| Author | Topic: Navigation Rules |
I just came across a rather entertaining program on BRAVO that follows a mega-yacht in the Caribbean charter trade. The show is called BELOW DECKS. It is something like Downton Abbey for luxury charter yachts. In a recent episode, the 154-foot mega-yacht was departing its slip at a marina and proceeding to the marina entrance channel, which was really the fairway in front of the slip. As soon as the yacht left its slip, it was more or less in the marina entrance channel. The yacht draws almost 7-feet. The depth in the channel is about 8-feet to 10-feet. As the mega-yacht begins to exit the marina channel to seaward, another vessel, a sailboat under power As the sailing vessel under power crosses the bow of the mega-yacht, it turns to starboard and passes very close abeam. A woman on the sailing vessel under power yells up to the bridge of the mega-yacht, saying "We have the right of way because we started toward the channel first." I don't think there is a rule in the Navigation Rules that says the right of way is first-come, first-served. The woman on the sailing vessel under power then rebukes the captain of the mega-yacht by saying, "Stupid one-percenters." In analyzing this situation, it looks to me like the woman on the sailing yacht was wrong, and they should have not proceeded into the marina entrance channel while the mega-yacht was trying to depart. The sailing vessel was obligated to keep clear on at least two rules. First, in a crossing situation, RULE 15 applies:
quote: (Rules are available on-line at http://www.navcen.uscg.gov/?pageName=navRulesContent Clearly the sailing vessel under power is now a power-driven vessel, and in a crossing situation must keep out of the way and avoid crossing ahead of the other vessel. The sailing vessel under power did not observe this rule; it did not keep clear, and it crossed ahead of the other vessel. Further, since this encounter took place in a narrow channel, RULE 9 applies: quote: With a draft of 7-feet and a channel depth of only 8 to 10-feet, the mega-yacht was likely constrained by her draft. The sailing vessel under power was about 40-feet in length, so it is clearly a "vessel of less than 20 meters in length" and it should not impede the passage of a vessel which can safely navigate only within a narrow channel or fairway. Finally, the comment from the woman that references "Stupid one-percenters" seem to explain the situation. Apparently the sailing vessel under power felt that it was time to extract some revenge on a wealthy person, and this motive was sufficient to override the navigation rules. It was an interesting situation. The professional captain of the mega-yacht managed to avoid the sailing vessel under power, and no collision or grounding occurred. |
| boatdryver |
There's also the over-riding rule (I don't know the number) which states, more or less, that both vessels are obligated to do what is possible to avoid a collision. The sailing vessel could have easily delayed entering the channel until the much larger vessel was clear. Then there's application of common sense which would advise not challenging a vessel 10 times your own displacement. Re the one percent issue, most people who own a 40 foot sailboat are themselves one-percenters. JimL |
| Dave Sutton |
In the crossing described by Jim, the vessel exiting the marina had the right of way.
Take a wander around the mooring fields of Key West sometime to get the full experience.... trust me on this one. Living "on the hook" down south for a few months was an eye opener.
JIml--Yes, I thought it was rather ironic for a woman who was sailing around the Caribbean in the winter on a 40-foot sailboat to begin to complain about other people doing the same thing, just in a bigger boat. |
During the encounter, the Mate on the 154-foot yacht comments that they are a vessel restricted in their ability to maneuver. I think he is wrong. RULE 3 gives the definition:
quote: Just because a vessel is deep draft does not make that vessel a vessel that is restricted in her ability to maneuver. You don't get the upper hand in any meeting just because you have more draft than the other guy. The special status of restricted in ability to maneuver comes only from the nature of the work the vessel is doing. A pleasure yacht pulling away from the dock is not a vessel restricted in her ability to maneuver under the navigation rules. The Mate was wrong. |
| Dave Sutton |
^^ Respectfully "sort of" disagree. That's study and experience gained from passing the test and then holding and routinely excercising a 100 Ton Masters License (Oceans, Motor & Steam, Commercial Towing Endorsement). A RAM (Rule 27) situation can also be "generally" applied to have the same cautions as can be applied to be vessel constrained by draft to a channel (Rule 28). The mate was not articulate in his differentiation of the rule, but he was pretty close. This vessel was not specifically a Rule 27 vessel but was certainly a rule 28 vessel. With that said, he also had privileges under Rule 9. I think from memory (Yes, I have it all memorized) that it's Paragraph C that gives priority to vessels over 20 meters in length when restricted by draft in a narrow channel or fairway.
