posted 07-16-2002 12:30 PM ET (US)
Brass is copper and around 35% zinc (depending on the alloy, more or less zinc).Bronze is mostly copper and (0-5%)silicon, (0-5%) lead, (0-5%) aluminum or some even has (0-5%) zinc.
Brass is not something you want to use where galvanic corrosion is present, like in a cooling system, submerged in salt water or below the waterline. What happens with brass is the zinc acts as a sacrificial anode (like on the outboard) and corrodes away, and you end up with porous copper. Porous copper isn't very strong or leak proof.
Bronze is much more corrosion resistant which is why good through hull fittings and valves are made from it.
For hinges on your bow locker, it probably doesn't make any difference. I suspect the bronze ones are a little more expensive and probably would last a little longer under severe service.
Dave S.
San Diego
