Topic: Repairing Drain hole
ScaughtY |
posted 04-11-2002 05:32 PM ET (US)
I need to fix my drain hole on a 13' whaler that rotted out last year. Any suggestions on how to repair it? I am curious to hear any suggestions on sealants I should use or any other pertinent product? Thanks
where2
posted 04-11-2002 07:28 PM ET (US)
Seen this thread before. Use plastic... If you set the articles to look for the last 2 years, then use "EDIT" "FIND ON THIS PAGE" and search for drain tubes, you'll find the last discussion. |
where2
posted 04-11-2002 07:29 PM ET (US)
jkh
posted 04-12-2002 03:31 PM ET (US)
I recently did this. I put in simi-flexive pvc pipe in the top two holes, and a piece of flexible reinforced tubing(a thick clear like rubber with some type of reinforcement woven in). I found these at Home Depot. They were about 9/16 diameter so I had to drill out the holes slightly. I didn't have a 9/16 bit. I had a grinding bit a took off just enough to ensure a snug fit. I sealed them in use 5200 marine sealant. Look like it is going to work fine. It was fairly simple to do after you find the tubing. Good luck. |
jkh
posted 04-12-2002 03:33 PM ET (US)
I assume you where talking about the bow drain holes. If you were talking about the rear drain holes - sorry. |
stinkyB
posted 04-16-2002 04:44 PM ET (US)
My drain tube was shot, so I replaced it with PVC and sealed with 5200. Cheap & easy!I used a wooden dowel to knock the old, corroded tube through. good luck. |
ScaughtY
posted 04-22-2002 11:07 AM ET (US)
Sorry Guys, I was talking about the rear drain hole Thanks |
Eric
posted 04-24-2002 10:28 AM ET (US)
I repaired my transom drain after the boatyard screwed it up. They had put in a non-standard (too large diameter) pipe. I enlarged the holes a bit more to fit a piece of schedule 40 PVC and sealed that in with 5200. The drain tube was a perfect fit within the PVC, and was sealed in after the first part of the repair dried. It's been 16 months, and I haven't seen any water dripping from the repair when the boat's back on the trailer. |
