posted 04-26-2001 04:15 PM ET (US)
Dick - Sounds like 5200, which is a bitch to scrape off.
Problem with many marina installs is that over the years, the bedding compound will breakdown and allow water to penetrate into the wood transom. Better way to avoid this is to oversize drill out the through-transom holes, coat the insides of the holes with epoxy and let dry, then clean out the holes to the proper size and mount the engine. Best way is to oversize drill then pour a solid plug of epoxy, let dry and redrill proper size (learned from a top rated fiberglass repair shop in the area that the above procedure is the _only_ way they mount outboards after replacing the transom. In fact the owner mentioned to me, that he keeps hoping that the new installs _never_ change to his method, he likes the work!)
What size of yamaha are you going with, and how are you mounting it?
