Topic: Seat Dimensions
Graham_J |
posted 06-03-2000 07:54 AM ET (US)
Greetings,First, a thanks to jimh for running such a great forum. I acquired a 1982 15' SS a few weeks ago and have found this site invaluable. I am redoing all the mahogany and have everything removed from the hull (lots of fun). The boat was missing the center bench seat. Can anyone supply the exact dimensions of the mahogany needed to build a replacement? Any recommendations for a source would be appreciated also. Thanks in advance! Graham
whalernut
posted 06-03-2000 08:31 AM ET (US)
Graham,scroll down in this same forum and you will find a company called Custom Skiffs and Repairs. It is under the topic wood and fiberglass consoles and componants. Hope this helps you redo you`re Rockland, Mass. Whaler. Regards and good luck-JACK. [Moderator's Note: this article has been edited.] |
posted 06-03-2000 08:50 AM ET (US)
The 15 SS had just two seats, a plain front thwart and a more elaborate rear thwart with backrest/storage compartment.The mahogany thwart seat width is easy to deduce from the pockets in the risers where it fits. The seat could be made by buying a "5/4" mahogany plank, then having the plank milled to 1" thick. The length is easily deduced from the width between the cockpit molded ledges on which it sits. Making the seat back and storage compartment will be a little harder! I don't know of a source of the exact dimensions. Maybe someone on the forum has a 15-foot Super Sport and could take a few measurements. The photographs in the REFERENCE/15/ section show pretty well the general shape and form of the seat/backrest/compartment. I think that there is some variation over the course of production for some parts, too. The front hatch on some boats is made from planks, while on others is is made from plywood. You'll need to find a lumber yard with good mahogany planks and a willingness to mill them down for you. And I'd save the mahogany sawdust to use in making epoxy thickener for gluing it all together, too. --jimh |
Backlash
posted 06-03-2000 06:13 PM ET (US)
Graham, I'm not sure which seat you're talking about. As Jim stated, there are only two...a front and back(helm)containing storage in the backrest. Be more specific. I have the complete mahogany interior from an '89 SS in my basement, so am able to supply you with any dimension desired. Steve |
Graham_J
posted 06-03-2000 10:12 PM ET (US)
Wow!Thanks for all the information. It is the front thwart seat that is missing. I measured the distance between the ledge and the rubber retainer on the side pieces and it is about 1-1/4" and I want to be exact in the width if I am going to hack into some expensive mahogany(I don't trust my measurements). My Whaler doesn't have any storage in the aft seat. In looking at the model descriptions, it appears it is a Sport 15 with Seatback Option, not a Super Sport. I assume that is one of the differences between the two models. Backlash, if you could supply the length, width and thickness of the front thwart seat, I would grreatly appreciate it. Thanks again... Graham
Backlash
posted 06-04-2000 09:21 AM ET (US)
Graham, My front thwart seat measures: 1" x 11-3/16" x 53-13/16" Good luck! Steve |
Graham_J
posted 06-04-2000 01:20 PM ET (US)
Backlash,Thanks for the information, that should do it! |
posted 06-04-2000 05:12 PM ET (US)
Just check the front thwart seat on the 15 Sport in the garage, and got these:L: 53 7/8 W: 11 5/8 H: 15/16 (hard to tell there is a slight bevel) Those are pretty close to Backlash's numbers. --jimh |
Graham_J
posted 06-04-2000 10:07 PM ET (US)
Hello Jim,Thanks. Hmmm, let me see if I interpolate between the two, that should be the most accurate -- right? I've taken out and taken apart every bit of interior mahogany as of this morning. I am using a citrus-based varnish remover to get rid of what's left of the last coat of varnish -- that job looks like it is going to take some work. I will just imagine how good it will look when it is completed! I just hope the dark spots will sand out or I can find some wood bleach to lighten them. Thanks again... Graham
Graham_J
posted 06-08-2000 04:52 PM ET (US)
Hello again!I dropped by a local hardwood lumber yard on the way home today and purchased a 5/4 X X 12 X 10' piece of Philippine mahogany (beautiful). They are going to plane it to 1" and I will then have some space lumber after trimming it to size. Will cost about $75 when I am done! Now I just hope it complements the existing wood that has probably lightened over the years. They do accept returns, I am sure. Graham |
lhg
posted 06-05-2001 07:26 PM ET (US)
With varnished Whaler mahogany, I have noticed that the wood definitely lightens over the years, with both the varnish turning yellow, and the wood itself bleaching out.Just stripping the wood of varnish, and lightly sanidng, is not enough. You must orbital sand off the bleached out surface wood, to get back down to the original "pinkish" mahogany color. In addition, I wipe on a coat of oil based mahogany stain before revarnishing. This will give you a beautiful dark varnished finish, and the additional stain pigment will keep the wood looking much better, longer. It will help prevent the UV degradation (bleaching out) of the wood itself. Kind of like sun block. |
