  Fiberglass vs Plastic vs Aluminum Fuel Tanks
Author Topic:   Fiberglass vs Plastic vs Aluminum Fuel Tanks
Jimm posted 01-07-2003 07:18 PM ET (US)   Profile for Jimm
I'm wondering what are the pros and cons of the different type of fuel tanks you would ordinarily see on a Montauk. I've talked to some of you and got your feelings but I hope that others will chime in with some facts.
Fiberglass - $$$$, long lasting (how long),
and stout. Only one I know of
is made by Pate.
Plastic- $$, long lasting, not as strong as
fiberglass,more easlily moved.
Moeller or Tempo -preference?
Aluminum-Most are custom made; I've got
a shop in NJ that'll make one
for about $265, that will fit
under my RPS (26 gallons)
(L x W xH :231=gallons) but
how do the hold up in a salt
water enviroment. It was pointed
out to me that there are a lot
of alum boats out there not do
ing too badly.
I'd be interested in your thoughts on these materials and how they hold up....Jim
Jerry Townsend posted 01-07-2003 08:51 PM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
Jim - In my mind, the best choice is aluminum in view of several considerations. First, the USCG has approved fuel tanks to be made of plastic, fiberglass and aluminum -so that is not a major problem. And, as you point out, there are aluminum alloys that hold up well in a salt water environment.
My thoughts are largely based from a safety viewpoint and the fact that one thing I certainly don't want on my boat is a fire. In this light, plastic and fiberglass are relatively easily punctured while aluminum is rather difficult to puncture. Rupture of the fuel envelope (puncture of the tank, leak or failure of a fitting or line, et.al) is a requisite of a fuel fire.
Another point of equal significance is the long term integrity of the tank. Normal operation of the boat induces dynamic fuel sloshing loads which can be quite large and with the continued operation will tend to fatigue the walls and corners of the tank. These sloshing loads increase with the length and width of the tank.
Consequently, one major reason I prefer aluminum is that baffels are frequently installed on aluminum tanks - which provide internal support to withstand the fuel sloshing loads. To the best of my knowledge, baffles are not incorporated in plastic or fiberglass tanks.
While touring BW's Edgewater facility, I observed the installation of plastic tanks in some boats. I questioned them on this practice and was told that they used aluminum on tanks over 50 gallons capacity. I don't know if their selection of the 50 gallons was based on a technical evaluation or was simply someone's subjective thought. The 56 gallon tank in my 17 OR is aluminum and is one of the first things I looked at when considering the boat. But, bringing this issue to one of my front burners, I will do some digging and provide some follow-up down the road a piece. ----- Jerry/Idaho
andygere posted 01-07-2003 11:15 PM ET (US)     Profile for andygere  Send Email to andygere
About the only downside I see in the Pate tanks is that they aren't easily removable to fill. If you always trailer your boat, no problem. If you keep it in a slip or on a mooring, you are at the mercy of gas dock prices. My Montauk has twin 12 gallon steelies, and with a handtruck (that I keep locked at my dock) I can easily fill the tanks at the low price gas station and cart them to the boat. Price differential has been as much as $0.70 per gallon, and the gas dock is a hassle (bad hours and usually a wait on weekends). The Outrage 22 with it's built-in tank is going to be an expensive habbit.
Tom W Clark posted 01-07-2003 11:32 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jimm,
I strongly favor the aluminum tanks. While the Pate fiberglass tanks seem to be popular here on the forum, I can see several downsides to them:
- They are not portable.
- They stick out from under the RPS.
- They can be difficult to fill if you have to slide it backwards.
- They can be a very tight fit.
- They are ugly.
In contrast, the twin 12 gallon tanks specifically made by both Tempo and Mirax to fit under the Whaler RPS are:
- Portable.
- Easy to fill by sliding them back or removing them from the boat.
- Useful in managing the trim of the vessel by keeping more fuel on one side or the other as well as giving you more warning when one tank runs dry.
- Easy to gauge the fuel level by just trying to lift one tank up and feeling the weight.
In addition, the Mirax tanks have been built of aluminum since the mid 1980’s and you can still get them now. While they are not inexpensive (about $175 each) they will be stronger and more durable than any other tank out there. They are also quite good looking!
weekendwarrior posted 01-08-2003 08:59 AM ET (US)     Profile for weekendwarrior  Send Email to weekendwarrior
I have a plastic 12gal tank under my console and the pros from my standpoint are:
1) Translucent - More accurate than a gas gague and no gague to ever break!
