posted 05-03-2001 08:52 AM ET (US)
It sounds like the wood must be the imbedded wood intended as backing for bow hardware mounting.I guess you have to decide if you are simply filling a crack, or if you need to make a structural repair.
Epoxy (like West System) is excellent for repairing the laminate because it will produce a stronger bond than polyester resins.
Epoxy also does not dissolve the foam; some polyester resins will melt the foam, which makes them less suitable for repairing areas which expose the foam core. It sounds like your repair may be down to the foam level since you are seeing the imbedded wood.
If you need to restore structural integrity to the damaged area, you will probably have to grind away some of the existing material and lay in some cloth.
The West System Repair Guide ($3) is an excellent guide on how to do this. Its pages and illustrations describe the process far better than I can here.
If the damaged area will be under the rubrail or under the flair of the bow, it may not be too visible when finished, so you don't have to worry about getting a seamless job in making the repair.
As for the rubrail, if it is the original style it is white and is retained by adhesive.
--jimh
