posted 05-11-2000 04:47 PM ET (US)
Simon - I've mounted 8' whips on my Montauks and Outrages in the following place:
Starboard inboard side, using the heavy duty chromed swivel bracket, (throughbolted on the Montauks).
Place it so the (in case of the 17's) antenna, in the down position rests on top of the stainless steel horizontal fittings that attach the rub rail to the hull.
On the later model Outrages, I mounted it again on the inside of the gunnel and mounted a small stainless steel bracket (usually used to clip bimini hold down straps to the hull) also on the inner gunnel about 1/2 inch from the top of the antenna. That way, when the antenna is stowed, I bend it slightly and insert the end into the clip.
My current '73 21' Outrage has that same system. Just throughbolted on the upper skin's gunnell.
Never had any problems with that type of install.
How do you like the 19'?
Best - Don
