posted 11-09-2013 05:50 PM ET (US)
1987 22 OUTRAGE W/2006 225 ETEC (1100 FLAWLESS HOURS) VENTURE BUNK TRAILER (NEEDS BRAKE WORK)T-TOP W/ NEW WINDOWS & CANVAS TOP, 4 ROCKET LAUNCHERS
LEANING POST W/ 4 ROD HOLDERS, 6 CUP HOLDERS
HUMMINBIRD 1197 CSI SIDE IMAGING SONAR/GPS WITH BUILT-IN MAP(10.4" COLOR SCREEN)
FURUNO 1623 LCD RADAR
GARMIN GPS 192 BACKUP GPS(SMALL COLOR SCREEN)
ICOM VHF RADIO
LENCO ELEC TRIM TABS
NORTHSTAR 210 FUEL FLOW METER
STEREO
26 GALLON LIVEWELL IN FRONT OF CONSOLE
RAW WATER WASHDOWN
77 GALLON MAIN TANK, 29 GALLON ALUMINUM AUXILARY TANK WHERE FISHWELL USED TO BE (PROFESSIONALLY BUILT)
ALL FUEL/VENT HOSES REPLACED 2008, TANK PRESSURE-TESTED
CUSTOM TABLE OVER ENGINE
LED SPREADER LIGHTS
TOTALLY REWIRED IN 2008 W/ BLUE SEAS SWITCH PANELS & HEAT SEAL CONNECTORS (16 CIRCUITS)
2 BATTERIES W/SWITCH
All plywood under deck replaced 2008, glued using thin slow-set epoxy (to allow epoxy to penetrate plywood).
Inside painted w/ Oyster White Interlux Perfection epoxy paint, non-skid areas mixed w/a touch of flattening agent and Intergrit. EASILY touched up.
Wood on gunwales replaced w/ new Mahogany 2008
Bottom has been barrier coated, painted w/Micron CSC w/Biolux antifouling paint.
The deep engine splash well in rear of boat was foamed in and glassed over, oversize drains installed. NO MORE WATER COLLECTION DEVICES!
$22,000 or B/O. TUNAON@COMCAST.NET
BILL 860-916-0694
Bristol, CT