2) Easily portable and will not scratch anything if I drag it around in the boat a little bit
3) inexpensive
The cons as I see it are:
1) Won't last forever in the sun
2) Won't store gas as long as metal (I use the boat year round, not a big deal)
Jimm posted 01-08-2003 11:43 AM ET (US)     Profile for Jimm
Question on aluminun tanks - Do they get overly hot in the sun and is there a need to groung them while filling?...Jim
andygere posted 01-08-2003 12:08 PM ET (US)     Profile for andygere  Send Email to andygere
Jimm,
My tanks are steel Tempos (Whaler OEM)not aluminum, but heat has never been a problem. They don't swell and leak like plastics do, and the mechanical gauges are very accurate. As Tom said, they slide out easily to fill, and secure on Whaler mats with a stout bungee cord. The fit under a Whaler RPS is ideal. I've never considered grounding them when filling, but I often take them out of the boat to fill. If I were buying a new tank(s) today, I'd go for the Mirax aluminums.
weekendwarrior posted 01-08-2003 01:02 PM ET (US)     Profile for weekendwarrior  Send Email to weekendwarrior
A note on filling tanks, the local gas stations here have a warning sign that states a portable tank must be on the ground before being filled to prevent sparks. In a boat I'm not sure how much different a tank sitting on the deck would be than a permanant tank but they seem roughly equal to me relative a tank sitting on the ground. Does anyone know if it really is more dangerous to fill a portable tank sitting on the deck in a boat instead of sitting on the ground?
Taylor posted 01-08-2003 01:17 PM ET (US)     Profile for Taylor  Send Email to Taylor
When I fill my Mirax tanks at the gas station (with the boat on the trailer) or at the fuel dock, I just hold the nozzle against the tank while the fuel flows. That is standard proceedure. How do you ground plastic tanks when filling?
John W posted 01-08-2003 01:18 PM ET (US)     Profile for John W  Send Email to John W
This is a little off topic, as the question was about on-deck tanks on a montauk, but I thought I'd add my 2 cents on tanks. All points here are good ones for a Montauk, but for under deck tanks in larger boats, there are definite advantages to plastic & fiberglass tanks over aluminum ones.
Aluminum fuel tanks leaking into bilges due to corrosion is a major problem in older boats. Aluminum will corrode if it is continuously exposed to water WITHOUT exposure to air. Aluminum fuel tanks corrode through quite often when the tanks are foamed in place (a practice many boat builders continue to use even though industry standards do not allow it). Foaming an aluminum tank in place can lead to water constantly trapped against the side of the tank, due to the tank expanding & contracting with heat while the foam stays in place. This cycle creates a small crack between the tank & the foam that will hold water from condensation. This leads to corrosion holes in the tanks & gas leaking in your bilge. I personally have replaced two aluminum fuel tanks that had holes due to corrosion & I've seen & heard about many many other cases of this happenning.
If an aluminum tank is mounted allowing good ventilation on all sides of the tank, including the bottom, it'll last pretty much forever, and the only corrosion will be the harmless surface oxidation you see on non-anodized aluminum fittings. But if it's foamed in place (as the tank on my Mako is), or if it's mounted where the tanks will be in constant contact with water at the mounting points, or if water can be trapped under a mounting strap, it will eventually lead to a corrosion problem.
I take David Pascoe's boat survey website with a grain of salt on his boat reviews, but he does have an excellent article on there on how to properly mount an aluminum tank to avoid these corrosion problems.
Corrosion problems due to improper mounting of aluminum tanks have become such a big problem that many builders are moving towards fire retardant plastic tanks. The larger ones are baffled just like custom aluminum tanks are.
If you go with aluminum tanks in a boat, read Pascoe's article and be careful in mounting them.
John W posted 01-08-2003 02:05 PM ET (US)     Profile for John W  Send Email to John W
The link to David Pascoe's article is www.yachtsurvey.com/fueltank.htm .
