posted 01-25-2002 04:06 PM ET (US)
Couple of thoughts here from West advocate...1) Don't mix big batches. If you use the pump system, take one pump of each. After mixing, split the portion into 2 cups, 1/3 left clear and the 2/3 cup for adding your filler.
2) Before you use the epoxy with filler, spread a small amount of the "clear" onto the area. It will hold better.
3) The cup with the epoxy and filler... spread the epoxy "butter" around in the cup. This will extend your pot life. If you leave lumped together in the bottom, it has the tendency to quickly heat up and become useless.
4) Once the epoxy starts to set, throw the rest away and mix a new batch. If you do, it will often ruin the finish.
5) Remember the epoxy needs to be covered with gel-coat or paint. Light will break it down in no time flat.
BW
