| Author | Topic: 2004 170 Montauk with E-TEC 90 H.O. |
| endus |
I saw some of the threads from earlier this year where the new E-TEC motors were discussed, but I am wondering if anyone has actually re-powered with one of the high-output four cylinder engines? We recently picked up an 2004 170 Montauk with the Mercury FOURSTROKE. The engine has been well maintained, but we are considering trading in and re-powering anyway. I'm aware of the major differences between two-stroke and four-stroke power cycle outboard engines, and we're specifically looking for the E-TEC. How big a difference will the high output will make> Is it worth it? Are there are any specific concerns? It sounds like the design of the motor is similar to an older and well-loved design. The dealer said he had one on a Montauk and it was _significantly_ faster. I wanted to see if anyone had any experience running the E-TEC 90 H.O. engine on a 170 Montauk. |
| Peter |
Given that the 90 H.O E-TEC model is built on the 1.7L V4 platform, it must have significantly better low and mid-range performance than a Mercury 4-stroke of the same HP and displacement. The 2004 Montauk 170 can handle the weight of the 90 H.O. E-TEC. I don't think I would put that motor on a classic Montauk as I think it is too heavy. |
| Chuck Tribolet |
How much does the E-TEC 90 H.O. weigh? My classic Montauk, and a lot of others, has a carburetor Chuck |
| ANDREW PITCHFORD |
[The E-TEC 90 H.O.] is listed at 390-lbs. |
| Chuck Tribolet |
I wonder where the 55 pounds came from? Does the H.O. still use a remote oil tank? Chuck |
| Teak Oil |
The HO will get the 170 on plane nicely and is a great fit for the 170 hull, since the 170 is only rated for 90-HP and it is well known that 115-HP makes the hull perform much better all the way around. With the 90 H.O. you are basically getting a 115 but will still be legal with the 90-HP limit. |
| thegage |
The H.O. is built off the V4 platform, not the in-line-3 of the standard 90, hence one of the reasons for the weight gain. |
| Peter |
Chuck--the 90 H.O. E-TEC is your 335-lbs Evinrude V4 90 with about 55-lbs of DFI components (injectors, fuel distribution lines, EMM, vapor separator, fuel injection recirculation pump, targeted oil pump and distribution system, exhaust sound baffling system, etc.) added to it. |
| Dave Sutton |
The key to a happy 'Tauk is a balance of power and weight. Low transom weights reward the boat and its owner greatly. The stock 90 is about perfect. The heavier HO? Not so much. Truthfully, a 70 is almost perfect too. There's very infrequent use for more.
I think Dave is speaking of the classic MONTAUK 17, not the newer 170 MONTAUK, when suggesting 70-HP might be adequate power. |
| Dave Sutton |
^^ True, the "170" is off my radar as being "anything", sorry. I lost interest in product changes when "Whaler" went to Florida and I stopped paying attention. A 17 Montauk is a self-describing thing, and they run well with a 70 for many applications. How different could a "170" be? Enough to need a 90 perhaps... if you say so.
| fishgutz |
Whaler specs state maximum engine weight of 410 pounds. I think the Montauk 170 and 90 H.O. would be a great combination. http://www.bostonwhaler.com/Page.aspx/pageId/29592/pmid/323825/ 170-Montauk.aspx |
| Ridge Runner |
I have the 170 Montauk with the E-Tec 115HO V4 (same block), it is a very good combination. |
| endus |
Thanks everyone! Yea, the weight was definitely something I thought about. The 390lb H.O. is definitely close to the transom weight limit. I've seen so many people on here mention powering with a 115, though, it seemed like it might be nice to wring a little more speed out of it without going over the official HP recommendation. 70lbs is a lot though. We were making about 29kts in flat-ish salt water turning about 5800rpm on the merc 4 stroke. The boat came with the rubber strip to protect the boat when beaching on it, so maybe that might impact top speed, but I wouldn't mind doing a little better. I need to make a run to a nice flat lake and see how I do there...people's talk of 40mph is intriguing and it sounds like the H.O. would do better than that. Maybe its a trim thing too. Dave Sutton - I drove a much older Montauk 17 with a 70 at a sailing place I worked at when I was younger. That definitely wasn't bad, but the 170 definitely "feels" much bigger to me. Even with the 90 I think it could get out of the hole a little better. The older boat felt a little more nimble and light, but the ride in rougher seas is *definitely* way better in the 170...no more spine crushers if you miss dropping the power for a wave. |
| EJO |
endus you were saying; "We were making about 29kts in flat-ish salt water turning about 5800rpm on the merc 4 stroke. The boat came with the rubber strip to protect the boat when beaching on it, so maybe that might impact top speed, but I wouldn't mind doing a little better." WE meaning more than one I assume? We meaning regular Americans of at least an average of 190 lbs? A little over 33 mph as you state wouldn't be bad with the drag of the Keel-guard (@ -1 mph). Alone and no keel-guard with good trimming gets you over 36 mph, do you really need to go faster? Now I do agree with that the hole shots are slow with the Mercs on the new Boston Whalers. But do you really need to get across the lake in a couple of seconds less when the seas are smooth? |
| ANDREW PITCHFORD |
You should be able to get over 40-mph with the merc 4 stroke. |
| Ridge Runner |
My 170 Montauk with the 115HO (127hp) will hit 51MPH with two onboard and 10 gallons of fuel running a 19" Stiletto prop. The big advantage is the hole shot and mid-range punch. I run a 4 blade Powertech SCD4 prop for pulling two 190lb skiers out of deep water starts and have a turboswing tow bar on my boat. |
| endus |
EJO - True, there were two of us and a full load of fuel, so that would impact things. We just worked out a setup where it will be pretty easy for me to take the boat out by myself, so I will have to give it a run with just me and a lighter load of fuel. I will mess with the trim as well...still figuring that out. |
| boatdryver |
dry weight of classic Montauk 17--950 lbs weight of Montauk 170---------1400 lbs JimL |
