| Author | Topic: New To Me 2005 Boston Whaler 150 Sport - and a flushing question |
| Sal A |
Well gents, I took the plunge and picked up a local 2005 Boston Whaler 150 Sport with Mercury 60 Two Stroke engine. The price was right, and I like the seating layout! Just looking at the boat reminds me of all of Moe's all old posts a decade a ago on this website, including his diagrams. (aside - how is Moe? Hope he is well) The boat will sit in the water off my dock (salt water}. I will want to flush the engine after each use. Is my only option muffs? To my knowledge there is no flush port on these engines. Any advice? Can I flush the motor with fresh water on muffs, while she is in the water, with the engine running, WHILE SHE IS TILTED UP? Thanks all. |
| Jeff |
Sal, For the paint, if you have bare metal exposed and you want to paint it, I would sand the area with 150 grit sand paper and wipe it down with lacquer thinner. Then I would use a Self etching primer over the area. Give it 2 coats and let it stand for 30 minutes. You can then come back over that with your gloss black paint. I would do 4-8 coats and give it 15 -30 minutes between coats. Less time the warmer the air temp is. For the self etching primer I would recommend the Duplicolor paint that you can pick up at most autoparts stores. http://www.duplicolor.com/products/selfEtchingPrimer/ For the Black Paint I would recommend using Gloss Black Rustoleum Enamel For the flushing, yes you can start the motor tilted up and up it on muffs. |
| Sal A |
Thanks Jeff. I will do just that. |
| Ridge Runner |
Congratulations Sal... your first upgrade should be to replace that steering wheel... http://s166.photobucket.com/user/josephp732/media/130%20Sport/PICT0105. jpg.html?sort=3&o=1 |
| Jeff |
Haha, given Sal's track record, he shouldn't upgrade a single thing on the boat. Especially the motor. That is Sal's kiss of death. |
| Sal A |
Thanks to all of you... Thanks for your inquiries. The boat is now sold.... (Kidding) |
| Robert V |
Nice looking boat Sal, glad you are back boating again! Did you get the house completed since Sandy? I hope you are doing well and things are back to normal for you. I have nothing to add regarding the flushing question, sorry. Robert |
| boatdryver |
Hey, Ridge I want a steering wheel like that. Do you know supplier and part number? JimL |
| Ridge Runner |
I believe that is a discounted model - the current Schmitt model that comes closest is the 702: http://www.amazon.com/Ongaro-Vision-Stainless-Wheel-FingerGrip/dp/ B00C24T24W/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1401828550&sr=1-3& keywords=schmitt+marine+stainless+steering+wheel |
| Sal A |
Thanks Robert. We rebuilt a smaller house. The old one was demolished. We are very pleased with the cozy feel of it, and can't wait to enjoy some summer fun again. I hope all of my Sandy Brethren faired well, as we did. It was our second home, and not our primary residence. |
| david2000 |
When I had my Montauk 150, I regularly flushed the 60HP EFI 4S with muffs tilted up dockside in saltwater. The most difficult part was attaching the muffs to the outboard. It worked okay. |
| tombro |
See, Sal...I told you about upgrading that stock wheel. I got the Schmitt Destroyer with an Edson SS powerknob. Same on the Ventura. |
| tedious |
Regarding flushing in the water - forget about it, it's not worth the trouble, since it's going to be in a salty environment anyway. Do it at the end of the year or anytime you haul and store it for a while, otherwise don't bother. Flushing, while leaving it in salt water, will not improve the motor's lifespan or reduce maintenance. Tim |
| Jkcam |
Single piling lift. No paint, easy to flush. You can install it yourself. |
| Sal A |
Jkcam, I have enough trouble putting together "no tools required" particle-board cheapo furniture. I am about as handy as Richard Simmons in an auto garage. |
