| Author | Topic: NAUSET Winter Cover |
| otter111 |
I [plan] to replace some tarps I used to cover my 1965 Nauset 16 with an off-the-shelf boat cover. After purchasing a couple from the Bass Pro Shop--one didn't fit, one had gotten terrible review--I am turning to my fellow Whaler enthusiasts. Can anyone recommend a brand and size that would fit, be durable, be good for winter, and good for trailering? I have both the center console and rails, and that seems to be problem for the covers I have gotten so far. I don't want to use the custom morring cover. I live in New York, and I need to keep off snow and ice. Also, I would like a cover that would be good for the road when trailering it. Thanks. |
| Jeff |
What you are looking for does not really exist and no matter what, there are no "Cheap" or "Off-the-shelf"cover solutions that work well, nor for a long period of time. A well made "snap to the hull" custom mooring cover can also be used for trailering and light winter use. Go to a local shop and tell them what you want to make and they should be able to help you. For heavy snows there is nothing other than tented shrink wrap, or a snow over with internal wood supports that would work and those do not work for trailering. |
| saumon |
A regular cover simply doesn't have enough slope for the snow to slide off. A $40 heavy-duty tarp with a wooden A-frame is perfect for winter covering, but obviously can't be trailered. http://www.myfishingpictures.com/data/500/medium/20150303_115725.jpg |
| Tom W Clark |
You want a Mills Mooring Cover from Wm. J. Mills & Co. There is nothing better. http://millscanvas.com/frame_index2.htm Part # 52-0753-01 for a 1965 Nauset with bow rail. Any color of Sunbrella you want. |
