| Author | Topic: Fuel Tank Mats Montauk |
| lizard |
I have a set of the original brown rubber mats that seat beneath the OEM Montauk fuel tanks. I am giving the tanks and mats to a friend who just picked up a Montauk. Any advice for how to restore, soften, make more pliable the mats, which are a bit dry and stiff? Thanks |
Armor All http://www.armorall.com/ |
| lizard |
Thanks JimH. Can you tell me, if the mats are pretty dry (my fault) is there any improved outcome by doing this on a hot day or doing several applications. I am kind of shocked and surprised how dry them seem. |
I have not tried Armor All on the tank mats, but it does a nice job on vinyl car floor mats. I would expect the tank mats would react in the same way. |
| Jeff |
Armorall is has never provided me good results for anything I have used it on. I would recommend using a high silicon content product like tirewet tire dressing instead of armorall in all cases. As silly as it sounds, use an old rag and wipe on a coating of heavy weight oil or even gear lube. Coat the rubber pieces and let it soak in for a couple days repeat and then wipe the excess off. It have brought life back into some old rubber mats doing that process. While not like new they are certainly more plyable and "rich" looking. |
Hydraulic steering fluid also will generally have a positive effect of plastics that seem to have dried out. |
Jeff--I will try some TireWet tire dressing on my tires next Spring. |
| frontier |
Would the mat need a dipstick to check the oil? :) Do you get oil rainbows when you wash the boat? The last set I had went right to the garbage can. Cracked like peanut brittle. |
| Dave Sutton |
Aviaton trick to swell and soften rubber seals in landing gear struts, etc., and works on almost any other rubber item: Lucas automotive power steering sealant. This comes in pint bottles and is designed to be added to power steering fluid to swell the rubber seals when they leak. It works on almost any rubber as well. Recommended. There is an aerospace product that is identical yet costs 10X more if you really want to guild the lily: Granville Strut Seal. The Lucas product has proven to be equal in performance. I'm certain it would have a beneficial effect on the mats. Make sure you buy the Lucas stuff, other manufacturers products have not proven themselves.
| trguy76 |
Like many of you, I appreciate oem products for keeping boats close to stock and try to utilize them whenever possible. I have a couple of old cars and follow that principle until a replacement part is no longer available and the original is no longer serviceable. Regarding the Montauk tank mats which are virtually impossible to find, I found three-quarter inch industrial rubberized floor matting, sold by the foot, at Tractor Supply. I cut two pieces in exactly the right size. After a full season, I am happy with the material. It is heavy, looks tidy, stays flat, does not slide, and seems impervious to gasoline. I have two six gallon tanks in my 2002 Montauk 170. In case the Lucas power steering fluid does not work on your old mats, this might be an inexpensive alternative to try. Jim C |
| lizard |
Thanks, Sutton, I have used Lucas Power Steering Sealant in a couple of unrelated applications and have it on hand. Thanks for the recommendation. |
| jhomeist |
Hi Lizard, Please let us know how the Lucas treatment works. I am interested because I have some original blue mats from a 1970 Sakonnet that need refreshing. Thanks, Jon |
| lizard |
I dropped the mats at Jon's already, but I will see his wife this weekend and give her the Lucas product. I am thinking a warm day is the best time to apply. |
