Topic: Sanding Wood With Palm Sheet Sander
littlehandegan |
posted 12-05-2013 08:14 PM ET (US)
Hello all. [I am] sanding my 15 SUPER SPORT mahogany interior. Is it okay to use a palm sheet sander? [I] plan to start with 80-grit and finish with 120-grit. Thanks
lanlubber
posted 12-05-2013 08:42 PM ET (US)
I'm currently using a Makita palm sander. I'm not looking forward to the louvers however. I read something online where someone attached a paint mixing stick to the palm sander with some sandpaper attached to the stick to do the louvers. Haven't tried it yet. |
frontier
posted 12-05-2013 09:08 PM ET (US)
I use a Porter Cable orbital sander and tape the shop vacuum hose right to the dust outlet. Just about dust free and works great. [Use] 60 grit to get the old varnish off quick, and finish with 150 grit. |
Buckda
posted 12-06-2013 09:27 AM ET (US)
60 grit on an orbital sander sounds VERY aggressive on expensive wood.I prefer to start with 100 or 120 grit on my projects. |
frontier
posted 12-06-2013 10:10 AM ET (US)
The Boston Whaler original varnish was amazing and very hard and tough. We had a classic 13 footer bought new and the original varnish was in new condition when we sold it 15 years later. Using 100 or 120 grit sandpaper to remove it would take forever and waste lots of sandpaper. Careful use of 60 grit or even 50 grit does the job quickly and easily. And it removes most, if not all, of the inevitable black spots from water. Following up with the 150 grit makes a smooth, beautiful surface. |
EJO
posted 12-06-2013 01:49 PM ET (US)
60 or 80 might be to aggressive on a belt-sander but not a palm sander. It is a great sheet to start removing varnish/paint with. If you're going to the bare wood use the 120 or 150 for final orbital sanding B-4 coating. Use 180 to 220 for in between coats. If you want it to last for a long time use CPES as your primer coat to protect the wood and get a perfect base for any of the major coats (Interlux, Spar, Pettit) I would use a Fein/Rockwell (or similar) oscillating tool for the louvers. Wood only will look as good as the time you spend preparing it. |
DVollrath
posted 12-06-2013 02:50 PM ET (US)
One other technique you might try is a heat gun and a paint or cabinet scraper. I've found this to be very quick and effective on some of the wood I've restored.Dennis |
Treypescatorie
posted 12-06-2013 08:05 PM ET (US)
I am re doing my 13 foot sport seats, what kind of varnish do you recommend? |
BobL
posted 12-06-2013 11:17 PM ET (US)
Any of the spar varnishes EJO named above are good. I have had success with Epifanes on my 13 Sport and 15 Super Sport. Be sure to buy a spar varnish with UV blockers. After all of your hard work, keep your newly refinished mahogany shielded from direct sunlight. Even the best finishes will break down in a few seasons if left in full sunlight.I never found it necessary to use more than 100 grit sandpaper to refinish my mahogany (also used a Makita palm sander). On badly oxidized wood I think I would go to 80 grit but after that coarser sandpaper is too aggressive in my opinion.
andygere
posted 12-07-2013 12:34 AM ET (US)
For a good varnish job, sand to 220 or you will see scratches through the varnish. I've had good luck stripping varnish with a heat gun, but keep it moving so you don't scorch the wood. |
boatdryver
posted 12-07-2013 09:38 AM ET (US)
Our cruising boat was an old Hatteras with a total of about 80 feet of wide teak handrail and cockpit coaming. Nothing more beautiful when varnished but nothing more detracting on an old classic vessel when it deteriorates to scaling and peeling. I kept it up myself for 6-7 years. Lots of work. When sanding down to bare wood and refinishing wood pieces that cannot be removed from the boat: After sanding with any shape sander there will be corners where the sander won't reach. I've had good luck with a long handled scraper with a triangular tip about a half inch on a side such that you can rotate the blade when it gets dull. Although these are made for scraping the grooves on moulding in homes, you can get into tight corners with a tool like this. I think the brand was "Hyde". Jumping ahead to the next step of applying coats of varnish, I always dreaded the problem of keeping an expensive varnish brush in good shape between coats and eventually gave up trying to do so. After talking to a fellow who was varnishing the beautiful teak handrail with a foam brush on his Grand Banks, I switched over to using the better quality foam brushes, not the low density super cheap ones, wrapping them in Saran Wrap between coats, and tossing them when they got stiff. Expert varnishers will scoff at using a foam brush, though. So give foam brushes a try if you tire of trying to maintain a fine varnish brush. JimL |
DVollrath
posted 12-07-2013 10:33 AM ET (US)
This may be changing. A recent article in Fine Woodworking by a finishing professional endorsed high quality foam brushes for some tasks. Dennis
littlehandegan
posted 12-07-2013 02:40 PM ET (US)
I will be using West Marines WoodPRO - its made by Epiphanes. Supposedly it is just like the Satin Epiphanes, will be doing a test piece tomorrow. |
PeteB88
posted 12-08-2013 10:09 PM ET (US)
