posted 08-12-2002 11:43 AM ET (US)
It is not unusual for one ram or the other to retract before the other one does. Did you cycle the trim down until you heard and saw it "bottom out"?On my motors one ram would typically retract all the way and then the other one would do the same. When both are fully retracted you can hear the pump lower its pitch while simultaneously the motor gives a little downward twitch which lets you know it has reached it fully retracted state and is ready for trailering.
I remember when I picked up my Outrage from its original owner after a deal had been struck. I backed my truck up, hitched it and then tilted the motor up and engaged the trailering bracket. I then lowered the motor down while the former owner watched. As soon as the bracket landed and I then continued to cycle the trim down he ran over and cautioned me not to do that. He told me to just let it touch down and then stop so as not to "blow out a seal" or something.
At this point is was a little discouraged to think this guy had trailered this boat around incorrectly for six years. He apparently had never read his owner's manual as it explicitly describes this process and the importance of fully retracting the rams so the motor will not bounce as you go down the road.
It is not enough to try to lift up on the gearcase to test whether the motor is "locked down" or not. The rams must be fully retracted. A good bump in the road can cause the motor to rise off its trailering bracket and fall back down with a real shock if you do not do so.
