   E-TEC G1 vs G2 250 HO on 23' Boat
Author Topic:   E-TEC G1 vs G2 250 HO on 23' Boat
seahorse posted 07-24-2014 10:21 AM ET (US)   Profile for seahorse
Here is a new discussion giving initial results of a re-power with the new G2 engine. The same prop was used in both tests. This was the first run and other props or heights were not played with at this time.
G1 vs. G2 250 HO Comparison on Same 23' Boat
Initial comparison with same propeller – 23-pitch Rebel
Average of two runs - engines tested on different days
You can see the fuel savings difference at cruise and at WOT with the new G2
Note the fuel load difference
G1
idle – 2.8 mph – 0.2 gph – 13.8 mpg
cruise – 33.6 mph –12.4 gph – 2.7 mpg
WOT – 60.4 mph – 26.2 gph - 2.3 mpg
Acceleration – 5.0 seconds
Fuel aboard – 48 gallons
G2
idle -- 2.5 mph – 0.2 gph -- 12.3 mpg
cruise – 33.2 mph – 9.8 gph – 3.4 mpg
WOT -- 60 .3 mph – 22.8 gph – 2.6 mpg
Acceleration – 3.7 seconds
Fuel aboard – 72 gallons
Jefecinco posted 07-24-2014 10:42 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
Pretty amazing difference in efficiency and time to plane particularly given the much heavier fuel load.
At approximately 25% better economy at cruising speed a commercial vessel should realize a significantly better return on investment.
Evinrude appears to have changed the game.
Peter posted 07-24-2014 10:49 AM ET (US)     Profile for Peter  Send Email to Peter
Wow. That is a significant improvement.
Dave Sutton posted 07-24-2014 11:01 AM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
Nice data. Keep it coming!
Dave
kwik_wurk posted 07-24-2014 07:13 PM ET (US)     Profile for kwik_wurk  Send Email to kwik_wurk
Hate to be a boo bird, but the differences are rather stunning, almost too good to be true. 25% mpg gain at cruise implies, the G1 was a dog (which could be to age), G2 is a engineering marvel, or the data has some explaining to do. -- What are the RPM's of the test points. I would expect improvements in the single digits.
Teak Oil posted 07-25-2014 10:15 PM ET (US)     Profile for Teak Oil  Send Email to Teak Oil
12 gph for the G1 seems pretty high at 33 mph, my G1 300 cruises a 22' boat at 33 mph and about 3600 rpm at under 10 gph routinely
jimh posted 07-26-2014 05:36 AM ET (US)     Profile for jimh  Send Email to jimh
The E-TEC G2 appears to provide a very significant improvement in fuel economy at the mid-range cruising speed. Cruising speed fuel economy is import to me. That is the engine operating condition where my boat consumes most of its fuel. If there is a significant improvement at cruising speed fuel economy, it will have a very significant improvement in overall boat fuel economy.
Mambo Minnow posted 07-26-2014 09:03 AM ET (US)     Profile for Mambo Minnow  Send Email to Mambo Minnow
The improvement in fuel efficiency is not surprising to me, as reviews I have read of side to side brand comparisons usually ranked Evinrude last in fuel efficiency. There was always room for improvement.
How does this compare to a four stroke's fuel efficiency?
jimh posted 07-26-2014 09:52 AM ET (US)     Profile for jimh  Send Email to jimh
The comparisons I have seen showed that the E-TEC (not G2) was already much better in fuel economy at idle speeds than four-stroke outboard engines, often by a factor of two. This is due to the stratified charge method used. My E-TEC (not G2) gets amazing fuel economy at low-throttle speeds. The only place a four-stroke outboard engine such as the HONDA lean-burn engines had an advantage in fuel economy was at mid-range cruise. The HONDA outboards in particular seem to be able to deliver really good fuel economy at cruising speeds. I attribute that to their automobile heritage, where fuel economy is absolutely necessary for survival.
Most of the head-to-head engine fuel economy comparisons provided by manufacturers tend to pick selected operating points where they can find an advantage over competitors' performance. Usually the variation is on the order of a few percent. I don't think anyone is going to base their choice of engine for a re-power completely on fuel economy, unless they are someone who runs 1,000-hours per year and lives where fuel is $9-gallon.
The best comparison of fuel economy among outboard engines is to look at the average fuel burn in GPH over an ICOMIA operating cycle.
