posted 07-28-2001 02:58 PM ET (US) On my 2001 Montauk I have two accessory switches marked ACC-1 and ACC-2 on the dash. I just hooked up my compass light to ACC-2.
I noticed that on ACC-1 there is a blue wire hooked up. I couldn't figure out where it goes and nothing happens when I click on the switch. Does anyone know what this wire might do? I didn't think anything was hooked up to these two accessory switches.
dgp
posted 07-29-2001 03:20 PM ET (US)
GAwhale, on my 2001 Montauk, the blue wire, which is the instrument illumination power wire, is wired to the Nav/Anc switch. BTW, I'd wire the compass illumination to the Nav side of switch. That way it's on only when you need it.
GAwhale
posted 07-29-2001 05:49 PM ET (US)
dgp-Thanx for the info.
On my boat the wires are gray on the NAV/ANC switch.
The wires are brown on the Bilge switch.
I just looked through my owners information packet again and could find nothing on these two switches or ACC-1 and ACC-2.
Dick
posted 07-29-2001 06:00 PM ET (US)
On my 99 Montauk there is only one accessory switch and nothing was powered off of it. The instrument lights are powered off of the nav light switch.
triblet
posted 07-30-2001 12:36 AM ET (US)
Is the blue wire part of the factory wiring harness? Is it wired to the switched side of ACC-1, or the always-hot side?
Also, ABYC codes:
Light Blue: Oil pressure sender to guage. Dark Blue: Fuse or Switch to cabin and instrument lights.
I'd check (at night) to see if it turns on the instrument lights. If it does, I'd wire to the NAV side of the running light switch.
GAwhale
posted 07-30-2001 08:05 AM ET (US)
Dick and Chuck - Thank you for the info.
I'm not much of a sparkchaser. I am bringing my boat to the dealer today for 'Over-Current Protection' warranty. See my post under Post-Classics. I will ask them. Maybe the two are related???
GAwhale
posted 07-30-2001 08:10 AM ET (US)
My instrument lights turn on when the ignition is in the on position. I switched ACC-1 on and off several times and it did nothing.
GAwhale
posted 08-13-2001 07:35 PM ET (US)
The blue wire on the ACC-1 switch is for Navigation Lights per Boston Whaler Tech Services (BWTS).
I picked up my boat from the dealer this past Wednesday. They completed the Over-Current Protection recall. They called BWTS last week, however all the Techs (plus two people from my dealer) where in meetings for the 2002 line up (something like that).
TAL Marine was nice enough to call me today with the information.
posted 08-13-2001 11:08 PM ET (US)
The blue wire may be the "Compass Light" power. This turns on the illumination for the compass. It is pretty hard to see this lighting except in darkness.
--jimh
White Bear
posted 08-14-2001 05:42 AM ET (US)
On my 1988 20'Outrage there is a factory installed switch for the compass lighting. I swapped the blue wire which powers the instrument lighting from the navigation/anchor light switch to the compass light switch as it seemed a more logical arrangement of systems.