Buckda is correct "60 grit on an orbital sander sounds VERY aggressive on expensive wood. I prefer to start with 100 or 120 grit on my projects." Be careful with those suckers. IF you follow the steps (dig into the reference section for tons of great info) and take NO shortcuts with materials and tools, you will have great results. AND take your time to ensure proper cure time between coats (test with sandpaper). Use commercial sandpaper and tools sometimes only available at auto body shop suppliers or pro painter supply houses. I use foam brushes and roller for sure but always have my varnish brushes ready (a couple over 20 years old) - and I usually wind up using them. Don't care about attitudes about no foam. I just think real brushes are easier to control especially for tipping off and I hate throwing things in trash. I've done miles of boards and acres of fine marine plywood panels including Brynzeel (various grades of their mahogany product) including panels used for entire boats. 1) Random orbital sanders are very aggressive and not the easiest to control. I have several, Porter Cable and Bosch. I always use finer paper with these machines. Be extremely careful with those units. 2) my "go to" commercial grade sandpaper for sanding high quality Whaler wood boards is either 120 or 150 using vibrator or hand sanding. I have Porter Cable and my original Makita I bought in pawn shop in Portland in 1984. I test finish condition and project this way. 3) Whaler wood - my experience confirms even if it looks butt ugly and seems ruined, it can be restored. I've had warped boards I've had run through a planer with terrific results. 4) As regards finish prep: assessing the job, for me, it goes like this a) if bright finish has lost 50% of it's original gloss, simple scuff sanding, removing the dust and a few coats of spar varnish (scuffed between coats) does the trick. b) if worse, then decide whether I am going to go all the way to bare wood or not. Considerations are exposed wood, checking, need to fair the wood, edge grain condition etc. Options are chemical striping or mechanical removal with sanders. Heat stripping is also an option but I've never had to do it. I prepare my tools including cabinet maker's scraper (w mill bastard file to keep burr on edge), vibrator/hand sanding and maybe a belt sander (very very carefully). I actually had great results with belt sanders and mahogany is hard enough that I didn't screw up the surface. 5) I have tons of 150 and go to 220 when I use random orbit sanders usually because they are so efficient. For scuffing I get great results hand sanding (quarter sheet, folded in thirds) as well as vibrator. 6) If you choose to strip with chemical products, have tons of painter rags, steel wool and solvent ready to scrub the grain as clean as possible. Gloves and respirator required. 7) curing time between coats is important to understand especially depending on temp and humidity. There are tricks and techniques for sure. I pulled all the wood out of my Harpoon and will be doing a few spots on the 13 in the Spring. All those pieces will need scuff sanding to prep for finish coats. The anchor cover from 13 was stripped to bare wood, when I got the boat some years ago, repaired and I chose to use WEST Systems epoxy base coats with spar varnish. A couple of corners have rubbed down through the varnish coats and exposed the epoxy which is real obvious. Plan is to apply varnish but gives me pause as to whether or not I would use epoxy base coats on marine mahogany in the future. I would totally do epoxy base coats on Douglas Fir Marine ply with 4 oz fiberglass cloth followed by epoxy saturation coats and spar varnish finish coats. |
PeteB88
posted 12-08-2013 10:10 PM ET (US)
I've used most of the varnishes and tend to go to Captain's (Z Spar). Some capable dudes posted on your thread so you should be fine. |
PeteB88
posted 12-08-2013 10:12 PM ET (US)
High gloss always for boats. |
wezie
posted 12-09-2013 02:04 PM ET (US)
Thanks Pete, and everyone else, your experiences help a lot. It seems to me that the shine on varnish comprises much of the UV protection. The chemicals help, I know; but sunshine reflected does not get a chance to do any damage. Once the gloss is gone, the degrading accelerates.Merry Christmas John |
Binkster
posted 12-09-2013 05:30 PM ET (US)
Once the gloss is gone, it looks like crap. Who would let it get that far. I learned to varnish as a teenager over 50 years ago. I worked part time after school in a boatyard in the spring, painting wooden boats. I became their varnish guy. I thin the first coat very little on new work. maybe 5%. I always heat the varnish, summer or winter. To do this, heat a pot of water on the stove to boiling. Remove from stove. Immerse a qt can of varnish in the pot of pre boiled water about halfway up the can. Let it sit for half hour. The warm varnish flows on and spreads better. I strain what varnish I will be using through a cone filter into a clean container. I scuff sand between coats with 320 paper on my orbital sander. Brush on thin coats, and use a dry brush on board edges. To do both sides of a board set the newly varnished side on a couple of wood dowels and then you can varnish the other side. If you use Pettits Captains Varnish as Pete and I do you can't go wrong. One more thing Palm sanders are mostly worthless. rich |
SpongeBob
posted 12-09-2013 08:25 PM ET (US)
