Topic: Pate Fuel Pickup Tube Drops Off
triblet |
posted 05-15-2000 10:02 AM ET (US)
I have a 1998 Montauk with the 25 gallon Pate tank, and about 200 hours on it.Saturday, about ten miles from the launch ramp, the engine quit and wouldn't restart. After about 15 minutes of problem determination, I figured out that the fuel pickup tube had dropped into the bottom of the tank. We stuffed the fuel hose in the filler hole till the primer bulb served as a stopper, then wrapped it in electrical tape, and got home, but has anyone else seen this problem? Chuck Tribolet triblet@garlic.com
lhg
posted 05-15-2000 04:16 PM ET (US)
Chuck: Small world, I've had the same thing happen to me, except with a Tempo tank. On the 12 gal Tempo's that I have, about 15 yrs old and originally designed to fit under the mahogany console Nauset, the withdrawl tube simply slides over the barb on the tank fitting, which screws into the tank top, and is held on by considerable friction. Or so I thought. But for some reason they come loose after soaking in a full tank of fuel for a month or so, and drop to the bottom of the tank like yours did. I suspect it's the 10% alcohol in the fuel these days. It seems to soften & lubricate the fuel hose, causing it to come loose. Try calling Pate directly for a solution. I also need an answer to this problem. A simple hose clamp would solve my problem, but I can't get one on there from the inside of the tank! |
triblet
posted 05-17-2000 10:25 PM ET (US)
The solution was the resolder it myself. Whoever did the original soldering didn't do a very good job. There was only about 50% solder coverage where the two pieces contacted. In your case, I presume you shove the rubber pickup hose through the hole, then screw down the fitting. Why not try one of the spring steel hose clamps? Put it on, then, if you have to, grind off the two little ears, then stuff the hose and screw down the fitting. Chuck Tribolet triblet@garlic.com |
lhg
posted 05-18-2000 01:53 AM ET (US)
Chuck: Your presumption is correct, and I'll try one of those spring clamps. Have not seen them before. Thanks for your idea! |
