  Calculating Size of Shelter
Author Topic:   Calculating Size of Shelter
Laurak posted 10-26-2013 09:42 PM ET (US)   Profile for Laurak   Send Email to Laurak
I am going to construct an A-frame building exclusively for storage of my [Boston Whaler 170 MONTAUK with a] trailer with swing tongue. The A-Frame will be open on the sides and both ends. It will function simply to keep falling leaves, limbs, and debris from falling on the rig. I would appreciate your advice on the width, length and height that I should build the structure. Hopefully, some of you have such a structure and can speak from personal experience. I will greatly appreciate hearing from you.
Thanks, Herb
Andy Holmes posted 10-26-2013 09:50 PM ET (US)     Profile for Andy Holmes  Send Email to Andy Holmes
I would build it a minimum of 12-feet wide by 24-feet long. The boat will be a little shorter and quite a bit narrower but the increased length and width will help keep stuff that blows in the sides and ends from making it all the way to the boat. I would expect, however, that with both ends and the sides open that some leaves will still find their way into the boat.
jimh posted 10-26-2013 10:04 PM ET (US)     Profile for jimh  Send Email to jimh
Do you get heavy snow in your winters? That will affect the pitch of the roof. With open sides, it sounds like you are going to use a post and beam construction. What does your local municipality say about building codes for a structure like this?
blacksmithdog posted 10-27-2013 06:00 AM ET (US)     Profile for blacksmithdog  Send Email to blacksmithdog
I'm getting ready to build a similar shelter for my Montauk. A friend of mine and I have come up with:
A 12-foot x 20-foot footprint (or the largest two-feet multiple) that will fit the space and materials available.
The rafters should be supported on the 20-foot side by a built-up beam (of two 2 x 10's). The beam should be supported by 6 x 6 posts spaced every 10-feet. Three posts total. If you go with a built-up 4 x 8 beam, use four posts for a beam span of 6-1/2-feet.
Twelve foot 6 x 6 should cover all contingencies of grade variations. When they are all set in place you can cut the tops to an equal height.
cc378 posted 10-27-2013 07:28 AM ET (US)     Profile for cc378  Send Email to cc378
I highly recomend this design: http://www.by-the-sea.com/stimsonmarine/bowroof.html
Laurak posted 10-27-2013 08:34 AM ET (US)     Profile for Laurak  Send Email to Laurak
Thanks for your replies. Andy brought to mind that the height of the shelter should be high enough to store the M170 on the trailer with the sun top in raised position with the boot on. I don't presently have the sun top, so if any of you can tell me the measurement for the height from the ground, up to the top of the boot, I would appreciate it.
Binkster posted 10-27-2013 08:39 AM ET (US)     Profile for Binkster  Send Email to Binkster
You say you want to build an A frame structure. There are no posts or beams in an A frame. The walls/roof are shaped like an A. To calculate the width of a building like this, you need to make a simple scale drawing. First measure the height of the gunwales of your boat off the ground, and the width of the whole rig. Then figure out how much clearence from the framework you want at the gunwales. Then you can draw the "A", and this will give you your total width of the structure dependent on the angle of the roof/walls, The wider the structure the lower the ridge, the narrower the structure the taller will be the ridge (top of the A). I don't know your carpentry experience, but it will not be a simple structure for the inexperienced. What will you use for sheathing and roofing material. If you are leaving the sides and ends open you will get debrees in the boat so you still need a boat cover. If you want simple, with no hassles like permits and plans check out Northern Tools. they have many portable garages that will work better for you.
rich (retired home builder/remodeler)
Binkster posted 10-27-2013 08:45 AM ET (US)     Profile for Binkster  Send Email to Binkster
This may work better for you.
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&ipp=24& Ntt=portable%2Bgarages
rich
Hoosier posted 10-27-2013 10:19 AM ET (US)     Profile for Hoosier  Send Email to Hoosier
Here's another option, note the caution about checking local codes.
http://www.menards.com/main/building-materials/ pole-barn-post-frame-materials/post-frame-projects/ versatube-12-x-19-10-x-7-carport/p-1495465-c-9901.htm
Peter posted 10-27-2013 11:22 AM ET (US)     Profile for Peter  Send Email to Peter
I used to build an "A" frame for my Outrage 18 for the winter. Actually, it was more like a very large saw horse. There was no precise measurments that I used and the construct was very simple.
Materials
- Four 10 or 12 foot 2x4s (the taller the better if you are in snow country because it will increase the pitch of the roof)
- two galvanized saw horse jaws
- two 12 foot long 1x6
- One cut to proper length 1 x 6 used as a vertical pole in the middle of the structure to prevent sagging and notched on one end to connect to the 1 x 6.
Erect the 10 or 12 foot long saw horse legs at each end of the boat so that they are leaning just slightly towards the boat. Lash the legs to the bow and stern of the boat with some rope.
Join the two 12 foot long 1x6s together at one end using some common bolts making the combined length long enough to cover the boat and motor (about a foot past the bow and motor cowl ). Insert the roof beam into the saw horse jaws.
Cut the other 1 x 6 to fit between the deck and the beam. Leave some overlength to notch the end of that 1 x 6 to fit the other 1 x 6. Do not worry about being very precise with that length because you simply use some wood to shim under the bottom near the deck.
Then cover with two tarps (I used the camouflaged 4 mil thick tarps) one for the bow should be about 20 x 12 and the one for the stern 10 x 12. Use bungie cords to hold tarp to trailer. I found that using two tarps were better than using one longer one for a variety of reasons including, easier to erect and provides access to the boat in the middle of the boat should you want to get in it.
I'm sorry but I don't have any pictures and the Outrage 18 was sold last year so I don't do this anymore.
Peter posted 10-27-2013 11:25 AM ET (US)     Profile for Peter  Send Email to Peter
One thing I forgot to mention, on the roof beam, cut the corners at the end at a 45 degree angle so they don't have a sharp point to wear on the cover. I used to put old unmatched socks (found a use for them) on either end. You can use a towel, rag or shirt, anything to prevent wear on the sharper corners.
Binkster posted 10-27-2013 04:13 PM ET (US)     Profile for Binkster  Send Email to Binkster
Im assumed he wanted to build a permanent shelter. You can throw together some sticks and visqueen and call it good for the winter.
rich
Peter posted 10-28-2013 06:05 AM ET (US)     Profile for Peter  Send Email to Peter
I'd only build a "permanent" shelter if I intended to use the boat during the off season. It's not clear from the original post whether that is the case but for most folks up here when you are thinking about keeping the leaves and debris out of the boat, the season is over because you've gone through all the steps to winterize both the boat and motor (assumes no Evinrude E-TEC on the transom of the Montauk 170).
