  Plastic vs Fiberglass and ethanol
Author Topic:   Plastic vs Fiberglass and ethanol
MikMal posted 03-04-2014 06:53 AM ET (US)   Profile for MikMal   Send Email to MikMal
I recently bought a 2000 Dauntless 22 that has a plastic fuel tank. I thought I was safe since I've read about ethanol affecting fiberglass only but now I'm thinking I may have been wrong; that the plastic tanks are affected as well. Does anyone know if the factory installed tanks from a 2000 boat are affected by ethanol? I'll be using the boat for half the year in Florida where I can get ethanol-free gas but for the other part of a year I'll be in Maryland where you can't get gas that doesn't contain ethanol.
Jefecinco posted 03-04-2014 08:21 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
The plastic tanks have not been affected by ethanol. I believe even the 2014 Boston Whalers are sold with virtually the same tanks. My previously owned 1999 Dauntless 16 had the same tank and the now owner tells me he has had no problems. My current 2009 190 Montauk has the same tank and is trouble free.
Don't worry and enjoy your Dauntless.
contender posted 03-04-2014 08:25 AM ET (US)     Profile for contender  Send Email to contender
Mik: This has been discuss here before, and for some reason the ethanol will eat the fiberglass tank and depending on which plastic tank you have it does the same. Ends up causing damage to your engine/fuel system. Some people here are die hard whaler fans and want to keep their boats as close to factory as possible. I think unless you are going to keep the boat in the garage and only show it this would be fine, I build my boat for my needs and wants so its a custom whaler. A custom Alum. fuel tank is the way to go, stronger and safer. Build the tank out of .125 thickness, your custom tank can be built in any shape and size. You can have your fuel fills and vents anywhere you want. Do this and you will never have to worry about a fuel tank again...
jollyrog305 posted 03-04-2014 10:44 AM ET (US)     Profile for jollyrog305
Mik,
Not sure where you will boating in Maryland, but there are a handful of gas stations that sell non-ethanol gasoline - http://www.buyrealgas.com/Maryland.html. I also was under the impression that Maryland only sold ethanol until recently when I was speaking to a Mercury mechanic who informed me of the one in Easton, MD. You could always call to confirm…
Tom W Clark posted 03-04-2014 10:46 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The fuel tank in a 2000 Dauntless 22 will not be affected by E10.
Aluminum fuel tanks have their own problems and liabilities.
Tom W Clark posted 03-04-2014 10:47 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
http://pure-gas.org/
MikMal posted 03-04-2014 06:25 PM ET (US)     Profile for MikMal  Send Email to MikMal
Thanks for the replies and especially the links to the non-ethanol stations in Maryland. Sounds like I shouldn't have an issue but none the less would like to run straight gas on it whenever I could.
Binkster posted 03-05-2014 09:08 AM ET (US)     Profile for Binkster  Send Email to Binkster
Tom sez, Aluminum fuel tanks have their own problems and liabilities.
Over time they tend to develop corrosion and pin holes when they are installed below deck and the bottom is immersed in bilge water. Installed on deck they should not cause a problem.
rich