There is a definition for a vessel constrained by her draft. It is in RULE 3:
quote: In the situation of the 154-foot mega-yacht with 7-foot draft operating in a channel with 8-foot to 10-foot draft, I would categorize the mega-yacht as being a "vessel constrained by her draft." The question is then to what special privileges such a vessel enjoys. RULE 18 says:
quote: Note that this applies only in international rules, not in inland rules. On that basis the mega-yacht did enjoy some privilege. On the other hand, I suspect a 40-foot sailboat also has about 7-feet of draft, too. |
| tedious |
On top of the nav rules, as a recreational boater, and a relatively experienced and careful one, I have some other rules that I apply to myself: 1) give all others the right of way, unless there's a good reason not to. I'm out there for fun, not to hurry around or assert my will over others - and you never know when someone else isn't going to know the rules. 2) always give people earning a living on the water the right of way - time is money for them, not for me. 3) check and make sure the fairway is clear before pushing off the dock or out of a slip. I have not seen the program, but it appears that the large motoryacht may have violated #3 and that the sailboater definitely violated #1. Furthermore, from the description of the behavior of the sailing vessel, it's almost a certainty the person behind the wheel drives a BMW. Tim |
| jimp |
tedious - Becareful with your #1. At times you are required to maintain course and speed. That way the "give way vessel" (as required by law) can take action to avoid you. If you change course, you violate the Rules... to a point. If you change course and let them proceed well in advance, no problem. Very similar to cars making a right turn at an intersection giving way to a car turning into the same road making a left turn. The left gives way to the right, but so often you see the right turn give way. Got to know the Rules.
| Dave Sutton |
"I suspect a 40-foot sailboat also has about 7-feet of draft, too" I suspect any sailboat of that length *cruising in the Bahamas* or *selected for future cruising in the Bahamas* will only have about a 4-5 foot draft. Otherwise.... well, let's just say that you're not going to go to very many spots.
| Dave Sutton |
Bahamas sayings: "With a 6 foot draft you can go pretty much anyplace you like, mon.. you just can't be choosy about when you want to go there, mon... " (think tides) "Shoal draft boats just let you go aground closer to the beach, mon..."
I think the incident took place in the British Virgin Islands, perhaps Tortola, in the Caribbean. |
| Dave Sutton |
"Be careful with your #1. At times you are required to maintain course and speed"
When all three lights I see ahead, I turn to Starboard and show my Red. Green to Green, Red to Red, Perfect Safety -- Go Ahead. But if to Starboard Red appear, It is my duty to keep clear -- To act as judgment says is proper: To Port or Starboard, Back or Stop her. And if upon my Port is seen, A Steamer's Starboard light of Green, I hold my course and watch to see, That Green to Port keeps Clear of me. Both in safety and in doubt, Always keep a good look out.
