posted 11-11-2001 11:00 PM ET (US)
JB,You needn't make this more difficult than it need be. You can do this and do it easily.
I build things for a living and I can assure you you will have a greater chance of success and a greater degree of accuracy if you do not get bogged down in a written description with dimensions and angles and such. By all means make a full sized pattern. Here is but one way to do it:
I suggest you start with a piece of cardboard. A large piece of corrugated cardboard from a large box would be best, one that does not have any folds in it, but a single fold won't hurt either.
We are dealing with a simple trapezoid here, the altitude of which can be measured easily enough with a tape measure (i.e. the front to rear dimension) You may precut the cardboard to this width.
Take the cardboard out to the boat and overlay it on the locker. Use masking tape to hold it in place if you want. The take a straight edge, be it a 4' level, a 2x4 or some other piece of straight lumber, a yard stick, whatever, and lay this on top of the cardboard so that one of its edges aligns with the edge of the locker minus the distance you want for the reveal (gap) around the edge. Take a pen or pencil and scribe (trace) the straightedge in the cardboard. Repeat on the other side.
Now remove the cardboard and cut along the sides. Either use a sharp utility knife (box cutter) and straight edge, or some tough scissors or good tin snips to make the cut.
Now that you have the basic shape, try placing the cardboard on the locker and see how it fits. If it needs trimming then do so.
For the corners, you can find some object laying around your house or garage that has the right diameter and nests into the corner of the locker and then just use that to trace the corner. Or you can just use scissors to "whittle" it down until it's just right.
For the corners at the rear, you can decide what radius you want, but it's something like 3/4" if I recall correctly.
Once you have the cardboard template perfectly fit you may either send it to the woodworker or use it to trace a paper template which will be easier to mail to them.
You can do this. It won't cost anything for materials so if your first attempt isn't perfect the second will be.
