posted 12-08-2013 10:14 AM ET (US)
My 12 gal steel Long cruise tanks were great, they fit perfect and lasted a long time, finally they developed pin holes in the bottoms all though I painted them and glassed the bottoms. Last year the last one went to the dump. I wish they still were made. They were about 90 dollars each A bit less the cost today as the Mirax with inflation .I have a couple of plastic tanks a 3 gal and a 6 I got both cheap on sales.The 3 is a extra tank that I grab if Im going any distance. I now use the 6 and a old Evinrude steel 6 gal tank that came with my original motor. Plus the 3 gal.
I have long thought of a big 24-27 gal tank I looked at the Pate some time ago, they developed troubles with ethanol gas. The Moller as described above is a nice tank I have considered that one and will have to place a new fuel hose hole in the deck if I ever go with that.
A couple of issues I have , had has me sitting it out with the plastic cheap tanks, One is that fuel does not keep very long and goes stale faster then in the past. I have gone out and had sour fuel stop me and changed tanks got back then had to drain out the bad gas and burn it off in my old truck little by little, a hassle. Gas stabilizer does work but its also not cheap.
The Mirax tanks are similure to my original Long Cruise, and are very nice looking, they are also expensive as they are high quality and custom made. They can be removed easy and drained of gas if the boats sitting a while.
This is a advantage to the Mirax tanks.
With the price of gas today , Montauk tanks are easy to steal hence with the Mirax tanks there goes gas plus expensive tanks and thats a disadvantage.
The Moller would be hard to steal as its big, but it can be done and with even 15 gallons in it, would be satisfying work for a thief. Of course its size makes it difficult to just pour out the gas into say a 5 gallon bucket then funnel into a thieves car. Perhaps a nice gas thief will simply siphon off the gas and leave the tank which would be Ok with me. When I get tired of my current tanks I think I will opt for the Moller.
I had a anchor stolen several years back I admired with amazement the clean cut that was made in the line when they took it and the chain it was attached to. And several batteries, gas tank hoses, lines, ...I will say if a boat is on a body of water where aircraft fly over, in and out of a airport like mine was stored and thieves steal anything that disables that vessel, gas, battery, gas line ect so it can not be used in a emergency water rescue, That type crime should be a federal felony.
