive for GM to want its vehicle to get anything less than the best fuel economy. However, we do not know the real reason why the enhanced highway fuel economy mode was not provided in the production version. It seems reasonable to infer that perhaps there was concern about performance, an impact on engine wear and tear, shortening of the life span of the catalytic convertor, or other consequences. I don't think we can say that the decision of GM to not employ the improved highway fuel economy mode must be only a result of concern about meeting emission compliance.
andrey320 posted 02-28-2013 01:32 PM ET (US)     Profile for andrey320  Send Email to andrey320
Honda has "lean burn" on many of its vehicles now that are sold in California. My Honda BF60 (bought in California) also has this feature as do most of their outboards.
dgoodhue posted 02-28-2013 05:06 PM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
When I am referring to lean burn engines, I am talking about engines running leaner than stoichiometric.
Honda has lean burn combustion chamber. The automobile engines with Honda lean burn combustion chambers that are for sale in [California] run stoichiometric air-fuel ratio like most automobile engines.
I am not sure what air-fuel ratio Honda outboard engines run at.
jimh posted 03-02-2013 09:32 AM ET (US)     Profile for jimh  Send Email to jimh
As I mentioned earlier in our discussion of outboard engines and their emission regulations, it seems clear that the regulations are intended to control exhaust gas emission, not fuel economy. It seems that a reasonable inference is the regulations prefer to move engines toward lower exhaust gas emission, not necessarily toward better fuel economy. Also, as mentioned before, there is an inherent tendency toward better fuel economy in better exhaust gas emission because the less fuel used the less total exhaust gas produced.
There seems to be a trend in the combustion process which causes a rise in NOx emissions in the combustion chamber under lean fuel-air mixtures. The lean fuel-air mixtures are used to enhance fuel economy. In order to maintain compliance with exhaust emission and use lean fuel-air mixtures, it appears to me that the trend is to treat the exhaust gases outside of the combustion chamber in a catalytic convertor. The higher NOx content in the exhaust gas can be changed in the catalytic convertor.
Whether or not marine outboard engines are adaptable to this technique seems to be a consideration undertaken by CARB, as evidenced by the studies done by Mercury regarding use of a catalytic convertor on their VERADO engines.
It seems like there is a natural, physical, chemical barrier in place for the combustion chamber, lean fuel-air mixtures, and NOx emissions. The regulatory agencies must be cognizant of this limitation. In order to move beyond this limit, it seems inevitable that the higher NOx emission has to be handled downstream of the combustion chamber. This seems to imply that if manufacturers of marine outboard engines want to meet exhaust emission regulations and improve the fuel economy of their engines, they will have to develop methods for handling the higher NOx exhaust downstream of the combustion chamber.
In the general process of imposing regulations there has always been an initial notion that the regulations would be impossible or unworkable, yet, with good design, engineering, and manufacturing, engine makers have been able to meet the regulatory limits, even those which at first seem unreachable. Whether or not we have truly reached the limits of engineering in the case of lean fuel-air mixtures and exhaust gas emission remains to be seen.
jimh posted 12-14-2013 11:20 AM ET (US)     Profile for jimh  Send Email to jimh
I revive this thread for two purposes. First, I want to acknowledge, again, the fantastic work of jharrell in implementing an analysis of the emission compliance of many modern outboard engines using a "decimal star" rating. As I said earlier, a bit of science and math is so much more significant than opinions and prejudice. The entire thread is a wonderful example of the depth of knowledge of the participants here and their ability to discuss a complex subject in an informed manner.
Second, I must ask this question: are there any new emission regulations in the USA or European Union that are coming into effect in 2014 that might affect the manufacturing of outboard engines? I have not kept abreast of this topic, so I would appreciate hearing from anyone who has knowledge of any new .
Peter posted 12-14-2013 01:26 PM ET (US)     Profile for Peter  Send Email to Peter
None in the U.S. that I'm aware of. You can see what emissions standards applied (and now apply) to a given model year here www.epa.gov/otaq/standards/nonroad/marinesi-exhaust.htm . Ordinarily, the EPA gives the manufacturers time to comply with new regulations and thus there is typically a phase in period. The last EPA regulatory change was put in place in 2008 and originally was supposed to be implemented in the 2009 model year but ultimately went into play for 2010 model year because the manufacturers needed more time. Motors made today have to comply with the 2010 standards. There are no further phase-ins unlike the the 2006 EPA regulations that were phased in over a period of 8 years.
Notice of the previously proposed and now 2010 emissions standards can be seen here www.epa.gov/nonroad/marinesi-equipld/420f07032.pdf . I cannot find any newer proposed standards that have not been enacted. One interesting thing to note from the proposed to the actual emissions standards (the 2010 standards) is that the proposed standards set CO emissions at 200 g/kw-hr for 40kW and above. The enacted standard is 300. It's not clear to me whether that was a typo or it was subsequently revised higher to the current 300 g/kw-hr standard.
However, what is clear from the comments (see cfpub.epa.gov/si/si_public_file_download.cfm?p_download_id=499576 ) is that the CO standard was purposely set so that outboards would NOT have to use catalytic converters because the technology as used in outboard motors is far more difficult to implement than in the case of stern drives and inboards and is unproven. I recall back in 2007 that some of the 4-stroke outboards had CO emissions that were higher than 200 g/kw-hr but few if any had emissions higher than 300 g/kw-hr. I don't recall any of the DFI 2-stroke outboards having CO emissions above 200 and some were below 100. So to the extent that the 200 g/kw-hr in the proposed regulations was accurate, it's likely that there was some industry push back from the 4-stroke makers.
