posted 09-03-2014 11:43 PM ET (US)
My experience with the application of screw fasteners into the Unibond hull of Boston Whaler boats that are more than 20-years-old--that's the range of my experience not my assessment of the range of what I am about to describe--has found that most factory-installed or dealer-installed (or even previous-owner-installed) fasteners that were not installed on the exterior of the hull and below the water line were typically not installed with a bedding compound or sealing compound. Literally every screw fastener on my Boston Whaler boats--three boats in total--seemed to have been installed without any attention to bedding the screw into a sealant to make the fastener and its hole into the hull water tight. Based on that experience, I would have concern for a boat in which a significant amount of standing water collected in the boat cockpit and cabin areas. I think water could penetrate into screw fastener holes that were not sealed. It is also typical that not every screw fastener in an older Boston Whaler boat is still tightened. Years of running the boat, with vibration from the engine and banging around in the waves, tends to loosen fasteners. A loose fastener in a hole without any sort of sealant or bedding will certainly have a path for water to enter.I am mostly concerned about water getting into fastener holes where the fastener is screwed into a wood backing--and, of course, that is where most fasteners are located, as a screw into just the laminate will not have much strength or purchase. Because the water that has been standing in the boat under discussion was rain water, it was fresh water. Fresh water tends to create rot in wood.
To assess the possibility that there has been ingress of water through fastener holes into the Unibond hull and embedded wood backing material, remove some of the suspected fasteners. Probe the fastener holes with a small pick, testing the hardness of the wood. If the wood is soft and appears to be rotted, the fastener holes may be weak and in decayed wood.
I do know how far water might travel from a poorly seated and poorly sealed fastener hole.
Anecdotal experience: when I bought my first larger Boston Whaler, a Revenge 20, I had to borrow a truck to haul it to my home from the seller's location, as I did not own a tow vehicle with enough capacity to handle the load. I parked the boat in my driveway. It sat there for about a week. It rained almost all that week. I did not realize it, but all the plugs were in the boat. The next weekend, when I had a chance to pull back the cover and go aboard my new boat, I was very upset to see that several inches of rain water had accumulated in the cockpit from all the rain. I immediately pulled the plug, and let all the water drain. The next Monday I called Boston Whaler, and spoke to Chuck Bennett about what had happened. He told me not to worry--no harm done. Of course, that water was only sitting there for a few days. If it sat there for two years it might be a different story.
