posted 09-20-2002 11:02 PM ET (US)
Howdy '63.The factory Service Manual will tell you to do this with the engine warm, spark plugs out, plug wires grounded and throttle all the way open.
You screw the fitting on the compression tester into spark plug hole #1 and crank the engine over at least 5 turns. I usually do this by jumping the starter solenoid so that nothing but the starter is "turned on". Record the guage reading. Repeat for each of the other cylinders.
Compression should be over 100psi in each cylinder and the range should not vary by more than 15%. The range is the most important number. If one cylinder is off from the others by more than 15% you have trouble.
The comression tester can be obtained at any auto parts store. Be sure to get the type that screws into the spark plug hole. Typical cost is about $20.
Good luck.
Red sky at night. . .
JB :)