| Hoosier |
Rule Zero: Tonnage Rules. |
| Sourpuss1 |
Jim, Your harbor navigation question is interesting, but the question (in this situation) is probably moot. This is a "reality" show. There is a good chance that the incident was artfully staged. I have seen bits and pieces of "below deck" and while it is an interesting premise, the actual crew of the vessell would not make for good TV! http://www.the-triton.com/article/the-reality-of-below-deck-on-bravo. html |
I would not be surprised to learn that some elements of the dramatization are scripted, but I doubt the producers of the show intended it as a vehicle for learning navigation rules and dreamed up the close encounter of the mega-yacht with the sailboaters to provide a good example for us to discuss. |
| macfam |
Where we boat is the busy Coast Guard Station Woods Hole. Most, if not all, of the Coast Guard vessels are equipped with fixed guns. I think they are for sailboats............. |
Perhaps it is also useful to note that in the situation being discussed, it is not apparent that all the proper day shape signals are being shown. The mega-yacht, if she wants to be considered as a vessel constrained by her draft, should be showing the signals specified in RULE 28:
quote: The "cylinder" is a day shape consisting of a black cylinder hoisted on a mast. See http://www.navcen.uscg.gov/?pageName=nr_28 The sailing vessel had her sails down, and was clearly proceeding under power. If she had sails up and was also under power, she should have displayed a day shape according to RULE 25:
quote: Regarding whistle signals, being an INLAND sailor, I was expecting the mega-yacht would have to sound one prolonged blast of her whistle before leaving the dock, but, upon some research, I see that is only an INLAND rule, not an INTERNATIONAL rule. When the mega-yacht was confused by the actions of the sailing vessel under power, she did sound a prolonged blast of her whistle. That was improper. She should have sounded according to RULE 34:
quote: |
| EJO |
I still say that the Capt. of the larger vessel should have sounded its horn. I know it is an inland rule but there is also a rule that states to make sure all your safety equipment is in working order [capital-bee-hypen-figure-four] leaving a berth. Hence, all captains of big boats sound their horn to make sure it is working as part of the safety check. It also lets crew, passengers, and landlubbers know that the ship is underway. Might not be an official rule but every over-20m-vessel captain does it. |
| tedious |
jimp, Dave, I agree - there are times where continuing on and asserting the right of way, if you have it, is the safe and sensible thing to do, typically in a crowded waterway. I'm lucky to mostly boat where it isn't crowded, but I do apply that rule on the Massachusetts roads! I have also taught my kids another rule that I think is pretty important, that being to be predictable. Don't veer around all over the place and keep other boaters guessing, and if you make a course change to avoid someone, make it a big, noticeable change so the other skipper knows you are doing so. Tim |
Re RULE 34 on whistle signals, on further thought the rule makes perfect sense. There cannot be an international rule for vessels leaving a dock because a dock cannot be in international water on the high seas. A dock is already in inland water. The inland rules of the country whose inland waters the vessel is navigating would apply. I don't know the inland rules of the British Virgin Islands, so I don't know if they require a prolonged blast before departing the dock. |
| jimp |
jimh - Alaska has no Inland Rules, International rules are used here. JimP |
Perhaps other jurisdictions and other nations just use the International Rules, and also do not bother with having two parallel by subtly different sets of rules. It makes more sense. It looks to me like in the USA we have Inland Rules in order to accommodate some existing practices or historical methods. For example, there are unusual rules about navigation lights on the Great Lakes in RULE 23:
quote: It seems to me that by allowing the maintaining of some historical method of navigation lighting, the burden of compliance with International Rules was eased for a few large commercial ship owners, but at the cost of a rather significant burden of having two sets of rules and requiring all mariners to be aware of them. My opinion is the greater burden is (and has been) placed on mariners by requiring them to know all sorts of arcane and obscure rules, and, instead, a few commercial ship owners should have been made to change their ways. For example, what is the point of this rule:
quote: Why can't boats in the exempted region just shown the same navigation lights as they would somewhere else? Where is the burden in that? It is a much greater burden to mariners to have to learn these arcane exceptions. |
| jimp |
JimH - The commercial guys are usually up to speed on what and where they need something. Others (pleasure boats) get away with what they have installed by the builder. Special Rules apply in certain areas, as you've pointed out. Boaters should be aware of these and comply as they are able. For years the International cmmunity has worked on the COLREGS and in the USA they've worked on making things simple. But in the rules, change is "bad". Additionally, enforcement of lights is usually the last thing that is looked at because people are pretty good. But, in two cases: In 1, if your lights are working, red/green, white 360, nobody will give you trouble. In 2, we stopped, boarded, and fined the guy at 0500 in the dark because he had just thoroughly confused a tug and tow. The COLREGs are "fun". JimP |
JimP--I am all for compliance with the rules for navigation lighting. I just don't understand why the rules ought to be different in different regions. ASIDE: on compliance, it was rather odd that a Coast Guard boat that was involved in a collision a few years ago was not fitted with navigation lighting that was in compliance. It seems it is possible for even the Coast Guard to become confused about the navigation rules. |