I started to reply to this thread earlier but figured there would be someone to reply and left it alone. I just looked in and feel I have to put my two cents worth.Do not use coarser than 100 grit on a vibrating palm sander as you will leave little circles gouged into the wood which can be difficult to get out. I rarely go below 120 grit. On random orbital sanders this can be eliminated for the most part, however it is a much more powerful machine and again I would caution against anything under 100 grit. It is also advisable to start a random orbital on the surface rather than above it and bring it down. In the random orbital what you have is essentially a grinder. The random helps but the orbital still can tear up your surface if left to come into contact with the surface at high speed. Both these machines were designed to sand relatively large flat surfaces and should be used sparingly, if at all on corners or small edge grain surfaces. What works very well and has been mentioned are scrapers. Not the ones with handles, but cabinet scrapers. These are made of tool steel and come in various shapes and sizes (check "Woodcraft"). Cabinet scrapers can remove a surprisingly large amount of material very quickly, leave no sanding marks, leave an almost blemish free surface, and instead of being thrown away like sandpaper they can be resharpened. This is probably what your grandfather used and is as valid a tool today as it was then. A far as Boston Whaler, which I have a high respect for and own three, varnish is concerned it is nothing special and the same basic formulas are available today. What is no longer available are companies, well few, that are willing to spend the time and care that Hacker Craft, Chris Craft, and Boston Whaler in its early boats spent to get that eight to twelve coat "Bristol Finish". Those coats are what makes a finish last and what makes it hard to get off. While I don't consider myself an expert by any stretch I have spent most of my adult life "working wood", first as a carpenter, then for the last thirty four years teaching young people how to "work wood" as a high school "shop" teacher. Please don't take this as pontificating, as I said it's just my two cents worth which in this day and age is still not worth much. Jeff
PeteB88
posted 12-09-2013 11:18 PM ET (US)
Right on Rich, I didn't know you did all that but know and respect your experience. I've never heated varnish and will do that for sure next time. As regards Cabinet Maker's Scrapers (not sure if proper name but capped for emphasis) I look for Sandvik brand. They are critical to my varnish/bright finish tool box. One incredibly important reason: once you apply finish coats, or I apply finish coats, I learned to "chase runs and sags" with a real brush as long as possible. Specifically, I search for runs and sags and use wet tip to reduce or spread out them out as long as I can thus reducing or best case, eliminating runs and sags. That is best accomplished if you can keep the object flat/horizontal but that's pretty impossible. Once the finish begins to really cure the window of opportunity for spreading out the run or sag goes away, surface gets sticky and impossible to brush or tip off. If, after object cures you find runs and sags there is NO way you can sand the blemish away. That's when you go to your trusty, old school cabinet maker's scraper and very carefully scrape away the run or sag. It's more like peeling it away layer by layer; follow up with sand paper and botta boom botta bing, it's gone or at least ready for next coat. I have never done 12 coats in my life that I can recall, If I get 5 coats on, that's cool as far as I'm concerned - got that rule down when I was into wood/epoxy drift boats out west. Seemed to work just fine - no complaints. I usually scuff sanded and recoated the hull two years after it was new, so boat got two or three coats a couple years later whether it needed it or not. To illustrate how simple it is, I could scuff sand exterior, rails, chine and gunwhales on a 16 foot, high side guide boat entirely in about 20 minutes (by hand especially if D Fir w/o epoxy base coats and glass cloth), sometimes using vibrator. I could get the dust off in about 10 minutes (vac and tack rags or my innovation) and have it ready for first coat within 45 minutes from flipping it over. I'd chase the runs, keep an eye on things through a couple of beers, pick the bugs out of the varnish and wait for full cure for next application maybe a day or two. Finish application for that whole boat probably another 30-45 minutes. Bottom line - Captain's Z Spar is a damn good product, tough, flows great when adjusted and no big deal. Plus skills you learn are applicable to other projects. I guess the big deal as you assess your project is to determine whether or not you have to fair the wood. ALSO - I've never had any problem with sanding swirls or lines ever. The finish is so viscous it fills microscratches in fine. The only reason to go 100 or coarser is if you want to "remove" or "reshape" wood for whatever reason. GOAL is to NOT remove wood unless you need to or to fair the surface. One more thing - Varnish loves a radius edge, NOT a sharp edge. My practice is to "break the edges" of the board using sandpaper hand sanding to make a slight radius or even (carefully) running power sander down the edge (not random orbit) following up with hand sanding. It's really easy and you want to achieve a very slight radius not like w a router. Your QA inspection tool is your hand. Constantly run your hand over your work to see how smooth it is and make uniform. ASLO when applying, I set up real bright lights to see how I am getting it covered and to look for "dry" spots, runs, sags and boo boos. I have a very bright hand held trouble light ready too.
