posted 06-01-2002 12:58 PM ET (US)
kenyon,Water weeping from screw holes in the transom of a Whaler is very common. Unless the screws used for mounting transducers and other pieces of equipment are caulked well, water will tend to get in there.
Do not panic if water is coming out. There may be a lot or a little in the plywood of the transom itself or it may be that the foam in the hull is wet too. Not much to be done about it other than to leave the boat out of the water for a few years and see what happens. Water will not really “drain” out. The foam holds it very well.
Really, I would just seal the holes so more water can't get in there. You could do a little probing with a stiff piece of wire to find out if the plywood is rotten or not.
If the boat has been mooring in the water for some part of its life then some water is almost to be expected. If it has been moored in salt water then that's better for the wood as salt water has somewhat of a pickling effect on wood and will rot it at a slower rate. This is one advantage of a saltwater Whaler.
If is possible the plywood is rotten but it will not necessarily be. On the 13’ Whaler that I cut up I found NO ROTTED WOOD anywhere even though it was 32 years old and wet through and through. It was a fresh water boat as well. This surprised me. The wood in Whalers may be better than we think.
Remember that both water and air are necessary for dry rot to occur and if the transom is well sealed up again a little moisture in there shouldn’t hurt anything.