I realize that some of you may find the idea of an aluminum fuel tank corroding as hard to believe...after all, there are aluminum boats from john boats to Striker yachts, and they're not leaking. I don't know why aluminum tanks corrode (beyond my comments above), but I know it happens...and if you talk to anyone who owns a large older (20+ years old) yacht with aluminum tanks, he's either had to replace them or is probably worried about it. I worked in a marina for a brief time in college, and replacing leaky corroded aluminum tanks was a frequent source of business for the marina. And the last time I had my boat in the shop for service, my mechanic was in the process of replacing the leaky corroded tank in an early-1980's Mako.
andygere posted 01-08-2003 03:55 PM ET (US)     Profile for andygere  Send Email to andygere
I can vouch for John W about foamed-in aluminum tanks corroding. My dad's mid 80's non-Whaler runabout had a foamed-in tank that corroded completely through and had to be replaced last year. The boat was kept on a trailer and stored in a heated garage, but there was enough water trapped in the bilge to rot out the bottom of the tank.
Jimm posted 01-08-2003 05:47 PM ET (US)     Profile for Jimm
So Pascoe says....."Fuel tanks don't corrode because they get wet; they corrode because at some point something is in contact with the tank that traps water between it and the tank....... Aluminum is self-protecting, so long as the surface gets adequate air exposure. Severe corrosion is always caused by water plus a lack of oxygen......... As long as the aluminum has a good air flow around all surfaces, contact with water will not damage it." (end Pascoe Quote.) In essence than an above board aluminum tank should never corrode as long as air iscirculating around it. I wonder then if you should prop it up so that air can flow under?...Jim
Jerry Townsend posted 01-08-2003 06:37 PM ET (US)     Profile for Jerry Townsend  Send Email to Jerry Townsend
Realize that there are different aluminum alloys, each with different properties - different strength, different toughness, different corrosion characteristics and each intended for a different application. Also realize that, in general, those alloys with the lesser strength, toughness, corrosion are going to be cheaper. You and I both know what the least expensive item oftentime brings.
And yes, there are aluminum alloys that will corrode - as well as stainless steels that will rust.
Therefore, when buying a fuel tank, or any other product, for your boat - buy quality, buy the a well built product from a knowledgable manufacturer. After all, that is what we all do when buying a BW - right? ---- Jerry/Idaho
John W posted 01-09-2003 10:06 AM ET (US)     Profile for John W  Send Email to John W
Jerry,
I'm no metal expert, but I can tell you that any aluminum fuel tank you can buy from any custom tank builder will corrode if left in constant contact with water for many years. Perhaps there are aluminum alloys that won't corrode, but if so, they're not commonly used for building marine fuel tanks. Many top quality yachts such as Bertram, Blackfin, etc have had their aluminum fuel tanks replaced because of corrosion, and those builders are certainly not using bottom-dollar tanks. (Hatteras uses fire retardant fiberglass tanks & they generally last forever).
You can look at any custom tank builder & buy their highest dollar aluminum tank & it will corrode in time if not properly installed. The more expensive ones are thicker guage, but they all seem to be made out of the same alloy (at least at the commercial shops that build marine tanks). I've shopped for tanks & have never seen different alloys offerred by anyone...only different (thicker) guages of aluminum.
I agree with you that you should certainly buy quality...I've always paid up for the thicker guage tanks...but it appears that proper installation is more important than anything in preventing aluminum tank corrosion.
Jimm, my guess is that under the bottom of the tank would be the only area that could trap water & be a problem on a Montauk on-deck tank. If the tank has tabs around the edge to prevent the bottom of the tank from sitting directly on the deck, you'll be fine. If it sits directly on the deck, adding plastic Starboard strips with 5200 as Pascoe describes would eliminate any potential problem.
Even under the worst foamed-in installation below decks, it takes 10 years or more for a tank to corrode through, so adding strips may be overkill on a Montauk. But I would at least check the bottom of the tank periodically for moisture & corrosion.
Tom W Clark posted 01-09-2003 01:44 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Add that to my list of benefits for the Mirax aluminum 12's: ease of inspecting the bottoms.
Jimm,
No, the aluminum tanks will not get overly hot in the sun. When filling, you ground them as Taylor describes, by maintaining contact between the nozzle and the tank itself.
There are no baffles in these tanks and there are no baffles in the aluminum tanks used on the recreational Whalers for built-in installations.
