posted 08-06-2001 06:08 PM ET (US)
I am looking at buying a 1976 13’ sport. The hull’s exterior is in pretty rough shape. The bottom has a 4-5 spots about 6 inches long that are worn through to the foam. It looks like the boat was ran aground (beached) repeatedly over a period of a few years. The boat has not been in the water for five years and has been on its trailer. I believe that there is no water trapped in the hull. The rub rail is pulling away from the hull in a couple of places but the hull behind the L-shaped piece looks OK. The transom and the drain tubes look OK. The interior of the boat is in good condition with the exception of the front hatch cover.My questions are: 1) Am I nuts? 2) How difficult are the worn through spots to fix? I assume this involves using the West System and lots of sanding. 3) The last step seems to be painting the hull. There have been two extensive recent threads on this. I understand most of the advice but still do not completely understand if can you paint the entire outside of the hull and have it last for a long time. I would trailer the boat and only have it in the water for a couple of days at a stretch. 4) Given that I have very little experience with these kinds of projects would I be biting off more than I can chew?
