ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods 1980 25 Whaler Hull question
Author | Topic: 1980 25 Whaler Hull question |
Cliff |
posted 08-23-2001 10:17 AM ET (US)
I recently had the opportunity to look at a 1980 25 Whaler for sale...price $18,750......after some research on this website and some emails back and forth to BW I was able to determine that this boat was the 23rd boat BW produced in this model year...the first year the 24,7 Outrage was produced(A40023). Anyway....the boat needs work, alot of it....checked out everything that could be a problem...drain tubes....condition of fiberglass, transom condition, etc. Of the many things I saw wrong with the boat that were fixable, one thing I saw concerned me above all else....While standing on the boat(while on a rack) I peered over the port and starboard gunnel and noticed that near the waterline, near the middle of the boat, there was a certain undulation or wavy look to the fiberglass....I don't believe I was imagining this and just wanted some feedback as to whether or not this condition would serve as the death knoll for this old whaler.... Additionally, when I opened the access panels to the gas tanks, the rear tank had what I thought to be an extreme amount of condensation buildup around the tank or at least where I could reach inside and feel.I have a feeling that that kind of moisture should not be present around a gas tank. Thanks in advance for all you comments and advice. Cliff |
Tom W Clark |
posted 08-23-2001 10:40 AM ET (US)
Cliff, There is nothing unusual, nor catastrophic about the waviness in the sides of the hull. It is present in almost all the boats of that era. I have been led to believe that it had to do with the foam they used in the hulls at that time. My local Whaler dealer, Terry McCartney of Jacobsen's Boats and Motors, told me Whaler changed foam vendors because of this. The amount of waviness varies quite a bit. My own '83 OR 18 had it to some degree and I have seen a hull so puckered it was returned, and replaced under warranty. The defect is essentially cosmetic and there is not much you can do about it except enjoy the boat. As to the fuel tank, there will always be water around the tank because it sits down in the bilge. While the tank is foamed into place it is not totally encapsulated in it and bilge water is free to make contact with the tank. As a result, there is always condensation down there. For better or worse, this is how Whaler built them. |
Cliff |
posted 08-23-2001 11:03 AM ET (US)
Tom Thanks for your reply....that is a relief to hear, but I am planning on having a survey done regardless..... Also I forgot to mention 2 other possible problems: The owner told me that one of the gas tanks had developed a leak that had flowed into the stern baitwell and that he had to have the deckplates removed and the leak fixed....could water be getting to the bilge and around the tank if the deckplates were not reinstalled properly? Also, there were a couple places on the hull below the waterline where the gelcoat had been damaged....the worst was the starboard chine where about 6-8inches of gelcoat was missing and the green fiberglass was visable.....how concerned should I be about water intrusion..... and delamination.... The transom also had areas where the backing plate washers had penetrated into the fiberglass as well... Thanks again for any responses Cliff |
LarrySherman |
posted 08-23-2001 11:11 AM ET (US)
Cliff, I know we talked about price before you saw the boat, but from the description you provide above, $18k is too much for this boat. Larry |
Cliff |
posted 08-23-2001 11:15 AM ET (US)
Hey Larry I agree....the boat needs some work without even taking into consideration the twin 1990 135 hp mercs....one of which I know had had the powerhead rebuilt....the only way I would take the boat would be for a lowball price......maybe 9K...I really think thats all its worth Cliff |
lhg |
posted 08-23-2001 01:27 PM ET (US)
The hull side waviness that TWC describes in the 1983 18' Outrage was a definite defect with the first models produced. I believe over 100 were replaced by Boston Whaler. But considerable hull side waviness in other, larger & heavier models is usually the result of long term improper hull support (no keel support) from either a bunk trailer or bunk storage rack. When the keel is not supported, the sides end up taking a lot of the stress, and tend to buckle a little under the load. I made the mistake of storing my 25 in one of these rack places, with no keel support. Sure enough, the hull started showing signs of initial waviness, so I put it back on the keel roller trailer. The problem stopped developing. |
Outraged |
posted 08-23-2001 06:36 PM ET (US)
I would definitly have that chine scape taken care of, with some filler,and then a shot of gelcoat. I would low ball them as well. Hope the deal works out for you. |
Cliff |
posted 08-23-2001 09:23 PM ET (US)
Everyone has recommended thaI lowball the guy for this boat....suppose he actually says yes to $9k????? Seriously, since none of you have seen the condition of this boat, and I know it is only a guess, what would be a respectable lowball...one that would be taken seriously? Also what is the average cost of a marine survey these days? Cliff |
bigz |
posted 08-24-2001 03:14 PM ET (US)
Cliff expect to pay from $300 to 500 for a survey. A lot depends on how far the surveyor has to travel and if there is a sea trial or not. Cliff, you'd be buying a lot of trouble from what you have explained as the condition of this boat. A surveyor isn't going to be of much good just to reaffirm what you have already assessed. Here is a link to a previous discussion this spring on "oil" can or "wavy" topsides. http://continuouswave.com/ubb/Forum1/HTML/000642.html Tom C and Larry G both pretty much explained that this can and does occur. The reason I bring this back up is to add a point which may or may not be relative. With all the work and dollars you'll have to spend to bring this 25 back up to shape (Yes you probably do have water in the hull from the areas you mentioned, if she sat for lengths in it) after is all said and done the wavy sides, regardless that they aren't a structural issue, are cosmetic! If and when you ever decide to sell her be prepared to a take major hit since people do buy with their eyes even if you have everything else pristine. That said, if this 25 was pristine and the only problem was "just" the wavy topside areas would then certainly consider her even at the price he is asking, at present after your evaluation even $9k seems high. Once you leave the under say 22 foot class cost for repairs etc begin to multiple by 2 to 3 fold. Just my two cents worth --- best of luck whatever you decide --- Tom Z |
Cliff |
posted 08-27-2001 09:41 AM ET (US)
BigZ Thanks so much for your insight and for answering my questions...the link you added was even more help. Sorry for my delayed response to yours....but over the weekend I traveled to see the boat again and to shoot a couple more rolls of film...... I am really in a quandery as to what to do.....make an offer or walk away.....I think it really depends on what this guy is willing to take and I am afraid it is more than I am willing to pay.. As they say...whatever the market will bear... All the points you and others made were good ones and now I think I really just need to weigh the pros and cons...... Thanks again and kudos to this site.....a marvelous resource....and wallet saver. Cliff |
