posted 06-03-2001 12:11 AM ET (US)
Kelly - If the factory didn't have to drill another hole during rigging, it probably isn't there.
How handy are you with a drill?
If I recall right, there is a small oval grommet that is glued, screwed or pop rivited in place. You might be able to contact the factory for the correct piece. In the alternative, a round grommet like the sort found in the newer hightech desks might be able to be used. Another type is called a chaffing ring, available through SSI, P.O. Box 99 Commerce Avenue, Hollywood, FL 20626, 301-373-2372. Ask for a catalog. Interesting stuff (my recessed panel for the breaker panel came from them).
After you cut, and before mounting whatever grommet you find, take some resin and coat the inside of the hole, where the wood is exposed, to prevent water infiltration.
don
