| Author | Topic: SAE Honors BRP Again |
The Society of Automotive Engineers (SAE) has recognized the contribution from two engineers from Bombardier Recreational Product's Evinrude division by presenting them with a 2014 Arch T. Colwell Merit Award. The honor was for engineering achievements described in a paper published in 2012 titled, "Development of a Compact Intake Porting Design for a 2-Stroke DI Outboard Engine. The engineers recognized are Paul Westhoff, Engineer Expert, Simulation for Evinrude, and Justin Johnson. This award and recognition from SAE is the second time BRP has been honored in the past ten years. In 2004 four BRP/Evinrude engineers also received a Colwell Award for work done in development of the E-TEC engine related to optimization of performance with computation fluid dynamics. An abstract of the 2012 paper from the SAE Technical papers library describes the work in more detail:
quote: The SAE describes itself as a "a global association of more than 138,000 engineers and related technical experts in the aerospace, automotive and commercial-vehicle industries." A total of 22 engineers were given a Colwell Award for engineering accomplishments in 2012. More at |
| Teak Oil |
Does this new intake porting makes it possible for the 250 H.O. to be three-star compliant? Or will it make the 300 three-star compliant next year? If the latter is true, that would mean the 300 is getting a 10-percent boost in power and economy. |
I believe the changes in EPA rules that are mentioned were implemented c.2013, and my inference is that the E-TEC engines sold c.2103 may have incorporated changes to meet those restrictions. But that is just a guess. My other observation is the 250 H.O. is three-star rated but the 300 model is two-star. That suggests to me they are producing different amounts of power and emissions. But that is another subject. |
| Teak Oil |
Since the 300 is still two star rated this intake design must only be in place for the 250 HO for 2014. Interesting. |
| Dave Sutton |
Unlike many of the so-called "Industry Awards" which are based on advertising with whoever is giving out the awards, the SAE awards are only given for peer-reviewed work that is considered to be of great technical merit. You can't buy a SAE` award, you need to really stand out. Well done for the recipients. This was pure research and may not be directly applicable to the products cited above. It may be applicable to current production, and it may just as well be "data in the can" for future use. Likely it's partially both. Dave . |
| Teak Oil |
Thanks Dave, You are probably right. Upon further reading it states "The model setup is a single cylinder with pressure boundary conditions incorporating an outwardly opening hollow cone fuel injector. CFD results, both integrated and spatially resolved, are evaluated on the basis of scavenging, mixture preparation and lost fuel out the exhaust port", though it never mentions an actual production environment oroperation on multiple cylinders. Perhaps this is coming out on the next generation outboard that they are driving around Florida with black covers over the motors lately. |
Dave--Your observations about SAE and their Colwell Merit Award are acute. When out of a global membership population of 138,000 engineers only 22 are recognized with this award in this particular year, that is quite a distinction. It is also quite interesting that the methodology and any insights gained are being shared openly with other engineers. In the context of the marine engine business, where we usually get marketing hype instead of real engineering, it is refreshing to see that a major outboard engine manufacturer is engaged in state-of-the-art engineering and improvement of their product with sophisticated methods. |
The same two engineers who received this SAE honor are named as the inventors on a U.S. Patent application which seems to be related to the same developments cited in the SAE award. The patent application describes the invention as providing an improvement in the operation of a two-stroke engine resulting in decreased emissions, increased power output, and improved fuel economy. That sounds like the Trifecta of engine improvement. |
