| Author | Topic: Propeller Shroud |
| jamesmylesmcp |
An interesting gizmo is being added here. It looks as if performance is enhanced with these add-on's. |
| kwik_wurk |
[A] Kort nozzle--a common device on low speed, high thrust situations. Very effective in high sea state as well, by reducing the localized turbulence at the prop. -- I use an enlarged prop guard on my kickers (bigger boat, not Montauk), and it will hold grip in amazing conditions. |
Using shrouded propellers is quite common on commercial towing boats. I don't see any evidence of improved performance. It would be more interesting if the authors of that article waited until they actually tested the device rather than just announcing they were going to use it. There's no results yet. I think the speed range of the boat is important in determining if a shrouded propeller is effective. I don't see many on boats that go 45-MPH. |
Here is a link to a report on propeller guard testing. In the report the concentric ring propeller guard is tested, and based on some pictures it appears to be the "Thruster" brand. The effectiveness of the concentric ring is rated good at speeds of 5-MPH, but not so good at planing speeds. At planing speed, an unguarded propeller was judged to be safer than any of the shrouded propellers. http://www.uscgboating.org/assets/1/AssetManager/ Propeller%20Guard%20Test%20Procedure.pdf |
Also see http://www.tradeonlytoday.com/home/ 526703-abyc-and-coast-guard-join-on-propeller-guard-test |
By the way, a Kort nozzle is a special type of shrouded propeller. It is the trade name of the company that manufacturers it. See http://www.kortpropulsion.com/kort_nozzles_and_propellers.htm There is also a good article on the topic of ducted propeller at Wikipedia: |
| pete r |
We use the prop shrouds on our rubber duck rescue boats (mandatory) and found they caveated at high revs. I think they contribute a little towards safety but still need more development. |
I wrote to the manufacturer of the THRUSTER to ask for a price quote on the model they would recommend for attachment to my 225-HP Evinrude two-stroke-cycle outboard with the M2 gear case turning a 15.5-inch propeller with 17-pitch. (That's my E-TEC with a MIRAGEplus.) The MSRP of a suitable shroud was $995. |
