| Author | Topic: Buying 1989 22' Outrage Cuddy |
| Matt22c |
I am in the process of buying a clean 89 Outrage Cuddy powered by twin 2004 Yamaha 115's. It has Whaler Drive, Super Console and a 120 Gallon gas tank. Anything really to watch out for with this boat? I will have the sea trial this week and my tech look the engines over after. This is the first Whaler I will own and all the reseach I have done, I can't find anything that stands out. This boat will be used for fishing on the Bay and family duty (wife and son). Thanks for your help. Matt |
| Teak Oil |
Open the gas tank and rigging tunnel access hatches and look for excess moisture. It won't look pretty, but you do not want water around the tank, especially. The rigging tunnels do get wet with normal usage. Twin 115's is marginal power for that boat IMO, expect a top end around 40mph. |
| csj |
Matt, I'm on my 4th and 5th whaler, a 23' conquest and a 13' for my son. With that said I have bought all used and know one of the main concerns is water intrusion. Assuming the bottom is painted, you really need to take a look for any prior damage/repair. Wet foam is really your worst enemy ass well as wet damaged wood. If it's not painted then it will be less likely of an issue and or more easily detected. The stance or profile of the boat in the water or the water line can also tell you whether its wet as well, providing your motors are within weight specs. Take a good look at the transom as well ! I fish, ski/tube (the kids) on the severn and bay. Any question please as here or on my email. Chris |
| Matt22c |
Thanks for the heads up on the gas tank and rigging tunnels. The boat is on a trailer with bottom paint. I inspected the hull and it looks in good shape. No bottoms repairs have been made. What is the best way to inspect the gas tank? |
| Matt22c |
This is the boat. http://m.yachtworld.com/mobile/boats/1989/Boston-Whaler-Outrage-22-2698382/Pasadena/MD/United-States |
| boatdryver |
Start by removing those deck plates. Photos look positive. Thousands of dollars of add-ons there, starting with the T top. Looks to be a good find, depending on price and checking out the details. I'm envious. Its rare to find something out West that looks that nice in photos. Too much year round boating weather. JimL |
| Jeff |
There are a lot of things to look at when surveying a large Whaler but, no stand out issues on a 22 Outrage Cuddy w/WhalerDrive. The one thing I would check for is rot and the overall integrity of the floor / fuel tank cover. Otherwise you will end up doing a repair like I did: http://continuouswave.com/whaler/reference/outrageRestore.html Every Classic Outrage is going to have to have this project done in it’s lifetime. Some much sooner than others. That hull you are looking at has a T-Top installed, that will always increase the likelihood of problems in the floor. If you want a go-by document here is a 20 something page write-up I created and use when I am inspecting Whalers. Just so I make sure I cover all the bases. Finally, that particular boat has been for sale for 12 – 18 months if not more. That to me says a few things. Without inspecting it in person you can only speculate that there might be problems with the boat. Also, as others point out, many would look at the 115’s on that hull and worry about it’s overall performance and see the hull as being underpowered. Truthfully I would want twin 150’s on that hull at a minimum. |
| Matt22c |
Are you sure the boat has been for sale for over 12 months? The guy selling it just bought his replacement boat 3 weeks ago. I only thought it was on the market for 2 months or so. |
| jimp |
2nd photo in the Yachtworld.com link shows the two engines - port has a 3-star rating decal, starborad has a 2-star rating decal. Engines look identical. Nice boat. |
| jlh49 |
Hi Matt, Just a couple of observations about the Whaler your considering. The boat has been for sale for a while. Twin F115's are a lot of weight for the provided horsepower, so I am with Jeff that the boat might be slightly underpowered. Based on my view of the referenced pictures, the lines of the bottom paint might indicate a possible heavy stern situation. I would certainly be aware during you boat test. Other than repeating the comments already stated, good luck with your decision in this regard. Jack |
| Jeff |
The listing on Yatch world might newer but it has been in Craiglist at least since this time last year. When it was first listed it was actually listed as a 25 Outrage likely because of the length overall and it was listed at $19,900 |
| Tom W Clark |
