posted 05-26-2001 04:19 PM ET (US) My fish finder when powered on disables my hand held 5W radio. All I hear is the "noise" on all chanels from the finders pulse and the scan fucntion won't work. Is there a way I can shield my hand held with an after market product? Radio = Hummingbird VHF5 Finder = Raytheon L365
Thank you
Dick
posted 05-26-2001 06:34 PM ET (US)
I have the Raytheon L365 fishfinder also and it doesn't bother my dash mounted VHF. I have never used my hand held on the boat so I just went out and tried it. A Raytheon 100, with the fishfinder turned on the handheld functions fine even setting against the fish finder. Scans allright too.
I am mystified.
Dick
70_Katama
posted 05-26-2001 06:41 PM ET (US)
Dick
What did you do with the excess transducer cable? I have mine looped and tied under the console. I wonder if I should burry the excess in the canal with the other cables?
Dick
posted 05-26-2001 07:36 PM ET (US)
My excess cable is also looped and tied under the console. The old flashers used to cause electrical interference but I have never had it happen with any of the modern units. I am at a total loss on this one. Good Luck Dick
triblet
posted 05-26-2001 08:17 PM ET (US)
My Humminbird Wide 3D Paramount doesn't bother either my handheld HF (Standard Horizon HX350S) or my console mount VHF (Standard Horizon Spectrum).
Something's really wrong, especially if it makes the VHF stop scanning. My first guess would be power supply noise, but the VHF is running off it's battery.
I'd try a buddy's handheld first. It it messes that up too (I suspect it will), complain to Raytheon.
Novice Dave
posted 05-26-2001 10:08 PM ET (US)
70_Katama we have a problem.
I also have a Raytheon L365 and a Humminbird VHF5 and hear a static pulse every second with the L365 on and none with it off. The VHF5 is not attached to the boat power or ground so I think it is radiated noise from the L365. If I move the VHF5 over 3 feet away from the L365, the noise pulse stops.
The VHF5 seems to be suseptible to the noise where other radios aren't...Raytheon and Humminbird may just blame each other.
70_Katama
posted 05-26-2001 10:21 PM ET (US)
Dave
Same thing. I can use the radio from the bow with the finder running. I think were screwed on this one. I'm going to make some calls, but I dont expect much. If I find anything worth while I'll let you know.
Thanks for all the input.
Novice Dave
posted 05-27-2001 01:38 AM ET (US)
I think I'll return my VHF5 radio to West Marine and get a different one.
It appears the Raytheon 100 works with the L365.
Tom Byrum
posted 05-27-2001 01:46 AM ET (US)
I had a Raytheon finder that caused the same static on both of my radios. (handheld Icom and regular Icom) I sold it and bought a Sitex and it had the same problem. I sold the Sitex and bought a Furuno and the problem went away.
70_Katama
posted 05-27-2001 09:41 AM ET (US)
BoatUS will credit my account for an exchange on a new radio. I'm going to install a fixed mount.