EJO
posted 12-10-2013 03:52 PM ET (US)
If we are going that deep into varnishing there are many book written by "pros". The question is what is the starting point. Both Pete and Rich already mentioned these aspects, but when i started with a grey wood boat, meaning most of the varnish is gone but some is still on you must use something coarser that 100 grit. Yes the 60 and 80 will leave swirls in the bare wood that must be taken out with 120, but if you want to get to the bare wood through old varnish that even chemical stripper won't break down you must use something coarser than 100-120 grit. After you get to the bare wood and the weathering is removed you can then seal the wood with either a reduced varnish or as I previously mentioned CPES. This will "prime" the wood raises it fibers and get it ready to be sanded with 120-250 grit. After you have smoothed out this first coat and the swirl marks have gone you can use varnish per the cans recommendations for the next 4-7 coats with 320 grit sanding in between to make sure the next coat "grabs". As an old Dutchman I also have been doing this for 50 years on my self built boat, Chris-crafts, and many cabin cruiser and sail-boat. I personally prefer the Schooner varnish from Interlux over the other Dutch brands Epifanes and/or Pettit. (note; pretty interesting that 3 of the 4 top varnish brands come out of Holland (Z-Spar isn't)) Schooner will give you a deeper "golden' hue especially on mahogany. Last but not least, mahogany is and never has been a hard wood as teak. I don't know if BW used any teak or mahogany on their older models, but assume it is African Mahogany which is a lot less expensive than teak and now easier available than the more thought after Honduras Mahogany. It could even be some kind of sapelle. I recommend use the the more golden deeper tone of the schooner varnish instead of captains of the the other brands. |
Binkster
posted 12-10-2013 05:46 PM ET (US)
One thing that hasn't been mentioned yet is the use of a planer. Any piece that is flat like a seat or a seat riser (clamp), can be run through a planer set so only the finish is removed, and you will have virtually new wood. A woodworking shop can help you with this if you don't own one. Caution about running old teak through a planer. I did this with mine and the blades quickly dulled, though the teak looked new. rich |
littlehandegan
posted 12-10-2013 11:08 PM ET (US)
Well my next simple question is thisWhen applying varnish, is it best for the wood to be laying flat? How do you "set up" your wood so you can get the whole piece coated, without it laying on something? I want to be able to do complete coverage on each coat, does anyone hang the pieces?
Chuck Tribolet
posted 12-10-2013 11:54 PM ET (US)
"How do you "set up" your wood so you can get the whole piece coated, without it laying on something?"If you can lay the wood flat, "Painter's Pyramids". The pro paint stores have them, as does the web, though I haven't noticed them in the big box HW stores. Chuck
Treypescatorie
posted 12-11-2013 06:23 AM ET (US)
I screwed small hooks to the sides and hung them from wires in the basement. |
DVollrath
posted 12-11-2013 10:16 AM ET (US)
I use a piece of rigid foam insulation on my workbench. I place nails with the heads cut off into the foam to support the pieces of wood. I also have painters pyramids, but they often got shifted around due to sticking and bumps (seemed like always when I had a wet piece in my hands ). The nails into foam works much better for me.The foam I use is foil faced. I use base layers of epoxy for some pieces, and the foil under the work along with heat lamps on top allow me to preheat the wood. The heat is removed before application of the epoxy, so the wood is cooling. The theory (from a West Marine app note) is that this will minimize air from the pores of the wood being driven out into the finish as bubbles due to the exothermic action of the epoxy curing. Seems to help to some degree. Dennis
Binkster
posted 12-11-2013 10:39 AM ET (US)
Well the easy and most effective way to do that is to run 4 1 5/8" drywall screws through a piece of scrap plywood near the 4 corners of the piece you are varnishing. Varnish the one side but not the edges, and holding the piece by the edges flip the board over and varnish the other side. Then brush the edges with the brush, but do not dip it into the varnish can when you do this. If you do, the excess varnish will run under the bottom of the board, and will have to be sanded off for the next coat.rich |
Binkster
posted 12-11-2013 10:44 AM ET (US)
I didn't mention that you lay the board to be varnished on the points of the drywall screws, and will be unnoticeable in the varnish job. I'm sure I really didn't have to mention this, you probably figured it out.rich |
