ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods 25 Evinrude on my 13' BW
Author | Topic: 25 Evinrude on my 13' BW |
Diggs |
posted 02-03-2002 01:17 PM ET (US)
It's too cold to work on the Whaler so I decided to check out the 25 HP Evinrude (not running) that came with the boat. The owner of the boat passed away last year and the wife only knew that the motor was not running.I have not put gas to it yet. The motor turns over, I can put it in rev, N and fwd and can tell the lower end is working. I suspect the original owner was trying to get to the impeller as the 4 bolts are missing that holds the lower end to the shaft.. http://www.sweetbreeze.com/evinrude.htm Can someone give me an idea how to get the lower end off or where I can get info on this motor? Diggs |
JohnAz |
posted 02-03-2002 03:00 PM ET (US)
There are several after market work books for your engine,,all are good and easy to follow, Looks like some one was trying to get to tdhe water pump, shift linkage has to be loosened first at top of shaft, below power head,,,,,get a book first,,Good Luck |
Diggs |
posted 02-03-2002 04:06 PM ET (US)
Hi JohnAz, I'm not certain if this is the original motor.. how can I tell the year of this 25 HP Evinrude in order to buy the right book? Diggs |
Tom W Clark |
posted 02-03-2002 04:38 PM ET (US)
Your motor is a 1979 model. ( http://www.evinrude.com/docktalk/modref/evmodyr/EHP25.html |
Diggs |
posted 02-03-2002 06:29 PM ET (US)
Thanx Tom, Little by little, thanx to this forum, I am gaining needed information. I will see if I can acquire the manual from the library first.. then if needed will purchase. thanx, Diggs |
JohnAz |
posted 02-03-2002 08:51 PM ET (US)
you might as well just buy the manuel $20.00 or so Sealock i think or some thing like that,,if you sell the motor just add it to the price,,,it's a good learnig tool,,i have one for each of my motors,,,, |
Dick |
posted 02-03-2002 09:18 PM ET (US)
The part number for the Seloc manual you need is #008-X (1302). Check at www.chiltonsonline.com |