The CPD/CGP boats always used baffled aluminum tanks and they still do. Whaler tried using plastic built-in tanks in the 22's and 25's in the early 1980's. It did not work out too well and they went back to aluminum tanks.
jameso posted 01-09-2003 02:36 PM ET (US)     Profile for jameso  Send Email to jameso
My two cents on corrosion of aluminum. My self and a lot of people in the aerospace industry have paid mortgages, bought cars and sent kids to college repairing corrosion on aluminum aircraft structure. The marine enviornment is a lot harsher than most aircraft see.
Just my 02, Jim Armstrong
lhg posted 01-09-2003 02:47 PM ET (US)     Profile for lhg
So what about the foamed-in tanks on all of the classic Whaler Outrages/Revenges/Temptations?
andygere posted 01-09-2003 05:03 PM ET (US)     Profile for andygere  Send Email to andygere
I cut a small drainage notch in the lip of the OEM Whaler tank mats so any water that collects under the tanks drains. Without the notch, the tanks sit in a puddle of water constantly. Anyone using steel or aluminum tanks on these mats should make this modification to extend the life of the tanks.
To answer Larry's question, from what I have read in the Forum, the foamed-in tanks on older Whalers do suffer from corrosion. I recall at least a few threads on tank replacement. I suspect that uncovered boats suffer more than those that are covered or garaged.
Knockerjoe posted 01-09-2003 05:38 PM ET (US)     Profile for Knockerjoe  Send Email to Knockerjoe
I am also curious as to the failure rate of aluminum tanks in older Boston whalers. Anyone?
triblet posted 01-09-2003 08:00 PM ET (US)     Profile for triblet  Send Email to triblet
The non-portability of the Pate tanks is their
size, not their construction material. And
that's only a concern if you have to move them
to fill them (I've got one and I don't have to
move it to fill it).
An additional advantage of the Pates is that
they have a fuel guage that will NEVER fail
-- a clear window in the side of the tank.
A mechanical or electical fuel guage on a
boat tells you how much gas you MIGHT have.
ratherwhalering posted 01-09-2003 08:08 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Tom, who's tank you callin' ugly? :-)
Harpoon posted 02-11-2003 09:47 AM ET (US)     Profile for Harpoon
So, who's had a mid 80's Whaler(22-25 Outrage, Revenge) thats' had to have the tanks replaced. What's the average cost and amount of time involved?
I certainly don't have the time or the experience to do a major job like this myself. However, if it's reasonable, it would seem like a good idea to have it done over the winter.
Man, how am I going to enjoy the time on the water if I'm constantly worring about my 20yr old tank leaking under foot with my kids on board.
Just when I thought it was safe to back out on the water again ;)
ajohnston posted 04-13-2003 03:08 PM ET (US)     Profile for ajohnston  Send Email to ajohnston
Searching the web for information on alumunim tanks, I ran across this forum. This is timely as I'm replacing the under deck, foamed in alum tank in my 30 year old 17' Mako. I was also surprised at the corrosion, but my boat clearly had a problem as evidenced by fuel continuously being in the bilge. After removing the tank, the leak/seaps are obvious. Incidently, I don't think there is any water around the tank, but the foam was saturated with gasoline, which I suppose would do the same thing as contributing to corrosion.
My question to the forum:
The Mako has a fiberglass tank compartment molded under deck (access via sealed floor panel). There is about 2" of space between the tank compartment bottom and the hull. This space is fill with foam and the access to that foam is thru four 3" holes in the bottom of the fiberglass tank compartment. All of the foam that I can reach thru the holes is saturated with gasoline.
It would be prefered, I supposed, to remove that gas saturated foam to reduce gas fumes and fire hazards, but how? I don't want to cut out the tank compartment as it's integral with the deck and probably not an easy/wise idea. Should I just hope the gas fumes disapates/evaporates over time?
Does anyone know any trick to removing foam, i.e. chemicals that could be sprayed on it?
Or what other ideas do any of you have about gas saturated foam in inaccessable locations.
Thanks,
Art Johnston.
Chris Mcguire posted 07-02-2003 05:20 PM ET (US)     Profile for Chris Mcguire  Send Email to Chris Mcguire
I have 2 12 Gallon steel Mirax tanks in my 79 Chekmate and one Rusted so bad that i had to pull it and i don't think I'll be puting Marix tank in my boat again but i guess Steel is not an option this round anyway.
