posted 02-26-2002 06:42 PM ET (US)
Dave:Putting in the new console is not difficult. Please just make certain that you have the appropriate wood backing diagram from whaler so that you anchor the new console into something more than fiberglass. Backfill any holes left from previous screws asap - even if it is a short term fix until you can patch the gelcoat.
The rerouting of the cable is fairly easy. What I cannot tell you is whether the cable length from the Standard is the same as for the Montauk. I replaced mine last year. If I remember rightly, the OEM cable for the Montauk is 18 foot. It is sized for optimal size radius bends in the cable. Check cable length first.
Are you getting the fully outfitted console? If so, it comes with switches, windshield, rails and a new Teleflex NFB steering system (but no cable I believe). Even if your cable is the correct length, you will need to check compatibility of the fittings. When I changed helm units, my old cable did not work.
Last, Teleflex warns that you attach the steering cable to the correct port. I do not know what happens if you do not, but...
Hope this is somewhat helpful. Good luck with the project. When you are done, you will be able to instruct everyone who has been considering buying the Alert and outfitting it as a Montauk.
Best,
Bob