I disagree that 230 HP is too little for an Outrage 22 whaler Drive. jimh has 225 HP on his 22 Whaler Drive and I've never heard him complain it is too little. The F115s weigh no more than the V-6 two strokes that boat was designed to accommodate, the motors don't have anything to do with the potential for this boat to be stern heavy. The bigger problem is the optional Extra Capacity (120 gallon) fuel tank, which is common on these 22 footers with Whaler Drive because back in the 1980s when they were equipped with twin two-strokes, the fuel consumption was very high so they really needed the extra capacity for a decent range. It's not so much the added weight if the extra fuel, but rather the sternward shift in the center of gravity of the fuel. Essentially, the Extra Range tank is just a standard 77 gallon tank extended in length into what would have been the fish well. This mean the center of gravity of the fuel is shifted sternward by about two feet and *this* makes a huge difference to the attitude of the boat. Combined with twin 400 pounds motors, these models always floated stern low. |
| Matt22c |
This sucks. I wonder way this thing has sat for so long. The owner seems very knowledgeable about the boat. Good records, etc. I have not sea trialed the boat or paid to have my mechanic look at it. Not sure if I should even think about spending the money to have it inspected. |
| andygere |
I have a standard notched transom 1989 Outrage 22 Cuddy, and it's an excellent boat. I agree with Tom that the power is adequate, and also that the weight problem is more related to the oversize fuel tank than the outboards. The good news is that you don't have to fill the tank all the way, and even though the fuel may roll to the back, I don't think it's an overwhelming deal killer. I think a sea trial of the boat with full fuel is necessary to give you a better picture of how the boat will sit at rest and perform on plane. Looking at the pictures, I put together a quick list of pros and cons, from my perspective. Pros Cons I would definitely want to see it in person, run it and then determine what it's worth. The sum of the parts may be worth close to the ask, but the devil is in the details. |
| Matt22c |
I know it does not have a full tank of gas. I believe it is around 3/8 full. I am doing a sea trial this Thursday. I will check to see how stern heavy the boat is. I will also look soft spots in the deck. I thought this boat would be good for fishing and taking the wife and 3 year old out. |
| Jeff |
If your primary use is going to be family day cruising and outings I would suggest a Revenge that gives you a much more open floorplan and more protection from the elements for the family. If it is going to be mostly fishing, you might want to consider a standard Outrage. I think you will find the floor space to be very tight on that boat. Also, the reason why I would want twin 150's is to be able to plane the hull off on one engine if you had to. Single 115 is never going to do that so to me that defeats the porpose of rigging twins. Finally after having a 22 Gaurdian with the large capacity fuel tank I can say when full the hull does sit low. Also when you are half empty and at rest I found that hull to pitch and roll more with the seas than my earlier 22 Ourtage with the smaller tank. |
| andygere |
My kids have both grown up in mine, but Jeff is right, there is less deck space than a Revenge, and especially since it has the closed transom and SuperConsole. The cushioned cooler seat in front of the console is a favorite place for the kids to ride, and they do hang out in the cuddy when it's cold outside. I took out the leaning post and put an RPS in mine, which added some seating. With a leaning post and no cooler in front, there is no place to sit on that boat. For fishing, no problem, for family use, perhaps. Ditto Jeff's comments on the 115's not planing out the boat. It's why I stayed with a single and a kicker when I repowered mine. |
| Matt22c |
That’s a good point about space. It will mostly be used for fishing. I have a old boat now for fishing that my wife will not step foot on. I was thinking this would be a good compromise with the cuddy to allow them to get out of the sun if needed. The boat is not cheap, so I am on the fence about it right now. The future repair of the gas tank and floor scare me because of the work involved. i.e., having to remove the T-tops and console. |
| Tom W Clark |
I'm pretty confident a 115 would plane an Outrage 22 Whaler Drive, even over-propped. The specified minimum power is only 90 HP. Any Whaler of that vintage has the same fuel tank dilemma (including my own 1988). If this boat needs a new one tank then haver to opportunity to replace it with a shorter tank that will improve how she floats. I do agree with these guys that a Revenge ay suit your needs better, especially a Revenge Walk-Through model. |
| Matt22c |
I am going ahead with the sea trial and go over the deck very closely. I am also going to keep the boat in the water. Do you think the outboards with tilt fully up out of the water with Whaler Drive? |
| crabby |