JOHN W MAYO posted 07-02-2003 10:24 PM ET (US)     Profile for JOHN W MAYO  Send Email to JOHN W MAYO
On my 1976 revenge 19,
I just pulled the deck to check the tank. I did not remove it as it is foamed in. The mats on the top of the tank appeared to be absorbing water, which increased the weight. There was some water on the sides of the tank in the foam area. The tank looked surprissing in good shape what I could see. In one area on top there was some minor rubbing of the foam pad on top to the aluminum ,I could not smell any fuel, nor any oil on the water. I check the fuel lines and everything I could for fuel leaks and then put some new foam pad back on top and secured the deck.
I removed the deck because I have been strongly considering using a Magma grill on board attached to the railing.
It took several hours to do what I did, I could do it again in probably 2hrs now that I have done it. The hardest part was removeing the passenger seat base.
PEikenberry posted 08-18-2003 01:00 PM ET (US)     Profile for PEikenberry  Send Email to PEikenberry
Very interesting forum. In my job in the Office of Boating Safety I am the lead person on fuel systems on boats. I thought I'd try to dispel a few myths and present some facts.
First, someone said something about tanks being Coast Guard approved. There is no such thing. The tank manufacturer has to certify that their tanks meet the Federal Standards. That's why there is a label on the tank. We would need a small army of inspectors to approve all the tanks that are made every year.
Tanks can be made of any material except terne-plate. (a lead-tin alloy that corrodes like mad) However, the American Boat and Yacht Council (http://www.abycinc.org) has set voluntary industry standards for tanks that the industry uses. If you get a copy of H-24, Gasoline Fuel Systems, you will find a lot of different materials that can be used for tanks. The two most common are aluminum in the 5000 series (5052, 5083, or 5086) because it's resistant to the marine environment, and polyethylene (plastic). Both materials can passes the 2 1/2 minute fire test (they have to resist a fire for 2 1/2 minutes without leaking) and all the other tests such as slosh, pressure impulse and shock.
Studies have shown that aluminum tanks last on the average of 10 years. No one knows how long plastic tanks will last, they have been in use for about 25-30 years and we haven't seen an trend in failures yet. Usually if a plastic tank leaks it's a leaky gasket or someone has accidentally put a hole in it.
Foaming in of tanks is a really bad idea (my opinion). The law permits it if the foam adheres to the tank with a bond who's breaking strength is greater than the sheer strength of the foam. In practice I've yet to see a foamed in tank that didn't collect mositure and corrode. Most manufacturers that foam in tanks do so because they don't want to have to build in a mounting system for the tank.
Aluminum corrodes because the natural oxide on the surface of the aluminum is a.) washed away by moisture b.) penetrated by a scratch or hole of some kind. As long as the natural oxide on the tank is not disturbed the tank should not corrode. This is also why it's a bad idea to paint an aluminum tank. To get the paint to adhere you have to remove the oxide.
Thickness of the aluminum is also important. The thicker the aluminum the longer it will take to corrode through. Also on large tanks (200 gals & up) you definitely need thicker aluminum for strength. Generally though for smaller tanks the thickness used is .090 in.
You don't see large plastic tanks because they are nearly impossible to baffle using the current roto-molding construction methods. Metal tanks can be baffled relatively easily and that reduces sloshing in large tanks.
As for the comments about grounding tanks. DON'T FOOL AROUND. I have a video (taken by a security camera at a gas station) of a portable tank blowing up that was not grounded and the guy went ahead and attempted to fill it. He spent a long time in the burn center. The fill nozzle is grounded back through the system but you can still get a spark that will jump from the tank to the nozzle. This is especially so with plastic portable tanks. Liquid fuel sloshing around in a plastic tank actually builds up static on the walls of the plastic. The same is true of fuel fill hose on boats. This is why the law requires them to be grounded. Always ground a portable tank before filling.
Last but not least fiberglass tanks are discouraged with gasoline (but not illegal). You have to make sure that the resin is gasoline resistant. I've seen some really nasty problems with fiberglass gasoline tanks. Yes, Hatteras makes fiberglass tanks. They are all diesel boats. Fiberglas works well with diesel.
Anybody who has questions can e-mail me at PEikenberry@comdt.uscg.mil or call me 202-267-6894
