Topic: drain tubes too short
beby138 |
posted 04-10-2001 08:38 PM ET (US)
I took out the old corroded tubes from my 13'68 (both),went to west marine yesterday bought 1 7/8 " and 3" (only sizes available on brass), but they're too shorts.Do they need another part?. Can i get larger sizes? Where?,any inconvenient w/ the plastic ones? Thanks in advanced for the help!
Dick
posted 04-10-2001 09:47 PM ET (US)
The original brass ones are available through Whaler dealers as well as the newer PVC ones. Don't think West Marine can supply the correct length. Dick |
Kim
posted 04-10-2001 10:30 PM ET (US)
I have done all the tubes in my montauk17. the dealer here said the order # for the tubs was such as ? well I'm trying to say that if ordered B/W would send what is the replacement . dose this make sence.(s/p) we had a hard a hard time finding the part # for a 1982 so what I did is go into the show room and showed him the new style tubs. and asked hem to order them for me. note * the plastic (new style) are a bit larger and the fibor glass will have to be drilled out. for this ; I first dtill a piece of wood, with a hole saw. then you can HOT GLUE it in place. (to use as a guide to start the hole) a normal hole saw can be used for this. I like (LENIX) (s/p) * I have the part # if you need them for a montauk.. hope htis helps. use LOTS of 5200 ... one LG tube is enought to do all the tubes... kim. PS.I think I saw some say they saw some tubes at west marine plastic ones might be the same thing. |
beby138
posted 04-11-2001 05:51 PM ET (US)
thanks for the info,I'll use the 3" for outside and PVC for inside. MikeMiami |