As the owner of a 22 Outrage Cuddy Whaler Drive with Super Console I have a few comments: This model is a bit bow heavy; the extra weight on the transom may help pick up the bow a little. I currently have a single engine setup and sometimes have issues with bow steering (even though I have removed the cuddy cabin). If you need to get the lower units out of the water when tilted you may have to add some weight to the bow that is easily removable (such as sand bags or buckets of water). I use this technique to get my engine bracket out of the water while docked. (Currently I only have a single engine and I removed the cuddy, so I need a little weight to raise the stern at the dock.) The cuddy takes up a lot of fishing room. I removed the cuddy as I got tired of trading off usable deck space for a tiny cabin with minimal head space. The cabin deck did make a nice casting platform however. The super console also takes up a lot of space. I removed the t-top that originally straddled the super console as there was less room to maneuver than I have on my Montauk. 230 horsepower should work. When one of my twin 150's died I used the boat for several weeks on a single 150 that was still propped for twins and it always planed with two big guys and two big dogs. I currently have a single 250hp E-Tec that will push the boat to 46 mph on a good day. BTW, my boat has the 77 gallon tank. And a previous poster is correct about the t-top potentially damaging the deck (and possibly the console) if not mounted very solidly. I needed to repair both the deck (two decks actually) and my console due to damage from the t-top shaking things loose. |
| home Aside |
I have a 1985 Revenge 22 WT with a Yamaha 225, no whaler drive, it has a 129 gallon fuel tank, even when the fuel tank is full, it floats like a cork.... |
| Matt22c |
Did the sea trial. The boat is nice. He had the deck up 1.5 years ago to inspect the tank and decking. He said there was no pitting in the tank and no issues with the deck. He replaced all hardware on the tank. He also inspected the foam, no water issues. Deck is very solid. I walked around with my shoes off and could not feel any give or soft spots. The guy has all records for work done and has saved all the teak taken off the boat. Getting the outboards looked at and hull by a service tech. He did not sell the boat last year because he did not have a replacement and he said he was asking to much. |
| andygere |
Big plus that the deck has been lifted and the tank inspected. I assume all the hoses were replaced at that time, a big job for a boat with a super console and T-top. How did it perform with the twin 115s? Did you try to plane the boat with a single motor? |
| Matt22c |
All hoses where replaced. It performed well. Top speed was 41. Cruse was about 30. It did get up on plane with one running. |
| Tom W Clark |
That's not bad at all. I can see from the ad photos that the motors are mounted all the way down when they should be mounted all the way up. Even back in the 1980s, Whaler shows twins on the Whaler Drive mounted all the way up. I can't see what propellers are on there, but I strongly suspect all aspects of the boat's performance improved with higher motor mounting and new props. |
| Matt22c |
The original add has many more pics. http://www.boatquest.com/listing/133265/1989-22-ft-dot--boston-whaler-24-outrage.html#.U0igvee9KSP |
| Tom W Clark |
The propellers in those photos look like the Yamaha Painted Stainless steel model that have subsequently been polished. If you end up buying the boat, take a closer look and see what they really are. The Yamaha painted Stainless steel model is not a bad prop for this application, though I think there are better. About the only thing I do not like about the F115s on this boat is that fact the F115 is an intermediate size gearcase motor and that limits the propeller choices and propeller size for the boat this size. You want as much blade area as you can get and it is hard with this size motor. Until recently there just were no good large blade area props available for the F115 |
| andygere |
That's pretty impressive performance, about what I get out of my notched transom 22 Cuddy with a single 200. Getting it on plane with a single 115 is a big plus. As I suspected, the gear cases are in the water even when tilted the way the outboards are currently mounted. I wonder if they would clear when mounted all the way up? If you plan to keep the boat on the trailer, it may be a non issue for you, but I would not want those gear cases in the water full time if the boat is kept on a mooring or in a slip. Overall, looking like a pretty solid opportunity. Consider the cost of a new trailer ($4.5-5K) in your valuation. |
| Matt22c |
This is what was came up in the survey. Let me know what you guys think. 04/15/2014 Twin Engine Survey & minor hull review for purchase 04/15/2014 FINDINGS; port Yamaha LF115TXRB 68W X 100061 visual inspect 04/15/2014 Stbd Yamaha F115TXRC 68V X 1030983 Visual inspect good, oil full but 04/15/2014 No indication of water in gear oil both engines- port trim not working from 04/15/2014 Hull: moisture test with Tramex meter indicates high levels in hull sides & |
| Matt22c |
I wanted to thank everyone for there input. I am picking her up today. |
| jimd |
Congrats Matt! Welcome to the 22 Cuddy Club! |
| andygere |
You will really enjoy that boat. it's really versatile, stable and well equipped. Congratulations! |
